path: root/drivers/rtc/rtc-coh901331.c
2014-04-03rtc: rtc-coh901331: use devm_ioremap_resource()Jingoo Han
Use devm_ioremap_resource() in order to make the code simpler, and remove redundant return value check of platform_get_resource() because the value is checked by devm_ioremap_resource(). Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03rtc: rtc-coh901331: use platform_{get,set}_drvdata()Jingoo Han
Use the wrapper functions for getting and setting the driver data using platform_device instead of using dev_{get,set}_drvdata() with &pdev->dev, so we can directly pass a struct platform_device. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03rtc: rtc-coh901331: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure, since commit 0998d063100 ("device-core: Ensure drvdata = NULL when no driver is bound"). Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-17rtc: coh901331: add devicetree supportLinus Walleij
This add devicetree probe support to the COH 901 331 RTC driver. Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-04-29rtc: rtc-coh901331: convert coh901331_driver to dev_pm_opsJingoo Han
Instead of using legacy suspend/resume methods, using newer dev_pm_ops structure allows better control over power management. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: rtc-coh90133: use devm_rtc_device_register()Jingoo Han
devm_rtc_device_register() is device managed and makes cleanup paths simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: rtc-coh901331: use module_platform_driver_probe()Jingoo Han
Use module_platform_driver_probe() macro which makes the code smaller and simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21rtc: rtc-coh901331: use devm_clk_get()Jingoo Han
Use devm_clk_get() to make cleanup paths more simple. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06drivers/rtc/rtc-coh901331.c: use clk_prepare_enable() and ↵Julia Lawall
clk_disable_unprepare() clk_prepare_enable and clk_disable_unprepare combine clk_prepare and clk_enable, and clk_disable and clk_unprepare. They make the code more concise, and ensure that clk_unprepare is called when clk_enable fails. A simplified version of the semantic patch that introduces calls to these functions is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression e; @@ - clk_prepare(e); - clk_enable(e); + clk_prepare_enable(e); @@ expression e; @@ - clk_disable(e); - clk_unprepare(e); + clk_disable_unprepare(e); // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30drivers/rtc/rtc-coh901331.c: use devm allocationLinus Walleij
Allocate memory, region, remap and irq for device state using devm_* helpers to simplify memory accounting. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30drivers/rtc/rtc-coh901331.c: use clk_prepare/unprepareLinus Walleij
Make sure we prepare/unprepare the clock for the COH901331 RTC driver as is required by the clk API especially if you use common clock. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23drivers/rtc: remove IRQF_DISABLEDYong Zhang
Since commit e58aa3d2d0cc ("genirq: run irq handlers with interrupts disabled") we run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled - see commit b738a50a2026 ("genirq: warn when handler enables interrupts"). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-20rtc: fix coh901331 startup crashLinus Walleij
The rtc_device_register() call has changed semantics so that it will immediately call out to rtc_read_alarm() and since the callbacks require the drvdata to be set, we need to set it before the registration call to avoid NULL dereference. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-06rtc-coh901331: fix braces in resume codeJames Hogan
The else part of the if statement is indented but does not have braces around it. It clearly should since it uses clk_enable and clk_disable which are supposed to balance. Signed-off-by: James Hogan <james@albanarts.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-16ARM: 5787/1: U300 COH 901 331 fixesLinus Walleij
This will fix some small issues with the COH 901 331 RTC driver: - Interrupt is disabled after alarm so that we don't fire multiple interrupts. - We return 0 from the coh901331_alarm_irq_enable() ridding a compile warning. - We alter the name in the U300 device registry to match that of the driver so they sucessfully resolve. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-23rtc: U300 COH 901 331 RTC driver v3Linus Walleij
This adds a driver for the RTC COH 901 331 found in the ST-Ericsson U300 series mobile platforms to the RTC subsystem. It integrates to the ARM kernel support recently added to RMKs ARM tree and will be enabled in the U300 defconfig in due time. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
