[ Upstream commit 83d0bdc7390b890905634186baaa294475cd6a06 ]
If a gettime64 call fails, return the error and avoid copying data back
to user.
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Jacob Keller <jacob.e.keller@intel.com>
Signed-off-by: Miroslav Lichvar <mlichvar@redhat.com>
commit efa61c8cf2950ab5c0e66cff3cabe2a2b24e81ba upstream.
pin_index can be indirectly controlled by user-space, hence leading
to a potential exploitation of the Spectre variant 1 vulnerability.
This issue was detected with the help of Smatch:
drivers/ptp/ptp_chardev.c:253 ptp_ioctl() warn: potential spectre issue
'ops->pin_config' [r] (local cap)
Fix this by sanitizing pin_index before using it to index
ops->pin_config, and before passing it as an argument to
function ptp_set_pinfunc(), in which it is used to index
info->pin_config.
Notice that given that speculation windows are large, the policy is
to kill the speculation on the first load and not worry if it can be
completed with a dependent load/store [1].
[1] https://marc.info/?l=linux-kernel&m=152449131114778&w=2
Cc: stable@vger.kernel.org
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Acked-by: Richard Cochran <richardcochran@gmail.com>
[ Upstream commit 9ba8376ce1e2cbf4ce44f7e4bee1d0648e10d594 ]
It seems that a *break* is missing in order to avoid falling through
to the default case. Otherwise, checking *chan* makes no sense.
Fixes: 72df7a7244c0 ("ptp: Allow reassigning calibration pin function")
[ Upstream commit d340266e19ddb70dbd608f9deedcfb35fdb9d419 ]
struct timespec is not y2038 safe on 32 bit machines.
The posix clocks apis use struct timespec directly and through struct
itimerspec.
Replace the posix clock interfaces to use struct timespec64 and struct
itimerspec64 instead. Also fix up their implementations accordingly.
Note that the clock_getres() interface has also been changed to use
timespec64 even though this particular interface is not affected by the
y2038 problem. This helps verification for internal kernel code for y2038
readiness by getting rid of time_t/ timeval/ timespec.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Cc: arnd@arndb.de
Cc: y2038@lists.linaro.org
Cc: netdev@vger.kernel.org
Cc: john.stultz@linaro.org
Link: http://lkml.kernel.org/r/1490555058-4603-3-git-send-email-deepa.kernel@gmail.com
The reserved field precise_offset->rsv is not cleared before being
copied to user space, leaking kernel stack memory. Clear the struct
before it's copied.
Signed-off-by: Vlad Tsyrklevich <vlad@tsyrklevich.net>
A call to 'ida_simple_remove()' is missing in the error handling path.
This as been spotted with the following coccinelle script which tries to
detect missing 'ida_simple_remove()' call in error handling paths.
expression x;
identifier l;
* x = ida_simple_get(...);
if (...) {
if (...) {
goto l;
* l: ... when != ida_simple_remove(...);
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
gpio_to_irq does not return NO_IRQ but instead returns a negative
error code on failure. Returning NO_IRQ from the function has no
negative effects as we only compare the result to the expected
interrupt number, but it's better to return a proper failure
code for consistency, and we should remove NO_IRQ from the kernel
entirely.
If we pass ERR_PTR(-EFAULT) to kfree() then it's going to oops.
Fixes: 2ece068e1b1d ('ptp: use memdup_user().')
Use memdup_user to duplicate a memory region from user-space to
kernel-space, instead of open coding using kmalloc & copy_from_user.
Signed-off-by: Muhammad Falak R Wani <falakreyaz@gmail.com>
Pull timer updates from Thomas Gleixner:
"The timer department delivers this time:
- Support for cross clock domain timestamps in the core code plus a
first user. That allows more precise timestamping for PTP and
later for audio and other peripherals.
The ptp/e1000e patches have been acked by the relevant maintainers
and are carried in the timer tree to avoid merge ordering issues.
- Support for unregistering the current clocksource watchdog. That
lifts a limitation for switching clocksources which has been there
from day 1
- The usual pile of fixes and updates to the core and the drivers.
