Drop unnecessary register write-unlock around two read accesses.
Signed-off-by: Johan Hovold <johan@kernel.org>
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
For completeness re-lock the registers also in the power-off error path.
Make sure to deregister the pin controller in case rtc registration
fails.
Fixes: 57072758623f ("rtc: omap: switch to rtc_register_device")
Cc: stable <stable@vger.kernel.org> # 4.14
Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Do not set the system power-off callback and omap power-off rtc pointer
until we're done setting up our device to avoid leaving stale pointers
around after a late probe error.
Fixes: 97ea1906b3c2 ("rtc: omap: Support ext_wakeup configuration")
Cc: stable <stable@vger.kernel.org> # 4.9
Cc: Marcin Niestroj <m.niestroj@grinn-global.com>
Cc: Tony Lindgren <tony@atomide.com>
Reviewed-by: Marcin Niestroj <m.niestroj@grinn-global.com>
The RTC core is always validating the rtc_time struct before calling
.set_time or .set_alarm. It is not necessary to do it again.
Also, rtc_time_to_tm never generates an invalid rtc_tm (it can be out of
range though).
Call rtc_nvmem_register instead of letting the core do it and stop using
the nvmem_config member of struct rtc_device.
There are 2 error paths after clk_prepare_enable() was called, where
clk_disable_unprepare() is missing.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Andreas Platschek <andreas.platschek@opentech.at>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Register an nvmem device to expose the 3 scratch registers (total of 12
bytes) to both userspace and kernel space.
Reviewed-by: Sekhar Nori <nsekhar@ti.com>
Tested-by: Keerthy <j-keerthy@ti.com>
Reviewed-by: Keerthy <j-keerthy@ti.com>
This removes a possible race condition and crash and allows for further
improvement of the driver.
If pinctrl_register() fails probe will return with an error without locking
the RTC and disabling pm_runtime.
Set ret and jump to err instead.
Instead of using #ifdef guards around PM methods, let's annotate
them as __maybe_unused, as it provides better compile coverage.
Also drop empty stub for omap_rtc_runtime_resume().
Even if bus is not hot-pluggable, devices can be unbound from the
driver via sysfs, so we should not be using __exit annotations on
remove() methods. The only exception is drivers registered with
platform_driver_probe(), which specifically disables sysfs bind/unbind
attributes.
Reviewed-By: Sebastian Reichel <sre@kernel.org>
The current pinconf packed format allows only 16-bit argument limiting
the maximum value 65535. For most types this is enough. However,
debounce time can be in range of hundreths of milliseconds in case of
mechanical switches so we cannot represent the worst case using the
current format.
In order to support larger values change the packed format so that the
lower 8 bits are used as type which leaves 24 bits for the argument.
This allows representing values up to 16777215 and debounce times up to
16 seconds.
We also convert the existing users to use 32-bit integer when extracting
argument from the packed configuration value.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
If RTC is running from an internal clock source, the RTC module can't
be disabled; otherwise it stops ticking completely. Current suspend
handler implementation disables the clock/module unconditionally,
instead fix this by disabling the clock only if we are running on
external clock source, which is not affected by suspend.
The prevention of disabling the clock must be done via implementing
the runtime_pm handlers for the device, and returning an error code
from the runtime suspend handler; otherwise OMAP core PM will disable
the clocks for the driver.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
Signed-off-by: Keerthy <j-keerthy@ti.com>
RTC can be clocked from an external 32KHz oscillator, or from the
Peripheral PLL. The RTC has an internal oscillator buffer to support
direct operation with a crystal.
| Device --------- |
| | RTCSS | |
OSC |<------| RTC | | | |
|------>| OSC |--- | | |
| ----|clk | |
| | PRCM |--- | | |
The RTC functional clock is sourced by default from the clock derived
from the Peripheral PLL. In order to select source as external osc clk
the following changes needs to be done:
- Enable the RTC OSC (RTC_OSC_REG[4]OSC32K_GZ = 0)
- Enable the clock mux(RTC_OSC_REG[6]K32CLK_EN = 1)
- Select the external clock source (RTC_OSC_REG[3]32KCLK_SEL = 1)
Fixes: 399cf0f63f6f2 ("rtc: omap: Add external clock enabling support")
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
Support configuration of ext_wakeup sources. This patch makes it
possible to enable ext_wakeup and set it's polarity, depending on board
configuration. AM335x's dedicated PMIC (tps65217) uses ext_wakeup to
notify about power-button presses. Handling power-button presses enables
to recover from RTC-only power states correctly.
Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com>
Acked-by: Rob Herring <robh@kernel.org>
Check for rtc_class_ops structures that are only passed to
devm_rtc_device_register, rtc_device_register,
platform_device_register_data, all of which declare the corresponding
parameter as const. Declare rtc_class_ops structures that have these
properties as const.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r disable optional_qualifier@
identifier i;
position p;
static struct rtc_class_ops i@p = { ... };
@ok@
identifier r.i;
expression e1,e2,e3,e4;
position p;
devm_rtc_device_register(e1,e2,&i@p,e3)
platform_device_register_data(e1,e2,e3,&i@p,e4)
@bad@
position p != {r.p,ok.p};
identifier r.i;
i@p
@depends on !bad disable optional_qualifier@
identifier r.i;
static
+const
struct rtc_class_ops i = { ... };
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Acked-by: Baruch Siach <baruch@tkos.co.il>
Acked-by: Hans Ulli Kroll <ulli.kroll@googlemail.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Configure the clock source to external clock if available.
