Minimum voltage for LDO0 was specified with a code construct,
better solve this with a voltage table. This avoids a warning
in kernel log, too.
Bug 798821
Original-Change-Id: I706276a9aae3359006ddc7fe9134b67e00ec34fd
Reviewed-on: http://git-master/r/25185
Reviewed-by: David Schalig <dschalig@nvidia.com>
Tested-by: David Schalig <dschalig@nvidia.com>
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Rebase-Id: R800f3239d35415e5cb2f5ff2570f6f0285e44adc
TPS6586x SM0, SM1 and SM2 port have 2 power switching modes:
- PWM only, or
- PMW-PFM auto mode
Some of TPS6586x have voltage spike in PFM-to-FWM transition can lockup
the CPU if choose PWM-PFM auto mode.
This patch enables such mode selection on SMs ports from the board level
power configuration file.
BUG 796364
Original-Change-Id: I7015798151d6753ff5dcc329703338fde105e2b0
Reviewed-on: http://git-master/r/22701
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Reviewed-by: Xin Xie <xxie@nvidia.com>
Tested-by: Xin Xie <xxie@nvidia.com>
Rebase-Id: R2f74b345bc3ea3adc22adcab40ee407c3e65cae9
after enabling any LDO/SM, there is a specific amount of delay
required before the regulator becomes stable.
Original-Change-Id: Ife675b46eeec22e862bafd9f93774bd31782d53b
Reviewed-on: http://git-master/r/20738
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Rebase-Id: R2f7428e60415d486a43b8fab367ee597e8fce945
Modify the max8907c regulator to use the new i2c api in the mfd driver
Original-Change-Id: Ib919e97069459a9deb595b1fa0d3142763205de1
Reviewed-on: http://git-master/r/16614
Tested-by: Thomas Cherry <tcherry@nvidia.com>
Rebase-Id: R10baa9eb3d5078457edc75a8774ec4be3228011d
The minimum, maximum, and step voltages for SD1 are different on max8907b
and max8907c. This change reads the version register of the device
and uses the proper values, defaulting to the max8907c values, unless
the device is a max8907b.
Bug 772688
Original-Change-Id: I2bc53e81c7784e47c50e4ff45c4f4d71d875e187
Reviewed-on: http://git-master/r/14503
Rebase-Id: R52c46e5096b21f9b530cfe19cea2cef964d640e5
Add max8907c regulator and mfd driver.
Add max8952 regulator driver.
Original-Change-Id: If63b724647d887a8088da0f2deb8af91e4fe3cfa
Signed-off-by: Jin Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/9902
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Rebase-Id: R34a5dc549ba3f6781e5b7371e8e182c3cf6368db
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6: (23 commits)
regulator: Improve WM831x DVS VSEL selection algorithm
regulator: Bootstrap wm831x DVS VSEL value from ON VSEL if not already set
regulator: Set up GPIO for WM831x VSEL before enabling VSEL mode
regulator: Add EPEs to the MODULE_ALIAS() for wm831x-dcdc
regulator: Fix WM831x DCDC DVS VSEL bootstrapping
regulator: Fix WM831x regulator ID lookups for multiple WM831xs
regulator: Fix argument format type errors in error prints
regulator: Fix memory leak in set_machine_constraints() error paths
regulator: Make core more chatty about some errors
regulator: tps65910: Fix array access out of bounds bug
regulator: tps65910: Add missing breaks in switch/case
regulator: tps65910: Fix a memory leak in tps65910_probe error path
regulator: TWL: Remove entry of RES_ID for 6030 macros
ASoC: tlv320aic3x: Add correct hw registers to Line1 cross connect muxes
regulator: Add basic per consumer debugfs
regulator: Add rdev_crit() macro
regulator: Refactor supply implementation to work as regular consumers
regulator: Include the device name in the microamps_requested_ file
regulator: Increase the limit on sysfs file names
regulator: Properly register dummy regulator driver
get_ctrl_reg() returns -EINVAL so the error handling won't work here
if reg is a u8.