Nothing outstanding and exciting"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (26 commits)
time/timekeeping: Work around false positive GCC warning
e1000e: Adds hardware supported cross timestamp on e1000e nic
ptp: Add PTP_SYS_OFFSET_PRECISE for driver crosstimestamping
x86/tsc: Always Running Timer (ART) correlated clocksource
hrtimer: Revert CLOCK_MONOTONIC_RAW support
time: Add history to cross timestamp interface supporting slower devices
time: Add driver cross timestamp interface for higher precision time synchronization
time: Remove duplicated code in ktime_get_raw_and_real()
time: Add timekeeping snapshot code capturing system time and counter
time: Add cycles to nanoseconds translation
jiffies: Use CLOCKSOURCE_MASK instead of constant
clocksource: Introduce clocksource_freq2mult()
clockevents/drivers/exynos_mct: Implement ->set_state_oneshot_stopped()
clockevents/drivers/arm_global_timer: Implement ->set_state_oneshot_stopped()
clockevents/drivers/arm_arch_timer: Implement ->set_state_oneshot_stopped()
clocksource/drivers/arm_global_timer: Register delay timer
clocksource/drivers/lpc32xx: Support timer-based ARM delay
clocksource/drivers/lpc32xx: Support periodic mode
clocksource/drivers/lpc32xx: Don't use the prescaler counter for clockevents
clocksource/drivers/rockchip: Add err handle for rk_timer_init
Currently, network /system cross-timestamping is performed in the
PTP_SYS_OFFSET ioctl. The PTP clock driver reads gettimeofday() and
the gettime64() callback provided by the driver. The cross-timestamp
is best effort where the latency between the capture of system time
(getnstimeofday()) and the device time (driver callback) may be
significant.
The getcrosststamp() callback and corresponding PTP_SYS_OFFSET_PRECISE
ioctl allows the driver to perform this device/system correlation when
for example cross timestamp hardware is available. Modern Intel
systems can do this for onboard Ethernet controllers using the ART
counter. There is virtually zero latency between captures of the ART
and network device clock.
The capabilities ioctl (PTP_CLOCK_GETCAPS), is augmented allowing
applications to query whether or not drivers implement the
getcrosststamp callback, providing more precise cross timestamping.
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: kevin.b.stanton@intel.com
Cc: kevin.j.clarke@intel.com
Cc: hpa@zytor.com
Cc: jeffrey.t.kirsher@intel.com
Signed-off-by: Christopher S. Hall <christopher.s.hall@intel.com>
[jstultz: Commit subject tweaks]
Signed-off-by: John Stultz <john.stultz@linaro.org>
Convert the driver to use ns_to_timespec64() and timespec64_to_ns()
instead of open coding the same logic.
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
All of the PHC drivers have been converted to the new methods. This patch
converts the three remaining callers within the core code and removes the
older methods for good. As a result, the core PHC code is ready for the
year 2038. However, some of the PHC drivers are not quite ready yet.
Signed-off-by: Richard Cochran <richardcochran@gmail.com>
The device has a 64 bit clock register, where each clock tick is 32
nanoseconds, and so with this patch the driver is ready for the year
2038.
Compile tested only.
The device has a 64 bit clock register, where each clock tick is 16
2038.
This patch changes the posix clock code to prefer the new methods
whenever they are implemented by the PHC drivers.
This patch changes the code to use the new method whenever implemented by
the PHC driver.
We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to
meet kernel coding style guidelines. This issue was reported by checkpatch.
A simplified version of the semantic patch that makes this change is as
follows (http://coccinelle.lip6.fr/):
// <smpl>
identifier i;
declarer name DEFINE_PCI_DEVICE_TABLE;
initializer z;
- DEFINE_PCI_DEVICE_TABLE(i)
+ const struct pci_device_id i[]
= z;
// </smpl>
[bhelgaas: add semantic patch]
Signed-off-by: Benoit Taine <benoit.taine@lip6.fr>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
The ptp pin function programming does not allow calibration pin to change
function. This is problematic on hardware that uses the default calibration
pin for other purposes.
Removing this limitation does not impact calibration if userspace does not
reprogram the calibration pin.
Signed-off-by: Stefan Sørensen <stefan.sorensen@spectralink.com>
The ptp_pch driver is for a companion chip to the Intel Atom E600
series processors. These are 32-bit x86 processors so the driver is
only needed on X86_32.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
drivers/net/ethernet/altera/altera_sgdma.c
net/netlink/af_netlink.c
net/sched/cls_api.c
net/sched/sch_api.c
The netlink conflict dealt with moving to netlink_capable() and
netlink_ns_capable() in the 'net' tree vs. supporting 'tc' operations
in non-init namespaces. These were simple transformations from
netlink_capable to netlink_ns_capable.
The Altera driver conflict was simply code removal overlapping some
void pointer cast cleanups in net-next.
Fix kconfig warnings:
PTP_1588_CLOCK selects NET_PTP_CLASSIFY, which depends on NET,
so PTP_1588_CLOCK should also depend on NET.
