path: root/drivers/rtc/rtc-pl031.c
2015-11-08rtc: pl031: remove misuse of IRQF_NO_SUSPEND flagSudeep Holla
The IRQF_NO_SUSPEND flag is used to identify the interrupts that should be left enabled so as to allow them to work as expected during the suspend-resume cycle, but doesn't guarantee that it will wake the system from a suspended state, enable_irq_wake is recommended to be used for the wakeup. This patch removes the use of IRQF_NO_SUSPEND flags and uses newly introduce PM wakeup APIs dev_pm_{set,clear}_wake_irq. Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com> Cc: rtc-linux@googlegroups.com Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-09-05rtc: pl031: fix typo for author emailLeo Yan
The email address missed character ">", so add it. Signed-off-by: Leo Yan <leo.yan@linaro.org> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2013-11-13drivers/rtc/rtc-pl03x.c: remove unnecessary amba_set_drvdata()Michal Simek
Driver core clears the driver data to NULL after device_release or on probe failure, so just remove it from here. The relevant driver core change was commit 0998d0631001 ("device-core: Ensure drvdata = NULL when no driver is bound"). Signed-off-by: Michal Simek <michal.simek@xilinx.com> Cc: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-18rtc: rtc-pl031: Set wakeup flag prior to registering rtcdevJohn Stultz
In some recent testing, I noticed the CLOCK_REALTIME_ALARM clockid wasn't functioning on my vexpress qemu environment. Looking into it I noticed the pl031 rtc driver doesn't set the wakeup flag on the device until after registering the device with the RTC subsystem. This causes the alarmtimer subsystem to not see the pl031 driver as a valid backing device, and that resuls in alarm clockids getting ENOTSUPP errors. Thus be sure to set the wakeup flag on the device prior to registering the rtcdev so the pl031 rtc driver can be used as the backing alarmtimer device. Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: "Jon Medhurst (Tixy)" <tixy@linaro.org> Cc: linux-arm-kernel@lists.infradead.org Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: John Stultz <john.stultz@linaro.org>
2013-05-24drivers/rtc/rtc-pl031.c: pass correct pointer to free_irq()Lars-Peter Clausen
free_irq() expects the same pointer that was passed to request_irq(), otherwise the IRQ is not freed. The issue was found using the following coccinelle script: <smpl> @r1@ type T; T devid; @@ request_irq(..., devid) @r2@ type r1.T; T devid; position p; @@ free_irq@p(..., devid) @@ position p != r2.p; @@ *free_irq@p(...) </smpl> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21drivers/rtc/rtc-pl031.c: add wakeup supportRob Herring
Mark the pl031 as wake-up capable so that rtcwake and suspend test can work. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-12drivers/rtc/rtc-pl031.c: restore ST variant functionalityLinus Walleij
Commit e7e034e18a0a ("drivers/rtc/rtc-pl031.c: fix the missing operation on enable") accidentally broke the ST variants of PL031. The bit that is being poked as "clockwatch" enable bit for the ST variants does the work of bit 0 on this variant. Bit 0 is used for a clock divider on the ST variants, and setting it to 1 will affect timekeeping in a very bad way. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Mian Yousaf KAUKAB <mian.yousaf.kaukab@stericsson.com> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-05drivers/rtc/rtc-pl031.c: fix the missing operation on enableHaojian Zhuang
The RTC control register should be enabled in the process of initializing. Without this patch, I failed to enable RTC in Hisilicon Hi3620 SoC. The register mapping section in RTC is always read as zero. So I doubt that ST guys may already enable this register in bootloader. So they won't meet this issue. Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30rtc: pl031: fix up IRQ flagsMattias Wallin
The pl031 interrupt is shared between the timer part and the clockwatch part of the same HW block on the ux500, so mark it IRQF_SHARED on this variant. This patch also adds the IRQF_NO_SUSPEND flag to the rtc irq on all variants as we don't want this pretty important IRQ to be disabled in suspend. Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Rickard Andersson <rickard.andersson@stericsson.com> Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30rtc: pl031: use per-vendor variables for special initLinus Walleij
Instead of hard-checking for certain vendor codes, follow the pattern of other AMBA (PrimeCell) drivers and use variables in the vendor data. Get rid of the locally cached vendor and hardware revision since we already have the nice vendor data variable in the state. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30rtc: pl031: encapsulate per-vendor opsLinus Walleij
Move the per-vendor operations for this RTC into a encapsulating struct so we can have more per-vendor variables than just the ops. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29drivers/rtc/rtc-pl031.c: remove RTC timer interrupt handlingRajkumar Kasirajan
Remove RTT interrupt handling, since PIE mode interrupts are now better emulated in generic code via an hrtimer we have no need for this, and there is no codepath in the driver that enables these periodic interrupts anyway. Signed-off-by: Rajkumar Kasirajan <rajkumar.kasirajan@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Cc: Mattias Wallin <mattias.wallin@stericsson.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-17drivers/rtc/rtc-pl031.c: configure correct wday for 2000-01-01Rajkumar Kasirajan
