path: root/drivers/rtc/rtc-sh.c
2011-03-29drivers: Final irq namespace conversionThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-09RTC: Clean out UIE icotl implementationsJohn Stultz
With the generic RTC rework, the UIE mode irqs are handled in the generic layer, and only hardware specific ioctls get passed down to the rtc driver layer. So this patch removes the UIE mode ioctl handling in the rtc driver layer, which never get used. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-03-09RTC: Cleanup rtc_class_ops->irq_set_freq()John Stultz
With the generic rtc code now emulating PIE mode irqs via an hrtimer, no one calls the rtc_class_ops->irq_set_freq call. This patch removes the hook and deletes the driver functions if no one else calls them. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-03-09RTC: Cleanup rtc_class_ops->irq_set_stateJohn Stultz
With PIE mode interrupts now emulated in generic code via an hrtimer, no one calls rtc_class_ops->irq_set_state(), so this patch removes it along with driver implementations. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-02-03RTC: Convert rtc drivers to use the alarm_irq_enable methodJohn Stultz
Some rtc drivers use the ioctl method instead of the alarm_irq_enable method for enabling alarm interupts. With the new virtualized RTC rework, its important for drivers to use the alarm_irq_enable instead. This patch converts the drivers that use the AIE ioctl method to use the alarm_irq_enable method. Other ioctl cmds are left untouched. I have not been able to test or even compile most of these drivers. Any help to make sure this change is correct would be appreciated! CC: Alessandro Zummo <a.zummo@towertech.it> CC: Thomas Gleixner <tglx@linutronix.de> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> Reported-by: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> Tested-by: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> Signed-off-by: John Stultz <john.stultz@linaro.org>
2010-11-08rtc: rtc-sh - fix a memory leakAxel Lin
request_mem_region() will call kzalloc to allocate memory for struct resource. release_resource() unregisters the resource but does not free the allocated memory, thus use release_mem_region() instead to fix the memory leak. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-15const: constify remaining dev_pm_opsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-09rtc: rtc-sh: Fix up oops in early periodic freq assignment.Paul Mundt
With the reordered init order, the rtc device is not registered until later, while sh_rtc_irq_set_freq() was attempting to assign ->irq_freq directly, resulting in an oops. This is handled by the upper layers for us, so just kill off the problematic dereference completely. Reported-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-08-20rtc: rtc-sh fixesAlessandro Zummo
- simplifies irq set freq - ioctl() was duplicating functionalities of rtc-dev core - corrected initialization sequence - use platform_driver_probe Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Angelo Castello <angelo.castello@st.com> Cc: Giuseppe Cavallaro <peppe.cavallaro@st.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Jamie Lenehan <lenehan@twibble.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-04-16rtc: rtc-sh: clock framework support.Paul Mundt
This adds clock framework support to the rtc-sh driver. With this in place, platforms can default to leaving the clock disabled rather than placing it in the always enabled state. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-04-02rtc: rtc-sh: use set_irq_wake()Magnus Damm
Modify the sh_rtc driver to use set_irq_wake() during suspend and resume. These functions are used to enable the rtc interrupts in the interrupt controller so the rtc can be used to wakeup the system from suspend. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-03-20sh: sh-rtc wakeup supportMagnus Damm
Flag that the SuperH RTC supports wakeup. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-03-20sh: sh-rtc invalid time reworkMagnus Damm
This patch modifies invalid time handling in the SuperH RTC driver. Instead of zeroing the returned value at read-out time we just return an error code and reset invalid values during probe. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-03-20sh: sh-rtc carry interrupt reworkMagnus Damm
This patch modifies the SuperH RTC driver to only enable carry interrupts when needed. So by default no interrupts are enabled with this patch. Without this patch a suspending system will most likely wake up by the carry interrupt regardless if the alarm interrupt has been enabled or not. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-03-06rtc: rtc-sh: Bump version up to reflect single IRQ support changes.Paul Mundt
2009-02-27rtc: sh-rtc: Add Single IRQ SupportMagnus Damm
Add support for single IRQ hardware to the sh-rtc driver. This is useful for processors with limited interrupt masking support such as sh7750 and sh7780. With this patch in place we can add logic to the intc code that merges all RTC vectors into a single linux interrupt with proper masking/unmasking support. Specify a single IRQ in the platform data to use this new shared IRQ feature. Separate Periodic/Carry/Alarm IRQs are still supported. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-01-06rtc: move power of 2 periodic frequency check down into driversJonathan Cameron
