The WM8994 regulator driver is perfectly happy if the GPIO used to enable
the regulator sleeps so call the appropriate GPIO API.
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (348 commits)
ALSA: hda - Fix NULL-derefence with a single mic in STAC auto-mic detection
ALSA: hda - Add missing NID 0x19 fixup for Sony VAIO
ALSA: hda - Fix ALC275 enable hardware EQ for SONY VAIO
ALSA: oxygen: fix Xonar DG input
ALSA: hda - Fix EAPD on Lenovo NB ALC269 to low
ALSA: hda - Fix missing EAPD for Acer 4930G
ALSA: hda: Disable 4/6 channels on some NVIDIA GPUs.
ALSA: hda - Add static_hdmi_pcm option to HDMI codec parser
ALSA: hda - Don't refer ELD when unplugged
ASoC: tpa6130a2: Fix compiler warning
ASoC: tlv320dac33: Add DAPM selection for LOM invert
ASoC: DMIC codec: Adding a generic DMIC codec
ALSA: snd-usb-us122l: Fix missing NULL checks
ALSA: snd-usb-us122l: Fix MIDI output
ASoC: soc-cache: Fix invalid memory access during snd_soc_lzo_cache_sync()
ASoC: Fix section mismatch in wm8995.c
ALSA: oxygen: add S/PDIF source selection for Claro cards
ALSA: oxygen: fix CD/MIDI for X-Meridian (2G)
ASoC: fix migor audio build
ALSA: include delay.h for msleep in Xonar DG support
Change the interface used by set_voltage() to report the selected value
to the regulator core in terms of a selector used by list_voltage().
This allows the regulator core to know the voltage that was chosen
without having to do an explict get_voltage(), which would be much more
expensive as it will generally access hardware.
LDO2 has a slightly different range of supported voltages on WM8958
so update the selector<->voltage mappings to match.
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
This ensures that if the GPIO was not enabled prior to the driver
starting the regulator API will insert the required powerup ramp
delay when it enables the regulator. The gpiolib API does not
provide this information.
[Rewrote changelog to describe the actual change -- broonie.]
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Cc: stable@kernel.org
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
It is a good tone to reset driver data after unbinding the device.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
The WM8994 contains two LDOs with mixed hardware/software control to
minimise the number of external supplies required while delivering
optimal voltages to minimise power consumption.
