path: root/drivers/s390/block/dasd_devmap.c
2013-08-22s390: replace strict_strtoul() with kstrtoul()Jingoo Han
The usage of strict_strtoul() is not preferred, because strict_strtoul() is obsolete. Thus, kstrtoul() should be used. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-01s390/dasd: Add 'timeout' attributeHannes Reinecke
This patch adds a 'timeout' attibute to the DASD driver. When set to non-zero, the blk_timeout function will be enabled with the timeout specified in the attribute. Setting 'timeout' to '0' will disable block timeouts. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-01s390/dasd: make number of retries configurableHannes Reinecke
Instead of having the number of retries hard-coded in the various functions we should be using a default retry value, which can be modified via sysfs. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-04-17s390/dasd: remove cast for kzalloc return valueZhang Yanfei
remove cast for kzalloc return value. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 update from Martin Schwidefsky: "Add support to generate code for the latest machine zEC12, MOD and XOR instruction support for the BPF jit compiler, the dasd safe offline feature and the big one: the s390 architecture gets PCI support!! Right before the world ends on the 21st ;-)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (41 commits) s390/qdio: rename the misleading PCI flag of qdio devices s390/pci: remove obsolete email addresses s390/pci: speed up __iowrite64_copy by using pci store block insn s390/pci: enable NEED_DMA_MAP_STATE s390/pci: no msleep in potential IRQ context s390/pci: fix potential NULL pointer dereference in dma_free_seg_table() s390/pci: use kmem_cache_zalloc instead of kmem_cache_alloc/memset s390/bpf,jit: add support for XOR instruction s390/bpf,jit: add support MOD instruction s390/cio: fix pgid reserved check vga: compile fix, disable vga for s390 s390/pci: add PCI Kconfig options s390/pci: s390 specific PCI sysfs attributes s390/pci: PCI hotplug support via SCLP s390/pci: CHSC PCI support for error and availability events s390/pci: DMA support s390/pci: PCI adapter interrupts for MSI/MSI-X s390/bitops: find leftmost bit instruction support s390/pci: CLP interface s390/pci: base support ...
2012-11-30s390/dasd: add safe offline interfaceStefan Haberland
The regular behavior of the DASD device driver when setting a device offline is to return all outstanding I/O as failed. This behavior is different from that of other System z operating systems and may lead to unexpected data loss. Adding an explicit 'safe' offline function will allow customers to use DASDs in the way they expect them to work. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-11-19Fix misspellings of "whether" in comments.Adam Buchbinder
"Whether" is misspelled in various comments across the tree; this fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-07-20s390/comments: unify copyright messages and remove file namesHeiko Carstens
Remove the file name from the comment at top of many files. In most cases the file name was wrong anyway, so it's rather pointless. Also unify the IBM copyright statement. We did have a lot of sightly different statements and wanted to change them one after another whenever a file gets touched. However that never happened. Instead people start to take the old/"wrong" statements to use as a template for new files. So unify all of them in one go. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2011-04-20[S390] dasd: fix race between open and offlineStefan Weinhuber
The dasd_open function uses the private_data pointer of the gendisk to find the dasd_block structure that matches the gendisk. When a DASD device is set offline, we set the private_data pointer of the gendisk to NULL and later remove the dasd_block structure, but there is still a small race window, in which dasd_open could first read a pointer from the private_data field and then try to use it, after the structure has already been freed. To close this race window, we will store a pointer to the dasd_devmap structure of the base device in the private_data field. The devmap entries are not deleted, and we already have proper locking and reference counting in place, so that we can safely get from a devmap pointer to the dasd_device and dasd_block structures of the device. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] dasd: Add support for raw ECKD access.Stefan Haberland
Normal I/O operations through the DASD device driver give only access to the data fields of an ECKD device even for track based I/O. This patch extends the DASD device driver to give access to whole ECKD tracks including count, key and data fields. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] dasd: Improve handling of stolen DASD reservationStefan Weinhuber
If a DASD device has been reserved by a Linux system, and later this reservation is ‘stolen’ by a second system by means of an unconditional reserve, then the first system receives a notification about this fact. With this patch such an event can be either ignored, as before, or it can be used to let the device fail all I/O request, so that the device will not block anymore. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] dasd: do path verification for paths added at runtimeStefan Weinhuber
When a new path is added at runtime, the CIO layer will call the drivers path_event callback. The DASD device driver uses this callback to trigger a path verification for the new path. The driver will use only those paths for I/O, which have been successfully verified. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-08-09[S390] dasd: tunable missing interrupt handlerStefan Haberland
