The tps65911 chip introduces new features, including changes in
the regulator module.
- VDD1 and VDD2 remain unchanged.
- VDD3 is now named VDDCTRL and has a wider voltage range.
- LDOs are now named LDO1...8 and voltage ranges are sequential,
making LDOs easier to handle.
Signed-off-by: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
The desc_id variable should not be a static variable.
The rest of the code assumes the desc_id must less than TPSxxxxx_NUM_REGULATOR.
If we set desc_id to be a static variable, checking the return value of
rdev_get_id() may return error.
Cc: Anuj Aggarwal <anuj.aggarwal@ti.com>
Cc: Graeme Gregory <gg@slimlogic.co.uk>
The regulator module consists of 3 DCDCs and 8 LDOs. The output
voltages are configurable and are meant to supply power to the
main processor and other components
Signed-off-by: Graeme Gregory <gg@slimlogic.co.uk>
