1. Fix this compilation error:
/workdir/oe/tmp-glibc/work-shared/verdin-imx8mm/kernel-source/drivers/
rpmsg/virtio_rpmsg_bus.c:1106:23: error: redeclaration of 'newch'
with no linkage
struct rpmsg_device *newch;
rpmsg/virtio_rpmsg_bus.c:1101:23: note: previous declaration of
'newch' was here
2. Fix warnings that are reproduced when RPMsg char device support is
disabled.
Fixes: 1172ee2e ("rpmsg: virtio rpmsg: Add RPMsg char driver support")
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
virtio rpmsg was not implemented to use RPMsg char driver.
Each virtio ns announcement will create a new RPMsg device which
is supposed to bound to a RPMsg driver. It doesn't support
dynamic endpoints with name service per RPMsg device.
With RPMsg char driver, you can have multiple endpoints per
RPMsg device.
Here is the change from this patch:
* Introduce a macro to indicate if want to use RPMsg char driver
for virtio RPMsg. The RPMsg device can either be bounded to
a simple RPMsg driver or the RPMsg char driver.
* Create Virtio RPMsg char device when the virtio RPMsg driver is
probed.
* when there is a remote service announced, keep it in the virtio
proc remote services list.
* when there is an endpoint created, bind it to a remote service
from the remote services list. If the service doesn't exist yet,
create one and mark the service address as ANY.
That patch ported to our 4.14 kernel + additional fixes added [1].
Example of usage from userspace app:
char data_buf [] = {'a', 'b', 'c', 'd', '\0'};
struct rpmsg_endpoint_info ept_info = {"rpmsg-openamp-demo-channel", 0x2, 0x1};
int fd = open("/dev/rpmsg_ctrl0", O_RDWR);
/* create endpoint interface */
ioctl(fd, RPMSG_CREATE_EPT_IOCTL, &ept_info);
/* create endpoint */
int fd_ept = open("/dev/rpmsg0", O_RDWR);
/* receive data from remote device */
read(fd_ept, &data_buf, sizeof(data_buf));
/* send data to remote device */
write(fd_ept, &data_buf, sizeof(data_buf));
/* destroy endpoint */
ioctl(fd_ept, RPMSG_DESTROY_EPT_IOCTL);
close(fd_ept);
close(fd);
[1] https://patchwork.kernel.org/patch/10145779/
Signed-off-by: Wendy Liang <jliang@xilinx.com>
Signed-off-by: Andri Schmidt <a.schmidt@scewo.ch>
Return ENOTTY if no reader is using the TTY. Note that the
VirtIO transport used by RPmsg currently does not use the
return value of this callback, hence currently will not
influence operation in any way.
Pushing data while there is no reader seems to lock/crash the TTY
layer in some way. Especially when a reader gets attached again,
the kernel crashes with
Unable to handle kernel paging request at virtual address 00002248
Also use tty_insert_flip_string which handels the copying and TTY
buffer resizing if necessary.
(cherry picked from commit 5aba75e2c61d4044bed21730b7c471822860fac1)
Since, the partition reset irq would be triggered anytime.
Do not read the status of the MU if master side is in suspend mode.
Signed-off-by: Richard Zhu <hongxing.zhu@nxp.com>
(cherry picked from commit 117dbcb1ce258587f8d162c0b3219f32d6de6fbc)
Some rpmsg user may require rpmsg resume before the user start
handle its irq, e.g the typec controller use a GPIO as irq and
use rpmsg to get event status, so move imx rpmsg power management
ops to noirq phrase.
Reviewed-by: Richard Zhu <hongxing.zhu@nxp.com>
Tested-by: Clark Wang <xiaoning.wang@nxp.com>
Signed-off-by: Anson Huang <anson.huang@nxp.com>
Signed-off-by: Li Jun <jun.li@nxp.com>
Remove the delay waiting, add the sync mechanism during partition reset.
In order to avoid the hang at master side during the rpmsg restore
procedure. Re-initialize the first_notify parameter, when rpmsg master
assumes remote processor is dead.
Otherwise, master side maybe hang during the rpmsg restore procedure
in some corner cases.
~14ms is required by M4 to process the MU message from the cold boot.
Set the max wait of MU_SendMessageTimeout to 20ms.
Reviewed-by: Robin Gong <yibin.gong@nxp.com>
(cherry picked from commit 6b5573a9c645b947688c171b2dbdb6b70b59356c)
Clear pending interrupt status of partition reboot during rpmsg
driver probe to avoid to unregister/register virtio device again.