Add regulator driver for AnalogicTech AAT2870.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
The tps65912 consist of 4 DCDCs and 10 LDOs. The output voltages can be
configured by the SPI or I2C interface, they are meant to supply power
to the main processor and other components.
Signed-off-by: Margarita Olaya Cabrera <magi@slimlogic.co.uk>
Acked-by: Liam Girdwood <lrg@ti.com>
Rather than using the maximum voltage we get passed to select the DVS
voltage to use remember the highest voltage we've ever seen. This improves
how the driver works when the consumer permits higher voltages than it
will ever selects in order to support the widest possible voltage range.
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
If we don't have a DVS VSEL value already set when we start up then start
it off with the value currently being used for ON.
If the VSEL is not in use prior to us starting up then we need to make
sure we initialise the GPIO before we push the DVS control to being done
by the GPIO.
Read our initial VSEL from the correct register.
With multiple wm831x devices the device IDs used for the regulators will
not always be contiguous so simply taking the modulus is not sufficient
to look up the ID, we need to reverse the way the ID is generated.
We need to dereference the pointers to print their values.
Properly kfree rdev->constraints in all set_machine_constraints() error paths.
Also properly kfree rdev->constraints in regulator_register() error paths.
Prevent some head scratching by making the core log about some rare but
possible errors with invalid voltage ranges and modes being set.
For tps65910, the number of regulator is 13. ( ARRAY_SIZE(tps65910_regs) is 13)
For tps65911, the number of regulator is 12. ( ARRAY_SIZE(tps65911_regs) is 12)
If we are using this driver for tps65911,
we hit array access out of bounds bug in tps65910_probe() because
current implementation always assume the number of regulator is 13 and
thus it will access tps65911_regs[12].
Fix it by setting correct num_regulators for both chips in tps65910_probe(),
and allocated neccessay memory accordingly.
Also add a default case in tps65910_list_voltage_dcdc to silence
'volt' may be used uninitialized in this function warning.
Fix a memory leak if chip id is not matched.
RES_ID is only used in 4030, to send PBM singular message to control
the state of dedicated resources. In 6030, we don't have concept of PBM,
hence removing the definition of RES_ID (num) from macros.
Signed-off-by: Ambresh K <ambresh@ti.com>
The ramp_delay variable can be set lower than the desired value.
This patch fixes it.
Signed-off-by: Donggeun Kim <dg77.kim@samsung.com>
Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
Signed-off-by: KyungMin Park <kyungmin.park@samsung.com>
Small cleanups for better readability.
The platform_data (pdata) may be pointing to __initdata section, which
may be free'd from the memory. The dependency on pdata in non-init
functions is removed in this patch to allow platform to declare
__initdata for platform data.
Currently, ramp_delay variable is used uninitialzed in
max8997_set_voltage_ldobuck which gets called through
regulator_register calls.
To fix the problem, in max8997_pmic_probe, ramp_delay initialization
code is moved before calls to regulator_register.
Cc: Liam Girdwood <lrg@ti.com>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: MyungJoo Ham <myungjoo.ham@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com>
Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com>
Report the requested load and voltage for each consumer in debugfs when it
is enabled.
No actual users but provide the macro so there's less surprise when it's
not there.
Currently the regulator supply implementation is somewhat complex and
fragile as it doesn't look like standard consumers but is instead a
parallel implementation. This causes issues with locking and reference
counting.
Move the implementation over to using standard consumers to address this.
Rather than only notifying the supply on the first enable/disable we do so
every time the regulator is enabled or disabled, simplifying locking as we
don't need to hold a lock on the consumer we are about to enable.
We may have multiple devices requesting a supply with the same name so
include the device name in the generated filename for microamps_requested
to avoid duplicate files.
With verbose filenames we can easily hit 32 characters.
Recent changes in the driver core appear to mean that the data structures
for the driver core are not fully initialised unless the driver is bound.
Make sure the driver core knows the dummy driver is in use by binding it
to a driver.
