Fill the desc.supply_name for each rail with corresponding
input pinname as per datasheet.
Change-Id: I6dda1a95255549cce1773e271d6529d0f4d10392
Reviewed-on: http://git-master/r/120891
The DCDC regulators can support of control through extrenal
signal. Add support of this feature.
Change-Id: I9564d09cbab4d8903e8ea2fddc6739bbeb1573e2
Reviewed-on: http://git-master/r/120890
The LDO1 and LDO2 are always-on regulator from device.
Add support for these rails.
Change-Id: I9636029a1ba293b4a48f596a8e6a91112f2d2299
Reviewed-on: http://git-master/r/120889
Add support of providing the supply name through
regualtor descriptor. This help to fill the supply name
in device based on datasheet.
This patch help to develop driver which is align with
mainline.
This change is small set of change in mainline
commit 69511a452e6dc6b74fe4f3671a51b1b44b9c57e3
Author: Rajendra Nayak <rnayak@ti.com>
regulator: map consumer regulator based on device tree
Change-Id: Ia3112f29efe4f0e0c9e98f2b7943255b2eae4c49
Reviewed-on: http://git-master/r/120883
Fix compilation warning of -Wmaybe-uninitialized
Change-Id: Iad929f87205723cc906d2520630c2e1f20df4cf6
Reviewed-on: http://git-master/r/120843
TPS65090 add mfd sub device of "tps65090-pmic" and
"tps65090-regualtor" which is same.
Remove one of them.
Change-Id: Id02a432cbd240bd9deec9dce6865491afcec6303
Reviewed-on: http://git-master/r/120840
The regulator of tps65090 is registered as mfd sub device
and hence all regulator should be register in one call
of tps65090 regulator probe.
Fixing this by providing the list of regulator platform data
and registering the regulators in single probe call.
Change-Id: I06600d0bf4dfd62238bed77713ee8abf2afe2371
Reviewed-on: http://git-master/r/120838
In regulator platform data for tps65090, convert the regulator
init data to a pointer type to have easy support in DT.
Change-Id: I00a88e9f12ce5c55880e5c5084357d495bc99b56
Reviewed-on: http://git-master/r/120837
Currently the regulator info is stored in the data structure of
device. This avoid to have multiple instance of this driver
as it can corrupt the other instance driver.
Separating driver specific data with device information.
Change-Id: I359f05e07c2d2f4ade216e84a1a37c6dd8d5cb34
Reviewed-on: http://git-master/r/120836
Renaming regulator enums from TPS65090_ID_* to
TPS65090_REGULATOR_* for better readability.
Change-Id: I402de2069045b97000686e8010897c4a0821a48d
Reviewed-on: http://git-master/r/120835
Reviewed-by: Venu Byravarasu <vbyravarasu@nvidia.com>
regulator_register never returns NULL.
Acked by: Venu Byravarasu <vbyravarasu@nvidia.com>
(Cherry-picked from mainline
0ca2d6e65268477a53f959320a43d13b0c4d6b70)
drivers/regulator/tps65090-regulator.c
Change-Id: Id79e2beb2a3e278ace32054c19c463783f334a16
Reviewed-on: http://git-master/r/120372
TPS80031 supports the three external regulator named
as REGEN1, REGEN2 and SYSEN.
Supports these regulator through regulator driver.
Change-Id: I6c22aab13499a66ab8b4c68e8a5833553222decd
Reviewed-on: http://git-master/r/119977
Converting tps80031 regulator driver to be register as mfd
sub device of the tps65910 and register all its regulators from
single probe calls.
Add separate platform data for the regulator to be supply from
board as part of tps80031 platform data.
Change-Id: Ie65b25f3058202070f7f917e64a4a660dd941210
Reviewed-on: http://git-master/r/119976
Currently the platform specific data is sharing with
device information structure and hence it restrict to
use the multiple instance of the device.
Separating the device specific information to the platform
specific data and allocating different memory for
storing platform specific data.
Change-Id: I74284514c764f1ceb84f5d9dda215fea7f3cbd13
Reviewed-on: http://git-master/r/119975
The platform data of tps80031 have the regualtor_init_data as
non-pointer type. Converting this as pointer type for aligning
to regulator driver policy and easy support for DT.
