path: root/drivers/rapidio
2011-08-25rapidio: fix use of non-compatible registersAlexandre Bounine
Replace/remove use of RIO v.1.2 registers/bits that are not forward-compatible with newer versions of RapidIO specification. RapidIO specification v.1.3 removed Write Port CSR, Doorbell CSR, Mailbox CSR and Mailbox and Doorbell bits of the PEF CAR. Use of removed (since RIO v.1.3) register bits affects users of currently available 1.3 and 2.x compliant devices who may use not so recent kernel versions. Removing checks for unsupported bits makes corresponding routines compatible with all versions of RapidIO specification. Therefore, backporting makes stable kernel versions compliant with RIO v.1.3 and later as well. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Chul Kim <chul.kim@idt.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-18rapidio: fix default routing initializationAlexandre Bounine
Fix switch initialization to ensure that all switches have default routing disabled. This guarantees that no unexpected RapidIO packets arrive to the default port set by reset and there is no default routing destination until it is properly configured by software. This update also unifies handling of unmapped destinations by tsi57x, IDT Gen1 and IDT Gen2 switches. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: <stable@kernel.org> [2.6.37+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-14RapidIO/mpc85xx: fix possible mport registration problemsAlexandre Bounine
Fix a possible problem with mport registration left non-cleared after fsl_rio_setup() exits on link error. Abort mport initialization if registration failed. This patch is applicable to 2.6.39-rc1 only. The problem does not exist for earlier versions. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-14RapidIO: add IDT CPS-1432 switch definitionsAlexandre Bounine
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23rapidio: fix potential null deref on failure pathDan Carpenter
If rio is not a switch then "rswitch" is null. Signed-off-by: Dan Carpenter <error27@gmail.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23rapidio: remove mport resource reservation from common RIO codeAlexandre Bounine
Removes resource reservation from the common sybsystem initialization code and make it part of mport driver initialization. This resolves conflict with resource reservation by device specific mport drivers. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23rapidio: modify mport ID assignmentAlexandre Bounine
Changes mport ID and host destination ID assignment to implement unified method common to all mport drivers. Makes "riohdid=" kernel command line parameter common for all architectures with support for more that one host destination ID assignment. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23rapidio: modify subsystem and driver initialization sequenceAlexandre Bounine
Subsystem initialization sequence modified to support presence of multiple RapidIO controllers in the system. The new sequence is compatible with initialization of PCI devices. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23rapidio: modify configuration to support PCI-SRIO controllerAlexandre Bounine
1. Add an option to include RapidIO support if the PCI is available. 2. Add FSL_RIO configuration option to enable controller selection. 3. Add RapidIO support option into x86 and MIPS architectures. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23rapidio: add architecture specific callbacksAlexandre Bounine
This set of patches eliminates RapidIO dependency on PowerPC architecture and makes it available to other architectures (x86 and MIPS). It also enables support of new platform independent RapidIO controllers such as PCI-to-SRIO and PCI Express-to-SRIO. This patch: Extend number of mport callback functions to eliminate direct linking of architecture specific mport operations. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23rapidio: add new sysfs attributesAlexandre Bounine
Add new sysfs attributes. 1. Routing information required to to reach the RIO device: destid - device destination ID (real for for endpoint, route for switch) hopcount - hopcount for maintenance requests (switches only) 2. device linking information: lprev - name of device that precedes the given device in the enumeration or discovery order (displayed along with of the port to which it is attached). lnext - names of devices (with corresponding port numbers) that are attached to the given device as next in the enumeration or discovery order (switches only) Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-17rapidio: change to new flag variablematt mooney
switches/ depends on RAPIDIO_DEBUG so the subdir-ccflags-y variant seems to be appropriate here. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-02-25rapidio: fix sysfs config attribute to access 16MB of maint spaceAlexandre Bounine
Fixes sysfs config attribute to allow access to entire 16MB maintenance space of RapidIO devices. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-22rapidio: fix new kernel-doc warningsRandy Dunlap
Fix new rapidio kernel-doc warnings: Warning(drivers/rapidio/rio-scan.c:953): No description found for parameter 'prev' Warning(drivers/rapidio/rio-scan.c:953): No description found for parameter 'prev_port' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13rapidio: add new idt sRIO switchesAlexandre Bounine
Add new sRIO switch device IDs and enable a basic support for them. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13rapidio: use Component Tag for unified switch identificationAlexandre Bounine
Change the way how switchid value is set. Local counter variable does not provide unified way to identify switch devices in a system with multiple processors. Using local counter leads to the situation when the same RIO switch has different switch ID for each processor. Replacing local counter with unique portion of the Component Tag provides unified reference to the switch by every processor in the system. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13rapidio: add device object linking into discoveryAlexandre Bounine
