path: root/drivers/rtc
2017-04-21rtc: tegra: Implement clock handlingThierry Reding
commit 5fa4086987506b2ab8c92f8f99f2295db9918856 upstream. Accessing the registers of the RTC block on Tegra requires the module clock to be enabled. This only works because the RTC module clock will be enabled by default during early boot. However, because the clock is unused, the CCF will disable it at late_init time. This causes the RTC to become unusable afterwards. This can easily be reproduced by trying to use the RTC: $ hwclock --rtc /dev/rtc1 This will hang the system. I ran into this by following up on a report by Martin Michlmayr that reboot wasn't working on Tegra210 systems. It turns out that the rtc-tegra driver's ->shutdown() implementation will hang the CPU, because of the disabled clock, before the system can be rebooted. What confused me for a while is that the same driver is used on prior Tegra generations where the hang can not be observed. However, as Peter De Schrijver pointed out, this is because on 32-bit Tegra chips the RTC clock is enabled by the tegra20_timer.c clocksource driver, which uses the RTC to provide a persistent clock. This code is never enabled on 64-bit Tegra because the persistent clock infrastructure does not exist on 64-bit ARM. The proper fix for this is to add proper clock handling to the RTC driver in order to ensure that the clock is enabled when the driver requires it. All device trees contain the clock already, therefore no additional changes are required. Reported-by: Martin Michlmayr <tbm@cyrius.com> Acked-By Peter De Schrijver <pdeschrijver@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> [bwh: Backported to 4.9: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12rtc: sun6i: Switch to the external oscillatorMaxime Ripard
commit fb61bb82cb46a932ef2fc62e1c731c8e7e6640d5 upstream. The RTC is clocked from either an internal, imprecise, oscillator or an external one, which is usually much more accurate. The difference perceived between the time elapsed and the time reported by the RTC is in a 10% scale, which prevents the RTC from being useful at all. Fortunately, the external oscillator is reported to be mandatory in the Allwinner datasheet, so we can just switch to it. Fixes: 9765d2d94309 ("rtc: sun6i: Add sun6i RTC driver") Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12rtc: sun6i: Add some lockingMaxime Ripard
commit a9422a19ce270a22fc520f2278fb7e80c58be508 upstream. Some registers have a read-modify-write access pattern that are not atomic. Add some locking to prevent from concurrent accesses. Acked-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12rtc: sun6i: Disable the build as a moduleMaxime Ripard
commit 3753941475ae6501dcd1e41832bd0e6c35247d6a upstream. Since we have to provide the clock very early on, the RTC driver cannot be built as a module. Make sure that won't happen. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-04rtc: omap: prevent disabling of clock/module during suspendTero Kristo
If RTC is running from an internal clock source, the RTC module can't be disabled; otherwise it stops ticking completely. Current suspend handler implementation disables the clock/module unconditionally, instead fix this by disabling the clock only if we are running on external clock source, which is not affected by suspend. The prevention of disabling the clock must be done via implementing the runtime_pm handlers for the device, and returning an error code from the runtime suspend handler; otherwise OMAP core PM will disable the clocks for the driver. Signed-off-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-11-04rtc: omap: Fix selecting external oscLokesh Vutla
RTC can be clocked from an external 32KHz oscillator, or from the Peripheral PLL. The RTC has an internal oscillator buffer to support direct operation with a crystal. ---------------------------------------- | Device --------- | | | | | | | RTCSS | | | --------- | | | OSC |<------| RTC | | | | |------>| OSC |--- | | | | -------- | | | | | ----|clk | | | -------- | | | | | | PRCM |--- | | | | -------- -------- | ---------------------------------------- The RTC functional clock is sourced by default from the clock derived from the Peripheral PLL. In order to select source as external osc clk the following changes needs to be done: - Enable the RTC OSC (RTC_OSC_REG[4]OSC32K_GZ = 0) - Enable the clock mux(RTC_OSC_REG[6]K32CLK_EN = 1) - Select the external clock source (RTC_OSC_REG[3]32KCLK_SEL = 1) Fixes: 399cf0f63f6f2 ("rtc: omap: Add external clock enabling support") Signed-off-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Dave Gerlach <d-gerlach@ti.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-10-20rtc: cmos: Don't enable interrupts in the middle of the interrupt handlerVille Syrjälä