Change-Id: I07f574953b09e0ed9ec3735d0ee7999ca35bee61
Reviewed-on: http://git-master/r/119974
Reviewed-by: Simone Willett <swillett@nvidia.com>
Renaming the regulator name from TPS80031_ID_* to
TPS80031_REGULATOR_* for better readability.
Change-Id: I627b6ddb78a60e44da2a869c0d51dd84166302ed
Reviewed-on: http://git-master/r/119972
This reverts commit 70e40e9cf025c73fde46d1a5577547dc37182a64
Change-Id: Iaf390c0d3ea16686f619f321bceea572ee7434fc
Reviewed-on: http://git-master/r/119802
All register fo TPS62361 is non-volatile and so implementing
this api for regmap actual caching.
bug 993297
Change-Id: I7695ed54bdb0fd9dec13e735264c12b60e18777a
Reviewed-on: http://git-master/r/119592
This reverts commit 5bc340e408aa3f009651735c71f3c97676fbe79f
Change-Id: I70e40e9cf025c73fde46d1a5577547dc37182a64
Reviewed-on: http://git-master/r/119800
Change-Id: I6176cb213d23e44061549fd1e81306756a324523
Align driver with mainline.
This is based on mainline change
452534e50780697a7e1d3cf87cdfdd2b5a0d3c6b
regulator: Add TPS65090 regulator driver
TPS65090 PMIC from TI consists of 3 step down converters,
2 always on LDOs and 7 current limited load switches. The
output voltages are ON/OFF controllable and are meant to
supply power to the components on target board.
Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Change-Id: I2aeacc948e2aa15aedd73c704787eef8ace9d336
Reviewed-on: http://git-master/r/119321
This driver supports voltage regulator driver for TI TPS51632
voltage regulator chip. The TPS52632 is 3-2-1 Phase D-Cap+ Step
Down Driverless Controller with Serial VID control and DVFS.
This device has only one voltage output.
bug 978821
Change-Id: I73f3fd696bab5267e76e788fb4b5bf8d9f10b5b5
Reviewed-on: http://git-master/r/117381
Adjust the tolerance voltage only when requested minimum voltage is
more than the rail's minimum voltage.
bug 997415
Change-Id: Ie139c657f8550adba07b74a0cd5d69e2b53d62c2
Signed-off-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Reviewed-on: http://git-master/r/116405
Sometimes the system allow to run in less than requested
minimum voltage and if this tolerance allow the regulator
to set voltage in lower side range than this saves the power.
For the example, if client request vmin = 975mV for regulator
voltage then it sets the voltage to 987.5mv as the nearest to this
desired value. The next lower side for the voltage is 974.8mv.
So if system runs on tolerance of 1mv and if it request for
975mv then driver can look for minimum voltage as 975 - tolerance(1)
= 974mv and possible configure 974.8mv rather than 987.5mV and so
it can save the power equivalent to 12.5mV higher voltage.
Support the configuration of tolerance value.
Change-Id: Ic8312bb397c2615a3ee0f84072ec394e513525ea
Reviewed-on: http://git-master/r/110523
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Allow to configure the rail into sleep-off mode even if
the external req is not supported for a regulator.
bug 979143
Change-Id: I3c1bd789410b557a2ffc3133ca15ec3753ed2004
Reviewed-on: http://git-master/r/110881
This change removes the read/write callback functions in favor of common
regmap accessors inside the header file. This change also makes use of
regmap_read/write for single register access which maps better onto what this
driver actually needs.
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
(Cherry-pick from mainline
3f7e82759c692df473675ed06fb90b20f1f225c3)
Change-Id: Ida79b196acf65ed14ff9fd2cc1f7c0048f99ba2b
Reviewed-on: http://git-master/r/105922
Reviewed-by: Rhyland Klein <rklein@nvidia.com>
GVS: Gerrit_Virtual_Submit
Change the mechanism of enabling the force PWM mode through
regulator set mode. This can be dynamically configured now.
In the REGULATOR_MODE_FAST the force PWM is enabled and in
REGULATOR_MODE_NORMAL the force PWM is disabled.
Cherry-picked from mainline commit 9a00630
Change-Id: I39a77dbe5d0c4c2a5b81dbfe51163a65894bc98c
Reviewed-on: http://git-master/r/105832
Fixing build issue reported by Paul Gortmaker:
It appears this breaks linux-next allmodconfig build, because it
uses an uppercase V in the v2 of its MODULE_LICENSE.
