path: root/drivers/s390/char/sclp_config.c
2013-08-22s390/sclp: reword cpu capability change messageHeiko Carstens
Change wording for the cpu capabiity changed message: If such an event occurs it only means that a cpu capability *may* have changed. A cpu capability change event may also occur for other reasons. Also change the severity of the message from warning to informational. If such an event happens user space should into /proc/sysinfo and verify if some capability values changed, if that is of interest. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-07-20s390/comments: unify copyright messages and remove file namesHeiko Carstens
Remove the file name from the comment at top of many files. In most cases the file name was wrong anyway, so it's rather pointless. Also unify the IBM copyright statement. We did have a lot of sightly different statements and wanted to change them one after another whenever a file gets touched. However that never happened. Instead people start to take the old/"wrong" statements to use as a template for new files. So unify all of them in one go. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2011-12-21cpu: convert 'cpu' and 'machinecheck' sysdev_class to a regular subsystemKay Sievers
This moves the 'cpu sysdev_class' over to a regular 'cpu' subsystem and converts the devices to regular devices. The sysdev drivers are implemented as subsystem interfaces now. After all sysdev classes are ported to regular driver core entities, the sysdev implementation will be entirely removed from the kernel. Userspace relies on events and generic sysfs subsystem infrastructure from sysdev devices, which are made available with this conversion. Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Borislav Petkov <bp@amd64.org> Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Cc: Len Brown <lenb@kernel.org> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Dave Jones <davej@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-23[S390] sclp: remove unnecessary sendmask checkHeiko Carstens
The sendmask check is not needed. Remove it. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] prevent unneccesary loops_per_jiffy recalculationHeiko Carstens
When the seqfile /proc/cpuinfo gets accesses for each possible cpu loops_per_jiffy gets recalculated. However its value is only needed on first access. In addition loops_per_jiffy should be recalculated when the machine reports a capability change. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] convert sclp printks to pr_xxx macros.Martin Schwidefsky
2008-08-01[S390] dont use kthread for smp_rescan_cpus().Heiko Carstens
Since git commit 3da1c84c00c7e5fa8348336bd8c342f9128b0f14 "workqueues: make get_online_cpus() useable for work->func()" it is safe to call get_online_cpus() from workqueue context. So remove the kthread workaround again. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-07-14[S390] Cleanup sclp printk messages.Martin Schwidefsky
Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-07-14[S390] sclp: fix possible deadlock on cpu rescan.Heiko Carstens
smp_rescan_cpus() calls get_online_cpus() from a multithreaded workqueue context. This may deadlock. This is the same bug as in arch/s390/kernel/topology.c. This patch can be reverted as soon as Oleg's patch gets merged. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-05-30[S390] Fix section mismatch warnings.Heiko Carstens
This fixes the last remaining section mismatch warnings in s390 architecture code. It reveals also a real bug introduced by... me with git commit 2069e978d5a6e7b45d58027e3de7f879b8c5e488 ("[S390] sparsemem vmemmap: initialize memmap.") Calling the generic vmemmap_alloc_block() function to get initialized memory is a nice idea, however that function is __meminit annotated and therefore the function might be gone if we try to call it later. This can happen if a DCSS segment gets added. So basically revert the patch and clear the memmap explicitly to fix the original bug. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-04-30[S390] Automatically detect added cpus.Heiko Carstens
2008-02-19[S390] sclp: clean up send/receive naming schemePeter Oberparleiter
Make state change events adjust the correct mask by cleaning up naming inconsistencies. Also remove chance for lockup by removing unnecessary mask related check before reading events. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-25cpu-hotplug: replace lock_cpu_hotplug() with get_online_cpus()Gautham R Shenoy
Replace all lock_cpu_hotplug/unlock_cpu_hotplug from the kernel and use get_online_cpus and put_online_cpus instead as it highlights the refcount semantics in these operations. The new API guarantees protection against the cpu-hotplug operation, but it doesn't guarantee serialized access to any of the local data structures. Hence the changes needs to be reviewed. In case of pseries_add_processor/pseries_remove_processor, use cpu_maps_update_begin()/cpu_maps_update_done() as we're modifying the cpu_present_map there. Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-04-27[S390] Processor degradation notification.Heiko Carstens
Generate uevents for all cpus if cpu capability changes. This can happen e.g. because the cpus are overheating. The cpu capability can be read via /sys/devices/system/cpu/cpuN/capability. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