PTP_1588_CLOCK_PCH selects PTP_1588_CLOCK so the former should
depend on NET.
warning: (IXP4XX_ETH && PTP_1588_CLOCK) selects NET_PTP_CLASSIFY which has unmet direct dependencies (NET)
warning: (SFC && TILE_NET && BFIN_MAC_USE_HWSTAMP && TIGON3 && FEC && E1000E && IGB && IXGBE && I40E && MLX4_EN && SXGBE_ETH && STMMAC_ETH && TI_CPTS && PTP_1588_CLOCK_GIANFAR && PTP_1588_CLOCK_IXP46X && DP83640_PHY && PTP_1588_CLOCK_PCH) selects PTP_1588_CLOCK which has unmet direct dependencies (NET)
[This warning is caused by the new 'depends on NET' in PTP_1588_CLOCK.]
PTP Hardware Clock drivers specify a maximum frequency adjustment that
their clocks can accommodate. Normally, user space programs will want to
respect the advertised limits. However, no kernel or driver code checks
that the dialed frequency offset is within the bounds, and out of range
values can lead to surprising results.
This patch fixes the issue by rejecting bad values.
This commit fixes a build error reported by Fengguang, that is
triggered when CONFIG_NETWORK_PHY_TIMESTAMPING is not set:
ERROR: "ptp_classify_raw" [drivers/net/ethernet/oki-semi/pch_gbe/pch_gbe.ko] undefined!
The fix is to introduce its own file for the PTP BPF classifier,
so that PTP_1588_CLOCK and/or NETWORK_PHY_TIMESTAMPING can select
it independently from each other. IXP4xx driver on ARM needs to
select it as well since it does not seem to select PTP_1588_CLOCK
or similar that would pull it in automatically.
This also allows for hiding all of the internals of the BPF PTP
program inside that file, and only exporting relevant API bits
to drivers.
This patch also adds a kdoc documentation of ptp_classify_raw()
API to make it clear that it can return PTP_CLASS_* defines. Also,
the BPF program has been translated into bpf_asm code, so that it
can be more easily read and altered (extensively documented in [1]).
In the kernel tree under tools/net/ we have bpf_asm and bpf_dbg
tools, so the commented program can simply be translated via
`./bpf_asm -c prog` where prog is a file that contains the
commented code. This makes it easily readable/verifiable and when
there's a need to change something, jump offsets etc do not need
to be replaced manually which can be very error prone. Instead,
a newly translated version via bpf_asm can simply replace the old
code. I have checked opcode diffs before/after and it's the very
same filter.
[1] Documentation/networking/filter.txt
Fixes: 164d8c666521 ("net: ptp: do not reimplement PTP/BPF classifier")
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Cc: Jiri Benc <jbenc@redhat.com>
This patch updates the many PTP Hardware Clock drivers with the
newly introduced field that advertises the number of programmable
pins. Some of these devices do have programmable pins, but the
implementation will have to wait for follow on patches.
Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
This patch adds the sysfs hooks needed in order to get and set the
programmable pin settings.
This patch adds a pair of new ioctls to the PTP Hardware Clock device
interface. Using the ioctls, user space programs can query each pin to
find out its current function and also reprogram a different function
if desired.
On archs like S390 or um this driver cannot build nor work.
Make it depend on HAS_IOMEM to bypass build failures.
drivers/ptp/ptp_pch.c: In function ‘pch_remove’:
drivers/ptp/ptp_pch.c:571:3: error: implicit declaration of function ‘iounmap’ [-Werror=implicit-function-declaration]
drivers/ptp/ptp_pch.c: In function ‘pch_probe’:
drivers/ptp/ptp_pch.c:621:2: error: implicit declaration of function ‘ioremap’ [-Werror=implicit-function-declaration]
Signed-off-by: Richard Weinberger <richard@nod.at>
This platform supports gpiolib, so remove the custom API use
and replace with calls to gpiolib. Also request the GPIO before
starting to use it.
Cc: Imre Kaloz <kaloz@openwrt.org>
Cc: Alexandre Courbot <acourbot@nvidia.com>
Acked-by: Krzysztof Halasa <khc@pm.waw.pl>
The dev_attrs field of struct class is going away soon, dev_groups
should be used instead. This converts the ptp class code to use the
correct field.
Some drivers can be built on more platforms than they run on. This is
a burden for users and distributors who package a kernel. They have to
manually deselect some (for them useless) drivers when updating their
configs via oldconfig. And yet, sometimes it is even impossible to
disable the drivers without patching the kernel.
