path: root/drivers/rtc
2011-06-27drivers/rtc/rtc-ds1307.c: add support for RTC device pt7c4338Priyanka Jain
PT7C4338 chip is being manufactured by Pericom Technology Inc. It is a serial real-time clock which provides: 1) Low-power clock/calendar. 2) Programmable square-wave output. It has 56 bytes of nonvolatile RAM. Its register set is same as that of rtc device: DS1307. Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Acked-by: Timur Tabi <timur@freescale.com> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-23rtc: vt8500: Fix build error & cleanup rtc_class_ops->update_irq_enable()Alexey Charkov
Now that the generic code handles UIE mode irqs via periodic alarm interrupts, no one calls the rtc_class_ops->update_irq_enable() method anymore. Further the rtc_class_ops doesn't have a update_irq_enable element anymore, so this causes a build error. This patch removes the driver hooks and implementations of update_irq_enable and the associated setup. [wsa: updated commit-message and removed update_irq_enable-function, too] [jstultz: improve commit message, clarifying build issue] Signed-off-by: Alexey Charkov <alchark@gmail.com> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-06-13Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rtc: Staticize non-exported __rtc_set_alarm() rtc: Fix ioctl error path return ptp: Fix some locking bugs in ptp_read() ptp: Return -EFAULT on copy_to_user() errors
2011-06-09unicore32: move rtc-puv3.c to drivers/rtc directoryGuan Xuetao
The patch moves rtc driver for PKUnity-v3 SoC from arch/unicore32/kernel/ to drivers/rtc/, with renaming it to rtc-puv3.c. Also, Kconfig, Makefile, and MAINTAINERS are modified correspondingly. Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-06-08spi/rtc-m41t93: Use spi_get_drvdata() for SPI devicesGeert Uytterhoeven
One new offender detected by the recently increased type checking in platform_get_drvdata(): drivers/rtc/rtc-m41t93.c: In function ‘m41t93_remove’: drivers/rtc/rtc-m41t93.c:192: warning: passing argument 1 of ‘platform_get_drvdata’ from incompatible pointer type Use spi_get_drvdata() instead of platform_get_drvdata(), cfr. commit 42fea15d6dc410e62dac6a764142045280624a5b ("spi/rtc-{ds1390,ds3234,m41t94}: Use spi_get_drvdata() for SPI devices") Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-01rtc: Staticize non-exported __rtc_set_alarm()Mark Brown
It's not referenced outside this file so there's no need for it to be in the global namespace and sparse warns about that. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-06-01rtc: Fix ioctl error path returnJohn Stultz
Bryan Henderson noticed that the "RTC: Fix rtc driver ioctl specific shortcutting" commit has a small bug: When an ioctl is called with an invalid command code and the clock driver does not have an "ioctl" method, the ioctl returns rc 0 instead of -ENOTTY. This patch fixes the issue. CC: Bryan Henderson <bryanh@giraffe-data.com> CC: Gabor Z. Papp <gzp@papp.hu> Reported-by: Bryan Henderson <bryanh@giraffe-data.com> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-05-26drivers/rtc/rtc-mxc.c: remove defines already included in rtc.hWolfram Sang
[akpm@linux-foundation.org: retain the code comments] Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Vladimir Zapolskiy <vzapolskiy@gmail.com> Cc: Alessandro Zummo <alessandro.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26drivers/rtc/rtc-pcf50633.c: don't request update IRQLars-Peter Clausen
Commit 51ba60c5 ("RTC: Cleanup rtc_class_ops->update_irq_enable()") removed the only user of the update IRQ, so there is no need to manage it any more. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> Cc: John Stultz <john.stultz@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26rtc: add support for spear rtcRajeev Kumar
Signed-off-by: Rajeev Kumar <rajeev-dlh.kumar@st.com> Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26drivers/rtc/rtc-mrst.c: use release_mem_region after request_mem_regionJulia Lawall
The memory allocated using request_mem_region should be released using release_mem_region, not release_region. The semantic patch that fixes part of this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression E1,E2,E3; @@ request_mem_region(E1,E2,E3) ... ?- release_region(E1,E2) + release_mem_region(E1,E2) // </smpl> [akpm@linux-foundation.org: use resource_size()] Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26rtc: add basic support for ST M41T93 SPI RTCVoss, Nikolaus
