path: root/drivers/s390/char
2011-08-24[S390] memory hotplug: only unassign assigned incrementsHeiko Carstens
Make sure that only assigned storage increments are unassigned when attaching a storage element. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-08-03[S390] sclp_async: Use kstrtoul_from_userPeter Huewe
This patch replaces the code for getting an unsigned long from a userspace buffer by a simple call to kstroul_from_user. This makes it easier to read and less error prone. Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-24[S390] kconfig: remove tape interface support commentMartin Schwidefsky
There is nothing below the menu entry "S/390 tape interface support". Remove it. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-07-15PM: Improve error code of pm_notifier_call_chain()Akinobu Mita
This enables pm_notifier_call_chain() to get the actual error code in the callback rather than always assume -EINVAL by converting all PM notifier calls to return encapsulate error code with notifier_from_errno(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-05-26[S390] irq: merge irq.c and s390_ext.cHeiko Carstens
Merge irq.c and s390_ext.c into irq.c. That way all external interrupt related functions are together. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-26[S390] irq: fix service signal external interrupt handlingHeiko Carstens
Interrupt sources like pfault, sclp, dasd_diag and virtio all use the service signal external interrupt subclass mask in control register 0 to enable and disable the corresponding interrupt. Because no reference counting is implemented each subsystem thinks it is the only user of subclass and sets and clears the bit like it wants. This leads to case that unloading the dasd diag module under z/VM causes both sclp and pfault interrupts to be masked. The result will be locked up system sooner or later. Fix this by introducing a new way to set (register) and clear (unregister) the service signal subclass mask bit in cr0. Also convert all drivers. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23[S390] get CPC image nameMartin Schwidefsky
Provide sysfs attributes that contain the CPC name and the HMC network name of the machine the operating system is running on. This information is retrieved with the operation communication parameters (OCF) sclp interface. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23[S390] sclp: event buffer dissectionMartin Schwidefsky
Move gds vector/subvector find functions to the sclp header file. Simplify event buffer dissection in sclp tty code. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23[S390] sclp: remove unnecessary sendmask checkHeiko Carstens
The sendmask check is not needed. Remove it. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23[S390] tape: remove unused/not handled return codesHeiko Carstens
Return codes are on purpose not handled or used. So remove them. Acked-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23[S390] monwriter: fix return code handlingHeiko Carstens
Fix return code handling within monwrite_new_hdr(). Return code handling is everwhere implemented, the return code of the diagnose function was just not passed. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23[S390] get rid of unused variablesHeiko Carstens
Remove trivially unused variables as detected with -Wunused-but-set-variable. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23[S390] Remove tape block device driver.Heiko Carstens
Remove the tape block device driver. It's not of real use but has already created some confusion when users wanted to access tape devices and used the block device nodes instead of the character device nodes. Also remove the whole tape documentation since it's completely outdated and we have the device drivers book which is the place where everything is properly documented. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-18Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blocklatestLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: don't delay blk_run_queue_async scsi: remove performance regression due to async queue run blk-throttle: Use task_subsys_state() to determine a task's blkio_cgroup block: rescan partitions on invalidated devices on -ENOMEDIA too cdrom: always check_disk_change() on open block: unexport DISK_EVENT_MEDIA_CHANGE for legacy/fringe drivers
2011-05-10[S390] sclp/memory hotplug: fix initial usecount of incrementsHeiko Carstens
Fix initial usecount of attached and assigned storage increments so they can be set offline. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-04-21block: unexport DISK_EVENT_MEDIA_CHANGE for legacy/fringe driversTejun Heo
In-kernel disk event polling doesn't matter for legacy/fringe drivers and may lead to infinite event loop if ->check_events() implementation generates events on level condition instead of edge. Now that block layer supports suppressing exporting unlisted events, simply leaving disk->events cleared allows these drivers to keep the internal revalidation behavior intact while avoiding weird interactions with userland event handler. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-25Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] cmpxchg: implement cmpxchg64() [S390] xchg/cmpxchg: move to own header file [S390] ccwgroup_driver: remove duplicate members [S390] ccw_bus_type: make it static [S390] ccw_driver: remove duplicate members [S390] qdio: prevent handling of buffers if count is zero [S390] setup: register bss section as resource [S390] setup: simplify setup_resources() [S390] wire up sys_syncfs [S390] wire up sys_clock_adjtime [S390] wire up sys_open_by_handle_at [S390] wire up sys_name_to_handle_at [S390] oprofile: disable hw sampling for CONFIG_32BIT [S390] early: limit savesys cmd string handling [S390] early: Fix possible overlapping data buffer
