In preparation to enabling -Wvla, remove VLA and replace it
with a fixed-length array instead.
>From a security viewpoint, the use of Variable Length Arrays can be
a vector for stack overflow attacks. Also, in general, as the code
evolves it is easy to lose track of how big a VLA can get. Thus, we
can end up having segfaults that are hard to debug.
Also, fixed as part of the directive to remove all VLAs from
the kernel: https://lkml.org/lkml/2018/3/7/621
Signed-off-by: Gustavo A. R. Silva <garsilva@embeddedor.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
The RTC core is always calling rtc_valid_tm after the read_time callback.
It is not necessary to call it just before returning from the callback.
This patch adds alarm support. This allows to configure the chip
to generate an interrupt when the alarm matches current time value.
Alarm can be programmed up to one year in the future
and is accurate to the second.
Signed-off-by: Emil Bartczak <emilbart@gmail.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
This patch adds support for saving/loading weekday value from the chip.
Fix whitespace and indentation errors and the following
checkpatch warnings:
- line 15: Block comments use a trailing */ on a separate line
- line 256: Line over 80 characters
No code change.
This patch doesn't change the code but replaces all bitmask values
with the BIT(x) macro.
According to Microchip errata some combinations of date and month
values may result in the date being reset to 1, even if the date
is also written with the month (for example 31-07 or 31-08).
As a workaround avoid writing date and month values within the same
Write command. Instead, terminate the Write command after loading
the date and begin a new command to write the month. In addition,
disable the oscillator before loading the new values. This is done
by ensuring both the ST and EXTOSC bits are cleared and waiting for
the OSCON bit to clear.
In linux rtc_time struct, tm_mon range is 0~11, while in RTC HW REG,
month range is 1~12. This patch adjusts difference of them.
According the datasheet the leap year is a fifth bit in month register.
Change rtc-mcp795.c to use the bcd2bin/bin2bcd functions.
This change fixes the wrong conversion of month value
from binary to BCD (missing right shift operation for 10 month).
Check for rtc_class_ops structures that are only passed to
devm_rtc_device_register, rtc_device_register,
platform_device_register_data, all of which declare the corresponding
parameter as const. Declare rtc_class_ops structures that have these
properties as const.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r disable optional_qualifier@
identifier i;
position p;
static struct rtc_class_ops i@p = { ... };
@ok@
identifier r.i;
expression e1,e2,e3,e4;
position p;
devm_rtc_device_register(e1,e2,&i@p,e3)
platform_device_register_data(e1,e2,e3,&i@p,e4)
@bad@
position p != {r.p,ok.p};
identifier r.i;
i@p
@depends on !bad disable optional_qualifier@
identifier r.i;
static
+const
struct rtc_class_ops i = { ... };
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Acked-by: Baruch Siach <baruch@tkos.co.il>
Acked-by: Hans Ulli Kroll <ulli.kroll@googlemail.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Add device tree support to the rtc-mcp795 driver.
Acked-by: Rob Herring <robh@kernel.org>
An spi_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Acked-by: Jonathan Cameron <jic23@kernel.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
Add driver for SPI RTC Microchip MCP795. Only supports saving/loading
time from the chip (i. e. no alarms/power events/ID).
Signed-off-by: Josef Gajdusek <atx@atx.name>
Cc: Jingoo Han <jg1.han@samsung.com>
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
