commit 5457e03de918f7a3e294eb9d26a608ab8a579976 upstream.
The buffer for iucv_message_receive() needs to be below 2 GB. In
__iucv_message_receive(), the buffer address is casted to an u32, which
would result in either memory corruption or an addressing exception when
using addresses >= 2 GB.
Fix this by using GFP_DMA for the buffer allocation.
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 updates from Martin Schwidefsky:
"The new features and main improvements in this merge for v4.9
- Support for the UBSAN sanitizer
- Set HAVE_EFFICIENT_UNALIGNED_ACCESS, it improves the code in some
places
- Improvements for the in-kernel fpu code, in particular the overhead
for multiple consecutive in kernel fpu users is recuded
- Add a SIMD implementation for the RAID6 gen and xor operations
- Add RAID6 recovery based on the XC instruction
- The PCI DMA flush logic has been improved to increase the speed of
the map / unmap operations
- The time synchronization code has seen some updates
And bug fixes all over the place"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (48 commits)
s390/con3270: fix insufficient space padding
s390/con3270: fix use of uninitialised data
MAINTAINERS: update DASD maintainer
s390/cio: fix accidental interrupt enabling during resume
s390/dasd: add missing \n to end of dev_err messages
s390/config: Enable config options for Docker
s390/dasd: make query host access interruptible
s390/dasd: fix panic during offline processing
s390/dasd: fix hanging offline processing
s390/pci_dma: improve lazy flush for unmap
s390/pci_dma: split dma_update_trans
s390/pci_dma: improve map_sg
s390/pci_dma: simplify dma address calculation
s390/pci_dma: remove dma address range check
iommu/s390: simplify registration of I/O address translation parameters
s390: migrate exception table users off module.h and onto extable.h
s390: export header for CLP ioctl
s390/vmur: fix irq pointer dereference in int handler
s390/dasd: add missing KOBJ_CHANGE event for unformatted devices
s390: enable UBSAN
con3270 contains an optimisation that reduces the amount of data to be
transmitted to the 3270 terminal by putting a Repeat to Address (RA)
order into the data stream. The RA order itself takes up space, so
con3270 only uses it if there's enough space left in the line
buffer. Otherwise it just pads out the line manually.
For lines that were _just_ short enough that the RA order still fit in
the line buffer, the line was instead padded with an insufficient
amount of spaces. This was caused by examining the size of the
allocated line buffer rather than the length of the string to be
displayed.
For con3270_cline_end(), we just compare against the line length. For
con3270_update_string() however that isn't available anymore, so we
check whether the Repeat to Address order is present.
Fixes: f51320a5 ("[PATCH] s390: new 3270 driver.") (tglx/history.git)
Tested-by: Jing Liu <liujbjl@linux.vnet.ibm.com>
Tested-by: Yang Chen <bjcyang@linux.vnet.ibm.com>
Signed-off-by: Sascha Silbe <silbe@linux.vnet.ibm.com>
For lines too long to include the RA order, one byte was left
uninitialised. This was caused by an off-by-one bug in the loop that
pads out the line. Since the buffer is allocated from a common pool,
the single byte left uninitialised contained some previous buffer
content. Usually this was just a space or some character (which can
result in clutter but is otherwise harmless). Sometimes, however, it
was a Repeat to Address order, messing up the entire screen layout and
causing the display to send the entire buffer content on every
keystroke.
Reported-by: Liu Jing <liujbjl@linux.vnet.ibm.com>
"irq" in vmur's int handler can be an error pointer. Don't dereference
this pointer in that case.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
Many modules call misc_register and misc_deregister in its module init
and exit methods without any additional code. This ends up being
boilerplate. This patch adds helper macro module_misc_device(), that
replaces module_init()/ module_exit() with template functions.
This patch also converts drivers to use new macro.
Change since v1:
Add device.h include in miscdevice.h as module_driver macro was not
available from other include files in some architectures.
Signed-off-by: PrasannaKumar Muralidharan <prasannatsmkumar@gmail.com>
Reuse existing functionality from memdup_user() instead of keeping
duplicate source code.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
Pull KVM updates from Paolo Bonzini:
- ARM: GICv3 ITS emulation and various fixes. Removal of the
old VGIC implementation.
- s390: support for trapping software breakpoints, nested
virtualization (vSIE), the STHYI opcode, initial extensions
for CPU model support.
- MIPS: support for MIPS64 hosts (32-bit guests only) and lots
of cleanups, preliminary to this and the upcoming support for
hardware virtualization extensions.
- x86: support for execute-only mappings in nested EPT; reduced
vmexit latency for TSC deadline timer (by about 30%) on Intel
hosts; support for more than 255 vCPUs.
- PPC: bugfixes.