Introduce a new config option COMPILE_TEST and make all those drivers
to depend on the platform they run on, or on the COMPILE_TEST option.
Now, when users/distributors choose COMPILE_TEST=n they will not have
the drivers in their allmodconfig setups, but developers still can
compile-test them with COMPILE_TEST=y.
Now the drivers where we use this new option:
* PTP_1588_CLOCK_PCH: The PCH EG20T is only compatible with Intel Atom
processors so it should depend on x86.
* FB_GEODE: Geode is 32-bit only so only enable it for X86_32.
* USB_CHIPIDEA_IMX: The OF_DEVICE dependency will be met on powerpc
systems -- which do not actually support the hardware via that
method.
* INTEL_MID_PTI: It is specific to the Penwell type of Intel Atom
device.
[v2]
* remove EXPERT dependency
[gregkh - remove chipidea portion, as it's incorrect, and also doesn't
apply to my driver-core tree]
Cc: Jeff Mahoney <jeffm@suse.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: linux-usb@vger.kernel.org
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: linux-geode@lists.infradead.org
Cc: linux-fbdev@vger.kernel.org
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: "Keller, Jacob E" <jacob.e.keller@intel.com>
Fix to release resources when ptp_clock_register() fail instead
of return error code directly.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
As network adapters supporting PTP are becoming more common, machines with
many NICs suddenly have many PHCs, too. The current limit of eight /dev/ptp*
char devices (and thus, 8 network interfaces with PHC) is insufficient. Let
the ptp driver allocate the char devices dynamically.
Tested with 28 PHCs, removing and re-adding some of them.
Thanks to Ben Hutchings for advice leading to simpler and cleaner patch.
Signed-off-by: Jiri Benc <jbenc@redhat.com>
This fixes a number of sparse warnings like:
warning: incorrect type in argument 2 (different address spaces)
expected void volatile [noderef] <asn:2>*addr
got unsigned int *<noident>
warning: Using plain integer as NULL pointer
Additionally this fixes a warning from checkpatch.pl like:
WARNING: sizeof pch_param.station should be sizeof(pch_param.station)
Signed-off-by: Sahara <keun-o.park@windriver.com>
Pull networking changes from David Miller:
1) Allow to dump, monitor, and change the bridge multicast database
using netlink. From Cong Wang.
2) RFC 5961 TCP blind data injection attack mitigation, from Eric
Dumazet.
3) Networking user namespace support from Eric W. Biederman.
4) tuntap/virtio-net multiqueue support by Jason Wang.
5) Support for checksum offload of encapsulated packets (basically,
tunneled traffic can still be checksummed by HW). From Joseph
Gasparakis.
6) Allow BPF filter access to VLAN tags, from Eric Dumazet and
Daniel Borkmann.
7) Bridge port parameters over netlink and BPDU blocking support
from Stephen Hemminger.
8) Improve data access patterns during inet socket demux by rearranging
socket layout, from Eric Dumazet.
9) TIPC protocol updates and cleanups from Ying Xue, Paul Gortmaker, and
Jon Maloy.
10) Update TCP socket hash sizing to be more in line with current day
realities. The existing heurstics were choosen a decade ago.
From Eric Dumazet.
11) Fix races, queue bloat, and excessive wakeups in ATM and
associated drivers, from Krzysztof Mazur and David Woodhouse.
12) Support DOVE (Distributed Overlay Virtual Ethernet) extensions
in VXLAN driver, from David Stevens.
13) Add "oops_only" mode to netconsole, from Amerigo Wang.
14) Support set and query of VEB/VEPA bridge mode via PF_BRIDGE, also
allow DCB netlink to work on namespaces other than the initial
namespace. From John Fastabend.
15) Support PTP in the Tigon3 driver, from Matt Carlson.
16) tun/vhost zero copy fixes and improvements, plus turn it on
by default, from Michael S. Tsirkin.
17) Support per-association statistics in SCTP, from Michele
Baldessari.
And many, many, driver updates, cleanups, and improvements. Too
numerous to mention individually.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits)
net/mlx4_en: Add support for destination MAC in steering rules
net/mlx4_en: Use generic etherdevice.h functions.
net: ethtool: Add destination MAC address to flow steering API
bridge: add support of adding and deleting mdb entries
bridge: notify mdb changes via netlink
ndisc: Unexport ndisc_{build,send}_skb().
uapi: add missing netconf.h to export list
pkt_sched: avoid requeues if possible
solos-pci: fix double-free of TX skb in DMA mode
bnx2: Fix accidental reversions.
bna: Driver Version Updated to 3.1.2.1
bna: Firmware update
bna: Add RX State
bna: Rx Page Based Allocation
bna: TX Intr Coalescing Fix
bna: Tx and Rx Optimizations
bna: Code Cleanup and Enhancements
ath9k: check pdata variable before dereferencing it
ath5k: RX timestamp is reported at end of frame
ath9k_htc: RX timestamp is reported at end of frame
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
This patch removes the large buffer from the stack of the system
offset ioctl and replaces it with a kmalloced buffer.
