Adding the regulator driver specific information and passing
this information through regulator driver data. This struture
is containing delay operation which is require to voltage to
be settle down after enabling rail.
Bug 939242
Change-Id: I7da6ec487fe5f04857d3fd5f06a383b4a8fbcc7b
Signed-off-by: Alok Chauhan <alokc@nvidia.com>
Reviewed-on: http://git-master/r/94500
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Modify the max8907c regulator to use the new i2c api in the mfd driver
Original-Change-Id: Ib919e97069459a9deb595b1fa0d3142763205de1
Reviewed-on: http://git-master/r/16614
Tested-by: Thomas Cherry <tcherry@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Rebase-Id: R10baa9eb3d5078457edc75a8774ec4be3228011d
The minimum, maximum, and step voltages for SD1 are different on max8907b
and max8907c. This change reads the version register of the device
and uses the proper values, defaulting to the max8907c values, unless
the device is a max8907b.
Bug 772688
Original-Change-Id: I2bc53e81c7784e47c50e4ff45c4f4d71d875e187
Reviewed-on: http://git-master/r/14503
Rebase-Id: R52c46e5096b21f9b530cfe19cea2cef964d640e5
Add max8907c regulator and mfd driver.
Add max8952 regulator driver.
Original-Change-Id: If63b724647d887a8088da0f2deb8af91e4fe3cfa
Signed-off-by: Jin Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/9902
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Rebase-Id: R34a5dc549ba3f6781e5b7371e8e182c3cf6368db