Move the power of 2 check on frequencies down into individual rtc drivers This is to allow for non power of 2 real time clock periodic interrupts such as those on the pxa27x to be found in the new pxa27x-rtc driver Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: bunch of drivers: fix 'no irq' case handingAnton Vorontsov
This patch fixes a bunch of irq checking misuses. Most drivers were getting irq via platform_get_irq(), which returns -ENXIO or r->start. rtc-cmos.c is special. It is using PNP and platform bindings. Hopefully nobody is using PNP IRQ 0 for RTC. So the changes should be safe. rtc-sh.c is using platform_get_irq, but was storing a result into an unsigned type, then was checking for < 0. This is fixed now. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (112 commits) sh: Move SH-4 CPU headers down one more level. sh: Only build in gpio.o when CONFIG_GENERIC_GPIO is selected. sh: Migrate common board headers to mach-common/. sh: Move the CPU definition headers from asm/ to cpu/. serial: sh-sci: Add support SCIF of SH7723 video: add sh_mobile_lcdc platform flags video: remove unused sh_mobile_lcdc platform data sh: remove consistent alloc cruft sh: add dynamic crash base address support sh: reduce Migo-R smc91x overruns sh: Fix up some merge damage. Fix debugfs_create_file's error checking method for arch/sh/mm/ Fix debugfs_create_dir's error checking method for arch/sh/kernel/ sh: ap325rxa: Add support RTC RX-8564LC in AP325RXA board sh: Use sh7720 GPIO on magicpanelr2 board sh: Add sh7720 pinmux code sh: Use sh7203 GPIO on rsk7203 board sh: Add sh7203 pinmux code sh: Use sh7723 GPIO on AP325RXA board sh: Add sh7723 pinmux code ...
2008-10-20drivers/rtc/: use bcd2bin/bin2bcdAdrian Bunk
Change drivers/rtc/ to use the new bcd2bin/bin2bcd functions instead of the obsolete BCD_TO_BIN/BIN_TO_BCD/BCD2BIN/BIN2BCD macros. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Merge branch 'master' of ↵Paul Mundt
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/kernel-parameters.txt arch/sh/include/asm/elf.h
2008-10-16rtc: file close() consistently disables repeating irqsDavid Brownell
Make the rtc framework consistent about disabling 1/second update IRQs that may have been activated through the /dev interface, when that /dev file is closed. (It may have closed because of coredump, etc.) This was previously done only for emulated update IRQs ... now, do it always. Also comment the current policy: repeating IRQs (periodic, update) that userspace enabled will be cleanly disabled, but alarms are left alone. Such repeating IRQs are a constant and pointless system load. Update some RTC drivers to remove now-needless release() methods. Most such methods just enforce that policy. The others all seem to be buggy, and mistreat in-kernel clients of periodic or alarm IRQs. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Andrew Sharp <andy.sharp@onstor.com> Cc: Angelo Castello <angelo.castello@st.com> Acked-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Thomas Hommel <thomas.hommel@gefanuc.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-11rtc-sh: Unsigned rtc->{periodic,carry,alarm}_irq cannot be negativeroel kluin
possibly since commit b420b1a7a17ea88531d0e12b2f2679a0c8365803 Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08rtc: rtc-sh: Fixup for 64-bit resources.Paul Mundt
ioremap() and friends get the size information right, so force everything to go through there. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-28rtc: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-18rtc: rtc-sh: Add support for periodic IRQs.Angelo Castello
This adds support for periodic IRQs to the rtc-sh driver. RTC_IRQP_READ/RTC_IRQP_SET are added, with a number of other fixes and reordering across the rest of the code. Signed-off-by: Angelo Castello <angelo.castello@st.com> Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-04-11rtc: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable RTC platform drivers, to re-enable module auto loading. [dbrownell@users.sourceforge.net: more drivers, minor fix] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28rtc: rtc-sh: Split out the CPU defs to asm/cpu/.Paul Mundt
With all of the different CPU types this was getting a but unwieldly. Since sh64 is now integrated, we don't have to worry about multiple architectures caring about the header definitions. Split out the defs for each asm/cpu/ to make rtc-sh slightly less visually offensive. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-28rtc: rtc-sh: SH-2A support.Paul Mundt
Trivial support for the SH-2A on-chip RTC. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-01-28rtc: rtc-sh: SH-5 support.Paul Mundt
Trivial support for the SH-5 (sh64) on-chip RTC. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-11-07rtc: rtc-sh: Zero out tm value for invalid rtc states.Paul Mundt