FATAL: modpost: GPL-incompatible module rc5t583-regulator.ko uses
GPL-only symbol 'platform_driver_unregister'
make[2]: *** [__modpost] Error 1
(cherry picked from commit 4eb06453648bb0d1eca3669f26798a19b6f40eb8)
Change-Id: I8c715cf5a8e72555721a954d6db6879aed2eb423
Reviewed-on: http://git-master/r/105884
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
The nsteps can be calculated by (_max_mv - _min_mv) * 1000 / _step_uV + 1,
thus we can remove _nsteps from RC5T583_REG macro, and then remove
nsteps from struct rc5t583_regulator_info.
Acked-by: Laxman Dewangan <ldewangan@nvidia.com>
(cherry picked from commit e3a7384c3e98c48b5f122e449e22cc8a1a6c7e0d)
Change-Id: If6db39255b2f7f8be38b848f2ca2619301b19b38
Reviewed-on: http://git-master/r/105883
The valid selector should be 0 ... nsteps-1.
(cherry picked from commit 9cc7a453b637d8c1f628f9873204ff55d7aa664c)
Change-Id: Ie1a39883036de3b2945d35854e0a16c46d2a9db2
Reviewed-on: http://git-master/r/105882
1. regulator_register returns ERR_PTR on error, thus use IS_ERR to check the
return value.
2. Fix off-by-one for unregistering the registered regulator.
Current code does not unregister regs[0].rdev in clean_exit.
(cherry picked from commit a69df8a14ae7b891ee22f0e4c081f3ff65c0640f)
Change-Id: Ib5e00e655020e313c73e5b838e62dbdea54c28d0
Reviewed-on: http://git-master/r/105881
The RC5T583 PMIC from RICOH consists of 4 DCDC and 10
LDOs. This driver supports the control of different
regulator output through regulator interface.
This driver depends on MFD driver of RC5T583 and uses
mfd rc5t583 apis to communicate to device for accessing
different device's registers.
(Cherry-picked from mainline commit
6ffc3270210efa2bea526953a142ffc908f5bd86)
Change-Id: If6bcc9c987fc97ff6f0c61e53de715cd84d0151b
Reviewed-on: http://git-master/r/105877
Fix multiple stylistic issue like:
- The print message should be not break into multiple line.
- line gap after variable declaration and statement.
- checkpatch error.
- some typo.
Some enhancement on error message printing to print error value
also along with proper text.
Avoid voltage_base conversion to microvolts every time.
Put init functions in init section.
Using efficient function inplace of calling multiple function
to reduce the code size.
(cherry picked from commit 2935fb18aa1e75e6afaab3303cdd1a4ac62be63e)
Change-Id: I988938f8f8cc6fb5355e32bd6ac25d95db94913c
Reviewed-on: http://git-master/r/105831
Settling time is require when there is voltage output change.
Implement set_voltage_time_sel() callback which returns delay time
for voltage change to settle down to new value.
(cherry picked from commit a60cfce051dd5e22329df1018d278bf3e52d82bc)
Change-Id: I522df8a72595622fd99cc46043c34610434d932f
Reviewed-on: http://git-master/r/105830
Enable cache of device register using regmap cache RBTREE.
(cherry picked from commit 16ea003bd1c95ea55a0b88187ce7cbeaca760fcf)
Change-Id: If747dd18a488d500f8295f903c8da92c241c293e
Reviewed-on: http://git-master/r/105829
(cherry picked from commit 9a4bdd87a29bf297d9046410b011d726d51c3999)
Change-Id: Ic7cca64e14b2b2e812140c8d368279b615da074f
Reviewed-on: http://git-master/r/105828
According to the datasheet[1], tps62360 is register compatible with tps62362.
tps62361B is register compatible with tps62363.
Thus this patch adds support for tps62362 and tps62363.
[1] http://www.ti.com/litv/pdf/slvsau9b
Change-Id: I62cdede0755d7decedeb7b1ef08e216a0dad3a12
(Cherry-picked from mainline commit d1cf4f6)
Change-Id: Ib9c4a63f06182c0ed2c1f27d9bf63342aa8474bc
Reviewed-on: http://git-master/r/105827
The client field of struct tps62360_chip is not used after converting to regmap.
The name field of struct tps62360_chip is not used in this driver.
