2015-08-19 | regulator: qcom_smd: Set n_voltages for pm8941_lnldo | Axel Lin | |
Just setting fixed_uV is not enough, the regulator core will also check n_voltages setting. The fixed_uV only works when n_voltages is 1. Signed-off-by: Axel Lin <axel.lin@ingics.com> Reviewed-by: Bjorn Andersson <bjorn.andersson@sonymobile.com> Signed-off-by: Mark Brown <broonie@kernel.org> | |||
2015-08-17 | regulator: Regulator driver for the Qualcomm RPM | Bjorn Andersson | |
Driver for regulators exposed by the Resource Power Manager (RPM) found in devices based on Qualcomm 8974 and newer platforms. Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com> Acked-by: Andy Gross <agross@codeaurora.org> Tested-by: Tim Bird <tim.bird@sonymobile.com> Signed-off-by: Mark Brown <broonie@kernel.org> |