This feature provides a user interface to specify the timeout for missing interrupts for standard I/O operations. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-07-19[S390] add missing device putStefan Haberland
The dasd_alias_show function does not return a device reference in case the device is an alias. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-05-17[S390] dasd: remove uid from devmapStefan Haberland
Remove the duplicate of the DASD uid from the devmap structure. Use the uid from the device private structure instead. This also removes a lockdep warning complaining about a possible SOFTIRQ-safe -> SOFTIRQ-unsafe lock order. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08[S390] dasd: automatic recognition of read-only devicesStefan Weinhuber
In z/VM it is possible to attach a device as read-only. To prevent unintentional write requests and subsequent I/O errors, we can detect this configuration using the z/VM DIAG 210 interface and set the respective linux block device to read-only as well. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-02-26[S390] dasd: fix refcounting.Stefan Haberland
The function dasd_device_from_cdev returns a reference to the dasd device and increases the refcount by one. If an exception occurs, the refcount was not decreased in all cases e.g. in dasd_discipline_show. Prevent the offline processing from hang by correcting two functions to decrease the refcount even if an error occured. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-06-16[S390] pm: dasd power management callbacks.Stefan Haberland
Introduce the power management callbacks to the dasd driver. On suspend the dasd devices are stopped and removed from the focus of alias management. On resume they are reinitialized by rereading the device characteristics and adding the device to the alias management. In case the device has gone away during suspend it will caught in the suspend state with stopped flag set to UNRESUMED. After it appears again the restore function is called again. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-03-26[S390] dasd: message cleanupStefan Haberland
Moved some Messages into s390 debug feature and changed remaining messages to use the dev_xxx and pr_xxx macros. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-03-26[S390] dasd: add High Performance FICON supportStefan Weinhuber
To support High Performance FICON, the DASD device driver has to translate I/O requests into the new transport mode control words (TCW) instead of the traditional (command mode) CCW requests. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-02-11[S390] dasd: bus_id -> dev_name() conversion.Cornelia Huck
bus_id usage crept in again; fix it. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-09[S390] dasd: add device attribute to disable blocking on lost pathsHolger Smolinski
When the connection between host and storage server is lost, the dasd device driver usually blocks all I/O on affected devices and waits for them to reappear. In some setups however it would be better if the I/O is returned as error so that device can be recovered by some other means, eg. in a raid or multipath setup. Signed-off-by: Holger Smolinski <Holger.Smolinski@de.ibm.com> Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] dasd: Use accessors instead of using driver_data directly.Cornelia Huck
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-10[S390] bus_id -> dev_name conversionsKay Sievers
bus_id -> dev_name() conversions in s390 code. [cornelia.huck@de.ibm.com: minor adaptions] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-08-01[S390] dasd: Add support for enhanced VM UIDStefan Weinhuber
When z/VM provides two virtual devices (minidisks) that reside on the same real device, both will receive the configuration data from the real device and thus get the same uid. To fix this problem, z/VM provides an additional configuration data record that allows to distinguish between minidisks. z/VM APAR VM64273 needs be installed so this fix has an effect. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-05-15[S390] dasd: Use const in busid functions.Cornelia Huck
We should use 'const char *' in the busid functions since the strings are not modified anyway. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-26[S390] dasd: add hyper PAV support to DASD device driver, part 1Stefan Weinhuber
Parallel access volumes (PAV) is a storage server feature, that allows to start multiple channel programs on the same DASD in parallel. It defines alias devices which can be used as alternative paths to the same disk. With the old base PAV support we only needed rudimentary functionality in the DASD device driver. As the mapping between base and alias devices was static, we just had to export an identifier (uid) and could leave the combining of devices to external layers like a device mapper multipath. Now hyper PAV removes the requirement to dedicate alias devices to specific base devices. Instead each alias devices can be combined with multiple base device on a per request basis. This requires full support by the DASD device driver as now each channel program itself has to identify the target base device. The changes to the dasd device driver and the ECKD discipline are: - Separate subchannel device representation (dasd_device) from block device representation (dasd_block). Only base devices are block devices. - Gather information about base and alias devices and possible combinations. - For each request decide which dasd_device should be used (base or alias) and build specific channel program. - Support summary unit checks, which allow the storage server to upgrade / downgrade between base and hyper PAV at runtime (support is mandatory). Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] dasd: Add ipldev parameter.Peter Oberparleiter
