path: root/drivers/regulator/ab8500.c
2011-03-26regulator: add ab8500 enable and raise time delaysLinus Walleij
This uses the new infrastructure to provide proper delays when enabling or setting the voltage of one specific regulator. Cc: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-26regulator: initialization for ab8500 regulatorsBengt Jonsson
The regulators on the AB8500 have a lot of custom hardware control settings pertaining to 8 external signals, settings which are board-specific and need be provided from the platform at startup. Initialization added for regulators Vana, VextSupply1, VextSupply2, VextSupply3, Vaux1, Vaux2, Vaux3, VTVout, Vintcore12, Vaudio, Vdmic, Vamic1, Vamic2, VrefDDR. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Reviewed-by: Rickard Andersson <rickard.andersson@stericsson.com> Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-26regulator: add support for USB voltage regulatorBengt Jonsson
Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulators: Removed macros for initialization of ab8500 regulatorsBengt Jonsson
This patch removes the macros for initializing the regulators. The purpose is to remove one layer of abstraction and make the code easier to read. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulators: Added verbose debug messages to ab8500 regulatorsBengt Jonsson
The verbose debug outputs register writes and reads that can be used to debug the driver. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulators: Modified ab8500 error handlingBengt Jonsson
Error handling is updated to catch NULL pointer errors. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulators: Updated ab8500 variable names, macro names and commentsBengt Jonsson
The regulator enumeration is used for putting the regulator data in correct place in the info array. This should be matched in the board configuration. Variable names are updated to be more consistent, comments are corrected and macros have been edited to be consistent. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulators: Added ab8500 v2 supportBengt Jonsson
The AUX3 regulator voltage setting is changed in ab8500 v2 compared to ab8500 v1. This patch adds v2 support while keeping support for v1. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulators: Clean out unused code in ab8500 regulatorsBengt Jonsson
The find_regulator function was unused so it has been removed. The ab8500 pointer in the regulator info structure was unused and so it has also been removed. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulators: Fixed errors in ab8500 register mappingBengt Jonsson
For INTCORE and TVOUT regulators, the low power register bit is included in the mask so that enable will set the regulator in normal (high power) mode. ANAMIC1, ANAMIC2, DMIC regulator settings are swapped with each other so that the correct regulator gets enabled/disabled. ANA regulator register address is corrected. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulators: Moved define for number of regulators in ab8500Bengt Jonsson
The define for number of regulators is moved from ab8500-core to ab8500-regulator so that the regulator driver can be updated independently of ab8500-core. This also changes the platform configuration structure of ab8500-core so that it contains a pointer to the regulator_init_data array plus number of regulators instead of an fixed size array of pointers to regulator_init_data. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulator: Report actual configured voltage to set_voltage()Mark Brown
Change the interface used by set_voltage() to report the selected value to the regulator core in terms of a selector used by list_voltage(). This allows the regulator core to know the voltage that was chosen without having to do an explict get_voltage(), which would be much more expensive as it will generally access hardware. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-10-29mfd: Align ab8500 with the abx500 interfaceMattias Wallin
This patch makes the ab8500 mixed signal chip expose the same interface for register access as the ab3100, ab3550 and ab5500 chip. The ab8500_read() and ab8500_write() is removed and replaced with abx500_get_register_interruptible() and abx500_set_register_interruptible(). Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-09-05regulator: ab8500 - fix off-by-one value range checking for selectorAxel Lin
selector is used as array index of info->supported_voltages Thus the valid value range should be 0 .. info->voltages_len -1 Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Mark Brown <broonie@openource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-09-01regulator: ab8500 - fix the logic to remove already registered regulators in ↵Axel Lin
error path In current implementation, ab8500_regulator_info[0].regulator is not unregistered if the error happen at i > 0. This patch fixes the resource leak and also improves the readability. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-09-01regulator/ab8500: move dereference below the check for NULLDan Carpenter
I moved the dereference of "ab8500" below the check for NULL. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-11regulator: add support for regulators on the ab8500 MFDSundar R IYER
Hi Mark, > I think that's everything. Please find the updated patch set as below. >From f4bf7eec4d210db5075c0bce4521d9be6bc76c8c Mon Sep 17 00:00:00 2001 From: Sundar R Iyer <sundar.iyer@stericsson.com> Date: Sun, 6 Jun 2010 19:12:12 +0530 Subject: [PATCH v3 1/2] regulator: add support for regulators on the ab8500 MFD Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Bengt JONSSON <bengt.g.jonsson@stericsson.com> Signed-off-by: Sundar R Iyer <sundar.iyer@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