Signed-off-by: Fugang Duan <fugang.duan@nxp.com>
For the virtual i2c driver should be initialized in subsystem before the
other modules initialize. So, the imx_rpmsg and virtio_rpmsg_bus should
be initialized before virtual i2c driver. Now, use arch_initcall to
initialize these two modules.
Signed-off-by: Clark Wang <xiaoning.wang@nxp.com>
of rpmsg device
Currently, issue RPMSG_NS_DESTROY before kick off ready notification to
m4 to let m4 side go through all the stale message in vring buffer without
doing anything after m4 reset, that's not good enough. The better way is to
clear vring buffer after m4 reset, thus everything will be done as the
first time of kernel/m4 bootup. So unregister/register virtio device
instead of rpmsg device if m4 partition reset.
Signed-off-by: Robin Gong <yibin.gong@nxp.com>
Allocate ivdev dynamically instead of static, so that ivdev could
be re-initialized by kzalloc() such as 'struct virtio_device', otherwise,
the later patch that unregister/register virtio device instead of rpmsg
device will cause kernel complain such as 'kobject: tried to init an
initialized' and finally register virtio device failure after m4 partition
reset.
Add the imx8mq/mm rpmsg variant in the driver.
No function changes.
Fix building error caused by commit c6cd4096c224f("MLK-20691-1:
rpmsg: imx_rpmsg: add new partition reset interrupt") because
of no scu functions on i.mx6sx/7d legancy chip.
Acked-by: Richard Zhu <hongxing.zhu@nxp.com>
unregister all rpmsg devices and kick off ready notifyication
again to restore back rpmsg communications after M4 partion
reset.
Add new partition reset interrupt group to know M4 reset and restore
back at rpmsg level later.
- reserve one per dev dma pool, and alloc the share memory
from it.
Acked-by: Fugang Duan <fugang.duan@nxp.com>
If RPMSG dma memory allocate from per-device mem pool by calling .dma_alloc_coherent(),
the size is bigger than 2M bytes and alignment with 2M (PMD_SIZE), then kernel dump by
calling .vmalloc_to_page().
Since per-device dma pool do vmap mappings by __ioremap(), __ioremap() might use
the hugepage mapping, which in turn will cause the vmalloc_page failed to return
the correct page due to the PTE not setup.
For exp, when reserve 8M bytes per-device dma mem pool, __ioremap() will use hugepage
mapping:
__ioremap
ioremap_page_range
ioremap_pud_range
ioremap_pmd_range
pmd_set_huge(pmd, phys_addr + addr, prot)
Commit:029c54b09599 ("mm/vmalloc.c: huge-vmap: fail gracefully on unexpected huge
vmap mapping") ensure that vmalloc_to_page() does not go off into the weeds trying
to dereference huge PUDs or PMDs as table entries:
rpmsg_sg_init ->
vmalloc_to_page->
WARN_ON_ONCE(pmd_bad(*pmd));
In generally, .dma_alloc_coherent() allocate memory from CMA pool/DMA pool/atomic_pool,
or swiotlb slabs pool, the virt address mapping to physical address should be lineal,
so for the rpmsg scatterlist initialization can use pfn to find the page to avoid to
call .vmalloc_to_page().