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (302 commits)
KVM: PPC: Introduce KVM_CAP_PPC_HTM
MIPS: Select HAVE_KVM for MIPS64_R{2,6}
MIPS: KVM: Reset CP0_PageMask during host TLB flush
MIPS: KVM: Fix ptr->int cast via KVM_GUEST_KSEGX()
MIPS: KVM: Sign extend MFC0/RDHWR results
MIPS: KVM: Fix 64-bit big endian dynamic translation
MIPS: KVM: Fail if ebase doesn't fit in CP0_EBase
MIPS: KVM: Use 64-bit CP0_EBase when appropriate
MIPS: KVM: Set CP0_Status.KX on MIPS64
MIPS: KVM: Make entry code MIPS64 friendly
MIPS: KVM: Use kmap instead of CKSEG0ADDR()
MIPS: KVM: Use virt_to_phys() to get commpage PFN
MIPS: Fix definition of KSEGX() for 64-bit
KVM: VMX: Add VMCS to CPU's loaded VMCSs before VMPTRLD
kvm: x86: nVMX: maintain internal copy of current VMCS
KVM: PPC: Book3S HV: Save/restore TM state in H_CEDE
KVM: PPC: Book3S HV: Pull out TM state save/restore into separate procedures
KVM: arm64: vgic-its: Simplify MAPI error handling
KVM: arm64: vgic-its: Make vgic_its_cmd_handle_mapi similar to other handlers
KVM: arm64: vgic-its: Turn device_id validation into generic ID validation
Use the same code structure when determining preferred consoles for
Linux running as KVM guest as with Linux running in LPAR and z/VM
guest:
- Extend the console_mode variable to cover vt220 and hvc consoles
- Determine sensible console defaults in conmode_default()
- Remove KVM-special handling in set_preferred_console()
Ensure that the sclp line mode console is also registered when the
vt220 console was selected to not change existing behavior that
someone might be relying on.
As an externally visible change, KVM guest users can now select
the 3270 or 3215 console devices using the conmode= kernel parameter,
provided that support for the corresponding driver was compiled into
the kernel.
Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
Signed-off-by: Jing Liu <liujbjl@linux.vnet.ibm.com>
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Rename DIAG308_IPL and DIAG308_DUMP to DIAG308_LOAD_CLEAR and
DIAG308_LOAD_NORMAL_DUMP to better reflect the associated IPL
functions.
Suggested-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Suggested-by: Christian Borntraeger <borntraeger@de.ibm.com>
Acked-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
Show the dynamic and static cpu mhz of each cpu. Since these values
are per cpu this requires a fundamental extension of the format of
/proc/cpuinfo.
Historically we had only a single line per cpu and a summary at the
top of the file. This format is hardly extendible if we want to add
more per cpu information.
Therefore this patch adds per cpu blocks at the end of /proc/cpuinfo:
cpu : 0
cpu Mhz dynamic : 5504
cpu Mhz static : 5504
cpu : 1
cpu : 2
cpu : 3
Right now each block contains only the dynamic and static cpu mhz,
but it can be easily extended like on every other architecture.
This extension is supposed to be compatible with the old format.
Acked-by: Sascha Silbe <silbe@linux.vnet.ibm.com>
Use memdup_user_nul to duplicate a memory region from user-space
to kernel-space and terminate with a NULL, instead of open coding
using kmalloc + copy_from_user and explicitly NULL terminating.
Signed-off-by: Muhammad Falak R Wani <falakreyaz@gmail.com>
[heiko.carstens@de.ibm.com: remove comment]
Let's correctly detect that facility.
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Let's detect that facility.
Let's detect if we have that facility.
Let's detect if we have the intervention bypass facility installed.
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Let's detect the Collaborative-memory-management-interpretation facility,
aka CMM assist, so we can correctly enable cmma later.
Let's detect that facility, so we can correctly handle its abscence.
Let's correctly detect that facility, so we can correctly handle its
abscence later on.
sclp_ocf.c is the only way to get the cpc name, as it registers the
sole event handler for the ocf event. By creating a new global
function that copies that name, we make it accessible to the world
which longs to retrieve it.
Additionally we now also store the cpc name as EBCDIC, so we don't
have to convert it to and from ASCII if it is requested in native
encoding.
Signed-off-by: Janosch Frank <frankja@linux.vnet.ibm.com>
Reviewed-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty and serial driver updates from Greg KH:
"Here's the large TTY and Serial driver update for 4.7-rc1.
A few new serial drivers are added here, and Peter has fixed a bunch
of long-standing bugs in the tty layer and serial drivers as normal.
Full details in the shortlog.