Add basic support for ST m41t93 SPI RTCs. Tested with factory-new and with "run-in" species with and without backup batteries. Signed-off-by: Nikolaus Voss <n.voss@weinmann.de> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26rtc: add rv3029c2 RTC supportHeiko Schocher
Add support for the Micro Crystal RV3029-C2 RTC chips. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Gregory Hermant <gregory.hermant@calao-systems.com> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26rtc: add EM3027 rtc driverMike Rapoport
Add support for EM Microelectronic EM3027 RTC chip. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26rtc: add support for the RTC in VIA VT8500 and compatiblesAlexey Charkov
This adds a driver for the RTC devices in VIA and WonderMedia Systems-on-Chip. Alarm, 1Hz interrupts, reading and setting time are supported. Signed-off-by: Alexey Charkov <alchark@gmail.com> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Alexey Charkov <alchark@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26mfd: Add rtc support to 88pm860xHaojian Zhuang
Enable rtc function in 88pm860x PMIC. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (26 commits) arch/tile: prefer "tilepro" as the name of the 32-bit architecture compat: include aio_abi.h for aio_context_t arch/tile: cleanups for tilegx compat mode arch/tile: allocate PCI IRQs later in boot arch/tile: support signal "exception-trace" hook arch/tile: use better definitions of xchg() and cmpxchg() include/linux/compat.h: coding-style fixes tile: add an RTC driver for the Tilera hypervisor arch/tile: finish enabling support for TILE-Gx 64-bit chip compat: fixes to allow working with tile arch arch/tile: update defconfig file to something more useful tile: do_hardwall_trap: do not play with task->sighand tile: replace mm->cpu_vm_mask with mm_cpumask() tile,mn10300: add device parameter to dma_cache_sync() audit: support the "standard" <asm-generic/unistd.h> arch/tile: clarify flush_buffer()/finv_buffer() function names arch/tile: kernel-related cleanups from removing static page size arch/tile: various header improvements for building drivers arch/tile: disable GX prefetcher during cache flush arch/tile: tolerate disabling CONFIG_BLK_DEV_INITRD ...
2011-05-19Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: hrtimer: Make lookup table const RTC: Disable CONFIG_RTC_CLASS from being built as a module timers: Fix alarmtimer build issues when CONFIG_RTC_CLASS=n timers: Remove delayed irqwork from alarmtimers implementation timers: Improve alarmtimer comments and minor fixes timers: Posix interface for alarm-timers timers: Introduce in-kernel alarm-timer interface timers: Add rb_init_node() to allow for stack allocated rb nodes time: Add timekeeping_inject_sleeptime
2011-05-17tile: add an RTC driver for the Tilera hypervisorChris Metcalf
This is a simple RTC driver that lets Tilera hardware boot up and set the clock correctly. Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-05-17Merge branch 'timers-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: tick: Clear broadcast active bit when switching to oneshot rtc: mc13xxx: Don't call rtc_device_register while holding lock rtc: rp5c01: Initialize drvdata before registering device rtc: pcap: Initialize drvdata before registering device rtc: msm6242: Initialize drvdata before registering device rtc: max8998: Initialize drvdata before registering device rtc: max8925: Initialize drvdata before registering device rtc: m41t80: Initialize clientdata before registering device rtc: ds1286: Initialize drvdata before registering device rtc: ep93xx: Initialize drvdata before registering device rtc: davinci: Initialize drvdata before registering device rtc: mxc: Initialize drvdata before registering device clocksource: Install completely before selecting
2011-05-11drivers/rtc/rtc-s3c.c: fixup wake support for rtcBen Dooks
The driver is not balancing set_irq and disable_irq_wake() calls, so ensure that it keeps track of whether the wake is enabled. The fixes the following error on S3C6410 devices: WARNING: at kernel/irq/manage.c:382 set_irq_wake+0x84/0xec() Unbalanced IRQ 92 wake disable Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-06rtc: mc13xxx: Don't call rtc_device_register while holding lockUwe Kleine-König
