There are several s390 diagnose calls, which must be executed below the
2GB memory boundary. In order to enforce this, those diagnoses must be
compiled into the kernel. Currently diag 14 can be called within the
vmur kernel module from addresses above 2GB. This leads to specification
exceptions. This patch moves diag10, diag14 and diag210 into the new
diag.c file.
Signed-off-by: Michael Holzheu <holzheu@de.ibm.com>
The function shouldn't have existed in the first place (not MSS-aware).
Introduce a new function ccw_device_get_id() that extracts the
ccw_dev_id structure of a ccw device and convert all users of
_ccw_device_get_device_number to ccw_device_get_id.
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
gcc incorrectly removes initialization of register 0 in dasd diag
inline assembly. Use different register to work around this compiler
bug.
Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com>
Right now ->flags is a bit of a mess: some are request types, and
others are just modifiers. Clean this up by splitting it into
->cmd_type and ->cmd_flags. This allows introduction of generic
Linux block message types, useful for sending generic Linux commands
to block devices.
Signed-off-by: Jens Axboe <axboe@suse.de>
Major cleanup of all s390 inline assemblies. They now have a common
coding style. Quite a few have been shortened, mainly by using register
asm variables. Use of the EX_TABLE macro helps as well. The atomic ops,
bit ops and locking inlines new use the Q-constraint if a newer gcc
is used. That results in slightly better code.
Thanks to Christian Borntraeger for proof reading the changes.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Dasd code cleanup: 1) remove white space, 2) remove the emacs override
sections, and 3) use kzalloc instead of kmalloc.
Signed-off-by: Horst Hummel <horst.hummel@de.ibm.com>
- Remove all CVS generated information like e.g. revision IDs from
drivers/s390 and include/asm-s390 (none present in arch/s390).
- Add newline at end of arch/s390/lib/Makefile to avoid diff message.
Acked-by: Andreas Herrmann <aherrman@de.ibm.com>
Acked-by: Frank Pavlic <pavlic@de.ibm.com>
Sanitize some s390 Kconfig options. We have ARCH_S390, ARCH_S390X,
ARCH_S390_31, 64BIT, S390_SUPPORT and COMPAT. Replace these 6 options by
S390, 64BIT and COMPAT.
To properly support multipath-failover handling, the linux block layer has
introduced a special request flag, 'REQ_FAILFAST'. This flag is now used to
return requests immediately in case the device is not operational.
Moved definition of CMS volume label to vtoc.h and modify partitions/ibm.c to
use this volume label definition instead of anonymous array.
Access to FBA disks via DIAG fails for block sizes > 512 byte. The device
analysis code of the DIAG discipline does not properly initialize the DIAG250
device environment after completion of the analysis. This results in VM only
serving 512 bytes per block I/O request whereas Linux expects larger block
sizes. Add proper device environment setup to end of analysis code.
Future versions of gcc may remove initialization code for control blocks used
by the diag250 inline assembly due to incompletely specified constraints.
This may lead to erratic behavior. Fix the diag250 inline assembly
constraints.
Add support for diag 250 access to dasd devices for 64 bit kernels. In
addition fix detach/attach for diag disks. The VM control block needs to get
recreated by a call to mdsk_init_io.
infrastructure for it.
Let it rip!