Using spin_lock_irq()/spin_unlock_irq() from within the interrupt handler is a no-no. Let's save/restore the flags to avoid turning on interrupts prematurely. We hit this in a bunch of our CI systems, but for whatever reason I wasn't able to reproduce on my own machine, so this fix is just based on the backtrace. [ 202.634918] WARNING: CPU: 0 PID: 0 at kernel/locking/lockdep.c:2729 trace_hardirqs_on_caller+0x113/0x1b0 [ 202.634919] DEBUG_LOCKS_WARN_ON(current->hardirq_context) [ 202.634929] Modules linked in: snd_hda_intel i915 x86_pkg_temp_thermal intel_powerclamp coretemp crct10dif_pclmul crc32_pclmul ghash_clmulni_intel lpc_ich snd_hda_codec_realtek snd_hda_codec_generic snd_hda_codec_hdmi snd_hda_codec snd_hwdep i2c_designware_platform i2c_designware_core snd_hda_core mei_me mei snd_pcm r8169 mii sdhci_acpi sdhci mmc_core i2c_hid [last unloaded: i915] [ 202.634930] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G U 4.9.0-rc1-CI-CI_DRM_1734+ #1 [ 202.634931] Hardware name: GIGABYTE M4HM87P-00/M4HM87P-00, BIOS F6 12/10/2014 [ 202.634933] ffff88011ea03d68 ffffffff8142dce5 ffff88011ea03db8 0000000000000000 [ 202.634934] ffff88011ea03da8 ffffffff8107e496 00000aa900000002 ffffffff81e249a0 [ 202.634935] ffffffff81815637 ffffffff82e7c280 0000000000000000 0000000000000004 [ 202.634936] Call Trace: [ 202.634939] <IRQ> [ 202.634939] [<ffffffff8142dce5>] dump_stack+0x67/0x92 [ 202.634941] [<ffffffff8107e496>] __warn+0xc6/0xe0 [ 202.634944] [<ffffffff81815637>] ? _raw_spin_unlock_irq+0x27/0x50 [ 202.634945] [<ffffffff8107e4fa>] warn_slowpath_fmt+0x4a/0x50 [ 202.634946] [<ffffffff810d6d83>] trace_hardirqs_on_caller+0x113/0x1b0 [ 202.634948] [<ffffffff810d6e2d>] trace_hardirqs_on+0xd/0x10 [ 202.634949] [<ffffffff81815637>] _raw_spin_unlock_irq+0x27/0x50 [ 202.634951] [<ffffffff81672042>] rtc_handler+0x32/0xa0 [ 202.634954] [<ffffffff814c08a3>] acpi_ev_fixed_event_detect+0xd4/0xfb [ 202.634956] [<ffffffff814c2ccb>] acpi_ev_sci_xrupt_handler+0xf/0x2d [ 202.634957] [<ffffffff814ab3ee>] acpi_irq+0x11/0x2c [ 202.634960] [<ffffffff810e5288>] __handle_irq_event_percpu+0x58/0x370 [ 202.634961] [<ffffffff810e55be>] handle_irq_event_percpu+0x1e/0x50 [ 202.634962] [<ffffffff810e5624>] handle_irq_event+0x34/0x60 [ 202.634963] [<ffffffff810e8906>] handle_fasteoi_irq+0xa6/0x170 [ 202.634966] [<ffffffff8101eef5>] handle_irq+0x15/0x20 [ 202.634967] [<ffffffff8101e548>] do_IRQ+0x68/0x130 [ 202.634968] [<ffffffff81816789>] common_interrupt+0x89/0x89 [ 202.634970] <EOI> [ 202.634970] [<ffffffff81814c73>] ? mwait_idle+0x93/0x210 [ 202.634971] [<ffffffff81814c6a>] ? mwait_idle+0x8a/0x210 [ 202.634972] [<ffffffff81026b0a>] arch_cpu_idle+0xa/0x10 [ 202.634973] [<ffffffff8181509e>] default_idle_call+0x1e/0x30 [ 202.634974] [<ffffffff810cbf6c>] cpu_startup_entry+0x17c/0x1f0 [ 202.634976] [<ffffffff8180ca87>] rest_init+0x127/0x130 [ 202.634978] [<ffffffff81f77f08>] start_kernel+0x3f6/0x403 [ 202.634980] [<ffffffff81f7728f>] x86_64_start_reservations+0x2a/0x2c [ 202.634981] [<ffffffff81f77404>] x86_64_start_kernel+0x173/0x186 [ 202.634982] ---[ end trace 293c99618fa08d34 ]--- Cc: Gabriele Mazzotta <gabriele.mzt@gmail.com> Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com> Fixes: 983bf1256edb ("rtc: cmos: Clear ACPI-driven alarms upon resume") Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-10-19rtc: cmos: remove all __exit_p annotationsLABBE Corentin
I got the following stack trace under qemu: [ 7.575243] BUG: unable to handle kernel NULL pointer dereference at 0000000000000010 [ 7.596098] IP: [<ffffffff814f5b08>] cmos_set_alarm+0x38/0x280 [ 7.615699] PGD 3ccbe067 [ 7.615923] PUD 3daf2067 [ 7.635156] PMD 0 [ 7.654358] Oops: 0000 [#1] SMP [ 7.673869] Modules linked in: [ 7.693235] CPU: 0 PID: 1701 Comm: hwclock Tainted: G W 4.9.0-rc1+ #24 [ 7.712455] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.9.3-0-ge2fc41e-prebuilt.qemu-project.org 04/01/2014 [ 7.753569] task: ffff88003d88dc40 task.stack: ffffc90000224000 [ 7.773743] RIP: 0010:[<ffffffff814f5b08>] [<ffffffff814f5b08>] cmos_set_alarm+0x38/0x280 [ 7.794893] RSP: 0018:ffffc90000227c10 EFLAGS: 00010296 [ 7.815890] RAX: 000000000000001d RBX: ffffc90000227d28 RCX: ffffffff8182be78 [ 7.836057] RDX: 0000000000000001 RSI: 0000000000000202 RDI: 0000000000000202 [ 7.856612] RBP: ffffc90000227c48 R08: 0000000000000000 R09: 0000000000000001 [ 7.877561] R10: 00000000000001c0 R11: 00000000000001c0 R12: 0000000000000000 [ 7.897072] R13: ffff88003d96f400 R14: ffff88003dac6410 R15: ffff88003dac6420 [ 7.917403] FS: 00007f77f42d9700(0000) GS:ffff88003fc00000(0000) knlGS:0000000000000000 [ 7.938293] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 7.958364] CR2: 0000000000000010 CR3: 000000003ccbb000 CR4: 00000000000006f0 [ 7.978028] Stack: [ 7.997120] ffff88003dac6000 ffff88003dac6410 0000000058049d01 ffffc90000227d28 [ 8.016993] ffff88003dac6000 ffff88003dac6410 ffff88003dac6420 ffffc90000227c98 [ 8.039505] ffffffff814f225d 0000001800227c98 000000090000002a 0000000900000011 [ 8.059985] Call Trace: [ 8.080110] [<ffffffff814f225d>] __rtc_set_alarm+0x8d/0xa0 [ 8.099421] [<ffffffff814f2389>] rtc_timer_enqueue+0x119/0x190 [ 8.119925] [<ffffffff814f2e6e>] rtc_update_irq_enable+0xbe/0x100 [ 8.140583] [<ffffffff814f3bb0>] rtc_dev_ioctl+0x3c0/0x480 [ 8.161162] [<ffffffff81146b6a>] ? user_path_at_empty+0x3a/0x50 [ 8.182717] [<ffffffff8114aa36>] do_vfs_ioctl+0x96/0x5c0 [ 8.204624] [<ffffffff8113e066>] ? vfs_stat+0x16/0x20 [ 8.225994] [<ffffffff8113e135>] ? SyS_newstat+0x15/0x30 [ 8.247043] [<ffffffff8114afa7>] SyS_ioctl+0x47/0x80 [ 8.267191] [<ffffffff815f5c77>] entry_SYSCALL_64_fastpath+0x1a/0xa9 [ 8.288719] Code: 6a 81 48 89 e5 41 57 41 56 41 55 49 89 fd 41 54 53 48 89 f3 48 c7 c6 20 c4 78 81 48 83 ec 10 e8 8f 00 ef ff 4d 8b a5 a0 00 00 00 <41> 8b 44 24 10 85 c0 0f 8e 2b 02 00 00 4c 89 ef 31 c0 b9 53 01 [ 8.335233] RIP [<ffffffff814f5b08>] cmos_set_alarm+0x38/0x280 [ 8.357096] RSP <ffffc90000227c10> [ 8.379051] CR2: 0000000000000010 [ 8.401736] ---[ end trace 5cbcd83a1f225ed3 ]--- This occur only when CONFIG_DEBUG_TEST_DRIVER_REMOVE is enabled and CONFIG_RTC_DRV_CMOS builtin. When cmos_set_alarm() is called dev is NULL and so trigger the deref via cmos->irq The problem comes from that the device is removed but no remove function are called due to _exit_p(). This patch remove all _exit_p() annotation. Signed-off-by: Corentin Labbe <clabbe.montjoie@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-10-19rtc: asm9260: fix module autoloadJavier Martinez Canillas
If the driver is built as a module, autoload won't work because the module alias information is not filled so user-space can't match the registered device with the corresponding module. Export the module alias information using the MODULE_DEVICE_TABLE() macro. Before this patch: $ modinfo drivers/rtc/rtc-asm9260.ko | grep alias $ After this patch: $ modinfo drivers/rtc/rtc-asm9260.ko | grep alias alias: of:N*T*Calphascale,asm9260-rtcC* alias: of:N*T*Calphascale,asm9260-rtc Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-10-14Merge tag 'rtc-4.9' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux Pull RTC updates from Alexandre Belloni: "RTC for 4.9 Subsystem: - delete owner assignment in multiple drivers - constify rtc_class_ops structures Drivers: - ac100: support clock-output-names - cmos: properly handle ACPI alarms and quirky BIOSes and other fixes - ds1307: fix century bit support while staying comaptible with previous behaviour by default - ds1347: switch to regmap - isl12057 is now handled by ds1307 - omap: support external wakeup - rv8803: allow to disable voltage drop detection" * tag 'rtc-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux: (25 commits) rtc: rv8803: set VDETOFF and SWOFF via device tree dt/bindings: Add bindings for Micro Crystal rv8803 devicetree: Add Micro Crystal AG vendor id rtc: cmos: avoid unused function warning rtc: ac100: Add NULL checking for devm_kzalloc call rtc: ds1347: changed raw spi calls to register map calls rtc: cmos: Restore alarm after resume rtc: cmos: Clear ACPI-driven alarms upon resume rtc: omap: Support ext_wakeup configuration rtc: cmos: Initialize hpet timer before irq is registered rtc: asm9260: rework locking rtc: asm9260: allow COMPILE_TEST rtc: constify rtc_class_ops structures rtc: ac100: support clock-output-names in device tree binding rtc: rx6110: remove owner assignment rtc: pic32: Delete owner assignment rtc: bq32k: Fix handling of oscillator failure flag rtc: bq32k: Use correct mask name for 'minutes' register. rtc: sysfs: fix a cast removing the const attribute Documentation: dt: Intersil isl12057 is not a trivial device ...
