2019-12-05 | pwm: bcm-iproc: Prevent unloading the driver module while in use | Uwe Kleine-König | |
[ Upstream commit 24906a41eecb73d51974ade0847c21e429beec60 ] The owner member of struct pwm_ops must be set to THIS_MODULE to increase the reference count of the module such that the module cannot be removed while its code is in use. Fixes: daa5abc41c80 ("pwm: Add support for Broadcom iProc PWM controller") Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Reviewed-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com> Signed-off-by: Sasha Levin <sashal@kernel.org> | |||
2016-07-11 | pwm: Add support for Broadcom iProc PWM controller | Yendapally Reddy Dhananjaya Reddy | |
Add support for the PWM controller present in Broadcom's iProc family of SoCs. It has been tested on the Northstar+ bcm958625HR board. Signed-off-by: Yendapally Reddy Dhananjaya Reddy <yendapally.reddy@broadcom.com> [thierry.reding@gmail.com: bunch of coding style fixes, cleanups] Signed-off-by: Thierry Reding <thierry.reding@gmail.com> |