All of these have been in linux-next for a while with no reported
issues"
* tag 'tty-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (88 commits)
MAINTAINERS: 8250: remove website reference
serial: core: Fix port mutex assert if lockdep disabled
serial: 8250_dw: fix wrong logic in dw8250_check_lcr()
tty: vt, finish looping on duplicate
tty: vt, return error when con_startup fails
QE-UART: add "fsl,t1040-ucc-uart" to of_device_id
serial: mctrl_gpio: Drop support for out1-gpios and out2-gpios
serial: 8250dw: Add device HID for future AMD UART controller
Fix OpenSSH pty regression on close
serial: mctrl_gpio: add IRQ locking
serial: 8250: Integrate Fintek into 8250_base
serial: mps2-uart: add support for early console
serial: mps2-uart: add MPS2 UART driver
dt-bindings: document the MPS2 UART bindings
serial: sirf: Use generic uart-has-rtscts DT property
serial: sirf: Introduce helper variable struct device_node *np
serial: mxs-auart: Use generic uart-has-rtscts DT property
serial: imx: Use generic uart-has-rtscts DT property
doc: DT: Add Generic Serial Device Tree Bindings
serial: 8250: of: Make tegra_serial_handle_break() static
"Small release overall.
x86:
- miscellaneous fixes
- AVIC support (local APIC virtualization, AMD version)
s390:
- polling for interrupts after a VCPU goes to halted state is now
enabled for s390
- use hardware provided information about facility bits that do not
need any hypervisor activity, and other fixes for cpu models and
facilities
- improve perf output
- floating interrupt controller improvements.
MIPS:
PPC:
- bugfixes only
ARM:
- 16K page size support
- generic firmware probing layer for timer and GIC
Christoffer Dall (KVM-ARM maintainer) says:
"There are a few changes in this pull request touching things
outside KVM, but they should all carry the necessary acks and it
made the merge process much easier to do it this way."
though actually the irqchip maintainers' acks didn't make it into the
patches. Marc Zyngier, who is both irqchip and KVM-ARM maintainer,
later acked at http://mid.gmane.org/573351D1.4060303@arm.com ('more
formally and for documentation purposes')"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (82 commits)
KVM: MTRR: remove MSR 0x2f8
KVM: x86: make hwapic_isr_update and hwapic_irr_update look the same
svm: Manage vcpu load/unload when enable AVIC
svm: Do not intercept CR8 when enable AVIC
svm: Do not expose x2APIC when enable AVIC
KVM: x86: Introducing kvm_x86_ops.apicv_post_state_restore
svm: Add VMEXIT handlers for AVIC
svm: Add interrupt injection via AVIC
KVM: x86: Detect and Initialize AVIC support
svm: Introduce new AVIC VMCB registers
KVM: split kvm_vcpu_wake_up from kvm_vcpu_kick
KVM: x86: Introducing kvm_x86_ops VCPU blocking/unblocking hooks
KVM: x86: Introducing kvm_x86_ops VM init/destroy hooks
KVM: x86: Rename kvm_apic_get_reg to kvm_lapic_get_reg
KVM: x86: Misc LAPIC changes to expose helper functions
KVM: shrink halt polling even more for invalid wakeups
KVM: s390: set halt polling to 80 microseconds
KVM: halt_polling: provide a way to qualify wakeups during poll
KVM: PPC: Book3S HV: Re-enable XICS fast path for irqfd-generated interrupts
kvm: Conditionally register IRQ bypass consumer
"The s390 patches for the 4.7 merge window have the usual bug fixes and
cleanups, and the following new features:
- An interface for dasd driver to query if a volume is online to
another operating system
- A new ioctl for the dasd driver to verify the format for a range of
tracks
- Following the example of x86 the struct fpu is now allocated with
the task_struct
- The 'report_error' interface for the PCI bus to send an
adapter-error notification from user space to the service element
of the machine"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (29 commits)
s390/vmem: remove unused function parameter
s390/vmem: fix identity mapping
s390: add missing include statements
s390: add missing declarations
s390: make couple of variables and functions static
s390/cache: remove superfluous locking
s390/cpuinfo: simplify locking and skip offline cpus early
s390/3270: hangup the 3270 tty after a disconnect
s390/3270: handle reconnect of a tty with a different size
s390/3270: avoid endless I/O loop with disconnected 3270 terminals
s390/3270: fix garbled output on 3270 tty view
s390/3270: fix view reference counting
s390/3270: add missing tty_kref_put
s390/dumpstack: implement and use return_address()
s390/cpum_sf: Remove superfluous SMP function call
s390/cpum_cf: Remove superfluous SMP function call
s390/Kconfig: make z196 the default processor type
s390/sclp: avoid compile warning in sclp_pci_report
s390/fpu: allocate 'struct fpu' with the task_struct
s390/crypto: cleanup and move the header with the cpacf definitions
The disconnect and later reconnect of a 3270 terminal does not do
a tty hangup. The current session is resumed which is a security
issue.