Kernel dump:
[ 0.881722] WARNING: CPU: 0 PID: 1 at mm/vmalloc.c:301 vmalloc_to_page+0xbc/0xc8
[ 0.889094] Modules linked in:
[ 0.892139] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.14.78-05581-gc61a572 #206
[ 0.899604] Hardware name: Freescale i.MX8QM MEK (DT)
[ 0.904643] task: ffff8008f6c98000 task.stack: ffff000008068000
[ 0.910549] PC is at vmalloc_to_page+0xbc/0xc8
[ 0.914987] LR is at rpmsg_sg_init+0x70/0xcc
[ 0.919238] pc : [<ffff0000081c80d4>] lr : [<ffff000008ac471c>] pstate: 40000045
[ 0.926619] sp : ffff00000806b8b0
[ 0.929923] x29: ffff00000806b8b0 x28: ffff00000961cdf0
[ 0.935220] x27: ffff00000961cdf0 x26: 0000000000000000
[ 0.940519] x25: 0000000000040000 x24: ffff00000961ce40
[ 0.945819] x23: ffff00000f000000 x22: ffff00000961ce30
[ 0.951118] x21: 0000000000000000 x20: ffff00000806b950
[ 0.956417] x19: 0000000000000000 x18: 000000000000000e
[ 0.961717] x17: 0000000000000001 x16: 0000000000000019
[ 0.967016] x15: 0000000000000033 x14: 616d64202c303030
[ 0.972316] x13: 3030306630303030 x12: 3066666666206176
[ 0.977615] x11: 203a737265666675 x10: 62203334394c203a
[ 0.982914] x9 : 000000000000009f x8 : ffff00000806b970
[ 0.988214] x7 : 0000000000000000 x6 : ffff000009690712
[ 0.993513] x5 : 0000000000000000 x4 : 0000000080000000
[ 0.998812] x3 : 00e8000090800f0d x2 : ffff8008ffffd3c0
[ 1.004112] x1 : 0000000000000000 x0 : ffff00000f000000
[ 1.009416] Call trace:
[ 1.011849] Exception stack(0xffff00000806b770 to 0xffff00000806b8b0)
[ 1.018279] b760: ffff00000f000000 0000000000000000
[ 1.026094] b780: ffff8008ffffd3c0 00e8000090800f0d 0000000080000000 0000000000000000
[ 1.033915] b7a0: ffff000009690712 0000000000000000 ffff00000806b970 000000000000009f
[ 1.041731] b7c0: 62203334394c203a 203a737265666675 3066666666206176 3030306630303030
[ 1.049550] b7e0: 616d64202c303030 0000000000000033 0000000000000019 0000000000000001
[ 1.057368] b800: 000000000000000e 0000000000000000 ffff00000806b950 0000000000000000
[ 1.065188] b820: ffff00000961ce30 ffff00000f000000 ffff00000961ce40 0000000000040000
[ 1.073008] b840: 0000000000000000 ffff00000961cdf0 ffff00000961cdf0 ffff00000806b8b0
[ 1.080825] b860: ffff000008ac471c ffff00000806b8b0 ffff0000081c80d4 0000000040000045
[ 1.088646] b880: ffff0000092c8528 ffff00000806b890 ffffffffffffffff ffff000008ac4710
[ 1.096461] b8a0: ffff00000806b8b0 ffff0000081c80d4
[ 1.101327] [<ffff0000081c80d4>] vmalloc_to_page+0xbc/0xc8
[ 1.106800] [<ffff000008ac4968>] rpmsg_probe+0x1f0/0x49c
[ 1.112107] [<ffff00000859a9a0>] virtio_dev_probe+0x198/0x210
[ 1.117839] [<ffff0000086a1c70>] driver_probe_device+0x220/0x2d4
[ 1.123829] [<ffff0000086a1e90>] __device_attach_driver+0x98/0xc8
[ 1.129913] [<ffff00000869fe7c>] bus_for_each_drv+0x54/0x94
[ 1.135470] [<ffff0000086a1944>] __device_attach+0xc4/0x12c
[ 1.141029] [<ffff0000086a1ed0>] device_initial_probe+0x10/0x18
[ 1.146937] [<ffff0000086a0e48>] bus_probe_device+0x90/0x98
[ 1.152501] [<ffff00000869ef88>] device_add+0x3f4/0x570
[ 1.157709] [<ffff00000869f120>] device_register+0x1c/0x28
[ 1.163182] [<ffff00000859a4f8>] register_virtio_device+0xb8/0x114
[ 1.169353] [<ffff000008ac5e94>] imx_rpmsg_probe+0x3a0/0x5d0
[ 1.175003] [<ffff0000086a3768>] platform_drv_probe+0x50/0xbc
[ 1.180730] [<ffff0000086a1c70>] driver_probe_device+0x220/0x2d4
[ 1.186725] [<ffff0000086a1dc8>] __driver_attach+0xa4/0xa8
[ 1.192199] [<ffff00000869fdc4>] bus_for_each_dev+0x58/0x98
[ 1.197759] [<ffff0000086a1598>] driver_attach+0x20/0x28
[ 1.203058] [<ffff0000086a1114>] bus_add_driver+0x1c0/0x224
[ 1.208619] [<ffff0000086a26ec>] driver_register+0x68/0x108
[ 1.214178] [<ffff0000086a36ac>] __platform_driver_register+0x4c/0x54
[ 1.220614] [<ffff0000093d14fc>] imx_rpmsg_init+0x1c/0x50
[ 1.225999] [<ffff000008084144>] do_one_initcall+0x38/0x124
[ 1.231560] [<ffff000009370d28>] kernel_init_freeable+0x18c/0x228
[ 1.237640] [<ffff000008d51b60>] kernel_init+0x10/0x100
[ 1.242849] [<ffff000008085348>] ret_from_fork+0x10/0x18
[ 1.248154] ---[ end trace bcc95d4e07033434 ]---
Suggested-and-reviewed-by: Jason Liu <jason.hui.liu@nxp.com>
To make sure that the message wound't be discarded when
M4 is running normally or in the suspend mode. Only use
the timeout mechanism by the first notify when the vdev
is registered.