2016-10-12rtc: rv8803: set VDETOFF and SWOFF via device treeOleksij Rempel
There might be designs where the power supply circuit is designed in a way that VDETOFF and SWOFF is required to be set. Otherwise the RTC detects a power loss. Add a device tree interface for this. Signed-off-by: Carsten Resch <Carsten.Resch@de.bosch.com> Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: Oleksij Rempel <fixed-term.Oleksij.Rempel@de.bosch.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-10-04Merge branches 'ib-mfd-gpio-4.9', 'ib-mfd-gpio-regulator-4.9', ↵Lee Jones
'ib-mfd-input-4.9', 'ib-mfd-regulator-4.9', 'ib-mfd-regulator-4.9.1', 'ib-mfd-regulator-rtc-4.9', 'ib-mfd-regulator-rtc-4.9-1' and 'ib-mfd-rtc-4.9' into ibs-for-mfd-merged
2016-09-22rtc: cmos: avoid unused function warningArnd Bergmann
A bug fix for the ACPI side of this driver caused a harmless build warning: drivers/rtc/rtc-cmos.c:1115:13: error: 'cmos_check_acpi_rtc_status' defined but not used [-Werror=unused-function] static void cmos_check_acpi_rtc_status(struct device *dev, We can avoid the warning and simplify the driver at the same time by removing the #ifdef for CONFIG_PM and rely on the SIMPLE_DEV_PM_OPS() to set everything up correctly. cmos_resume() has to get marked as __maybe_unused so we don't introduce another warning, and the two variants of cmos_poweroff() can get merged into one using an IS_ENABLED() check. Fixes: 983bf1256edb ("rtc: cmos: Clear ACPI-driven alarms upon resume") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-09-22rtc: ac100: Add NULL checking for devm_kzalloc callAxel Lin
devm_kzalloc can return NULL, add NULL checking to prevent NULL pointer dereference. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-09-22rtc: ds1347: changed raw spi calls to register map callsRaghavendra Ganiga
This patch changes calls of spi read write calls to register map read and write calls in rtc ds1347 Signed-off-by: Raghavendra Chandra Ganiga <ravi23ganiga@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-09-21rtc: cmos: Restore alarm after resumeGabriele Mazzotta
Some platform firmware may interfere with the RTC alarm over suspend, resulting in the kernel and hardware having different ideas about system state but also potentially causing problems with firmware that assumes the OS will clean this case up. This patch restores the RTC alarm on resume to ensure that kernel and hardware are in sync. The case we've seen is Intel Rapid Start, which is a firmware-mediated feature that automatically transitions systems from suspend-to-RAM to suspend-to-disk without OS involvement. It does this by setting the RTC alarm and a flag that indicates that on wake it should perform the transition rather than re-starting the OS. However, if the OS has set a wakeup alarm that would wake the machine earlier, it refuses to overwrite it and allows the system to wake instead. This fails in the following situation: 1) User configures Intel Rapid Start to transition after (say) 15 minutes 2) User suspends to RAM. Firmware sets the wakeup alarm for 15 minutes in the future 3) User resumes after 5 minutes. Firmware does not reset the alarm, and as such it is still set for 10 minutes in the future 4) User suspends after 5 minutes. Firmware notices that the alarm is set for 5 minutes in the future, which is less than the 15 minute transition threshold. It therefore assumes that the user wants the machine to wake in 5 minutes 5) System resumes after 5 minutes The worst case scenario here is that the user may have put the system in a bag between (4) and (5), resulting in it running in a confined space and potentially overheating. This seems reasonably important. The Rapid Start support code got added in 3.11, but it can be configured in the firmware regardless of kernel support. Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-09-21rtc: cmos: Clear ACPI-driven alarms upon resumeGabriele Mazzotta