This patch removes the large buffer from the stack of the read file
operation and replaces it with a kmalloced buffer.
In commit a24006ed12616bde1bbdb26868495906a212d8dc ('ptp: Enable clock
drivers along with associated net/PHY drivers') I wrongly made
PTP_1588_CLOCK_PCH depend on PCH_GBE. The dependency is really the
other way around. Therefore make PCH_GBE select PTP_1588_CLOCK_PCH
and remove the 'default y' from the latter.
Reported-by: Randy Dunlap <rdunlap@xenotime.net>
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
This patch adds an ioctl for PTP Hardware Clock (PHC) devices that allows
user space to measure the time offset between the PHC and the system
clock. Rather than hard coding any kind of estimation algorithm into the
kernel, this patch takes the more flexible approach of just delivering
an array of raw clock readings. In that way, the user space clock servo
may be adapted to new and different hardware clocks.
Acked-by: Jacob Keller <jacob.e.keller@intel.com>
Where a PTP clock driver is associated with a net or PHY driver, it
should be enabled automatically whenever that driver is enabled.
Therefore:
- Make PTP clock drivers select rather than depending on PTP_1588_CLOCK
- Remove separate boolean options for PTP clock drivers that are built
as part of net driver modules. (This also fixes cases where the PTP
subsystem is wrongly forced to be built-in.)
- Set 'default y' for PTP clock drivers that depend on specific net
drivers but are built separately
PTP hardware clock drivers that select PTP_1588_CLOCK must currently
also select PPS. For those drivers that don't, the user must enable
PPS, then enable PTP_1588_CLOCK, then the driver. Simplify things for
developers and users by putting this selection in one place.
These are now established subsystems, and we want drivers to be able
to select PPS and PTP_1588_CLOCK without depending on EXPERIMENTAL.
Further, the use of EXPERIMENTAL is now deprecated in general.
PTP Hardware Clock devices appear as class devices in sysfs. This patch
changes the registration API to use the parent device, clarifying the
clock's relationship to the underlying device.
Acked-by: Ben Hutchings <bhutchings@solarflare.com>
If the timex.mode field indicates a query, then we provide the value of
the current frequency adjustment.
[ Get rid of extraneous empty lines -DaveM ]
This patch adds a field to the representation of a PTP hardware clock in
order to remember the frequency adjustment value dialed by the user.
Adding this field will let us answer queries in the manner of adjtimex
in a follow on patch.
Initial version by Stuart Hodgson <smhodgson@solarflare.com>
Some PHC device drivers may deliver PPS events with a significant
and variable delay, but still be able to measure precisely what
that delay is.
Add a pps_sub_ts() function for subtracting a delay from the
timestamp(s) in a PPS event, and a PTP event type (PTP_CLOCK_PPSUSR)
for which the caller provides a complete PPS event.
Pull trivial updates from Jiri Kosina:
"As usual, it's mostly typo fixes, redundant code elimination and some
documentation updates."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (57 commits)
edac, mips: don't change code that has been removed in edac/mips tree
xtensa: Change mail addresses of Hannes Weiner and Oskar Schirmer
lib: Change mail address of Oskar Schirmer
net: Change mail address of Oskar Schirmer
arm/m68k: Change mail address of Sebastian Hess
i2c: Change mail address of Oskar Schirmer
net: Fix tcp_build_and_update_options comment in struct tcp_sock
atomic64_32.h: fix parameter naming mismatch
Kconfig: replace "--- help ---" with "---help---"
c2port: fix bogus Kconfig "default no"
edac: Fix spelling errors.
qla1280: Remove redundant NULL check before release_firmware() call
remoteproc: remove redundant NULL check before release_firmware()
qla2xxx: Remove redundant NULL check before release_firmware() call.
aic94xx: Get rid of redundant NULL check before release_firmware() call
tehuti: delete redundant NULL check before release_firmware()
qlogic: get rid of a redundant test for NULL before call to release_firmware()
bna: remove redundant NULL test before release_firmware()
tg3: remove redundant NULL test before release_firmware() call
typhoon: get rid of redundant conditional before all to release_firmware()