Fix the kernel panic during tty rpmsg str echo demo.
Root cause: The driver name may be flushed.
Use the kasprintf to setup the rpmsg tty driver name to
fix this issue.
[ 35.494361] Unable to handle kernel paging request at virtual address
ffff000021b4ba40
[ 35.502321] Mem abort info:
[ 35.505117] Exception class = DABT (current EL), IL = 32 bits
[ 35.511099] SET = 0, FnV = 0
[ 35.514188] EA = 0, S1PTW = 0
[ 35.517328] Data abort info:
[ 35.520255] ISV = 0, ISS = 0x00000007
[ 35.524130] CM = 0, WnR = 0
[ 35.527140] swapper pgtable: 4k pages, 48-bit VAs, pgd =
ffff0000096dd000
[ 35.533964] [ffff000021b4ba40] *pgd=000000097fffe803,
*pud=000000097fffd803, *pmd=0000000973d20003, *pte=0000000000000000
[ 35.544976] Internal error: Oops: 96000007 [#1] PREEMPT SMP
[ 35.550553] Modules linked in: imx_rpmsg_tty
[ 35.554843] CPU: 2 PID: 3911 Comm: sh Not tainted
4.14.62-05098-gcff652e-dirty #41
[ 35.562419] Hardware name: Freescale i.MX8QM MEK (DT)
[ 35.567479] task: ffff8008f3950000 task.stack: ffff000021b10000
[ 35.573413] PC is at string+0x28/0x98
[ 35.577080] LR is at vsnprintf+0x3c0/0x688
[ 35.581177] pc : [<ffff000008d5f1a0>] lr : [<ffff000008d61c70>]
pstate: a0000145
[ 35.588577] sp : ffff000021b13970
[ 35.591894] x29: ffff000021b13970 x28: ffff80097365f56f
[ 35.597219] x27: ffff0000092cf03a x26: ffff0000092cf03a
[ 35.602544] x25: ffff000021b13a80 x24: ffff8008f365f570
[ 35.607869] x23: 00000000ffffffd8 x22: ffff000008fc08dc
[ 35.613195] x21: 000000007fffffff x20: ffff000008fc08cc
[ 35.618512] x19: ffff8008f365f570 x18: 0000000000000000
[ 35.623827] x17: 0000ffffbec93588 x16: ffff00000820b2c0
[ 35.629144] x15: 0000000000000000 x14: ffffffffffffffff
[ 35.634461] x13: 0000000000000018 x12: 0101010101010101
[ 35.639777] x11: 0000000000000000 x10: ffff000021b13a80
[ 35.645085] x9 : ffff000021b13a80 x8 : ffff000021b13a80
[ 35.650402] x7 : ffff8008f365f570 x6 : fffffffffffffffe
[ 35.655718] x5 : 00000000ffffffd0 x4 : ffff000021b4ba40
[ 35.661035] x3 : ffff0a00ffffff04 x2 : ffff80097365f56f
[ 35.666354] x1 : ffff80097365f56f x0 : ffffffffffffffff
[ 35.671672] Process sh (pid: 3911, stack limit = 0xffff000021b10000)
[ 35.678022] Call trace:
[ 35.680465] Exception stack(0xffff000021b13830 to 0xffff000021b13970)
[ 35.686911] 3820: ffffffffffffffff
ffff80097365f56f
[ 35.694748] 3840: ffff80097365f56f ffff0a00ffffff04 ffff000021b4ba40
00000000ffffffd0
[ 35.702581] 3860: fffffffffffffffe ffff8008f365f570 ffff000021b13a80
ffff000021b13a80
[ 35.710409] 3880: ffff000021b13a80 0000000000000000 0101010101010101
0000000000000018
[ 35.718245] 38a0: ffffffffffffffff 0000000000000000 ffff00000820b2c0
0000ffffbec93588
[ 35.726081] 38c0: 0000000000000000 ffff8008f365f570 ffff000008fc08cc
000000007fffffff
[ 35.733908] 38e0: ffff000008fc08dc 00000000ffffffd8 ffff8008f365f570
ffff000021b13a80
[ 35.741744] 3900: ffff0000092cf03a ffff0000092cf03a ffff80097365f56f
ffff000021b13970
[ 35.749583] 3920: ffff000008d61c70 ffff000021b13970 ffff000008d5f1a0
00000000a0000145
[ 35.757417] 3940: ffff8008fff5fb00 0000000000001c00 0000ffffffffffff
ffff000008d61930
[ 35.765254] 3960: ffff000021b13970 ffff000008d5f1a0
[ 35.770129] [<ffff000008d5f1a0>] string+0x28/0x98
[ 35.774837] [<ffff000008d61c70>] vsnprintf+0x3c0/0x688
[ 35.779980] [<ffff000008d620e4>] sprintf+0x4c/0x58
Reviewed-by: Fugang Duan <fugang.duan@nxp.com>
- Add the timeout mu msg send api.
