commit aaa3cee5deffa28415a6e1852c5afae0f5d210e2 upstream.
The rv8803 has its own driver that should be used. Remove its id from
the rx8025 driver.
Fixes: b1f9d790b59dc04f8813a49a92ddd8651770ffee
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
braces {} are not necessary for single statement blocks
Check time validity when reading time as this is when we need to know.
RX8025_BIT_CTRL2_CTFG was set to 0 only when it was already 0.
irq_freq is already initialized to 1 in rtc_device_register()
Wait for the user to set the time to reset the validity bits. Until then,
the time may be invalid.
rx8025_init_client is modifying ctrl[0] and writing it to RX8025_REG_CTRL2
but ctrl[0] is actually RX8025_REG_CTRL1.
Instead of bailing out, disable alarms and continue when
devm_request_threaded_irq() fails. This allows to still provide some
functionality.
Remove useless error messages, at that point, the user already knows
something went wrong but will not be able to do anything about it anyway.
It is also highly unlikely that some registers are readable/writable
but not some other ones.
Also, transform rx8025_read_reg to be more resemblant to
i2c_smbus_read_byte_data()
Stop setting the time to epoch when it is invalid. The proper way to handle
that is to return an error when it is invalid instead of returning an
incorrect value.
The datasheet specifies that transfer mode must be 0 for write and either
0x4 (simplified read) or 0 (standard read). 0x8 is not specified, use
standard mode.
The hardware is only capable of handling dates between 2000 and 2099,
enforce that.
Use BIT() instead of hand coding.
It is useless to print a message when probe fails as the user is already
aware that it failed.
Use devm_request_threaded_irq() so it is not necessary to call free_irq()
explicitly.
The driver currently emulates the concept of threaded IRQ using a
workqueue, switch to threaded IRQ instead.
Remove the useless includes and order the remaining ones alphabetically.
rtc_update_irq()
Since commit e6229bec25be ("rtc: make rtc_update_irq callable with irqs
enabled") rtc_update_irq() is callable with irqs enabled.
Signed-off-by: Henri Roosen <henriroosen@gmail.com>
i2c_driver does not need to set an owner because i2c_register_driver()
will set it.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
The site-specific OOM messages are unnecessary, because they duplicate
the MM subsystem generic OOM message.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Use devm_*() functions to make cleanup paths simpler.
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Factor out some boilerplate code for i2c driver registration into
module_i2c_driver.
Cc: Piotr Ziecik <kosmo@semihalf.com>
Cc: Scott Wood <scottwood@freescale.com>
Cc: Srikanth Srinivasan <srikanth.srinivasan@freescale.com>
Cc: Mike Rapoport <mike@compulab.co.il>
Cc: Sergey Lapin <slapin@ossfans.org>
Cc: Roman Fietze <roman.fietze@telemotive.de>
Cc: Herbert Valerio Riedel <hvr@gnu.org>
Cc: Alexander Bigga <ab@mycable.de>
Cc: Dale Farnsworth <dale@farnsworth.org>
Cc: Gregory Hermant <gregory.hermant@calao-systems.com>
Cc: Wolfgang Grandegger <wg@grandegger.com>
Cc: Martyn Welch <martyn.welch@ge.com>
Cc: Byron Bradley <byron.bbradley@gmail.com>
With PIE mode interrupts now emulated in generic code via an hrtimer,
no one calls rtc_class_ops->irq_set_state(), so this patch removes it
along with driver implementations.
CC: Thomas Gleixner <tglx@linutronix.de>
CC: Alessandro Zummo <a.zummo@towertech.it>
CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br>
CC: rtc-linux@googlegroups.com
Signed-off-by: John Stultz <john.stultz@linaro.org>
flush_scheduled_work() is deprecated and scheduled to be removed. On
removal, directly cancel the work, and flush the uie_task in
rtc-dev.c::clear_uie().
Cc: rtc-linux@googlegroups.com
Fix typo in comments. Replace charater with character.
Characteristics too.
Signed-off-by: Thomas Weber <weber@corscience.de>
I2C drivers can use the clientdata-pointer to point to private data. As I2C
devices are not really unregistered, but merely detached from their driver, it
used to be the drivers obligation to clear this pointer during remove() or a
failed probe(). As a couple of drivers forgot to do this, it was agreed that it
was cleaner if the i2c-core does this clearance when appropriate, as there is
no guarantee for the lifetime of the clientdata-pointer after remove() anyhow.
This feature was added to the core with commit
e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers.
As there is no need anymore to clear the clientdata-pointer, remove all current
occurrences in the drivers to simplify the code and prevent confusion.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Richard Purdie <rpurdie@linux.intel.com>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Add support for the Epson RX-8025SA/NB RTC chips. It includes support for
alarms, periodic interrupts (1 Hz) and clock precision adjustment.
For clock precision adjustment, the SYSFS file "clock_adjust_ppb" gets
created in "/sys/class/rtc/rtcX/device". It permits to set and get the
clock adjustment in ppb (parts per billion), e.g.:
# echo -183000 > /sys/class/rtc/rtc0/device/clock_adjust_ppb
# cat /sys/class/rtc/rtc0/device/clock_adjust_ppb
-183000
This allows to compensate temperature dependent clock drifts. According
to the RX8025 SA/NB application manual the frequency and temperature
characteristics can be approximated using the following equation:
df = a * (ut - t)**2
df: Frequency deviation in any temperature
a : Coefficient = (-35 +-5) * 10**-9
ut: Ultimate temperature in degree = +25 +-5 degree
t : Any temperature in degree
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Signed-off-by: Dmitry Rakhchev <rda@emcraft.com>
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Acked-by: Jean Delvare <khali@linux-fr.org>
Signed-off-by: Alessandro Zummo <a.zummo@towertech.it>
Cc: David Brownell <david-b@pacbell.net>