The n_voltages initializer for the TWL6030_ADJUSTABLE_LDO macro is
off by one, causing the the highest supported voltage to be
unreachable. Setting the machine constraints to only allow the
highest voltage causes errors:
machine_constraints_voltage: VAUX3_6030: unsupportable voltage constraints
twl_reg twl_reg.39: can't register VAUX3_6030, -22
twl_reg: probe of twl_reg.39 failed with error -22
This patch fixes the off by one error. Tested by setting
VAUX3_6030 to 3.3V.
Signed-off-by: Colin Cross <ccross@android.com>
The WM8994 regulator driver is perfectly happy if the GPIO used to enable
the regulator sleeps so call the appropriate GPIO API.
In order to reduce the impact of ramp times rather than enabling the
regulators for a device in series use async tasks to run the actual
enables. This means that the delays which the enables implement can all
run in parallel, though it does mean that the order in which the
supplies come on may be unstable.
For super bonus fun points if any of the regulators are shared between
multiple supplies on the same device (as is rather likely) then this
will test our locking. Note that in this case we only delay once for
each physical regulator so the threads shouldn't block each other while
delaying.
It'd be even nicer if we could coalesce writes to a shared enable registers
in PMICs but that's definitely future work, and it may also be useful
and is certainly more achievable to optimise out the parallelism if none
of the regulators implement ramp delays.
In the case of get_voltage callback is NULL, current implementation in
_regulator_get_voltage will return -EINVAL.
Also returns proper error if ret is negative value.
Adding support for the twl6025. Major difference in the twl6025 is the
group functionality has been removed from the chip so this affects how
regulators are enabled and disabled.
The names of the regulators also changed.
The DCDCs of the 6025 are software controllable as well.
Since V1
Use the features variable passed via platform data instead of calling
global function.
Change the very switch like if statements to be a more readable
switch statement.
Since V2
twl6025 doesn't use remap so remove it from the macros.
Since V3
enable/disable functions for 4030/6030 were seperated upstream so rebase
on top of this. Change DCDC reference to SMPS as this is used in TRM.
Change list_voltage slightly to have less code.
Signed-off-by: Graeme Gregory <gg@slimlogic.co.uk>
TWL6030: regulator is disabled via VREG_STATE
TWL4030: regulator is disabled via VREG_GRP
Since there is nothing common, split twlreg_enable similar to other regulator_ops
Signed-off-by: Balaji T K <balajitk@ti.com>
TWL6030: regulator is enabled via VREG_STATE
TWL4030: regulator is enabled via VREG_GRP
The tps65911 chip introduces new features, including changes in
the regulator module.
- VDD1 and VDD2 remain unchanged.
- VDD3 is now named VDDCTRL and has a wider voltage range.
- LDOs are now named LDO1...8 and voltage ranges are sequential,
making LDOs easier to handle.
Signed-off-by: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk>
We use val as array index,
thus the valid value rangae for val should be 0 .. n_voltages-1.
Voltage values should be expressed in microvolts, not in milivolts.
Signed-off-by: Ranjani Vaidyanathan <ra5478@freescale.com>
MAX8997_REG_BUCK1DVS/MAX8997_REG_BUCK2DVS/MAX8997_REG_BUCK5DVS macros
In current implementation, the original macro implementation assumes the caller
pass the parameter starting from 1 (to match the register names in datasheet).
Thus we have unneeded plus one then minus one operations
when using MAX8997_REG_BUCK1DVS/MAX8997_REG_BUCK2DVS/MAX8997_REG_BUCK5DVS macros.
This patch removes these macros to avoid unneeded plus one then minus one operations
without reducing readability.
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
When applying the set_voltage() requests from consumers skip over those
consumers that haven't set anything, otherwise we'll come out with a
maximum voltage of zero.
If either a regulator driver can't tell us what the optimum mode is (or
doesn't have modes in the first place) or the system doesn't allow DRMS
changes then it's more helpful for users to just say that we're in the
optimal mode, even if it's from a selection of one.
Still report errors if the process of picking and setting a mode changes as
this may indicate that we're stuck in a low power mode and unable to deliver
a higher current that the consumer just asked for.
fix unreachable code.