- Use the timeout mu send message function to do the
notification when multi-vdev is enabled on one channel.
Add the power management operations into imx
rpmsg driver.
Initialize spinlock before using, otherwise the below oops triggered if
CONFIG_DEBUG_SPINLOCK enabled.
BUG: spinlock bad magic on CPU#0, kthreadd/2
lock: imx_rpmsg_vprocs+0x1240/0x24a0, .magic: 00000000, .owner: <none>/-1, .ow0
CPU: 0 PID: 2 Comm: kthreadd Not tainted 4.9.88-04946-gf984c92 #324
Hardware name: Freescale i.MX7ULP (Device Tree)
[<8010ea64>] (unwind_backtrace) from [<8010b184>] (show_stack+0x10/0x14)
[<8010b184>] (show_stack) from [<803c3a8c>] (dump_stack+0x78/0x8c)
[<803c3a8c>] (dump_stack) from [<8016a744>] (do_raw_spin_lock+0xc4/0x120)
[<8016a744>] (do_raw_spin_lock) from [<809f7448>] (_raw_spin_lock_irqsave+0x20/)
[<809f7448>] (_raw_spin_lock_irqsave) from [<807bcdc8>] (imx_mu_rpmsg_isr+0x38/)
[<807bcdc8>] (imx_mu_rpmsg_isr) from [<801722d8>] (__handle_irq_event_percpu+0x)
[<801722d8>] (__handle_irq_event_percpu) from [<8017237c>] (handle_irq_event_pe)
[<8017237c>] (handle_irq_event_percpu) from [<801723f0>] (handle_irq_event+0x38)
[<801723f0>] (handle_irq_event) from [<801757f4>] (handle_fasteoi_irq+0xd0/0x1a)
[<801757f4>] (handle_fasteoi_irq) from [<80171594>] (generic_handle_irq+0x24/0x)
[<80171594>] (generic_handle_irq) from [<80171abc>] (__handle_domain_irq+0x7c/0)
[<80171abc>] (__handle_domain_irq) from [<801014e8>] (gic_handle_irq+0x48/0x8c)
[<801014e8>] (gic_handle_irq) from [<8010bb8c>] (__irq_svc+0x6c/0xa8)
This patch was cherry picked from
https://patchwork.kernel.org/patch/10155143/
When virtio-rpmsg device is provided via virtio-mmio transport, the
dma_alloc_coherent() (called by rpmsg_probe()) fails on ARM/ARM64
systems because "vdev->dev.parent->parent" device is used as parameter
to dma_alloc_coherent().
The "vdev->dev.parent->parent" device represents underlying remoteproc
platform device when virtio-rpmsg device is provided via
virtio-remoteproc
transport. When virtio-rpmsg device is provided via virtio-mmio
transport,
the "vdev->dev.parent->parent" device represents the parent device of
virtio-mmio platform device and dma_alloc_coherent() fails for this
device
because generally there is no corresponding platform device and dma_ops
are not setup for "vdev->dev.parent->parent".
This patch fixes dma_alloc_coherent() usage in rpmsg_probe() by trying
dma_alloc_coherent() with "vdev->dev.parent" device when it fails with
"vdev->dev.parent->parent" device.