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-23[S390] ccw_driver: remove duplicate membersSebastian Ott
Remove the owner and name members of struct ccw_driver and convert all drivers to store this data in the embedded struct device_driver. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-03-16Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (76 commits) pch_uart: reference clock on CM-iTC pch_phub: add new device ML7213 n_gsm: fix UIH control byte : P bit should be 0 n_gsm: add a documentation serial: msm_serial_hs: Add MSM high speed UART driver tty_audit: fix tty_audit_add_data live lock on audit disabled tty: move cd1865.h to drivers/staging/tty/ Staging: tty: fix build with epca.c driver pcmcia: synclink_cs: fix prototype for mgslpc_ioctl() Staging: generic_serial: fix double locking bug nozomi: don't use flush_scheduled_work() tty/serial: Relax the device_type restriction from of_serial MAINTAINERS: Update HVC file patterns tty: phase out of ioctl file pointer for tty3270 as well tty: forgot to remove ipwireless from drivers/char/pcmcia/Makefile pch_uart: Fix DMA channel miss-setting issue. pch_uart: fix exclusive access issue pch_uart: fix auto flow control miss-setting issue pch_uart: fix uart clock setting issue pch_uart : Use dev_xxx not pr_xxx ... Fix up trivial conflicts in drivers/misc/pch_phub.c (same patch applied twice, then changes to the same area in one branch)
2011-03-10Merge branch 'for-2.6.39/stack-plug' into for-2.6.39/coreJens Axboe
Conflicts: block/blk-core.c block/blk-flush.c drivers/md/raid1.c drivers/md/raid10.c drivers/md/raid5.c fs/nilfs2/btnode.c fs/nilfs2/mdt.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-09s390/tape_block: Convert to bdops->check_events()Tejun Heo
Convert from ->media_changed() to ->check_events(). s390/tape_block buffers media changed state and clears it on revalidation. It will behave correctly with kernel event polling. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com>
2011-03-03[S390] tape: deadlock on system work queueMartin Schwidefsky
The 34xx and 3590 tape driver uses the system work queue to defer work from the interrupt function to process context, e.g. a medium sense after an unsolicited interrupt. The tape commands started by the work handler need to be asynchronous, otherwise a deadlock on the system work queue can occur. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-03-03[S390] keyboard: integer underflow bugDan Carpenter
The "ct" variable should be an unsigned int. Both struct kbdiacrs ->kb_cnt and struct kbd_data ->accent_table_size are unsigned ints. Making it signed causes a problem in KBDIACRUC because the user could set the signed bit and cause a buffer overflow. Cc: <stable@kernel.org> Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-02-25tty: phase out of ioctl file pointer for tty3270 as wellHeiko Carstens
The patch "tty: now phase out the ioctl file pointer for good" missed the tty3270 driver. This is the missing piece. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-10headers: kobject.h reduxAlexey Dobriyan
Remove kobject.h from files which don't need it, notably, sched.h and fs.h. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-07Merge branch 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (33 commits) usb: don't use flush_scheduled_work() speedtch: don't abuse struct delayed_work media/video: don't use flush_scheduled_work() media/video: explicitly flush request_module work ioc4: use static work_struct for ioc4_load_modules() init: don't call flush_scheduled_work() from do_initcalls() s390: don't use flush_scheduled_work() rtc: don't use flush_scheduled_work() mmc: update workqueue usages mfd: update workqueue usages dvb: don't use flush_scheduled_work() leds-wm8350: don't use flush_scheduled_work() mISDN: don't use flush_scheduled_work() macintosh/ams: don't use flush_scheduled_work() vmwgfx: don't use flush_scheduled_work() tpm: don't use flush_scheduled_work() sonypi: don't use flush_scheduled_work() hvsi: don't use flush_scheduled_work() xen: don't use flush_scheduled_work() gdrom: don't use flush_scheduled_work() ... Fixed up trivial conflict in drivers/media/video/bt8xx/bttv-input.c as per Tejun.
2011-01-05[S390] prevent unneccesary loops_per_jiffy recalculationHeiko Carstens
When the seqfile /proc/cpuinfo gets accesses for each possible cpu loops_per_jiffy gets recalculated. However its value is only needed on first access. In addition loops_per_jiffy should be recalculated when the machine reports a capability change. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] sclp: use register_external_interrupt()Heiko Carstens
Use register_external_interrupt() instead of register_early_external_interrupt(). The early variant is not necessary since kmalloc works already. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] vmur: add support for irq statisticsHeiko Carstens
Add support for VMUR I/O interrupt statistics in /proc/interrupts. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] tape: add support for irq statisticsHeiko Carstens
Add support for ccw based tape I/O interrupt statistics in /proc/interrupts. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] 3270: add support for irq statisticsHeiko Carstens
Add support for 3270 I/O interrupt statistics in /proc/interrupts. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] 3215: add support for irq statisticsHeiko Carstens
Add support for 3215 I/O interrupt statistics in /proc/interrupts. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] irq: have detailed statistics for interrupt typesHeiko Carstens