Currently ACPI-driven alarms are not cleared when they wake the system. As consequence, expired alarms must be manually cleared to program a new alarm. Fix this by correctly handling ACPI-driven alarms. More specifically, the ACPI specification [1] provides for two alternative implementations of the RTC. Depending on the implementation, the driver either clear the alarm from the resume callback or from ACPI interrupt handler: - The platform has the RTC wakeup status fixed in hardware (ACPI_FADT_FIXED_RTC is 0). In this case the driver can determine if the RTC was the reason of the wakeup from the resume callback by reading the RTC status register. - The platform has no fixed hardware feature event bits. In this case a GPE is used to wake the system and the driver clears the alarm from its handler. [1] http://www.acpi.info/DOWNLOADS/ACPI_5_Errata%20A.pdf Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-09-21rtc: omap: Support ext_wakeup configurationMarcin Niestroj
Support configuration of ext_wakeup sources. This patch makes it possible to enable ext_wakeup and set it's polarity, depending on board configuration. AM335x's dedicated PMIC (tps65217) uses ext_wakeup to notify about power-button presses. Handling power-button presses enables to recover from RTC-only power states correctly. Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-09-20rtc: cmos: Initialize hpet timer before irq is registeredPratyush Anand
We have observed on few x86 machines with rtc-cmos device that hpet_rtc_interrupt() is called just after irq registration and before cmos_do_probe() could call hpet_rtc_timer_init(). So, neither hpet_default_delta nor hpet_t1_cmp is initialized by the time interrupt is raised in the given situation, and this results in NMI watchdog LOCKUP. It has only been observed sporadically on kdump secondary kernels. See the call trace: ---<-snip->--- [ 27.913194] Kernel panic - not syncing: Watchdog detected hard LOCKUP on cpu 0 [ 27.915371] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.0-342.el7.x86_64 #1 [ 27.917503] Hardware name: HP ProLiant DL160 Gen8, BIOS J03 02/10/2014 [ 27.919455] ffffffff8186a728 0000000059c82488 ffff880034e05af0 ffffffff81637bd4 [ 27.921870] ffff880034e05b70 ffffffff8163144a 0000000000000010 ffff880034e05b80 [ 27.924257] ffff880034e05b20 0000000059c82488 0000000000000000 0000000000000000 [ 27.926599] Call Trace: [ 27.927352] <NMI> [<ffffffff81637bd4>] dump_stack+0x19/0x1b [ 27.929080] [<ffffffff8163144a>] panic+0xd8/0x1e7 [ 27.930588] [<ffffffff8111d3e0>] ? restart_watchdog_hrtimer+0x50/0x50 [ 27.932502] [<ffffffff8111d4a2>] watchdog_overflow_callback+0xc2/0xd0 [ 27.934427] [<ffffffff811612c1>] __perf_event_overflow+0xa1/0x250 [ 27.936232] [<ffffffff81161d94>] perf_event_overflow+0x14/0x20 [ 27.937957] [<ffffffff81032ae8>] intel_pmu_handle_irq+0x1e8/0x470 [ 27.939799] [<ffffffff8164164b>] perf_event_nmi_handler+0x2b/0x50 [ 27.941649] [<ffffffff81640d99>] nmi_handle.isra.0+0x69/0xb0 [ 27.943348] [<ffffffff81640f49>] do_nmi+0x169/0x340 [ 27.944802] [<ffffffff816401d3>] end_repeat_nmi+0x1e/0x2e [ 27.946424] [<ffffffff81056ee5>] ? hpet_rtc_interrupt+0x85/0x380 [ 27.948197] [<ffffffff81056ee5>] ? hpet_rtc_interrupt+0x85/0x380 [ 27.949992] [<ffffffff81056ee5>] ? hpet_rtc_interrupt+0x85/0x380 [ 27.951816] <<EOE>> <IRQ> [<ffffffff8108f5a3>] ? run_timer_softirq+0x43/0x340 [ 27.954114] [<ffffffff8111e24e>] handle_irq_event_percpu+0x3e/0x1e0 [ 27.955962] [<ffffffff8111e42d>] handle_irq_event+0x3d/0x60 [ 27.957635] [<ffffffff811210c7>] handle_edge_irq+0x77/0x130 [ 27.959332] [<ffffffff8101704f>] handle_irq+0xbf/0x150 [ 27.960949] [<ffffffff8164a86f>] do_IRQ+0x4f/0xf0 [ 27.962434] [<ffffffff8163faed>] common_interrupt+0x6d/0x6d [ 27.964101] <EOI> [<ffffffff8163f43b>] ? _raw_spin_unlock_irqrestore+0x1b/0x40 [ 27.966308] [<fffff8111ff07>] __setup_irq+0x2a7/0x570 [ 28.067859] [<ffffffff81056e60>] ? hpet_cpuhp_notify+0x140/0x140 [ 28.069709] [<ffffffff8112032c>] request_threaded_irq+0xcc/0x170 [ 28.071585] [<ffffffff814b24a6>] cmos_do_probe+0x1e6/0x450 [ 28.073240] [<ffffffff814b2710>] ? cmos_do_probe+0x450/0x450 [ 28.074911] [<ffffffff814b27cb>] cmos_pnp_probe+0xbb/0xc0 [ 28.076533] [<ffffffff8139b245>] pnp_device_probe+0x65/0xd0 [ 28.078198] [<ffffffff813f8ca7>] driver_probe_device+0x87/0x390 [ 28.079971] [<ffffffff813f9083>] __driver_attach+0x93/0xa0 [ 28.081660] [<ffffffff813f8ff0>] ? __device_attach+0x40/0x40 [ 28.083662] [<ffffffff813f6a13>] bus_for_each_dev+0x73/0xc0 [ 28.085370] [<ffffffff813f86fe>] driver_attach+0x1e/0x20 [ 28.086974] [<ffffffff813f8250>] bus_add_driver+0x200/0x2d0 [ 28.088634] [<ffffffff81ade49a>] ? rtc_sysfs_init+0xe/0xe [ 28.090349] [<ffffffff813f9704>] driver_register+0x64/0xf0 [ 28.091989] [<ffffffff8139b070>] pnp_register_driver+0x20/0x30 [ 28.093707] [<ffffffff81ade4ab>] cmos_init+0x11/0x71 ---<-snip->--- This patch moves hpet_rtc_timer_init() before IRQ registration, so that we can gracefully handle such spurious interrupts. It also masks HPET RTC interrupts, in case IRQ registration fails. We were able to reproduce the problem in maximum 15 trials of kdump secondary kernel boot on an hp-dl160gen8 FCoE host machine without this patch. However, more than 35 trials went fine after applying this patch. Suggested-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Pratyush Anand <panand@redhat.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-09-05rtc: asm9260: rework lockingAlexandre Belloni
The rtc-asm9260 driver uses a discrete spinlock (wrongly uninitialized). Use the rtc mutex to lock mmio accesses instead. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-09-05rtc: asm9260: allow COMPILE_TESTAlexandre Belloni
The rtc-asm9260 driver compiles correctly on other architectures, add COMPILE_TEST to improve code coverage. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-09-02rtc: constify rtc_class_ops structuresJulia Lawall
Check for rtc_class_ops structures that are only passed to devm_rtc_device_register, rtc_device_register, platform_device_register_data, all of which declare the corresponding parameter as const. Declare rtc_class_ops structures that have these properties as const. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r disable optional_qualifier@ identifier i; position p; @@ static struct rtc_class_ops i@p = { ... }; @ok@ identifier r.i; expression e1,e2,e3,e4; position p; @@ ( devm_rtc_device_register(e1,e2,&i@p,e3) | rtc_device_register(e1,e2,&i@p,e3) | platform_device_register_data(e1,e2,e3,&i@p,e4) ) @bad@ position p != {r.p,ok.p}; identifier r.i; @@ i@p @depends on !bad disable optional_qualifier@ identifier r.i; @@ static +const struct rtc_class_ops i = { ... }; // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Baruch Siach <baruch@tkos.co.il> Acked-by: Hans Ulli Kroll <ulli.kroll@googlemail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-08-31rtc: ac100: support clock-output-names in device tree bindingChen-Yu Tsai
The ac100 device tree binding specifies the usage of clock-output-names to specify the names of its 3 clock outputs. This is needed for orphan clock resolution, when the ac100 is probed much later than any clocks that consume any of its outputs. This wasn't supported by the driver. Add support for this. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-08-31rtc: rx6110: remove owner assignmentAlexandre Belloni
.owner is already set by the spi core. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-08-31rtc: pic32: Delete owner assignmentMarkus Elfring
The field "owner" is set by core. Thus delete an extra initialisation. Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-08-31rtc: bq32k: Fix handling of oscillator failure flagJan Östlund
While the oscillator failure flag is set, the RTC registers should be considered invalid. bq32k_rtc_read_time() now returns an error instead of an invalid time. The failure flag is cleared the next time the clock is set. Signed-off-by: Jan Östlund <jao@hms.se> Signed-off-by: Daniel Romell <daro@hms.se> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-08-31rtc: bq32k: Use correct mask name for 'minutes' register.Jan Östlund
The BQ32K_SECONDS_MASK and BQ32K_MINUTES_MASK both has the same value. This is no functional change. Signed-off-by: Jan Östlund <jao@hms.se> Signed-off-by: Daniel Romell <daro@hms.se> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-08-31rtc: sysfs: fix a cast removing the const attributeLABBE Corentin
The char pointer buf_ptr is assigned an address from a const char pointer buf (parameter of wakealarm_store). The data pointer by buf_ptr is never modified. So casting it to a (char *) is useless. This patch remove this cast, and transform buf_ptr to a const char pointer. Signed-off-by: LABBE Corentin <clabbe.montjoie@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-08-31rtc: isl12057: remove driverAlexandre Belloni
