path: root/drivers/rapidio/rio-access.c
2008-04-29[RAPIDIO] Add RapidIO multi mport supportZhang Wei
The original RapidIO driver suppose there is only one mpc85xx RIO controller in system. So, some data structures are defined as mpc85xx_rio global, such as 'regs_win', 'dbell_ring', 'msg_tx_ring'. Now, I changed them to mport's private members. And you can define multi RIO OF-nodes in dts file for multi RapidIO controller in one processor, such as PCI/PCI-Ex host controllers in Freescale's silicon. And the mport operation function declaration should be changed to know which RapidIO controller is target. Signed-off-by: Zhang Wei <wei.zhang@freescale.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-27[PATCH] spin/rwlock init cleanupsIngo Molnar
locking init cleanups: - convert " = SPIN_LOCK_UNLOCKED" to spin_lock_init() or DEFINE_SPINLOCK() - convert rwlocks in a similar manner this patch was generated automatically. Motivation: - cleanliness - lockdep needs control of lock initialization, which the open-coded variants do not give - it's also useful for -rt and for lock debugging in general Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] RapidIO support: core baseMatt Porter
Adds a RapidIO subsystem to the kernel. RIO is a switched fabric interconnect used in higher-end embedded applications. The curious can look at the specs over at http://www.rapidio.org The core code implements enumeration/discovery, management of devices/resources, and interfaces for RIO drivers. There's a lot more to do to take advantages of all the hardware features. However, this should provide a good base for folks with RIO hardware to start contributing. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
