path: root/drivers/s390/char/tape_block.c
2011-05-23[S390] Remove tape block device driver.Heiko Carstens
Remove the tape block device driver. It's not of real use but has already created some confusion when users wanted to access tape devices and used the block device nodes instead of the character device nodes. Also remove the whole tape documentation since it's completely outdated and we have the device drivers book which is the place where everything is properly documented. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-04-21block: unexport DISK_EVENT_MEDIA_CHANGE for legacy/fringe driversTejun Heo
In-kernel disk event polling doesn't matter for legacy/fringe drivers and may lead to infinite event loop if ->check_events() implementation generates events on level condition instead of edge. Now that block layer supports suppressing exporting unlisted events, simply leaving disk->events cleared allows these drivers to keep the internal revalidation behavior intact while avoiding weird interactions with userland event handler. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10Merge branch 'for-2.6.39/stack-plug' into for-2.6.39/coreJens Axboe
Conflicts: block/blk-core.c block/blk-flush.c drivers/md/raid1.c drivers/md/raid10.c drivers/md/raid5.c fs/nilfs2/btnode.c fs/nilfs2/mdt.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-09s390/tape_block: Convert to bdops->check_events()Tejun Heo
Convert from ->media_changed() to ->check_events(). s390/tape_block buffers media changed state and clears it on revalidation. It will behave correctly with kernel event polling. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com>
2010-12-24s390: don't use flush_scheduled_work()Tejun Heo
flush_scheduled_work() is deprecated and scheduled to be removed. * tape_3590: Create and use tape_3590_wq instead of the system_wq. * tape_block: Directly flush requeue_task on cleanup instead of using flush_scheduled_work(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux390@de.ibm.com Cc: linux-s390@vger.kernel.org
2010-10-05block: autoconvert trivial BKL users to private mutexArnd Bergmann
The block device drivers have all gained new lock_kernel calls from a recent pushdown, and some of the drivers were already using the BKL before. This turns the BKL into a set of per-driver mutexes. Still need to check whether this is safe to do. file=$1 name=$2 if grep -q lock_kernel ${file} ; then if grep -q 'include.*linux.mutex.h' ${file} ; then sed -i '/include.*<linux\/smp_lock.h>/d' ${file} else sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file} fi sed -i ${file} \ -e "/^#include.*linux.mutex.h/,$ { 1,/^\(static\|int\|long\)/ { /^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex); } }" \ -e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \ -e '/[ ]*cycle_kernel_lock();/d' else sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \ -e '/cycle_kernel_lock()/d' fi Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-08-23block: switch s390 tape_block and mg_disk to elevator_change()Jens Axboe
Now that we have this API, switch the two in-kernel users to it. Resolves an oops introduced by commit 1abec4fdbb142e3ccb6ce99832fae42129134a96. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: push down BKL into .open and .releaseArnd Bergmann
The open and release block_device_operations are currently called with the BKL held. In order to change that, we must first make sure that all drivers that currently rely on this have no regressions. This blindly pushes the BKL into all .open and .release operations for all block drivers to prepare for the next step. The drivers can subsequently replace the BKL with their own locks or remove it completely when it can be shown that it is not needed. The functions blkdev_get and blkdev_put are the only remaining users of the big kernel lock in the block layer, besides a few uses in the ioctl code, none of which need to serialize with blkdev_{get,put}. Most of these two functions is also under the protection of bdev->bd_mutex, including the actual calls to ->open and ->release, and the common code does not access any global data structures that need the BKL. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-02-26block: Consolidate phys_segment and hw_segment limitsMartin K. Petersen
Except for SCSI no device drivers distinguish between physical and hardware segment limits. Consolidate the two into a single segment limit. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-02-26block: Rename blk_queue_max_sectors to blk_queue_max_hw_sectorsMartin K. Petersen
The block layer calling convention is blk_queue_<limit name>. blk_queue_max_sectors predates this practice, leading to some confusion. Rename the function to appropriately reflect that its intended use is to set max_hw_sectors. Also introduce a temporary wrapper for backwards compability. This can be removed after the merge window is closed. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-01-13[S390] tape_block: remove ioctl functionHeiko Carstens
This is just a complicated construct which always returns -EINVAL. Just remove it. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-18[S390] tape: Add pr_fmt() macro to all tape source filesMichael Holzheu
Without defining the pr_fmt() macro, the "tape: " prefix will not be printed when using the pr_xxx printk macros. This patch adds the missing definitions. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-07[S390] tape: remove BKL from tape driverMartin Schwidefsky
Replace BLK with a per device mutex. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-12-07[S390] tape: cleanup reference countingMartin Schwidefsky
