During shutdown/reboot process, its better to
finish any pending irqwork so that the work is
not scheduled after devices like i2c are shutdown.
This patch provides hook to be called from rtc driver after disabling
rtc irq. Also any further request to access rtc_class_ops will
be prohibited.
Bug 200072946
Change-Id: I8eb20e5214a31fbc8a280ccfff8e190a5fabbb96
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/677750
GVS: Gerrit_Virtual_Submit
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
devm_rtc_device_register()
Other devm_* APIs use 'struct device *dev' as the first argument. Thus,
in order to sync with other devm_* functions, struct device is used as
the first argument for devm_rtc_device_register().
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Alessandro Zummo <a.zummo@towertech.it>
These functions allow the driver core to automatically clean up any
allocation made by rtc drivers. Thus it simplifies the error paths.
Acked-by: Tejun Heo <tj@kernel.org>
Fix the checkpatch warning as below:
WARNING: Prefer netdev_err(netdev, ... then dev_err(dev, ... then pr_err(... to printk(KERN_ERR ...
into timers/core
Trivial conflict in arch/x86/Kconfig
All the RTC suspend and resume functions are to compensate the
sleep time, but this is already done in timekeeping.c if persistent
clock exist.
Cc: John Stultz <john.stultz@linaro.org>
Cc: Arve Hjønnevåg <arve@android.com>
Signed-off-by: Feng Tang <feng.tang@intel.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Revert commit 2830a6d20139df2198d63235df7957712adb28e5.
We already perform the ida_simple_remove() in rtc_device_release(),
which is an appropriate place. Commit 2830a6d20 ("rtc: recycle id when
unloading a rtc driver") caused the kernel to emit
ida_remove called for id=0 which is not allocated.
warnings when rtc_device_release() tries to release an alread-released
ID.
Let's restore things to their previous state and then work out why
Vincent's kernel wasn't calling rtc_device_release() - presumably a bug
in a specific sub-driver.
Reported-by: Lothar Waßmann <LW@KARO-electronics.de>
Acked-by: Alexander Holler <holler@ahsoftware.de>
Cc: Vincent Palatin <vpalatin@chromium.org>
Cc: <stable@vger.kernel.org> [3.7.x]
Without this patch /sys/class/rtc/$CONFIG_RTC_HCTOSYS_DEVICE/hctosys
contains a 1 (meaning "This rtc was used to initialize the system
clock") even if setting the time by do_settimeofday() at bootup failed.
The RTC can also be used to set the clock on resume, if it did 1,
otherwise 0. Previously there was no indication if the RTC was used
to set the clock in resume.
This uses only CONFIG_RTC_HCTOSYS_DEVICE for conditional compilation
instead of it and CONFIG_RTC_HCTOSYS to be more consistent.
rtc_hctosys_ret was moved to class.c so class.c no longer depends on
hctosys.c.
[sfr@canb.auug.org.au: fix build]
Signed-off-by: David Fries <David@Fries.net>
Cc: Matthew Garrett <mjg@redhat.com>
Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
When calling rtc_device_unregister, we are not freeing the id used by the
driver. So when doing a unload/load cycle for a RTC driver (e.g. rmmod
rtc_cmos && modprobe rtc_cmos), its id is incremented by one. As a
consequence, we no longer have neither an rtc0 driver nor a
/proc/driver/rtc (as it only exists for the first driver).
Signed-off-by: Vincent Palatin <vpalatin@chromium.org>
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
clockevents: Set noop handler in clockevents_exchange_device()
tick-broadcast: Stop active broadcast device when replacing it
clocksource: Fix bug with max_deferment margin calculation
rtc: Fix some bugs that allowed accumulating time drift in suspend/resume
rtc: Disable the alarm in the hardware
The current code checks if abs(delta_delta.tv_sec) is greater or
equal to two before it discards the old delta value, but this can
trigger at close to -1 seconds since -1.000000001 seconds is stored
as tv_sec -2 and tv_nsec 999999999 in a normalized timespec.
rtc_resume had an early return check if the rtc value had not changed
since rtc_suspend. This effectivly stops time for the duration of the
short sleep. Check if sleep_time is positive after all the adjustments
have been applied instead since this allows the old_system adjustment
in rtc_suspend to have an effect even for short sleep cycles.