Since commit f44f7f9 (RTC: Initialize kernel state from RTC) rtc_device_register reads the programmed alarm. As reading the alarm needs to take the mc13xxx lock, release it before calling rtc_device_register. This fixes a deadlock during boot: INFO: task swapper:1 blocked for more than 120 seconds. "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. swapper D c02b175c 0 1 0 0x00000000 [<c02b175c>] (schedule+0x304/0x4f4) from [<c02b25a8>] (__mutex_lock_slowpath+0x7c/0x110) [<c02b25a8>] (__mutex_lock_slowpath+0x7c/0x110) from [<c020b4cc>] (mc13xxx_rtc_read_time+0x1c/0x118) [<c020b4cc>] (mc13xxx_rtc_read_time+0x1c/0x118) from [<c0208f04>] (__rtc_read_time+0x58/0x5c) [<c0208f04>] (__rtc_read_time+0x58/0x5c) from [<c0209508>] (rtc_read_time+0x30/0x48) [<c0209508>] (rtc_read_time+0x30/0x48) from [<c0209dd4>] (__rtc_read_alarm+0x1c/0x290) [<c0209dd4>] (__rtc_read_alarm+0x1c/0x290) from [<c0208d58>] (rtc_device_register+0x150/0x27c) [<c0208d58>] (rtc_device_register+0x150/0x27c) from [<c02b0b74>] (mc13xxx_rtc_probe+0x128/0x17c) [<c02b0b74>] (mc13xxx_rtc_probe+0x128/0x17c) from [<c01d5280>] (platform_drv_probe+0x1c/0x24) [<c01d5280>] (platform_drv_probe+0x1c/0x24) from [<c01d3e58>] (driver_probe_device+0x80/0x1a8) [<c01d3e58>] (driver_probe_device+0x80/0x1a8) from [<c01d400c>] (__driver_attach+0x8c/0x90) [<c01d400c>] (__driver_attach+0x8c/0x90) from [<c01d3654>] (bus_for_each_dev+0x60/0x8c) [<c01d3654>] (bus_for_each_dev+0x60/0x8c) from [<c01d2f6c>] (bus_add_driver+0x180/0x248) [<c01d2f6c>] (bus_add_driver+0x180/0x248) from [<c01d4664>] (driver_register+0x70/0x15c) [<c01d4664>] (driver_register+0x70/0x15c) from [<c01d5700>] (platform_driver_probe+0x18/0x98) [<c01d5700>] (platform_driver_probe+0x18/0x98) from [<c00273a8>] (do_one_initcall+0x2c/0x168) [<c00273a8>] (do_one_initcall+0x2c/0x168) from [<c00083ac>] (kernel_init+0xa0/0x150) [<c00083ac>] (kernel_init+0xa0/0x150) from [<c0033ff8>] (kernel_thread_exit+0x0/0x8) Reported-by: Vagrant Cascadian <vagrant@debian.org> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Closes: http://bugs.debian.org/625804 [Tweaked commit log -jstultz] Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-05-06rtc: rp5c01: Initialize drvdata before registering deviceJohn Stultz
Commit f44f7f96a20 ("RTC: Initialize kernel state from RTC") uncovered an issue in a number of RTC drivers, where the drivers call rtc_device_register before initializing the device or platform drvdata. This frequently results in null pointer dereferences when the rtc_device_register immediately makes use of the rtc device, calling rtc_read_alarm. The solution is to ensure the drvdata is initialized prior to registering the rtc device. CC: Wolfram Sang <w.sang@pengutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Thomas Gleixner <tglx@linutronix.de> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-05-06rtc: pcap: Initialize drvdata before registering deviceJohn Stultz
2011-05-06rtc: msm6242: Initialize drvdata before registering deviceJohn Stultz
2011-05-06rtc: max8998: Initialize drvdata before registering deviceJohn Stultz
2011-05-06rtc: max8925: Initialize drvdata before registering deviceJohn Stultz
2011-05-06rtc: m41t80: Initialize clientdata before registering deviceJohn Stultz
Commit f44f7f96a20 ("RTC: Initialize kernel state from RTC") uncovered an issue in a number of RTC drivers, where the drivers call rtc_device_register before initializing the clientdata. This frequently results in null pointer dereferences when the rtc_device_register immediately makes use of the rtc device, calling rtc_read_alarm. The solution is to ensure the clientdata is initialized prior to registering the rtc device. CC: Wolfram Sang <w.sang@pengutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Thomas Gleixner <tglx@linutronix.de> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-05-06rtc: ds1286: Initialize drvdata before registering deviceJohn Stultz
2011-05-06rtc: ep93xx: Initialize drvdata before registering deviceWolfram Sang
Commit f44f7f96a20 ("RTC: Initialize kernel state from RTC") uncovered an issue in a number of RTC drivers, where the drivers call rtc_device_register before initializing the device or platform drvdata. This frequently results in null pointer dereferences when the rtc_device_register immediately makes use of the rtc device, calling rtc_read_alarm. The solution is to ensure the drvdata is initialized prior to registering the rtc device. CC: Alessandro Zummo <a.zummo@towertech.it> CC: Thomas Gleixner <tglx@linutronix.de> CC: rtc-linux@googlegroups.com Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> [Fixed up commit log -jstultz] Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-05-06rtc: davinci: Initialize drvdata before registering deviceWolfram Sang