Fixes: b5ab5e24e960 ("remoteproc: maintain a generic child device for
Signed-off-by: Anup Patel <anup@brainfault.org>
Signed-off-by: Adriana Reus <adriana.reus@nxp.com>
NXP i.MX7ULP EVK boards all sensors connect with M4 core, A core
has to conmunicate with sensors by virtual io bus like rpmsg bus.
The driver implement the virtual sensor input driver to configure
sensors active/idle/delay actions and report the sensors' event to
user space.
Supply below sysfs for user to enable/disable detector and counter,
set poll delay:
/sys/class/misc/step_counter/enable
/sys/class/misc/step_detector/enable
/sys/class/misc/step_counter/poll_delay
Reviewed-by: Elven Wang <elven.wang@nxp.com>
Because that there are two M4 cores on iMX8QM.
Enable the multi-core string echo support.
BuildInfo:
- SCFW a6fd9a48, IMX-MKIMAGE 0, ATF 0
- U-Boot 2017.03-imx_v2017.03_4.9.11_imx8_alpha+g258936c
Reviewed-by: Frank Li <frank.li@nxp.com>
- Init multi-core mu power and clk.
- enable the multi-core rpmsg support
BuildInfo:
Tested-by: Andy Duan <fugang.duan@nxp.com>
Add rpmsg virtual gpio driver support.
i.MX7ULP GPIO PTA and PTB resource are managed by M4 core, setup one
simple protocol with M4 core based on RPMSG virtual IO to let A core
access such GPIOs that is what the driver do.
- Init mu power and clk.
- Change the cycles of the pingpong demot refer to
the limitation of M4 side.
When the received data larger than 100, the
pingpong of M4 side would be finished.
BuildInfo: SCFW 9e9f6ec6, IMX-MKIMAGE 0, ATF 0
Add rpmsg support for imx8qxp.
The pingpong demo had been verified on 8qxp platforms.
Use memset_io replace memset, because that
the memory type of rpvq->addr is strong order type.
There would be kernel dump when memset is used
on imx8qxp.
Need call MU_Init before call other function
Signed-off-by: Frank Li <Frank.Li@nxp.com>
Signed-off-by: Shenwei Wang <shenwei.wang@nxp.com>
Commit 2a596c353234 ("MLK-13981-2 rpmsg: imx: enable rpmsg virt tty")
enabled support for imx7ulp but it broke support for imx7d since the
currently distributed M4 image for imx7d still uses the old
"rpmsg-openamp-demo-channel" naming.
While we could change the channel name in the M4 image it is better to
maintain backwards compatibility, so add the old naming back to the id
table.
Signed-off-by: Octavian Purdila <octavian.purdila@nxp.com>
Add rpmsg-keys driver on i.mx7ulp-evk board since vol+/vol- keys
are connected on m4 side and have to get the status of keys by
rpmsg.
[Irina: updated for 4.9 APIs]
Signed-off-by: Irina Tirdea <irina.tirdea@nxp.com>
- add the .data into the imx_rpmsg_dt_ids table, thus
the driver can distinguish the different platforms.
Tested-by: Daniel Baluta <daniel.baluta@nxp.com>
- change the module_init to subsys_initcall.
Otherwise, the pf1550-rpmsg would be invoked before
the rpmsg bus driver on imx7ulp.
Then, sdhc wouldn't be powered up properly if pf1550
isn't functional.
- remove the no longer used imc_rpmsg_exit.
- pass the real device id if the shared irq is requested.
- move imx_rpmsg from arch/arm/ to drivers/rpmsg.
- use the new MU generic APIs in the rpmsg implementation.
- Validated the pingpong test on both imx6sx and imx7d sdb boards.
Message can be transferred between remote
device and iMX7ULP M4.
Then the message can be transferred between A7
and M4 by rpmsg channel.
demo howto:
- insmode the imx_rpmsg_tty.ko module after
login A7/Linux.
- Receive messages. Used the following command
to dump out the msg from the virtual tty.
./unit_tests/mxc_mcc_tty_test.out /dev/ttyRPMSG 115200 R 100 1000 &
- Send: use the following command to send the
message to M4.
echo <your string message> /dev/ttyRPMSG
Set the imx rpmsg tests to be module in defaut.