Add setting links between rio_dev objects into the discovery process. This needed to report device connections on agent (non-host) processors that perform RIO discovery. Originally, these links have been introduced for enumerating host only to support error management. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13rapidio: add definitions of Component Tag fieldsAlexandre Bounine
Add definition of the unique device identifier field in the component tag. RIO_CTAG_UDEVID does not take all 32 bits of the component tag value to allow future extensions to the component tag use. Selected size of the RIO_CTAG_UDEVID field (17 bits) is sufficient to accommodate maximum number of endpoints in large RIO network (16-bit id) plus switches. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13rapidio: integrate rio_switch into rio_devAlexandre Bounine
Convert RIO switches device structures (rio_dev + rio_switch) into a single allocation unit. This change is based on the fact that RIO switches are using common RIO device objects anyway. Allocating RIO switch objects as RIO devices with added space for switch information simplifies handling of RIO switch devices. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13rapidio: use common destid storage for endpoints and switchesAlexandre Bounine
Change code to use one storage location common for switches and endpoints. This eliminates unnecessary device type checks during basic access operations. Logic that assigns destid to RIO devices stays unchanged - as before, switches use an associated destid because they do not have their own. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-12rapidio: use resource_size()Dan Carpenter
The size calculation is done incorrectly here because it should include both the start and end (end - start + 1). It's easiest to just use resource_size() which does the right thing. I was worried there was something non-standard going on because the printk() subtracts "end - 1", but the rest of the file uses the normal resource size calculations. This function is only called from fsl_rio_setup() in arch/powerpc/sysdev/fsl_rio.c and the calculation there is also: port->iores.start = law_start; port->iores.end = law_start + law_size - 1; So I think this is the correct fix. Signed-off-by: Dan Carpenter <error27@gmail.com> Cc: Alexandre Bounine <alexandre.bounine@idt.com> Acked-by: Li Yang <leoli@freescale.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rapidio: fix destructive port EM initialization for Tsi568Alexandre Bounine
Replace possibly damaging broadcast writes into the per-port SP_MODE registers with individual writes for each port. This will preserve individual port configurations in case if ports are configured differently. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rapidio: fix maximum port number in tsi57x EM initializationAlexandre Bounine
Replace hardcoded maximum port number with actual reported number of switch ports. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rapidio: fix IDLE2 bits corruptionAlexandre Bounine
RapidIO spec v.2.1 adds Idle Sequence 2 into LP-Serial Physical Layer. The fix ensures that corresponding bits are not corrupted during error handling. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rapidio: add handling of redundant routesAlexandre Bounine
Detects RIO link to the already enumerated device and properly sets links between device objects. Changes to the enumeration/discovery logic: 1. Use Master Enable bit to signal end of the enumeration - agents may start their discovery process as soon as they see this bit set (Component Tag register was used before for this purpose). 2. Enumerator sets Component Tag (!= 0) immediately during device setup. This allows to identify the device if the redundant route exists in a RIO system. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rapidio: add support for IDT CPS Gen2 switchesAlexandre Bounine
Add the RIO switch driver and definitions for IDT CPS-1848 and CPS-1616 Gen2 devices. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rapidio: add device access check into the enumerationAlexandre Bounine
Add explicit device access check before performing device enumeration. This gives a chance to clear possible link error conditions by issuing safe maintenance read request(s). Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rapidio: add handling of orphan port-write messageAlexandre Bounine
Add check for access to port-write (PW) message source device before processing the PW message. If source RIO device is not available (power down or RIO link failure) trace back to a last available switch/port on the PW message route and service failure at that point. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rapidio: modify sysfs initialization for switchesAlexandre Bounine
1. Change to create attribute "routes" only for switches. 2. Add a switch-specific callback to create/remove proprietary attributes. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rapidio: add default handler for error-stopped stateAlexandre Bounine
The default error-stopped state handler provides recovery mechanism as defined by RIO specification. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rapidio: add relation links between RIO device structuresAlexandre Bounine
Create back and forward links between RIO devices. These links are intended for use by error management and hot-plug extensions. Links for redundant RIO connections between switches are not set (will be fixed in a separate patch). Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rapidio: use stored ingress port number instead of register readAlexandre Bounine
The switch port information is obtained and stored during RIO device setup. Therefore repeated reads from Switch Port Information CAR may be removed. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rapidio: fix RapidIO sysfs hierarchyAlexandre Bounine