CC: stable@kernel.org
Signed-off-by: Arve Hjønnevåg <arve@android.com>
This is the one use of an ida that doesn't retry on receiving -EAGAIN.
I'm assuming do so will cause no harm and may help on a rare occasion.
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
Because the RTC interface is only a second granular interface,
each time we read from the RTC for suspend/resume, we introduce a
half second (on average) of error.
In order to avoid this error accumulating as the system is suspended
over and over, this patch measures the time delta between the RTC
and the system CLOCK_REALTIME.
If the delta is less then 2 seconds from the last suspend, we compensate
by using the previous time delta (keeping it close). If it is larger
then 2 seconds, we assume the clock was set or has been changed, so we
do no correction and update the delta.
Note: If NTP is running, ths could seem to "fight" with the NTP corrected
time, where as if the system time was off by 1 second, and NTP slewed the
value in, a suspend/resume cycle could undo this correction, by trying to
restore the previous offset from the RTC. However, without this patch,
since each read could cause almost a full second worth of error, its
possible to get almost 2 seconds of error just from the suspend/resume
cycle alone, so this about equal to any offset added by the compensation.
Further on systems that suspend/resume frequently, this should keep time
closer then NTP could compensate for if the errors were allowed to
accumulate.
Credits to Arve Hjønnevåg for suggesting this solution.
This patch also improves some of the variable names and adds more clear
comments.
CC: Arve Hjønnevåg <arve@android.com>
CC: Thomas Gleixner <tglx@linutronix.de>
Some platforms cannot implement read_persistent_clock, as
their RTC devices are only accessible when interrupts are enabled.
This keeps them from being used by the timekeeping code on resume
to measure the time in suspend.
The RTC layer tries to work around this, by calling do_settimeofday
on resume after irqs are reenabled to set the time properly. However,
this only corrects CLOCK_REALTIME, and does not properly adjust
the sleep time value. This causes btime in /proc/stat to be incorrect
as well as making the new CLOCK_BOTTTIME inaccurate.
This patch resolves the issue by introducing a new timekeeping hook
to allow the RTC layer to inject the sleep time on resume.
The code also checks to make sure that read_persistent_clock is
nonfunctional before setting the sleep time, so that should the RTC's
HCTOSYS option be configured in on a system that does support
read_persistent_clock we will not increase the total_sleep_time twice.
When we register an rtc device at boot, we read the alarm value
in hardware and set the rtc device's aie_timer to that value.
The initial method to do this was to simply call rtc_set_alarm()
with the value read from hardware. However, this may cause problems
as rtc_set_alarm may enable interupts, and the RTC alarm might fire,
which can cause invalid pointer dereferencing since the RTC registration
is not complete.
This patch solves the issue by initializing the rtc_device.aie_timer
y hand via rtc_initialize_alarm(). This avoids any calls to the RTC
hardware which might enable interrupts too early.
CC: Alessandro Zummo <a.zummo@towertech.it>
Reported-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Mark Brown pointed out a corner case: that RTC alarms should
be allowed to be persistent across reboots if the hardware
supported it.
The rework of the generic layer to virtualize the RTC alarm
virtualized much of the alarm handling, and removed the
code used to read the alarm time from the hardware.
Mark noted if we want the alarm to be persistent across
reboots, we need to re-read the alarm value into the
virtualized generic layer at boot up, so that the generic
layer properly exposes that value.
This patch restores much of the earlier removed
rtc_read_alarm code and wires it in so that we
set the kernel's alarm value to what we find in the
hardware at boot time.