Rename tape_get_device to tape_find_device and tape_get_device_reference to tape_get_device. The old names didn't make too much sense. Follow the get_device()/put_device() semantic and convert tape_put_device to a void function. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-10-14[S390] tape390: Fix request queue handling in block driverMichael Holzheu
When setting a channel attached tape online under Linux 2.6.31, the "vol_id" process from udev hangs in sync_page(): 2 sync_page+144 [0x1dfaac] 3 __wait_on_bit_lock+194 [0x58c23e] 4 __lock_page+116 [0x1df9dc] 5 truncate_inode_pages_range+728 [0x1ed7cc] 6 __blkdev_put+244 [0x25f738] 7 __fput+300 [0x229c4c] 8 filp_close+122 [0x225a3a] The reason for that is an error in the request queue handling. It can happen that we fetch a request, but do not process it further because the number of queued requests exceeds TAPEBLOCK_MIN_REQUEUE. To fix this, we should call blk_peek_request() instead of blk_fetch_request() in the while condition and fetch the request in the loop body afterwards. This bug was introduced with the patch "block: implement and enforce request peek/start/fetch" (9934c8c04561413609d2bc38c6b9f268cba774a4) Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-09-22const: make block_device_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-11[S390] tape: Use pr_xxx instead of dev_xxx in shared driver codeMichael Holzheu
For messages from the tape core that is shared between the 3590 and 34xx tape disciplines, we want to have the "tape" prefix instead of "tape_3590" or "tape_34xx". In order to fix this, we now use the pr_xxx printk macros. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-09-11[S390] tape: Fix device online messagesMichael Holzheu
Currently, when a tape device is set online and no cartridge is loaded, we get the messages "The tape cartridge has been successfully unloaded" and "Determining the size of the recorded area". These messages are not correct. To fix this, we now print the "cartridge loaded/unloaded" messages only, when the load/unload event really occurs. In addition to that, the message "Determining the size of the recorded area" is only printed, if a cartridge is loaded. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-05-22block: Do away with the notion of hardsect_sizeMartin K. Petersen
Until now we have had a 1:1 mapping between storage device physical block size and the logical block sized used when addressing the device. With SATA 4KB drives coming out that will no longer be the case. The sector size will be 4KB but the logical block size will remain 512-bytes. Hence we need to distinguish between the physical block size and the logical ditto. This patch renames hardsect_size to logical_block_size. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: implement and enforce request peek/start/fetchTejun Heo
Till now block layer allowed two separate modes of request execution. A request is always acquired from the request queue via elv_next_request(). After that, drivers are free to either dequeue it or process it without dequeueing. Dequeue allows elv_next_request() to return the next request so that multiple requests can be in flight. Executing requests without dequeueing has its merits mostly in allowing drivers for simpler devices which can't do sg to deal with segments only without considering request boundary. However, the benefit this brings is dubious and declining while the cost of the API ambiguity is increasing. Segment based drivers are usually for very old or limited devices and as converting to dequeueing model isn't difficult, it doesn't justify the API overhead it puts on block layer and its more modern users. Previous patches converted all block low level drivers to dequeueing model. This patch completes the API transition by... * renaming elv_next_request() to blk_peek_request() * renaming blkdev_dequeue_request() to blk_start_request() * adding blk_fetch_request() which is combination of peek and start * disallowing completion of queued (not started) requests * applying new API to all LLDs Renamings are for consistency and to break out of tree code so that it's apparent that out of tree drivers need updating. [ Impact: block request issue API cleanup, no functional change ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Mike Miller <mike.miller@hp.com> Cc: unsik Kim <donari75@gmail.com> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: David S. Miller <davem@davemloft.net> Cc: Laurent Vivier <Laurent@lvivier.info> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Adrian McMenamin <adrian@mcmen.demon.co.uk> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: Pierre Ossman <drzeus@drzeus.cx> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Stefan Weinhuber <wein@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: convert to pos and nr_sectors accessorsTejun Heo
With recent cleanups, there is no place where low level driver directly manipulates request fields. This means that the 'hard' request fields always equal the !hard fields. Convert all rq->sectors, nr_sectors and current_nr_sectors references to accessors. While at it, drop superflous blk_rq_pos() < 0 test in swim.c. [ Impact: use pos and nr_sectors accessors ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Tested-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Mike Miller <mike.miller@hp.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Dario Ballabio <ballabio_dario@emc.com> Cc: David S. Miller <davem@davemloft.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: unsik Kim <donari75@gmail.com> Cc: Laurent Vivier <Laurent@lvivier.info> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28block: implement and use [__]blk_end_request_all()Tejun Heo