External clock is preferred as it can be ticking during suspend.
The rtc can be clocked by an internal 32K clock. Adding the support
to enable the same.
module_platform_driver_probe() prevents driver from requesting probe
deferral. So using module_platform_drive() to support probe deferral.
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Paul Walmsley <paul@pwsan.com>
Cc: Tero Kristo <t-kristo@ti.com>
Cc: Sekhar Nori <nsekhar@ti.com>
register writes
RTC module contains a kicker mechanism to prevent any spurious writes from
changing the register values. This mechanism requires two MMR writes to
the KICK0 and KICK1 registers with exact data values before the kicker
lock mechanism is released.
Currently the driver release the lock in the probe and leaves it enabled
until the rtc driver removal. This eliminates the idea of preventing
spurious writes when RTC driver is loaded. So implement rtc lock and
unlock functions before and after register writes.
This is as advised by Paul to implement lock and unlock functions in the
driver and not to unlock and leave it in probe. The same discussion can
be seen here:
http://www.mail-archive.com/linux-omap%40vger.kernel.org/msg111588.html
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg KH:
"Here's the set of driver core patches for 3.19-rc1.
They are dominated by the removal of the .owner field in platform
drivers. They touch a lot of files, but they are "simple" changes,
just removing a line in a structure.
Other than that, a few minor driver core and debugfs changes. There
are some ath9k patches coming in through this tree that have been
acked by the wireless maintainers as they relied on the debugfs
changes.
Everything has been in linux-next for a while"
* tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits)
Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries"
fs: debugfs: add forward declaration for struct device type
firmware class: Deletion of an unnecessary check before the function call "vunmap"
firmware loader: fix hung task warning dump
devcoredump: provide a one-way disable function
device: Add dev_<level>_once variants
ath: use seq_file api for ath9k debugfs files
debugfs: add helper function to create device related seq_file
drivers/base: cacheinfo: remove noisy error boot message
Revert "core: platform: add warning if driver has no owner"
drivers: base: support cpu cache information interface to userspace via sysfs
drivers: base: add cpu_device_create to support per-cpu devices
topology: replace custom attribute macros with standard DEVICE_ATTR*
cpumask: factor out show_cpumap into separate helper function
driver core: Fix unbalanced device reference in drivers_probe
driver core: fix race with userland in device_add()
sysfs/kernfs: make read requests on pre-alloc files use the buffer.
sysfs/kernfs: allow attributes to request write buffer be pre-allocated.
fs: sysfs: return EGBIG on write if offset is larger than file size
Drop the vendor-prefix from the "ti,system-power-controller" device-tree
property name.
It has been agreed to make "system-power-controller" a standard property
and to drop the vendor-prefix that is currently used by several drivers.
Note that drivers that have used "<vendor>,system-power-controller" in a
released kernel will need to support both versions.
Cc: Benot Cousson <bcousson@baylibre.com>
Cc: Felipe Balbi <balbi@ti.com>
Add myself to the list of copyright holders.
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Keerthy J <j-keerthy@ti.com>
Tested-by: Felipe Balbi <balbi@ti.com>
Fix minor coding style issues like comment style, indentation and remove
a few unnecessary casts.
Also drop the 1 from OMAP1 in the driver description.
The ALARM interrupt must not be disabled during shutdown in order to be
able to power up the system using an RTC alarm.
Add new property "ti,system-power-controller" to register the RTC as a
power-off handler.
Some RTC IP revisions can control an external PMIC via the pmic_power_en
pin, which can be configured to transition to OFF on ALARM2 events and
back to ON on subsequent ALARM (wakealarm) events.
This is based on earlier work by Colin Foe-Parker and AnilKumar Ch. [1]
[1] https://www.mail-archive.com/linux-omap@vger.kernel.org/msg82127.html
[akpm@linux-foundation.org: add comment]
Cc: Colin Foe-Parker <colin.foeparker@logicpd.com>
Cc: AnilKumar Ch <anilkumar@ti.com>
Add helper to read full register width.
Add helper to read raw BCD time that can be used in interrupt context.
Some legacy RTC IP revisions has a power-up reset flag in the status
register that later revisions lack.
As this flag is always read back as set on later revisions (or is
overloaded with a different flag), make sure to only clear the flag and
print the info message on legacy platforms.
Add structured device-type info to encode IP-block revision differences.
Remove DRIVER_NAME macro which was used for unrelated strings (e.g.
id-table entry and module name), but not for related ones (e.g. module
name and alias).
Also move the module alias to the other module-info entries.
Add struct omap_rtc to hold previously global data as well as the
IP-block feature flags.