Specifying 'ipldev' in the dasd= kernel parameter will automatically activate the boot device for use by the dasd driver. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] dasd: Add sysfs attribute status and generate uevents.Horst Hummel
This patch adds a sysfs-attribute 'status' to make the DASD device-status accessible from user-space. In addition, the DASD driver generates an uevent(CHANGE) for the ccw-device on each device-status change. This enables user-space applications (e.g. udev) to do related processing. Signed-off-by: Horst Hummel <horst.hummel@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-02-05[S390] Avoid excessive inlining.Heiko Carstens
2006-12-08[S390] New DASD feature for ERP related loggingHorst Hummel
It is now possible to enable/disable ERP related logging without re-compile and re-ipl. A additional sysfs-attribute 'erplog' allows to switch the logging non-interruptive. Signed-off-by: Horst Hummel <horst.hummel@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-04[S390] return 'count' for successful execution of dasd_eer_enable.Horst Hummel
Currently the return value of 'dasd_eer_enable' is returned - even if the function returned '0'. Now return 'count' for successful execution. Signed-off-by: Horst Hummel <horst.hummel@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-04[S390] handle incorrect values when writing to dasd sysfs attributes.Horst Hummel
When writing to dasd attributes (e.g. readonly), all values besides '1' are handled like '0'. Other sysfs-attributes like 'online' are checking for '1' and for '0' and do not accept other values. Therefore enhanced checking and error handling in dasd_devmap attribute store functions. Signed-off-by: Horst Hummel <horst.hummel@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-09-20[S390] Replace nopav-message on VM.Peter Oberparleiter
Specifying kernel parameter "dasd=nopav" on systems running under VM has no function but results in message "disable PAV mode". Correct message is "'nopav' not supported on VM". Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-09-20[S390] dasd deadlock after state change pending interrupt.Martin Schwidefsky
The dasd_device_from_cdev function is called from interrupt context to get the struct dasd_device associated with a ccw device. The driver_data of the ccw device points to the dasd_devmap structure which contains the pointer to the dasd_device structure. The lock that protects the dasd_devmap structure is acquire with out irqsave. To prevent the deadlock in dasd_device_from_cdev if it is called from interrupt context the dependency to the dasd_devmap structure needs to be removed. Let the driver_data of the ccw device point to the dasd_device structure directly and use the ccw device lock to protect the access. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-08-24[S390] dasd PAV enabling.Horst Hummel
The subsystem check in the PAV code is incorrect, it enables PAV per device instead of per subsystem. Signed-off-by: Horst Hummel <horst.hummel@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-08-16[S390] inaccessible PAV alias devices on LPAR.Peter Oberparleiter
In some situations PAV alias devices on LPAR are not accessible. The initialization procedure required to enable access to PAV alias devices has to be performed per storage server subsystem and not only once per storage server. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-08-16[S390] dasd slab cache alignment.Heiko Carstens
The dasd_page_cache should return page addresses and therefore the cache must be created with an alignment of PAGE_SIZE. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-08-10[S390] dasd calls kzalloc while holding a spinlock.Horst Hummel
The dasd function dasd_set_uid calls kzalloc while holding the dasd_devmap_lock. Rearrange the code to do the memory allocation outside the lock. Signed-off-by: Horst Hummel <horst.hummel@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-07-12[S390] Fix sparse warnings.Heiko Carstens
2006-06-29[S390] add PAV support to the dasd driver.Horst Hummel
Add support for parallel-access-volumes to the dasd driver. This allows concurrent access to dasd devices with multiple channel programs. Signed-off-by: Horst Hummel <horst.hummel@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-06-29[S390] dasd whitespace and other cosmetics.Horst Hummel
Dasd code cleanup: 1) remove white space, 2) remove the emacs override sections, and 3) use kzalloc instead of kmalloc. Signed-off-by: Horst Hummel <horst.hummel@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-04-28[PATCH] s390: dasd device identifiersHorst Hummel
Generate new sysfs-attribute 'uid' that contains an device specific unique identifier. This can be used to identity multiple ALIASES of the same physical device (PAV). In addition the sysfs-attributes 'vendor' (containing the manufacturer of the device) and 'alias' (identify alias or base device) is added. This is first part of PAV support in LPAR (also valid on zVM). Signed-off-by: Horst Hummel <horst.hummel@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26BUG_ON() Conversion in drivers/s390/block/dasd_devmap.cEric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
