Add Ricoh583 PMU RTC driver along with make files.
bug 902137
Change-Id: If9a62ca897e4d41735c7638fff17c7b7570bc3c6
Signed-off-by: venu byravarasu <vbyravarasu@nvidia.com>
Reviewed-on: http://git-master/r/70017
arch/arm/mach-tegra/Kconfig
arch/arm/mach-tegra/board-ventana.c
drivers/misc/Kconfig
drivers/video/tegra/dc/hdmi.c
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Add RTC driver for Maxim PMU MAX77663.
Bug 849360
Original-Change-Id: Ia7c910a852527f6a7bf5d2622cb1f76fd72222cd
Signed-off-by: Jin Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/49584
Rebase-Id: R716e08b9f98c3be480877009bef0db99ccf8043e
With this change, RTC driver for TI PMU 80031 is being checked in.
bug 833336
Original-Change-Id: If4789a5dd49163d2391ab016845ff5807c061f12
Reviewed-on: http://git-master/r/34453
Tested-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Rebase-Id: R98c49f456537e65d02460e738029673e7eea1bc0
With this check in native driver for TPS6591x RTC
is added to linux kernel.
Original-Change-Id: I267cc11b1451b8e2a4117cdff0b808f9f8fcc42a
Reviewed-on: http://git-master/r/20754
Original-Change-Id: If55c1d1d7ebdedace4f0dea0b19bbda088a6cb1e
Rebase-Id: Rdd5b5c4b3c14b247608dffb5ee017051e802e5a1
Initial checkin for Maxim max8907c RTC driver
Original-Change-Id: I764440cc1b0410e54f480a6e0ce424103052df14
Reviewed-on: http://git-master/r/16615
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: R1ccd0bd1d3e4ae3a353facb4edd9cb2d69bb5c2f
arch/arm/mm/cache-l2x0.c
drivers/misc/Makefile
Drivers can now create alarms that will use an hrtimer while the
system is running and the rtc to wake up from suspend.
Signed-off-by: Arve Hjønnevåg <arve@android.com>
Change-Id: Ie22a19b662fda6365b1c514aaf83c9de12fabbd4
Signed-off-by: Gary King <gking@nvidia.com>
Add support for PMIC8xxx based RTC. PMIC8xxx is Qualcomm's power
management IC that internally houses an RTC module. This driver
communicates with the PMIC module over SSBI bus.
[akpm@linux-foundation.org: cosmetic tweaks]
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Anirudh Ghayal <aghayal@codeaurora.org>
Signed-off-by: Ashay Jaiswal <ashayj@codeaurora.org>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
The patch moves rtc driver for PKUnity-v3 SoC from arch/unicore32/kernel/
to drivers/rtc/, with renaming it to rtc-puv3.c.
Also, Kconfig, Makefile, and MAINTAINERS are modified correspondingly.
Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
Signed-off-by: Rajeev Kumar <rajeev-dlh.kumar@st.com>
Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
Add basic support for ST m41t93 SPI RTCs. Tested with factory-new and
with "run-in" species with and without backup batteries.
Signed-off-by: Nikolaus Voss <n.voss@weinmann.de>
Cc: Grant Likely <grant.likely@secretlab.ca>
Add support for the Micro Crystal RV3029-C2 RTC chips.
Signed-off-by: Gregory Hermant <gregory.hermant@calao-systems.com>
Add support for EM Microelectronic EM3027 RTC chip.
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
This adds a driver for the RTC devices in VIA and WonderMedia
Systems-on-Chip. Alarm, 1Hz interrupts, reading and setting time are
supported.
Signed-off-by: Alexey Charkov <alchark@gmail.com>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Alexey Charkov <alchark@gmail.com>
Enable rtc function in 88pm860x PMIC.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
This is a simple RTC driver that lets Tilera hardware boot up and
set the clock correctly.
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
This is a platform driver that supports the built-in real-time clock on
Tegra SOCs.
Signed-off-by: Andrew Chew <achew@nvidia.com>
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
Acked-by: Jon Mayo <jmayo@nvidia.com>
Replace EXTRA_CFLAGS with ccflags-y.