NOTE: Not all hardware supports persistent RTC alarm state across
system reset. rtc-cmos for example will keep the alarm time, but
disables the AIE mode irq. Applications should not expect the RTC
alarm to be valid after a system reset. We will preserve what
we can, to represent the hardware state at boot, but its not
guarenteed.
Further, in the future, with multiplexed RTC alarms, the
soonest alarm to fire may not be the one set via the /dev/rt
ioctls. So an application may set the alarm with RTC_ALM_SET,
but after a reset find that RTC_ALM_READ returns an earlier
time. Again, we preserve what we can, but applications should
not expect the RTC alarm state to persist across a system reset.
Big thanks to Mark for pointing out the issue!
Thanks also to Marcelo for helping think through the solution.
CC: Mark Brown <broonie@opensource.wolfsonmicro.com>
CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br>
CC: rtc-linux@googlegroups.com
Reported-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
This patch prevents a user space program from calling the RTC_IRQP_SET
ioctl with a negative value of frequency. Also, if this call is make
with a zero value of frequency, there would be a division by zero in the
kernel code.
[jstultz: Also initialize irq_freq to 1 to catch other divbyzero issues]
Signed-off-by: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br>
* 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rtc: Namespace fixup
RTC: Remove UIE emulation
RTC: Rework RTC code to use timerqueue for events
Fix up trivial conflict in drivers/rtc/rtc-dev.c
rtctimer_* is already occupied by sound/core/rtctimer.c. Instead of
fiddling with that, rename the new functions to rtc_timer_* which
reads nicer anyway.
Cc: John Stultz <johnstul@us.ibm.com>
This patch reworks a large portion of the generic RTC code
to in-effect virtualize the rtc interrupt code.
The current RTC interface is very much a raw hardware interface.
Via the proc, /dev/, or sysfs interfaces, applciations can set
the hardware to trigger interrupts in one of three modes:
AIE: Alarm interrupt
UIE: Update interrupt (ie: once per second)
PIE: Periodic interrupt (sub-second irqs)
The problem with this interface is that it limits the RTC hardware
so it can only be used by one application at a time.
The purpose of this patch is to extend the RTC code so that we can
multiplex multiple applications event needs onto a single RTC device.
This is done by utilizing the timerqueue infrastructure to manage
a list of events, which cause the RTC hardware to be programmed
to fire an interrupt for the next event in the list.
In order to preserve the functionality of the exsting proc,/dev/ and
sysfs interfaces, we emulate the different interrupt modes as follows:
AIE: We create a rtc_timer dedicated to AIE mode interrupts. There is
only one per device, so we don't change existing interface semantics.
UIE: Again, a dedicated rtc_timer, set for periodic mode, is used
to emulate UIE interrupts. Again, only one per device.
PIE: Since PIE mode interrupts fire faster then the RTC's clock read
granularity, we emulate PIE mode interrupts using a hrtimer. Again,
one per device.
With this patch, the rtctest.c application in Documentation/rtc.txt
passes fine on x86 hardware. However, there may very well still be
bugs, so greatly I'd appreciate any feedback or testing!
LKML Reference: <1290136329-18291-4-git-send-email-john.stultz@linaro.org>
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
CC: Richard Cochran <richardcochran@gmail.com>
If device_register() fails then call put_device(). See comment to
device_register.
Signed-off-by: Vasiliy Kulikov <segooon@gmail.com>
Cc: Wan ZongShun <mcuos.com@gmail.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The idr should be destroyed when the module is unloaded. Found with
kmemleak.
Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com>
Cc: stable <stable@kernel.org>
Acked-By: Greg Kroah-Hartman <gregkh@suse.de>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Cc: David Brownell <david-b@pacbell.net>
Add kernel/kernel and kernel/user locking for the periodic irq feature of
the rtc class.
PIE ioctls are also supported.