There are many [__]blk_end_request() call sites which call it with full request length and expect full completion. Many of them ensure that the request actually completes by doing BUG_ON() the return value, which is awkward and error-prone. This patch adds [__]blk_end_request_all() which takes @rq and @error and fully completes the request. BUG_ON() is added to to ensure that this actually happens. Most conversions are simple but there are a few noteworthy ones. * cdrom/viocd: viocd_end_request() replaced with direct calls to __blk_end_request_all(). * s390/block/dasd: dasd_end_request() replaced with direct calls to __blk_end_request_all(). * s390/char/tape_block: tapeblock_end_request() replaced with direct calls to blk_end_request_all(). [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Mike Miller <mike.miller@hp.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-26[S390] tape message cleanupCarsten Otte
This is a cleanup of all the messages this driver prints. It uses the dev_message macros now. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-28[S390] tape block: complete request with correct lockingFrank Munzert
__blk_end_request must be called with request queue lock held. We need to use blk_end_request rather than __blk_end_request. Signed-off-by: Frank Munzert <munzert@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-21[PATCH] switch tape_blockAl Viro
2008-10-21[PATCH] beginning of methods conversionAl Viro
To keep the size of changesets sane we split the switch by drivers; to keep the damn thing bisectable we do the following: 1) rename the affected methods, add ones with correct prototypes, make (few) callers handle both. That's this changeset. 2) for each driver convert to new methods. *ALL* drivers are converted in this series. 3) kill the old (renamed) methods. Note that it _is_ a flagday; all in-tree drivers are converted and by the end of this series no trace of old methods remain. The only reason why we do that this way is to keep the damn thing bisectable and allow per-driver debugging if anything goes wrong. New methods: open(bdev, mode) release(disk, mode) ioctl(bdev, mode, cmd, arg) /* Called without BKL */ compat_ioctl(bdev, mode, cmd, arg) locked_ioctl(bdev, mode, cmd, arg) /* Called with BKL, legacy */ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-10[S390] bus_id -> dev_name conversionsKay Sievers
bus_id -> dev_name() conversions in s390 code. [cornelia.huck@de.ibm.com: minor adaptions] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-05-30[S390] tape: Fix race condition in tape block device driverMichael Holzheu
Due to incorrect function call sequence it can happen that a tape block request is finished before the request is taken from the block request queue. The following sequence leads to that condition: * tapeblock_start_request() -> start CCW program * Request finishes -> IO interrupt * tapeblock_end_request() * end_that_request_last() If blkdev_dequeue_request() has not been called before end_that_request_last(), a kernel bug is triggered in end_that_request_last() because the request is still queued. To solve that problem blkdev_dequeue_request() has to be called before starting the CCW program. Signed-off-by: Michael Holzheu <holzheu@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-28blk_end_request: changing s390 (take 4)Kiyoshi Ueda
This patch converts s390 to use blk_end_request interfaces. Related 'uptodate' arguments are converted to 'error'. As a result, the interfaces of internal functions below are changed: o dasd_end_request o tapeblock_end_request Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux390@de.ibm.com Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-24[BLOCK] Get rid of request_queue_t typedefJens Axboe
Some of the code has been gradually transitioned to using the proper struct request_queue, but there's lots left. So do a full sweet of the kernel and get rid of this typedef and replace its uses with the proper type. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-02-05[S390] Avoid excessive inlining.Heiko Carstens
2006-12-08[S390] more workqueue fixes.Martin Schwidefsky
2006-04-11[PATCH] s390: minor tape fixesPeter Oberparleiter
Cleanup of minor bugs found by a source code checker. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-01BUG_ON() Conversion in drivers/s390/char/tape_block.cEric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-06Merge branch 'post-2.6.15' of git://brick.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
Manual fixup for merge with Jens' "Suspend support for libata", commit ID 9b847548663ef1039dd49f0eb4463d001e596bc3. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: atomic primitivesMartin Schwidefsky
Hugh Dickins <hugh@veritas.com> Fix the broken atomic_cmpxchg primitive. Add atomic_sub_and_test, atomic64_sub_return, atomic64_sub_and_test, atomic64_cmpxchg, atomic64_add_unless and atomic64_inc_not_zero. Replace old style atomic_compare_and_swap by atomic_cmpxchg. Shorten the whole header by defining most primitives with the two inline functions atomic_add_return and atomic_sub_return. In addition this patch contains the s390 related fixes of Hugh's "mm: fill arch atomic64 gaps" patch. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[BLOCK] add @uptodate to end_that_request_last() and @error to rq_end_io_fn()Tejun Heo
add @uptodate argument to end_that_request_last() and @error to rq_end_io_fn(). there's no generic way to pass error code to request completion function, making generic error handling of non-fs request difficult (rq->errors is driver-specific and each driver uses it differently). this patch adds @uptodate to end_that_request_last() and @error to rq_end_io_fn(). for fs requests, this doesn't really matter, so just using the same uptodate argument used in the last call to end_that_request_first() should suffice. imho, this can also help the generic command-carrying request jens is working on. Signed-off-by: tejun heo <htejun@gmail.com> Signed-Off-By: Jens Axboe <axboe@suse.de>