(cherry picked from commit 20adce35ef6abfd6b0a52207febe069c7f09a1be)
send a message to our remote processor, and tell remote
processor about this channel
Signed-off-by: Richard Zhu <Richard.Zhu@freescale.com>
(cherry picked from commit 2708c004a60c5b6da020803ee9291b83984d4a65)
enable the rpmsg pingpong and tty string echo tests
on imx amp socs
- pingpong test howto
insmod imx_rpmsg_pingpong.ko
- tty string echo test howto
- step 1, load the imx_rpmsg_tty.ko
insmod imx_rpmsg_tty.ko
- step 2, lanunch the mxc_mcc_tty_test.out in backend
./mxc_mcc_tty_test.out /dev/ttyRPMSG 115200 R 512 512 &
- step 3, issue the echo command
echo <string> > /dev/ttyRPMSG
commit 940c620d6af8fca7d115de40f19870fba415efac upstream.
Currently a failed allocation of channel->name leads to an
immediate return without freeing channel. Fix this by setting
ret to -ENOMEM and jumping to an exit path that kfree's channel.
Detected by CoverityScan, CID#1473692 ("Resource Leak")
Fixes: 53e2822e56c7 ("rpmsg: Introduce Qualcomm SMD backend")
Cc: stable@vger.kernel.org
Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
This reverts commit 1ed3a93072307265d6385031b72929a904b50f87 which is
commit fe782affd0f440a4e60e2cc81b8f2eccb2923113 upstream
Rafael reports that this patch causes problems:
> -rc2 looks good. There is a problem on dragonboard during boot that was
> introduced in v4.14.71 that I didn't notice last week. We'll bisect it
> and report back later this week. dragonboard on the other branches (4.9,
> 4.18, mainline) looks fine.
As Dan pointed out, during validation, we have bisected this issue on
a dragonboard 410c (can't find root device) to the following commit
for v4.14:
[1ed3a9307230] rpmsg: core: add support to power domains for devices
There is an on-going discussion on "[PATCH] rpmsg: core: add support
to power domains for devices" about this patch having other
dependencies and breaking something else on v4.14 as well.
so drop it.
Reported-by: Rafael Tinoco <rafael.tinoco@linaro.org>
Cc: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Cc: Bjorn Andersson <bjorn.andersson@linaro.org>
Cc: Sasha Levin <alexander.levin@microsoft.com>
[ Upstream commit fe782affd0f440a4e60e2cc81b8f2eccb2923113 ]
Some of the rpmsg devices need to switch on power domains to communicate
with remote processor. For example on Qualcomm DB820c platform LPASS
power domain needs to switched on for any kind of audio services.
This patch adds the missing power domain support in rpmsg core.
Without this patch attempting to play audio via QDSP on DB820c would
reboot the system.
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
commit 4a2e84c6ed85434ce7843e4844b4d3263f7e233b upstream.
All the managed resources would be freed by the time release function
is invoked. Handling such memory in qcom_smd_edge_release() would do
bad things.
Found this issue while testing Audio usecase where the dsp is started up
and shutdown in a loop.
This patch fixes this issue by using simple kzalloc for allocating
channel->name and channel which is then freed in qcom_smd_edge_release().
Without this patch restarting a remoteproc would crash the system.
Cc: <stable@vger.kernel.org>
[ Upstream commit 93dd4e73c0d9cc32f835d76a54257020b0bfc75a ]
Added "rpmsg:rpmsg_chrdev" MODULE_ALIAS to autoload
rpmg_chrdev module automatically.
Signed-off-by: Ramon Fried <rfried@codeaurora.org>
[ Upstream commit 2394facb17bcace4b3c19b50202177a5d8903b64 ]
The "intent_req_comp" variable is used without initialization which
results in NULL pointer dereference in qcom_glink_request_intent().
we need to initialize the completion variable before using it.
Fixes: 27b9c5b66b23 ("rpmsg: glink: Request for intents when unavailable")
Signed-off-by: Arun Kumar Neelakantam <aneela@codeaurora.org>
commit 1e0d5615bbc37deb7732491798abccf8d3c3d244 upstream.
The qcom_glink_native driver is missing a MODULE_LICENSE(), correct
this.
Fixes: 835764ddd9af ("rpmsg: glink: Move the common glink protocol implementation to glink_native.c")
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
We need to free "intent" and "intent->data" on a couple error paths.
Fixes: 933b45da5d1d ("rpmsg: glink: Add support for TX intents")
Acked-by: Sricharan R <sricharan@codeaurora.org>
If qcom_glink_tx() fails, then we need to unlock before returning the
error code.