Commit f44f7f96a20 ("RTC: Initialize kernel state from RTC") uncovered an issue in a number of RTC drivers, where the drivers call rtc_device_register before initializing the device or platform drvdata. This frequently results in null pointer dereferences when the rtc_device_register immediately makes use of the rtc device, calling rtc_read_alarm. The solution is to ensure the drvdata is initialized prior to registering the rtc device. CC: Alessandro Zummo <a.zummo@towertech.it> CC: Thomas Gleixner <tglx@linutronix.de> CC: rtc-linux@googlegroups.com Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> [fixed up commit log -jstultz] Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-05-06rtc: mxc: Initialize drvdata before registering deviceWolfram Sang
2011-05-02Merge branch 'linus' into timers/coreThomas Gleixner
Reason: Pick up the hrtimer_clock_to_base_table fix from mainline Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-05-02RTC: Disable CONFIG_RTC_CLASS from being built as a moduleJohn Stultz
The RTC subsystem has a number of accessors that are available via include/linux/rtc.h. However many of these interfaces are not available for use if CONFIG_RTC_CLASS=m. So in order to support wider use of the RTC in the kernel, I'm removing the tristate config option for a bool, so that code can easily be conditionalized if the RTC class is present or not. Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-04-28rtc: max8925: Call dev_set_drvdata before rtc_device_registerZhangfei Gao
We call rtc_read_alarm from rtc_device_register, so it is important that the rtc device is fully initialized prior to registration. rtc-max8925 sets drvdata after register, so the rtc_read_alarm code dereferences a NULL pointer. Call dev_set_drvdata before rtc_device_register. [ jstultz/tglx: Massaged commit message ] Signed-off-by: Zhangfei Gao <zhangfei.gao@marvell.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Link: http://lkml.kernel.org/r/%3C1303929869-25249-1-git-send-email-john.stultz%40linaro.org%3E Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-04-26time: Add timekeeping_inject_sleeptimeJohn Stultz
Some platforms cannot implement read_persistent_clock, as their RTC devices are only accessible when interrupts are enabled. This keeps them from being used by the timekeeping code on resume to measure the time in suspend. The RTC layer tries to work around this, by calling do_settimeofday on resume after irqs are reenabled to set the time properly. However, this only corrects CLOCK_REALTIME, and does not properly adjust the sleep time value. This causes btime in /proc/stat to be incorrect as well as making the new CLOCK_BOTTTIME inaccurate. This patch resolves the issue by introducing a new timekeeping hook to allow the RTC layer to inject the sleep time on resume. The code also checks to make sure that read_persistent_clock is nonfunctional before setting the sleep time, so that should the RTC's HCTOSYS option be configured in on a system that does support read_persistent_clock we will not increase the total_sleep_time twice. CC: Arve Hjønnevåg <arve@android.com> CC: Thomas Gleixner <tglx@linutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-04-25Merge branch 'for-torvalds' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson * 'for-torvalds' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson: rtc: fix coh901331 startup crash mach-ux500: fix i2c0 device setup regression
2011-04-20rtc: fix coh901331 startup crashLinus Walleij
The rtc_device_register() call has changed semantics so that it will immediately call out to rtc_read_alarm() and since the callbacks require the drvdata to be set, we need to set it before the registration call to avoid NULL dereference. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-04-18RTC: rtc-omap: Fix a leak of the IRQ during init failureAxel Lin
In omap_rtc_probe error path, free_irq() was using NULL rather than the driver data as the data pointer so free_irq() wouldn't have matched. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: "George G. Davis" <gdavis@mvista.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: rtc-linux@googlegroups.com Link: http://lkml.kernel.org/r/%3C1303005778.2889.2.camel%40phoenix%3E Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-04-16Merge branches 'core-fixes-for-linus', 'perf-fixes-for-linus', ↵Linus Torvalds
