path: root/drivers/rtc/rtc-rx8581.c
2010-07-27drivers/rtc/rtc-rx8581.c: fix setdatetimeRudolf Marek
Fix the logic while writing new date/time to the chip. The driver incorrectly wrote back register values to different registers and even with wrong mask. The patch adds clearing of the VLF register, which should be cleared if all date/time values are set. Signed-off-by: Rudolf Marek <rudolf.marek@sysgo.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Cc: Martyn Welch <martyn.welch@gefanuc.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-14rtc: e-mail corrections following split of GE Fanuc joint ventureMartyn Welch
This patch corrects author and copyright notices following the split-up of the GE Fanuc joint venture. Signed-off-by: Martyn Welch <martyn.welch@ge.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-11-12rtc: basic implementation of Epson RX-8581 I2C Real Time ClockMartyn Welch
Provide the basic "get" and "set" functionality for the Epson RX-8581 I2C RTC. It currently does not support the RTC's Alarm or Fixed-cycle timer. [akpm@linux-foundation.org: need log2.h for ilog2(), remove unneeded initialisation] Signed-off-by: Martyn Welch <martyn.welch@gefanuc.com> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
