path: root/drivers/s390/char/sclp_config.c
2008-12-25[S390] convert sclp printks to pr_xxx macros.Martin Schwidefsky
2008-08-01[S390] dont use kthread for smp_rescan_cpus().Heiko Carstens
Since git commit 3da1c84c00c7e5fa8348336bd8c342f9128b0f14 "workqueues: make get_online_cpus() useable for work->func()" it is safe to call get_online_cpus() from workqueue context. So remove the kthread workaround again. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-07-14[S390] Cleanup sclp printk messages.Martin Schwidefsky
Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-07-14[S390] sclp: fix possible deadlock on cpu rescan.Heiko Carstens
smp_rescan_cpus() calls get_online_cpus() from a multithreaded workqueue context. This may deadlock. This is the same bug as in arch/s390/kernel/topology.c. This patch can be reverted as soon as Oleg's patch gets merged. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-05-30[S390] Fix section mismatch warnings.Heiko Carstens
This fixes the last remaining section mismatch warnings in s390 architecture code. It reveals also a real bug introduced by... me with git commit 2069e978d5a6e7b45d58027e3de7f879b8c5e488 ("[S390] sparsemem vmemmap: initialize memmap.") Calling the generic vmemmap_alloc_block() function to get initialized memory is a nice idea, however that function is __meminit annotated and therefore the function might be gone if we try to call it later. This can happen if a DCSS segment gets added. So basically revert the patch and clear the memmap explicitly to fix the original bug. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-04-30[S390] Automatically detect added cpus.Heiko Carstens
2008-02-19[S390] sclp: clean up send/receive naming schemePeter Oberparleiter
Make state change events adjust the correct mask by cleaning up naming inconsistencies. Also remove chance for lockup by removing unnecessary mask related check before reading events. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-25cpu-hotplug: replace lock_cpu_hotplug() with get_online_cpus()Gautham R Shenoy
Replace all lock_cpu_hotplug/unlock_cpu_hotplug from the kernel and use get_online_cpus and put_online_cpus instead as it highlights the refcount semantics in these operations. The new API guarantees protection against the cpu-hotplug operation, but it doesn't guarantee serialized access to any of the local data structures. Hence the changes needs to be reviewed. In case of pseries_add_processor/pseries_remove_processor, use cpu_maps_update_begin()/cpu_maps_update_done() as we're modifying the cpu_present_map there. Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-04-27[S390] Processor degradation notification.Heiko Carstens
Generate uevents for all cpus if cpu capability changes. This can happen e.g. because the cpus are overheating. The cpu capability can be read via /sys/devices/system/cpu/cpuN/capability. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