This set of RapidIO patches extends support for standard error recovery mechanism and adds new IDT Gen2 sRIO switch devices - CPS-1848 and CPS-1616. Implementation of the standard error-stopped state recovery mechanism (as defined by the RapidIO specification) is required for the new switches. Version 2 of this set of patches addresses received comments and fixes an error notification setup issue found in the idt_gen2.c after the first version was released. This patch: Make RapidIO devices appear in /sys/devices/rapidio directory instead of top of /sys/devices directory. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Micha Nelissen <micha@neli.hopto.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-16fix typos concerning "associate"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-30rapidio: fix new kernel-doc warningsRandy Dunlap
Fix a bunch of new rapidio kernel-doc warnings: Warning(include/linux/rio.h:123): No description found for parameter 'comp_tag' Warning(include/linux/rio.h:123): No description found for parameter 'phys_efptr' Warning(include/linux/rio.h:123): No description found for parameter 'em_efptr' Warning(include/linux/rio.h:123): No description found for parameter 'pwcback' Warning(include/linux/rio.h:247): No description found for parameter 'set_domain' Warning(include/linux/rio.h:247): No description found for parameter 'get_domain' Warning(drivers/rapidio/rio-scan.c:1133): No description found for parameter 'rdev' Warning(drivers/rapidio/rio-scan.c:1133): Excess function parameter 'port' description in 'rio_init_em' Warning(drivers/rapidio/rio.c:349): No description found for parameter 'rdev' Warning(drivers/rapidio/rio.c:349): Excess function parameter 'mport' description in 'rio_request_inb_pwrite' Warning(drivers/rapidio/rio.c:393): No description found for parameter 'port' Warning(drivers/rapidio/rio.c:393): No description found for parameter 'local' Warning(drivers/rapidio/rio.c:393): No description found for parameter 'destid' Warning(drivers/rapidio/rio.c:393): No description found for parameter 'hopcount' Warning(drivers/rapidio/rio.c:393): Excess function parameter 'rdev' description in 'rio_mport_get_physefb' Warning(drivers/rapidio/rio.c:845): Excess function parameter 'local' description in 'rio_std_route_clr_table' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Alexandre Bounine <alexandre.bounine@idt.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: use default route value for CPS switchesAlexandre Bounine
Fix to use correct default value for routing table entries. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Thomas Moll <thomas.moll@sysgo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: add switch domain routinesAlexandre Bounine
Add switch specific domain routines required for 16-bit routing support in switches with hierarchical implementation of routing tables. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Thomas Moll <thomas.moll@sysgo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: modify initialization of switch operationsAlexandre Bounine
Modify the way how RapidIO switch operations are declared. Multiple assignments through the linker script replaced by single initialization call. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Thomas Moll <thomas.moll@sysgo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: add debug configuration optionAlexandre Bounine
Add debug configuration option for RapidIO subsystem. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Thomas Moll <thomas.moll@sysgo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: fix typos and minor editsAlexandre Bounine
2010-05-27rapidio: add enabling SRIO port RX and TXThomas Moll
Add the functionality to enable Input receiver and Output transmitter of every port, to allow non-maintenance traffic. Signed-off-by: Thomas Moll <thomas.moll@sysgo.com> Signed-off-by: Alexandre Bounine <abounine@tundra.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: add Port-Write handling for EMAlexandre Bounine
Add RapidIO Port-Write message handling in the context of Error Management Extensions Specification Rev.1.3. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Tested-by: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: add switch locking during discoveryAlexandre Bounine
Add switch access locking during RapidIO discovery. Access lock is required when reading switch routing table contents due to indexed mechanism of RT addressing. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Tested-by: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: add IDT CPS/TSI switchesAlexandre Bounine
Extentions to RapidIO switch support: 1. modify switch route operation declarations to allow using single switch-specific file for family of switches that share the same route table operations. 2. add standard route table operations for switches that that support route table manipulation registers as defined in the Rev.1.3 of RapidIO specification. 3. add clear-route-table operation for switches 4. add CPSxx and TSIxxx families of RapidIO switches Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Tested-by: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-21sysfs: add struct file* to bin_attr callbacksChris Wright
This allows bin_attr->read,write,mmap callbacks to check file specific data (such as inode owner) as part of any privilege validation. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15rio: warn_unused_result warnings fixYang Li
Adding failure path for the following two cases. warning: ignoring return value of 'device_add', declared with attribute warn_unused_result warning: ignoring return value of 'sysfs_create_bin_file', declared with attribute warn_unused_result Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-05-19rapidio: fix section mismatch warningsLi Yang
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-24rapidio: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Cc: mporter@kernel.crashing.org Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