Also convert the register-access macros to proper inline helper functions.
Make platform-device id table const.
Use dev_info rather than pr_info.
Remove register-base define, which is no longer used.
Make sure not to register the class device until after the device has
been configured.
Currently, the device is not fully configured (e.g. 24-hour mode) when
the class device is registered, something which involves driver
callbacks for example to read the current time.
Remove some debug messages and return errors from subsystems rather than
always fail with -EIO.
Note that the class-registration error has already been logged by rtc
core.
Use writel instead of writeb when disabling interrupts at probe as
ALARM2 is not cleared otherwise on some IP-block revisions (e.g.
AM3352).
Note that the driver currently never enables the ALARM2 interrupt.
The platform device must be registered as wakeup capable before
registering the class device, or the wakealarm attribute will not be
created.
Also make sure to unregister the wakeup source on probe errors.
Fixes: 1d2e2b65d098 ("rtc: omap: restore back (hard-code) wakeup support")
Reviewed-by: Felipe Balbi <balbi@ti.com>
Cc: <stable@vger.kernel.org>
This series fixes a few issues with the omap rtc-driver, cleans up a
bit, adds device abstraction, and finally adds support for the PMIC
control feature found in some revisions of this RTC IP block.
Ultimately, this allows for powering off the Beaglebone and waking it up
again on RTC alarms.
This patch (of 20):
Make sure not to reset the clock-source configuration when enabling the
32kHz clock mux.
Until the clock source can be configured through device tree we must not
overwrite settings made by the bootloader (e.g. clock-source
selection).
Fixes: cd914bba03d8 ("drivers/rtc/rtc-omap.c: add support for enabling 32khz clock")
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
When RTC CLKTRCTRL bit is configured in HW_AUTO, module goes to sleep in
IDLE state.
The Alarm SWakeup event can be used to wakeup the RTC when it is in IDLE
state. In order to do so, the alarm needs to be set and enabled before
RTC enters the IDLE state. Also the wakeup generation for alarm/timer
event needs to be set (bits [1:0] in RTC_IRQWAKEEN register).
Currently RTC_IRQWAKEEN bits are set only in suspend/resume paths. With
this ALARM interrupts are not generated when it enters IDLE state. So
programming the RTC_IRQWAKEEN bits when ever ALARM is set.
Acked-by: Sekhar Nori <nsekhar@ti.com>
Cc: Grant Likely <grant.likely@linaro.org>
Cc: Rob Herring <robh+dt@kernel.org>
Newer versions of OMAP RTC IP such as those found in AM335x and DRA7x
need an explicit enable of 32khz functional clock which ticks the RTC.
AM335x support was working so far because of settings done in U-Boot.
However, the DRA7x U-Boot does no such enable of 32khz clock and this
patch is need to get the RTC to work on DRA7x at least. In general, it
is better to not depend on settings done in U-Boot.
Thanks to Lokesh Vutla for noticing this.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Use BIT() macro for RTC_HAS_<FEATURE> defines instead of hand-writing
bit masks.
Use BIT() macros for register bit field definitions.
While at it, fix indentation done using spaces.
No functional change in this patch.
Remove multiple superfluous device id checks. Since an id_table is
present in the driver probe() should never encounter an empty device id
entry. In case of OF style match, of_match_device() returns an matching
entry.
For paranoia sake, check for device id entry once and fail probe() if none
is found. This is much better than checking for it multiple times.
The data structure of_match_ptr() protects is always compiled in.
Hence of_match_ptr() is not needed.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
On some platforms (like AM33xx), a special register (RTC_IRQWAKEEN) is
available to enable Alarm Wakeup feature. This register needs to be
properly handled for the rtcwake to work properly.
Platforms using such IP should set "ti,am3352-rtc" in rtc device dt
compatibility node.
Signed-off-by: Hebbar Gururaja <gururaja.hebbar@ti.com>
Acked-by: Kevin Hilman <khilman@linaro.org>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Rob Landley <rob@landley.net>
rtc-omap driver modules is used both by OMAP1/2, Davinci SoC platforms.
However, rtc wake support on OMAP1 is broken. Hence the
device_init_wakeup() was removed from rtc-omap driver and moved to
platform board files that supported it (DA850/OMAP-L138). [1]
However, recently [2] it was suggested that driver should always do a
device_init_wakeup(dev, true). Platforms that don't want/need
wakeup support can disable it from userspace via:
echo disabled > /sys/devices/.../power/wakeup
Also, with the new DT boot-up, board file doesn't exist and hence there
is no way to have device wakeup support rtc.
The fix for above issues, is to hard code device_init_wakeup() inside
driver and let platforms that don't need this, handle it through the
sysfs power entry.
[1]
https://patchwork.kernel.org/patch/136731/
[2]
http://www.mail-archive.com/davinci-linux-open-source@linux.
davincidsp.com/msg26077.html
Use #include <linux/io.h> instead of <asm/io.h> as pointed out by
checkpatch.
Cc: George G. Davis <gdavis@mvista.com>
Cc: Jingoo Han <jg1.han@samsung.com>