Up to now /proc/interrupts only has statistics for external and i/o interrupts but doesn't split up them any further. This patch adds a line for every single interrupt source so that it is possible to easier tell what the machine is/was doing. Part of the output now looks like this; CPU0 CPU2 CPU4 EXT: 3898 4232 2305 I/O: 782 315 245 CLK: 1029 1964 727 [EXT] Clock Comparator IPI: 2868 2267 1577 [EXT] Signal Processor TMR: 0 0 0 [EXT] CPU Timer TAL: 0 0 0 [EXT] Timing Alert PFL: 0 0 0 [EXT] Pseudo Page Fault [...] NMI: 0 1 1 [NMI] Machine Checks Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] cleanup s390 KconfigMartin Schwidefsky
Make use of def_bool and def_tristate where possible and add sensible defaults to the config symbols where applicable. This shortens the defconfig file by another ~40 lines. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-12-24s390: don't use flush_scheduled_work()Tejun Heo
flush_scheduled_work() is deprecated and scheduled to be removed. * tape_3590: Create and use tape_3590_wq instead of the system_wq. * tape_block: Directly flush requeue_task on cleanup instead of using flush_scheduled_work(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux390@de.ibm.com Cc: linux-s390@vger.kernel.org
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-10[S390] vmlogrdr: purge after recording is switched offStefan Weinhuber
If automatic purge is enabled for a vmlogrdr device, old records are purged before an IUCV recording service is switched on or off. If z/VM generates a large number of records between purging and switching the recording service off, these records remain queued, and may have a negative performance impact on the z/VM system. To avoid this problem, we need to purge the records after recording is switched off. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-11-10[S390] tape: add medium state notificationsMartin Schwidefsky
Add uevent notifications for tape cartridge load and tape cartridge unload events. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-10-29[S390] tape: fix dbf usageSebastian Ott
Get rid of the format string "%s" usage with volatile strings to prevent use after free errors in the s390dbf. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-10-25[S390] cleanup lowcore access from external interruptsMartin Schwidefsky
Read external interrupts parameters from the lowcore in the first level interrupt handler in entry[64].S. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-10-25[S390] drivers/s390/char: Use static const char arraysJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
2010-10-22Merge branch 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: block: autoconvert trivial BKL users to private mutex drivers: autoconvert trivial BKL users to private mutex ipmi: autoconvert trivial BKL users to private mutex mac: autoconvert trivial BKL users to private mutex mtd: autoconvert trivial BKL users to private mutex scsi: autoconvert trivial BKL users to private mutex Fix up trivial conflicts (due to addition of private mutex right next to deletion of a version string) in drivers/char/pcmcia/cm40[04]0_cs.c
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-07Fix IRQ flag handling namingDavid Howells
Fix the IRQ flag handling naming. In linux/irqflags.h under one configuration, it maps: local_irq_enable() -> raw_local_irq_enable() local_irq_disable() -> raw_local_irq_disable() local_irq_save() -> raw_local_irq_save() ... and under the other configuration, it maps: raw_local_irq_enable() -> local_irq_enable() raw_local_irq_disable() -> local_irq_disable() raw_local_irq_save() -> local_irq_save() ... This is quite confusing. There should be one set of names expected of the arch, and this should be wrapped to give another set of names that are expected by users of this facility. Change this to have the arch provide: flags = arch_local_save_flags() flags = arch_local_irq_save() arch_local_irq_restore(flags) arch_local_irq_disable() arch_local_irq_enable() arch_irqs_disabled_flags(flags) arch_irqs_disabled() arch_safe_halt() Then linux/irqflags.h wraps these to provide: raw_local_save_flags(flags) raw_local_irq_save(flags) raw_local_irq_restore(flags) raw_local_irq_disable() raw_local_irq_enable() raw_irqs_disabled_flags(flags) raw_irqs_disabled() raw_safe_halt() with type checking on the flags 'arguments', and then wraps those to provide: local_save_flags(flags) local_irq_save(flags) local_irq_restore(flags) local_irq_disable() local_irq_enable() irqs_disabled_flags(flags) irqs_disabled() safe_halt() with tracing included if enabled. The arch functions can now all be inline functions rather than some of them having to be macros. Signed-off-by: David Howells <dhowells@redhat.com> [X86, FRV, MN10300] Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> [Tile] Signed-off-by: Michal Simek <monstr@monstr.eu> [Microblaze] Tested-by: Catalin Marinas <catalin.marinas@arm.com> [ARM] Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [AVR] Acked-by: Tony Luck <tony.luck@intel.com> [IA-64] Acked-by: Hirokazu Takata <takata@linux-m32r.org> [M32R] Acked-by: Greg Ungerer <gerg@uclinux.org> [M68K/M68KNOMMU] Acked-by: Ralf Baechle <ralf@linux-mips.org> [MIPS] Acked-by: Kyle McMartin <kyle@mcmartin.ca> [PA-RISC] Acked-by: Paul Mackerras <paulus@samba.org> [PowerPC] Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [S390] Acked-by: Chen Liqin <liqin.chen@sunplusct.com> [Score] Acked-by: Matt Fleming <matt@console-pimps.org> [SH] Acked-by: David S. Miller <davem@davemloft.net> [Sparc] Acked-by: Chris Zankel <chris@zankel.net> [Xtensa] Reviewed-by: Richard Henderson <rth@twiddle.net> [Alpha] Reviewed-by: Yoshinori Sato <ysato@users.sourceforge.jp> [H8300] Cc: starvik@axis.com [CRIS] Cc: jesper.nilsson@axis.com [CRIS] Cc: linux-cris-kernel@axis.com