Follows the changes of some of the other RTC drivers. If the tm value is bogus, just zero it out. Adds some sanity for RTC_RD_TIME. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-11-07rtc: sh-rtc: Handle rtc_device_register() failure properly.Paul Mundt
Currently if rtc_device_register() fails we have an IS_ERR() on the wrong pointer, which causes this to always be skipped. Fix this up to actually check the right pointer. The return value was always correct, even though the check was wrong. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21rtc: rtc-sh: Support 4-digit year on SH7705/SH7710/SH7712.Paul Mundt
All SH-4 parts have a 4-digit year, while the SH-3 parts typically only use a 2-digit one. The SH7705, SH7710, and SH7712 SH-3 parts however opted to extend it to 4-digit and still look and act like an SH-3 RTC in all other ways. This adds a capability flag (RTC_CAP_4_DIGIT_YEAR) that these corner-case CPU subtypes can set in their platform data and cleans up some of the ifdef mess in the driver as a result. Reported-by: Markus Brunner <super.firetwister@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-07-26rtc: rtc-sh: Correct sh_rtc_set_time() for some SH-3 parts.Markus Brunner
Some SH-3 parts (SH7720 and SH7705 at least) need to have the start bit explicitly cleared, as the reset is not enough. This is safe across all parts, so simply clear the start bit in the sh_rtc_set_time() path. Signed-off-by: Markus Brunner <super.firetwister@gmail.com> Signed-off by: Mark Jonas <toertel@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-05-09rtc: rtc-sh: Fix rtc_dev pointer for rtc_update_irq().Paul Mundt
When the rtc_update_irq() callsites stopped passing in the class_dev, the rtc_dev references weren't fixed. Fix it up, so we pass in the proper pointer. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-05-09rtc: rtc-sh: Fix up dev_dbg() warnings.Paul Mundt
2007-05-08rtc: rtc interfaces don't use class_deviceDavid Brownell
This patch removes class_device from the programming interface that the RTC framework exposes to the rest of the kernel. Now an rtc_device is passed, which is more type-safe and streamlines all the relevant code. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-23[PATCH] rtc-sh: act on rtc_wkalrm.enabled when setting an alarmJamie Lenehan
This fixes the SH rtc driver correctly act on the "enabled" flag when setting an alarm. Signed-off-by: Jamie Lenehan <lenehan@twibble.org> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <alessandro.zummo@towertech.it> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-11[PATCH] rtc-sh: correctly report rtc_wkalrm.enabledDavid Brownell
This fixes the SH rtc driver to (a) correctly report 'enabled' status with other alarm status; (b) not duplicate that status in its procfs dump Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-12rtc: rtc-sh: alarm support.Jamie Lenehan
This adds alarm support for the RTC_ALM_SET, RTC_ALM_READ, RTC_WKALM_SET and RTC_WKALM_RD operations to rtc-sh. The only unusual part is the handling of the alarm interrupt. If you clear the alarm flag (AF) while the time in the RTC still matches the time in the alarm registers than AF is immediately re-set, and if the alarm interrupt (AIE) is still enabled then it re-triggers. I was originally getting around 20k+ interrupts generated during the second when the RTC and alarm registers matches. The solution I've used is to clear AIE when the alarm goes off and then use the carry interrupt to re-enabled it. The carry interrupt will check AF and re-enabled AIE if it's clear. If AF is not clear it'll clear it and then the check will be repeated next carry interrupt. This a bit in rtc structure that indicates that it's waiting to have AIE re-enabled so it doesn't turn it on when it wasn't enabled anyway. Signed-off-by: Jamie Lenehan <lenehan@twibble.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-12-12rtc: rtc-sh: fix rtc for out-by-one for the month.Jamie Lenehan
The RMONCNT register, which holds the month in the RTC, takes a value between 1 and 12 while the tm_mon field in the time structures takes a value between 0 and 11. This wasn't being taken into account in rtc-sh resulting in the month being out by one. eg, on my board during boot the RTC is set to: RTC is set to Thu Jul 01 09:00:00 1999 but "hwclock -r" immediately after logging in was showing: Sun Aug 1 09:01:43 1999 0.000000 seconds Signed-off-by: Jamie Lenehan <lenehan@twibble.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-12-12rtc: rtc-sh: fix for period rtc interrupts.Jamie Lenehan
When testing the per second interrupt support (RTC_UIE_ON/RTC_UIE_OFF) of the new RTC system it would die in sh_rtc_interrupt due to a null ptr dereference. The following gets it working correctly. Signed-off-by: Jamie Lenehan <lenehan@twibble.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-10-06sh: Updates for IRQ handler changes.Paul Mundt
Trivial fixes for build breakage introduced by IRQ handler changes. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-27rtc: New RTC driver for SuperH On-Chip RTC.Paul Mundt
This replaces the old SH RTC driver, and allows us to clean quite a lot of things up on the board-specific side. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