Signed-off-by: matt mooney <mfm@muteddisk.com>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
Provide the standard kernel rtc driver interface on top of the vrtc layer
added in the previous patch.
Signed-off-by: Feng Tang <feng.tang@intel.com>
LKML-Reference: <20101110172911.3311.20593.stgit@localhost.localdomain>
[Fixed swapped arguments on IPC]
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
[Cleaned up and the device creation moved to arch/x86/platform]
Signed-off-by: Alan Cox <alan@linux.intel.com>
The mfd driver for MC13783 recently got support for MC13892 and was
renamed accordingly from mc13783-core to mc13xxx-core. Do the same for
rtc-mc13783.
The only relevant change is to use platform id's to tell the platform bus
that this driver is responsible for mc13892-rtc devices, too.
This adds support for the RTC provided by the Maxim 8998 chip. This
driver was tested on a GONI board by using the rtc-test application from
the Documentation/rtc.txt.
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Add an RTC driver for the built-in RTC in the LPC32XX SoC. This patch
includes updates from the initial review comments and updates from the v3
review.
Signed-off-by: Kevin Wells <wellsk40@gmail.com>
Signed-off-by: Durgesh Pattamatta <durgesh.pattamatta@nxp.com>
Reviewed-by: Wolfram Sang <w.sang@pengutronix.de>
Add a driver for the DS3232 RTC chip via the I2C bus. Alarms are not
supported in this version of the driver.
[akpm@linux-foundation.org: fix Kconfig help text]
Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com>
Signed-off-by: Jingchang Lu <b22599@freescale.com>
Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com>
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Cc: Kumar Gala <kumar.gala@freescale.com>
- derived from rtc-pcf8563
- no SRAM driver
Signed-off-by: Roman Fietze <roman.fietze@telemotive.de>
This driver is based on code from Freescale which accompanies their i.MX25
PDK board, with some cleanup.
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
Cc: Sascha Hauer <kernel@pengutronix.de>
Add support for the RTC unit on JZ4740 SoCs.
Cc: Paul Gortmaker <p_gortmaker@yahoo.com>
Cc: rtc-linux@googlegroups.com
Cc: linux-mips@linux-mips.org
Cc: Alessandro Zummo <a.zummo@towertech.it>,
Patchwork: https://patchwork.linux-mips.org/patch/1424/
Add a driver for the RTC on the AB8500 power management chip. This is a
client of the AB8500 MFD driver.
Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com>
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
This driver features:
* Alarm support.
* Periodic interrupt by using a timer include into the RTC module.
* The update interrupt is not supported by this RTC module.
This driver was tested on a DM365 EVM by using the rtc-test application
from the Documentation/rtc.txt.
Signed-off-by: Miguel Aguilar <miguel.aguilar@ridgerun.com>
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
MAX8925 is a PMIC that contains RTC component.
Add support for MPC5121 real time clock module.
Signed-off-by: John Rigby <jcrigby@gmail.com>
Signed-off-by: Piotr Ziecik <kosmo@semihalf.com>
Signed-off-by: Wan ZongShun <mcuos.com@gmail.com>
Cc: Hu Ruihuan <specter118@gmail.com>
Cc: "jack wang" <jack_wang@usish.com>
Cc: David Brownell <david-b@pacbell.net>
This patch adds basic support for Texas Instruments BQ32000 I2C RTC. Only
time reading/writing is implemented. Advanced features, such as trickle
charger and crystal calibration are not supported.
Signed-off-by: Alessandro Zummo <a.zummo@towertech.it>
This driver provides support for the RTC part integrated into the
Freescale MC13783 PMIC and bases on patch created earlier by Sascha
Hauer.
Acked-by: Valentin Longchamp <valentin.longchamp@epfl.ch>
The upcoming TWL6030 is companion chip for OMAP4 like the current TWL4030
for OMAP3. The common modules like RTC, Regulator creates opportunity
to re-use the most of the code from twl4030.