Signed-off-by: Alessandro Zummo <a.zummo@towertech.it>
This avoids use of the kernel-internal "xtime" variable directly outside
of the actual time-related functions. Instead, use the helper functions
that we already have available to us.
This doesn't actually change any behaviour, but this will allow us to
fix the fact that "xtime" isn't updated very often with CONFIG_NO_HZ
(because much of the realtime information is maintained as separate
offsets to 'xtime'), which has caused interfaces that use xtime directly
to get a time that is out of sync with the real-time clock by up to a
third of a second or so.
Signed-off-by: John Stultz <johnstul@us.ibm.com>
Fix a goof in the revised classdev support for RTCs: make sure the /dev
node info is ready before the device is registered, not after. Otherwise
the /sys/class/rtc/rtcN/dev attribute won't be created and then udev won't
have the information it needs to create the /dev/rtcN node.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
RTC class suspend/resume support, re-initializing the system clock on resume
from the clock used to initialize it at boot time.
- The reinit-on-resume is hooked to the existing RTC_HCTOSYS config
option, on the grounds that a clock good enough for init must also
be good enough for re-init.
- Inlining a version of the code used by ARM, to save and restore the
delta between a selected RTC and the current system wall-clock time.
- Removes calls to that ARM code from AT91, OMAP1, and S3C RTCs. This
means that systems using those RTCs across suspend/resume will likely
want to change their kernel configs to enable RTC_HCTOSYS.
If HCTOSYS isn't using a second RTC (with battery?), this changes the
system's initial date from Jan 1970 to the epoch this hardware uses:
1998 for AT91, 2000 for OMAP1 (assuming no split power mode), etc.
This goes on top of the patch series removing "struct class_device" usage
from the RTC framework. That's all needed for class suspend()/resume().
Acked-By: Alessandro Zummo <a.zummo@towertech.it>
Finish converting the RTC framework so it no longer uses class_device.
This simplifies the RTC procfs support by removing the class_interface that
hooks it into the rtc core. If it's configured, then sysfs support is now
part of the RTC core, and is never a separate module.
It also removes the class_interface hook, now that its last remaining user is
gone. (That API is usable only with a "struct class_device".)
It's another step towards being able to remove "struct class_device".
This simplifies the RTC sysfs support by removing the class_interface that
This simplifies the /dev support by removing a superfluous class_device (the
/sys/class/rtc-dev stuff) and the class_interface that hooks it into the rtc
core. Accordingly, if it's configured then /dev support is now part of the
[bunk@stusta.de: drivers/rtc/rtc-dev.c should #include "rtc-core.h"]
Fix an oops on the rtc_device_unregister() path by waiting until the last
moment before nulling the rtc->ops vector. Fix some potential oopses by
having the rtc_class_open()/rtc_class_close() interface increase the RTC's
reference count while an RTC handle is available outside the RTC framework.
Update RTC framework so that drivers can constify their method tables, moving
them from ".data" to ".rodata". Then update the drivers.
This makes RTC core components use "subsys_init" instead of "module_init", as
appropriate for subsystem infrastructure. This is mostly useful for
statically linking drivers in other parts of the tree that may provide an RTC
interface as a secondary functionality (e.g. part of a multifunction chip);
they won't need to worry so much about drivers/Makefile link order.
Acked-by: Oleg Verych <olecom@flower.upol.cz>
We need to serialize access to the global rtc_idr even in this error path.
Signed-off-by: Sonny Rao <sonny@burdell.org>
Centralize CAP_SYS_XXX checks to avoid duplicate code and missing checks in
the drivers.
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
Move registration error message from drivers to core.
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Add the basic RTC subsystem infrastructure to the kernel.
rtc/class.c - registration facilities for RTC drivers
rtc/interface.c - kernel/rtc interface functions
rtc/hctosys.c - snippet of code that copies hw clock to sw clock
at bootup, if configured to do so.