(cherry picked from mainline commit c60f1718f508a40964c149f1139b4eaaae825fd3)
Change-Id: If7b0606b60bd887bc20ecbdaf5cafa6ccba8ff77
Reviewed-on: http://git-master/r/105826
The variable 'selector' is a 'unsigned int', so it can never be less than zero.
(cherry picked from commit 46783a046e13588f0459271ad6db9785fa8dcb8b)
Change-Id: I920b1628016b7d1c0b626497f24210c5c1f549ab
Reviewed-on: http://git-master/r/105825
Enable output discharge always to have faster ramp-down
time.
bug 981330
Change-Id: I0a00ab38e9be631a58bc8b11148be5c3c508d119
Reviewed-on: http://git-master/r/102882
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
This driver supports ivoltage regulator driver for MAX8973
voltage regulator chip. The MAX8973 high-efficiency, three-phase,
DC-DC step-down switching regulator delivers up to 9A of
output current.
bug 981355
Change-Id: I6e4ff62139face4e47e2be269554a64c2654e74b
Reviewed-on: http://git-master/r/102148
The regulator module consists of 1 DCDC. The output voltage
is configurable and is meant for supply power to the core
voltage of Soc.
Change-Id: Ic62d100a588f7b6f1b30c11fd44a925c97393069
Reviewed-on: http://git-master/r/100653
Fix fps update condition in max77663_regulator_set_fps().
Bug 930883
Change-Id: I2f57603320a91b2727932586fc3c66d9de347d64
signed-off-by: Jinyoung Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/92707
Added support for enable/disable rails from user space.
bug 966960
Change-Id: Iae660699c60f537296f90508a78bd40959c46535
Reviewed-on: http://git-master/r/99186
Reviewed-by: Hunk Lin <hulin@nvidia.com>
Tested-by: Hunk Lin <hulin@nvidia.com>
If sd power rail is not configured to FORCED_PWM_MODE or
FSRADE_DISABLE, clear corresponding bits(FPWM and FSRADE)
when initialization.
Change-Id: I4e08329a430c6ccf7179b77cc7a283460ffaedd1
Signed-off-by: Jinyoung Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/98715
Adding the regulator driver specific information and passing
this information through regulator driver data. This struture
is containing delay operation which is require to voltage to
be settle down after enabling rail.
Bug 939242
Change-Id: I7da6ec487fe5f04857d3fd5f06a383b4a8fbcc7b
Signed-off-by: Alok Chauhan <alokc@nvidia.com>
Reviewed-on: http://git-master/r/94500
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
The gpio_switch regulator is NV driver developed during
tegra3 bringup time. The driver functionality is upstreamed
to mainline into fixed regulator and it is accepted by community.
The required functionality is also downstream and required client
driver is moved to use the fixed regulator. Hence this driver
is just duplicating functionality with fixed regulator and hence
removing this.
Change-Id: I893328497644612a2267f2c24298ff2f668e75d4
Reviewed-on: http://git-master/r/94198
Adding flag on fixed regulator board configuration structure
to specify whether gpio is open drain type or not.
Passing this information to gpio library when requesting
gpio so that gpio driver can set the pin state accordingly,
for open drain type:
- Pin can be set HIGH as setting as input, PULL UP on
pin make this as HIGH.
- Pin can be set LOW as setting it as output and drive to LOW.
The non-open drain pin can be set HIGH/LOW by setting it to
output and driving it to HIGH/LOW.
a4d9f179cc788b7f4b735d32c2e4a3b2562e8240
Change-Id: I2ee7789db67fdeea77c0d6ac2b44876af36c803e
Reviewed-on: http://git-master/r/94150
Settling time is require when there is dcdc rail's voltage change.
Returning proper delay time for dcdc voltage change to settle down
the output voltage to new value.
(cherry picked from commit 18039e0f16d50c8243fe0388a587c25a3b155ece)
Change-Id: Ibd67d2661dd1d5b014754c221d44963baeb13726
Reviewed-on: http://git-master/r/90518
There is settling time for each rails when it is switched to
ON. Implementing enable time for returning proper settling time
of regulator rails when it is enabled.
Filling the on-time for each rail as per tps65910/tps65911
datasheets.
(cherry picked from commit 0651eed5e094a079a0a9fccd80a41cb3e7f2aa99)
Change-Id: Ibdb05171cfb4c4e7a064c8f65193647997e8e9a8
Reviewed-on: http://git-master/r/90517