This patch renames few common drivers twl4030* files to twl* to enable
the code re-use.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Signed-off-by: Balaji T K <balajitk@ti.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Acked-by: Kevin Hilman <khilman@deeprootsystems.com>
Acked-by: Alessandro Zummo <alessandro.zummo@towertech.it>
[ospite@studenti.unina.it: get pcap data from the parent device]
Signed-off-by: guiming zhuo <gmzhuo@gmail.com>
Signed-off-by: Daniel Ribeiro <drwyrm@gmail.com>
Signed-off-by: Antonio Ospite <ospite@studenti.unina.it>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Add support for RTC on the Freescale STMP37xx/378x platform.
Signed-off-by: dmitry pervushin <dpervushin@embeddedalley.com>
This adds a driver for the RTC COH 901 331 found in the ST-Ericsson U300
series mobile platforms to the RTC subsystem. It integrates to the ARM
kernel support recently added to RMKs ARM tree and will be enabled in the
U300 defconfig in due time.
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
This adds a driver for Freescale's MXC internal real time clock modules.
The code is taken from Freescale's BSPs, but modified to fit the current
kernel coding mechanisms. Also, the PMIC external clock function was
removed for now to not add dead bits and keep the code as simple as
possible.
[akpm@linux-foundation.org: make PIE_BIT_DEF[] static]
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Daniel Mack <daniel@caiaq.de>
Add support for the Philips/NXP PCF2123 RTC.
Signed-off: Chris Verges <chrisv@cyberswitching.com>
Tested-by: Chris Verges <chrisv@cyberswitching.com>
Signed-off: Christian Pellegrin <chripell@fsfe.org>
Tested-by: Christian Pellegrin <chripell@fsfe.org>
This adds support for the RTC found inside the AB3100 Mixed Signal chip.
The symbols used for communicating with the chip is found in the
mfd/ab3100-core.c driver that also provides the platform device.
The WM831x series of PMICs contain RTC functionality. The hardware
provides a 32 bit counter incrementing at 1Hz together with a per
tick interrupt and an alarm value. For simplicity the driver chooses
to define the epoch for the counter as the Unix epoch - if required
platform data can be used in future to customise this.
When powered on from a completely cold state the RTC reports that it
has not been configured - when this happens an error is returned
when attempting to read the RTC in order to avoid use of values we
know to be invalid.
The hardware also provides security features which mean that it can
ignore attempts to set the RTC time in certain circumstances, most
notably if the RTC is written to too often. These errors are detected
by verifying the written RTC value.
Add support for the Epson RX-8025SA/NB RTC chips. It includes support for
alarms, periodic interrupts (1 Hz) and clock precision adjustment.
For clock precision adjustment, the SYSFS file "clock_adjust_ppb" gets
created in "/sys/class/rtc/rtcX/device". It permits to set and get the
clock adjustment in ppb (parts per billion), e.g.:
# echo -183000 > /sys/class/rtc/rtc0/device/clock_adjust_ppb
# cat /sys/class/rtc/rtc0/device/clock_adjust_ppb
-183000
This allows to compensate temperature dependent clock drifts. According
to the RX8025 SA/NB application manual the frequency and temperature
characteristics can be approximated using the following equation:
df = a * (ut - t)**2
df: Frequency deviation in any temperature
a : Coefficient = (-35 +-5) * 10**-9
ut: Ultimate temperature in degree = +25 +-5 degree
t : Any temperature in degree
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Signed-off-by: Dmitry Rakhchev <rda@emcraft.com>
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Acked-by: Jean Delvare <khali@linux-fr.org>
Create a real RTC driver for PS3, and unhook the deprecated
ppc_md.[gs]et_rtc_time.
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Acked-by: Geoff Levand <geoffrey.levand@am.sony.com>
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
PowerPC has been a long time user of the generic RTC abstraction, so hook up
rtc-generic:
- Create the "rtc-generic" platform device if ppc_md.get_rtc_time is set,
- Kill rtc-ppc, as rtc-generic offers the same functionality in a more
generic way, and supports autoloading through udev.
Acked-by: David Woodhouse <David.Woodhouse@intel.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