'sched-fixes-for-linus', 'timer-fixes-for-linus' and 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: futex: Set FLAGS_HAS_TIMEOUT during futex_wait restart setup * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf_event: Fix cgrp event scheduling bug in perf_enable_on_exec() perf: Fix a build error with some GCC versions * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Fix erroneous all_pinned logic sched: Fix sched-domain avg_load calculation * 'timer-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: RTC: rtc-mrst: follow on to the change of rtc_device_register() RTC: add missing "return 0" in new alarm func for rtc-bfin.c RTC: Fix s3c compile error due to missing s3c_rtc_setpie RTC: Fix early irqs caused by calling rtc_set_alarm too early * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, amd: Disable GartTlbWlkErr when BIOS forgets it x86, NUMA: Fix fakenuma boot failure x86/mrst: Fix boot crash caused by incorrect pin to irq mapping x86/ce4100: Add reg property to bridges
2011-04-14drivers/rtc/rtc-mc13xxx.c: fix unterminated platform_device_id tableAxel Lin
The platform_device_id table is supposed to be zero-terminated. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-13Merge branch 'fortglx/39/tip/timers/rtc' of ↵Thomas Gleixner
git://git.linaro.org/people/jstultz/linux into timers/urgent
2011-04-07Merge branches 'x86-fixes-for-linus', 'sched-fixes-for-linus', ↵Linus Torvalds
'timers-fixes-for-linus', 'irq-fixes-for-linus' and 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86-32, fpu: Fix FPU exception handling on non-SSE systems x86, hibernate: Initialize mmu_cr4_features during boot x86-32, NUMA: Fix ACPI NUMA init broken by recent x86-64 change x86: visws: Fixup irq overhaul fallout * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Clean up rebalance_domains() load-balance interval calculation * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86/mrst/vrtc: Fix boot crash in mrst_rtc_init() rtc, x86/mrst/vrtc: Fix boot crash in rtc_read_alarm() * 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: Fix cpumask leak in __setup_irq() * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf probe: Fix listing incorrect line number with inline function perf probe: Fix to find recursively inlined function perf probe: Fix multiple --vars options behavior perf probe: Fix to remove redundant close perf probe: Fix to ensure function declared file
2011-04-07Merge branch 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6: Fix common misspellings
2011-04-07rtc, x86/mrst/vrtc: Fix boot crash in rtc_read_alarm()Feng Tang
Commit f44f7f96a20 ("RTC: Initialize kernel state from RTC") caused a boot regression on the MRST platform. The reason is that rtc_device_register() calls rtc_read_alarm() after that change, which function does not have all driver data set up yet. The rtc-mrst driver needs to call dev_set_drvdata() before rtc_device_register() gets called. Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Acked-by: John Stultz <john.stultz@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1302140384-27571-1-git-send-email-feng.tang@intel.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-04-06RTC: rtc-mrst: follow on to the change of rtc_device_register()Feng Tang
commit f44f7f96a20 (RTC: Initialize kernel state from RTC) will call rtc_read_alarm() inside rtc_device_register(), so rtc-mrst driver need to call dev_set_drvdata() before rtc_device_register() get called. Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: John Stultz <john.stultz@linaro.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-04-04rtc-mrst: Fix section typesMajor Lee
Fix the following section mismatch warning. WARNING: drivers/rtc/built-in.o(.data+0xa0): Section mismatch in reference from the variable vrtc_mrst_platform_driver to the function .init.text:vrtc_mrst_platform_probe() The variable vrtc_mrst_platform_driver references the function __init vrtc_mrst_platform_probe() If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console, Signed-off-by: Major Lee <major_lee@wistron.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-29RTC: add missing "return 0" in new alarm func for rtc-bfin.cMike Frysinger
The new bfin_rtc_alarm_irq_enable function forgot to add a "return 0" to the end leading to the build warning: drivers/rtc/rtc-bfin.c: In function 'bfin_rtc_alarm_irq_enable': drivers/rtc/rtc-bfin.c:253: warning: control reaches end of non-void function CC: stable@kernel.org CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-03-29RTC: Fix s3c compile error due to missing s3c_rtc_setpieVasily Khoruzhick
s3c_rtc_setpie was removed, and it resulted in compiler error: drivers/rtc/rtc-s3c.c: In function s3c_rtc_release drivers/rtc/rtc-s3c.c:339:2: error: implicit declaration of function s3c_rtc_setpie Fix it by removing s3c_rtc_release calls. [jstultz: An identical fix was also sent in by Jiri Pinkava <jiri.pinkava@vscht.cz>] CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: John Stultz <john.stultz@linaro.org>