The Intersil isl12057 is now supported by the ds1307 driver. Acked-by: Arnaud Ebalard <arno@natisbad.org> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-08-31rtc: ds1307: add Intersil ISL12057 supportAlexandre Belloni
Intersil ISL12057 is a drop-in replacement for DS1337. It can be supported by the ds1307 driver. Acked-by: Arnaud Ebalard <arno@natisbad.org> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-08-31rtc: ds1307: fix century bit supportAlexandre Belloni
Add an option to properly support the century bit of ds1337 and compatibles and ds1340. Because the driver had a bug until now, it is not possible to switch users to the fixed code directly as RTCs in the field will wrongly have the century bit set. Acked-by: Arnaud Ebalard <arno@natisbad.org> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-08-31rtc: pcf2123: Add missing error code assignment before testChristophe JAILLET
It is likely that checking the result of 'pcf2123_write_reg' is expected here. Also fix a small style issue. The '{' at the beginning of the function is misplaced. Fixes: 809b453b76e15 ("rtc: pcf2123: clean up writes to the rtc chip") Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-08-31rtc: Kconfig: Name RK818 in Kconfig for RTC_DRV_RK808Wadim Egorov
The RK808 and RK818 PMICs are using a similar register map. We can reuse the rtc driver for the RK818 PMIC. So let's add the RK818 in the Kconfig description. Signed-off-by: Wadim Egorov <w.egorov@phytec.de> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2016-08-31rtc: rtc-pm8xxx: Add support for pm8018 rtcNeil Armstrong
In order to support RTC on Qualcomm MDM9615 SoC, add support for the pm8018 rtc in rtc-pm8xxx driver. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Reviewed-by: Bjorn Andersson <bjorn.andersson@linaro.org> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2016-08-08rtc: ac100: Add clk output supportChen-Yu Tsai
The AC100's RTC side has 3 clock outputs on external pins, which can provide a clock signal to the SoC or other modules, such as WiFi or GSM modules. Support this with a custom clk driver integrated with the rtc driver. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2016-08-08rtc: ac100: Add RTC driver for X-Powers AC100Chen-Yu Tsai
X-Powers AC100 is a codec / RTC combo chip. This driver supports the RTC sub-device. The RTC block also has clock outputs and non-volatile storage. Non-volatile storage wthin the RTC hardware is not supported. Clock output support is added in the next patch. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2016-08-05Merge tag 'rtc-4.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux Pull RTC updates from Alexandre Belloni: "RTC for 4.8 Cleanups: - huge cleanup of rtc-generic and char/genrtc this allowed to cleanup rtc-cmos, rtc-sh, rtc-m68k, rtc-powerpc and rtc-parisc - move mn10300 to rtc-cmos Subsystem: - fix wakealarms after hibernate - multiples fixes for rctest - simplify implementations of .read_alarm New drivers: - Maxim MAX6916 Drivers: - ds1307: fix weekday - m41t80: add wakeup support - pcf85063: add support for PCF85063A variant - rv8803: extend i2c fix and other fixes - s35390a: fix alarm reading, this fixes instant reboot after shutdown for QNAP TS-41x - s3c: clock fixes" * tag 'rtc-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux: (65 commits) rtc: rv8803: Clear V1F when setting the time rtc: rv8803: Stop the clock while setting the time rtc: rv8803: Always apply the I²C workaround rtc: rv8803: Fix read day of week rtc: rv8803: Remove the check for valid time rtc: rv8803: Kconfig: Indicate rx8900 support rtc: asm9260: remove .owner field for driver rtc: at91sam9: Fix missing spin_lock_init() rtc: m41t80: add suspend handlers for alarm IRQ rtc: m41t80: make it a real error message rtc: pcf85063: Add support for the PCF85063A device rtc: pcf85063: fix year range rtc: hym8563: in .read_alarm set .tm_sec to 0 to signal minute accuracy rtc: explicitly set tm_sec = 0 for drivers with minute accurancy rtc: s3c: Add s3c_rtc_{enable/disable}_clk in s3c_rtc_setfreq() rtc: s3c: Remove unnecessary call to disable already disabled clock rtc: abx80x: use devm_add_action_or_reset() rtc: m41t80: use devm_add_action_or_reset() rtc: fix a typo and reduce three empty lines to one rtc: s35390a: improve two comments in .set_alarm ...