The reset date of the ST Micro version of PL031 is 2000-01-01. The correct weekday for 2000-01-01 is saturday, but pl031 is initialized to sunday. This may lead to alarm malfunction, so configure the correct wday if RTC_DR indicates reset. Signed-off-by: Rajkumar Kasirajan <rajkumar.kasirajan@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Cc: Mattias Wallin <mattias.wallin@stericsson.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-12drivers/rtc/rtc-pl031.c: enable clock on all ST variantsLinus Walleij
The ST variants of the PL031 all require bit 26 in the control register to be set before they work properly. Discovered this when testing on the Nomadik board where it would suprisingly just stand still. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Cc: Mian Yousaf Kaukab <mian.yousaf.kaukab@stericsson.com> Cc: Alessandro Rubini <rubini@unipv.it> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23Merge branch 'amba' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull #2 ARM updates from Russell King: "Further ARM AMBA primecell updates which aren't included directly in the previous commit. I wanted to keep these separate as they're touching stuff outside arch/arm/." * 'amba' of git://git.linaro.org/people/rmk/linux-arm: ARM: 7362/1: AMBA: Add module_amba_driver() helper macro for amba_driver ARM: 7335/1: mach-u300: do away with MMC config files ARM: 7280/1: mmc: mmci: Cache MMCICLOCK and MMCIPOWER register ARM: 7309/1: realview: fix unconnected interrupts on EB11MP ARM: 7230/1: mmc: mmci: Fix PIO read for small SDIO packets ARM: 7227/1: mmc: mmci: Prepare for SDIO before setting up DMA job ARM: 7223/1: mmc: mmci: Fixup use of runtime PM and use autosuspend ARM: 7221/1: mmc: mmci: Change from using legacy suspend ARM: 7219/1: mmc: mmci: Change vdd_handler to a generic ios_handler ARM: 7218/1: mmc: mmci: Provide option to configure bus signal direction ARM: 7217/1: mmc: mmci: Put power register deviations in variant data ARM: 7216/1: mmc: mmci: Do not release spinlock in request_end ARM: 7215/1: mmc: mmci: Increase max_segs from 16 to 128
2012-03-23drivers/rtc: remove IRQF_DISABLEDYong Zhang
Since commit e58aa3d2d0cc ("genirq: run irq handlers with interrupts disabled") we run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled - see commit b738a50a2026 ("genirq: warn when handler enables interrupts"). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-16ARM: 7362/1: AMBA: Add module_amba_driver() helper macro for amba_driverviresh kumar
For simple modules that contain a single amba_driver without any additional setup code then ends up being a block of duplicated boilerplate. This patch adds a new macro, module_amba_driver(), which replaces the module_init()/module_exit() registrations with template functions. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-22rtc: pl031: Enable module alias autogeneration for AMBA driversDave Martin
Signed-off-by: Dave Martin <dave.martin@linaro.org>
2011-03-17Merge branches 'defcfg', 'drivers' and 'cyberpro-next' of ↵Linus Torvalds
master.kernel.org:/home/rmk/linux-2.6-arm * 'defcfg' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6647/1: add Versatile Express defconfig ARM: 6644/1: mach-ux500: update the U8500 defconfig * 'drivers' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6764/1: pl011: factor out FIFO to TTY code ARM: 6763/1: pl011: add optional RX DMA to PL011 v2 ARM: 6758/1: amba: support pm ops ARM: amba: make amba_driver id_table const ARM: amba: make internal ID table handling const ARM: amba: make probe() functions take const id tables ARM: 6662/1: amba: make amba_bustype non-static ARM: mmci: add dmaengine-based DMA support ARM: mmci: no need for separate host->data_xfered ARM: mmci: avoid unnecessary switch to data available PIO interrupts ARM: mmci: no need to call flush_dcache_page() with sg_miter API ARM: mmci: avoid reporting too many completed bytes on fifo overrun ALSA: AACI: make fifo variables more explanitory ALSA: AACI: no need to call snd_pcm_period_elapsed() for each period ALSA: AACI: use snd_pcm_lib_period_bytes() ALSA: AACI: clean up AACI announcement printk ALSA: AACI: fix channel mask selection ALSA: AACI: fix number of channels for record ALSA: AACI: fix multiple IRQ claiming * 'cyberpro-next' of master.kernel.org:/home/rmk/linux-2.6-arm: VIDEO: cyberpro: remove unused cyber2000fb_get_fb_var() VIDEO: cyberpro: remove useless function extreg pointers VIDEO: cyberpro: update handling of device structures VIDEO: cyberpro: add support for video capture I2C VIDEO: cyberpro: make 'reg_b0_lock' always present VIDEO: cyberpro: add I2C support VIDEO: cyberpro: select lowest multipler/divisor for PLL
2011-03-09RTC: Cleanup rtc_class_ops->irq_set_freq()John Stultz
With the generic rtc code now emulating PIE mode irqs via an hrtimer, no one calls the rtc_class_ops->irq_set_freq call. This patch removes the hook and deletes the driver functions if no one else calls them. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-03-09RTC: Cleanup rtc_class_ops->irq_set_stateJohn Stultz
With PIE mode interrupts now emulated in generic code via an hrtimer, no one calls rtc_class_ops->irq_set_state(), so this patch removes it along with driver implementations. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-02-23ARM: amba: make probe() functions take const id tablesRussell King
Make Primecell driver probe functions take a const pointer to their ID tables. Drivers should never modify their ID tables in their probe handler. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-09drivers/rtc/rtc-pl031.c: do not mark PL031 IRQ as sharedLinus Walleij
