path: root/drivers/regulator/88pm8607.c
2011-05-26regulator: Fix 88pm8607.c printk format warningRandy Dunlap
Fix printk format warning (seen on x86_64) and change to unsigned output format: drivers/regulator/88pm8607.c:417: warning: format '%d' expects type 'int', but argument 3 has type 'resource_size_t' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Avoid to use constraint name in 88pm860x regulator driverHaojian Zhuang
Avoid to use constraint name in regulator driver. So use regulator id is used instead in platform driver. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Use mfd cell platform_data for 88pm860x cells platform bitsSamuel Ortiz
With the addition of a platform device mfd_cell pointer, MFD drivers can go back to passing platform back to their sub drivers. This allows for an mfd_cell->mfd_data removal and thus keep the sub drivers MFD agnostic. This is mostly needed for non MFD aware sub drivers. Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Cc: Richard Purdie <rpurdie@rpsys.net> Acked-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-23mfd: Adopt mfd_data in 88pm860x regulatorHaojian Zhuang
Copy 88pm860x platform data into different mfd_data structure for regulator driver. So move the identification of device node from regulator driver to mfd driver. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-01-12regulator: Report actual configured voltage to set_voltage()Mark Brown
Change the interface used by set_voltage() to report the selected value to the regulator core in terms of a selector used by list_voltage(). This allows the regulator core to know the voltage that was chosen without having to do an explict get_voltage(), which would be much more expensive as it will generally access hardware. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-09-05regulator: 88pm8607 - fix value range checking for accessing info->vol_tableAxel Lin
In choose_voltage(), we use i as array index of info->vol_table. The valid value range for i should be 0 .. ARRAY_SIZE(info->vol_table) - 1. Take LDO1 as example, ARRAY_SIZE(LDO1_table) is 4, vol_nbits of LDO1 is 2. for (i = 0; i < (2 << info->vol_nbits); i++) is equivalent to for (i = 0; i < 8; i++) which is wrong. The same value range checking also applies for index in pm8607_list_voltage(). Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Mark Brown <broonie@openource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-05-25regulator: use voltage number array in 88pm860xHaojian Zhuang
A lot of condition comparision statements are used in original driver. These statements are used to check the boundary of voltage numbers since voltage number isn't linear. Now use array of voltage numbers instead. Clean code with simpler way. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-05-25regulator: make 88pm860x sharing one driver structureHaojian Zhuang
Remove a lot of driver structures in 88pm860x driver. Make regulators share one driver structure. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-03-07regulator: Unsupport 88pm8607 A0 and A1Haojian Zhuang
Remove the support 88PM8607 A0/A1 stepping. There's some register definition changes in B0 stepping. It can make software more efficient. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-03-07mfd: Support 88pm8606 in 860x driverHaojian Zhuang
88PM8606 and 88PM8607 are two discrete chips used for power management. Hardware designer can use them together or only one of them according to requirement. There's some logic tightly linked between these two chips. For example, USB charger driver needs to access both chips by I2C interface. Now share one driver to these two devices. Only one I2C client is identified in platform init data. If another chip is also used, user should mark it in companion_addr field of platform init data. Then driver could create another I2C client for the companion chip. All I2C operations are accessed by 860x-i2c driver. In order to support both I2C client address, the read/write API is changed in below. reg_read(client, offset) reg_write(client, offset, data) The benefit is that client drivers only need one kind of read/write API. I2C and MFD driver can be shared in both 8606 and 8607. Since API is changed, update API in 8607 regulator driver. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-12-17regulator: Ensure val is initialised in 88pm8607 choose_voltage()Mark Brown
If we fall through it means that we hit an unknown regulator/chip combination so set -ENOENT as an explicit flag (the return code is only used internally). Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-12-17regulator: add 88PM8607 PMIC driverHaojian Zhuang
Hi Liam, Since Samuel merged a new version of mfd 88pm8607 driver, I format a new patch on regulator 88pm8607. I paste the new patch in mail. Please help to review again. And I also attach the mfd driver in mail. From: Haojian Zhuang <haojian.zhuang@marvell.com> Date: Thu, 8 Oct 2009 09:36:53 -0400 Subject: [PATCH] regulator: Add 88PM8607 PMIC driver This patch adds regulator drivers for Marvell 88PM8607 PMIC. This controller contains 3 DVC and 14 LDO regulators. This controller uses I2C interface. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