2016-07-28rtc: rv8803: Clear V1F when setting the timeBenoît Thébaudeau
V1F indicates that the time accuracy may have been compromised because of a voltage drop (possibly only temporary) below VLOW1, which stops the temperature compensation. When the time is set, the accuracy is restored, so V1F should be cleared in order to indicate this and to be able to detect the next temperature compensation loss. This is the same principle as for V2F, which is cleared when the time is set to indicate that the time is no longer invalid and to be able to detect the next data loss. Signed-off-by: Benoît Thébaudeau <benoit@wsystem.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-07-28rtc: rv8803: Stop the clock while setting the timeBenoît Thébaudeau
According to the application manual of the RX8900, the RESET bit must be set to 1 to prevent a timer update while setting the time. This also resets the subsecond counter. The application manual of the RV-8803 does not mention such a requirement, and it says that the 100th Seconds register is cleared when writing to the Seconds register, but using the RESET bit for the RV-8803 too should not be an issue and is probably safer. This change also ensures that the RESET bit is initialized properly in all cases. Indeed, all the registers must be initialized if the voltage has been lower than VLOW2 (triggering V2F), but not low enough to trigger a POR. Signed-off-by: Benoît Thébaudeau <benoit@wsystem.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-07-28rtc: rv8803: Always apply the I²C workaroundBenoît Thébaudeau
The I²C NACK issue of the RV-8803 may occur after any I²C START condition, depending on the timings. Consequently, the workaround must be applied for all the I²C transfers. This commit abstracts the I²C transfer code into register access functions. This avoids duplicating the I²C workaround everywhere. This also avoids the duplication of the code handling the return value of i2c_smbus_read_i2c_block_data(). Error messages are issued in case of definitive register access failures (if the workaround fails). This change also makes the I²C transfer return value checks consistent. Signed-off-by: Benoît Thébaudeau <benoit@wsystem.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-07-28rtc: rv8803: Fix read day of weekBenoît Thébaudeau
The Weekday register is encoded as 2^tm_wday, with tm_wday in 0..6, so using tm_wday = ffs(reg) to fill tm_wday from the register value is wrong because this gives the expected value + 1. This could be fixed as tm_wday = ffs(reg) - 1, but tm_wday = ilog2(reg) works as well and is more direct. Signed-off-by: Benoît Thébaudeau <benoit@wsystem.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-07-28rtc: rv8803: Remove the check for valid timeBenoît Thébaudeau
The RTC core always calls rtc_valid_tm() after ->read_time() in case of success (in __rtc_read_time()), so do not call it twice. Signed-off-by: Benoît Thébaudeau <benoit@wsystem.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-07-28rtc: rv8803: Kconfig: Indicate rx8900 supportBenoît Thébaudeau
This driver supports the Epson RX8900, but this was not indicated in Kconfig. Signed-off-by: Benoît Thébaudeau <benoit@wsystem.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-07-27rtc: asm9260: remove .owner field for driverWei Yongjun
Remove .owner field if calls are used which set it automatically. Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci Signed-off-by: Wei Yongjun <weiyj.lk@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-07-26rtc: at91sam9: Fix missing spin_lock_init()Wei Yongjun
The driver allocates the spinlock but not initialize it. Use spin_lock_init() on it to initialize it correctly. This is detected by Coccinelle semantic patch. Signed-off-by: Wei Yongjun <weiyj.lk@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-07-21rtc: m41t80: add suspend handlers for alarm IRQStefan Christ
Allow the alarm IRQ of RTC to be used as a wakeup source for the system suspend. Signed-off-by: Stefan Christ <s.christ@phytec.de> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-07-21rtc: m41t80: make it a real error messageStefan Christ
It should be a real error message, when the driver cannot enable the IRQ of the device. Signed-off-by: Stefan Christ <s.christ@phytec.de> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-07-19rtc: pcf85063: Add support for the PCF85063A deviceChris DeBruin
The current rtc-pcf85063 driver only supports the PCF85063TP device. Using the existing driver on a PCF85063A will result in the time being set correctly into the RTC, but the RTC is held in the stopped state. Therefore, the time will no longer advance and no error is indicated. The PCF85063A device has a bigger memory map than the PCF85063TP. The existing driver make use of an address rollover condition, but the rollover point is different in the two devices. Signed-off-by: Chris DeBruin <cdeb5783@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-07-19rtc: pcf85063: fix year rangeAlexandre Belloni
The year range is not validated properly As the driver has been mainlined in 2014, it is not an issue to stop handling dates between 1970 and 2000 with the benefit of handling dates up to 2100. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-07-19rtc: hym8563: in .read_alarm set .tm_sec to 0 to signal minute accuracyUwe Kleine-König
Set .tm_sec to 0 instead of -1 to signal minute accuracy. Signed-off-by: Uwe Kleine-König <uwe@kleine-koenig.org> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