It was a mistake to mark the PL031 IRQ as shared (for the U8500), we misread the datasheet. Get rid of this. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Cc: Jonas Aberg <jonas.aberg@stericsson.com> Cc: Mian Yousaf Kaukab <mian.yousaf.kaukab@stericsson.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11drivers/rtc/rtc-pl031.c: remove unused #include <linux/version.h>Huang Weiyi
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-27ARM: Fix section build warnings for AMBA driversRussell King
Found in the Versatile build: WARNING: drivers/built-in.o(.data+0x14c): Section mismatch in reference from the variable pl061_gpio_driver to the (unknown reference) .init.data:(unknown) The variable pl061_gpio_driver references the (unknown reference) __initdata (unknown) WARNING: drivers/built-in.o(.data+0x40f8): Section mismatch in reference from the variable pl011_driver to the (unknown reference) .init.data:(unknown) The variable pl011_driver references the (unknown reference) __initdata (unknown) WARNING: drivers/built-in.o(.data+0x5ab4): Section mismatch in reference from the variable pl031_driver to the (unknown reference) .init.data:(unknown) The variable pl031_driver references the (unknown reference) __initdata (unknown) Basically, amba_id structures must not be __initdata. Also fix: WARNING: drivers/built-in.o(.data+0x138): Section mismatch in reference from the variable pl061_gpio_driver to the function .init.text:pl061_probe() The variable pl061_gpio_driver references the function __init pl061_probe() which is an incorrectly annotated probe function. Fix it to reflect the other AMBA bus probe functions by removing the __init attributation. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-04ARM: 5914/1: Modify PL031 for Nomadik and U8500 v2Linus Walleij
This extends the existing PrimeCell PL031 driver with support for the ST Microelectronics and ST-Ericsson derivatives, in a first and second version as used on the Nomadik and U8500 platforms. It also rids the old ioctl() alarm on/off functions in favor of the new .alarm_irq_enable field of the RTC class ops. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-16rtc: remove __raw_* accessors from PL031 RTCLinus Walleij
This switches __raw_[read|write]l() for plain [read|write]l in the PL031 RTC driver. The sister driver for PL030 use the simple accessors as most PrimeCell drivers. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11[ARM] 5544/1: Trust PrimeCell resource sizesLinus Walleij
I found the PrimeCell/AMBA Bus drivers distrusting the resource passed in as part of the struct amba_device abstraction. This patch removes all hard coded resource sizes found in the PrimeCell drivers and move the responsibility of this definition back to the platform/board device definition, which already exist and appear to be correct for all in-tree users of these drivers. We do this using the resource_size() inline function which was also replicated in the only driver using the resource size, so that has been changed too. The KMI_SIZE was left in kmi.h in case someone likes it. Test-compiled against Versatile and Integrator defconfigs, seems to work but I don't posess these boards and cannot test them. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-05-20[ARM] 5519/1: amba probe: pass "struct amba_id *" instead of void *Alessandro Rubini
The second argument of the probe method points to the amba_id structure, so it's better passed with the correct type. None of the current in-tree drivers uses the pointer, so they have only been checked for a clean compile. Change suggested by Russell King. Signed-off-by: Alessandro Rubini <rubini@unipv.it> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-16rtc: remove some NOP open/release methodsDavid Brownell
Remove NOP methods from rtc-pl030 and rtc-pl031 drivers; this is pure wasted code. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-22[RTC] rtc-pl031: use proper resources, use proper apis, clean up includesRussell King
Clean up PL031 RTC includes, make driver use proper resource checking, and use amba bus specific accessors. Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-19remove asm/bitops.h includesJiri Slaby
remove asm/bitops.h includes including asm/bitops directly may cause compile errors. don't include it and include linux/bitops instead. next patch will deny including asm header directly. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: rtc interfaces don't use class_deviceDavid Brownell
This patch removes class_device from the programming interface that the RTC framework exposes to the rest of the kernel. Now an rtc_device is passed, which is more type-safe and streamlines all the relevant code. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-01[PATCH] constify rtc_class_ops: update driversDavid Brownell
Update RTC framework so that drivers can constify their method tables, moving them from ".data" to ".rodata". Then update the drivers. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: misc drivers: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] Add driver for ARM AMBA PL031 RTCDeepak Saxena
Add a driver for the ARM PL031 RTC found on some ARM SOCs. The driver is fairly trivial as the RTC only provides a read/write and alarm capability. [akpm@osdl.org: compile fix] Signed-off-by: Deepak <dsaxena@plexity.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