Do a tty hangup after a unit check has been received.
If an existing 3270 terminal disconnects and reconnects with a
different size, the 3270 driver still works with the old size.
If the new dimensions are larger the output merely looks funny,
if the new dimensions are smaller the terminal is unusable.
To fix this restart the size detection after a unit check has
been received.
Let's add hypervisor-managed facility-apportionment indications field to
SCLP structs. KVM will use it to reduce maintenance cost of
Non-Hypervisor-Managed facility bits.
Signed-off-by: Alexander Yarygin <yarygin@linux.vnet.ibm.com>
Reviewed-by: Eric Farman <farman@linux.vnet.ibm.com>
We want the pty fixes in here as well so that patches can build on it.
If a 3270 terminal is disconnected while the tty view is active
the 3270 driver goes into an endless loop of failed I/O requests
until the terminal is connected again.
Add code to the raw3270 interrupt handler to check for unit checks
due to failed I/O requests and put the device to sleep with the
RAW3270_FLAGS_BUSY flag until a unsolicited device end interrupt
indicates that the device can be used again. while we are at it
simplify the 3270 irq handling and remove unnecessary code.
The tty3270_update function tries to optimize the output stream by
skipping the TO_SBA command to position the output offset if the
TO_RA command of the previous line ended at the same offset.
But some lines do not have the TO_RA at the end, namely those
with a length equal to the number of columns.
Make sure there is a TO_RA at the end of the previous line to avoid
funny looking output.
The tty3270_close function set tty->driver_data to NULL after the
open count dropped to zero but tty3270_cleanup still needs the
pointer to the tty3270 view to drop the reference count.
Move the clearing of tty->driver_data to tty3270_cleanup and
drop the unnecessary tty_port_tty_set calls in tty3270_install.
The tty3270_resize_work functions acquires a reference to the tty
to call tty_do_resize but fails to release the reference again.
Add the missing tty_kref_put.
Replace ASYNC_INITIALIZED bit in the tty_port::flags field with
TTY_PORT_INITIALIZED bit in the tty_port::iflags field. Introduce helpers
tty_port_set_initialized() and tty_port_initialized() to abstract
atomic bit ops.
Note: the transforms for test_and_set_bit() and test_and_clear_bit()
are unnecessary as the state transitions are already mutually exclusive;
the tty lock prevents concurrent open/close/hangup.
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
Replace ASYNC_SUSPENDED bit in the tty_port::flags field with
TTY_PORT_SUSPENDED bit in the tty_port::iflags field. Introduce helpers
tty_port_set_suspended() and tty_port_suspended() to abstract
atomic bit ops.
Abstract TTY_IO_ERROR status test treewide with tty_io_error().
NB: tty->flags uses atomic bit ops; replace non-atomic bit test
with test_bit().
The sclp_ctl_ioctl_sccb function uses two copy_from_user calls to
retrieve the sclp request from user space. The first copy_from_user
fetches the length of the request which is stored in the first two
bytes of the request. The second copy_from_user gets the complete
sclp request, but this copies the length field a second time.
A malicious user may have changed the length in the meantime.
Reported-by: Pengfei Wang <wpengfeinudt@gmail.com>
Reviewed-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Fix the initialization of a local variable to remove this warning:
All warnings (new ones prefixed by >>):
drivers/s390/char/sclp_pci.c: In function 'sclp_pci_report':
>> drivers/s390/char/sclp_pci.c:127:9: warning: missing braces around initializer [-Wmissing-braces]
struct sclp_req req = {0};
drivers/s390/char/sclp_pci.c:127:9: warning: (near initialization for 'req.list') [-Wmissing-braces]
Fixes: 12283a4035691697 "s390/sclp: add error notification command"
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Sort the sclp event type defines and use a macro to create the
corresponding event type masks. In addition to that one unused
type/mask pair is removed and another previously unused define
is used now (it was probably unused/unknown because it didn't
follow the EVTYP_X EVTYP_X_MASK convention).
Add SCLP event 24 "Adapter-error notification".
sclp commands only used by the PCI code shouldn't be build for
!CONFIG_PCI. Instead of adding more ifdefs to sclp_cmd.c just
move them to a new file.
Pull tty/serial updates from Greg KH:
"Here's the big tty/serial driver pull request for 4.6-rc1.
Lots of changes in here, Peter has been on a tear again, with lots of
refactoring and bugs fixes, many thanks to the great work he has been
doing. Lots of driver updates and fixes as well, full details in the
shortlog.
All have been in linux-next for a while with no reported issues"
* tag 'tty-4.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (220 commits)
serial: 8250: describe CONFIG_SERIAL_8250_RSA
serial: samsung: optimize UART rx fifo access routine
serial: pl011: add mark/space parity support
serial: sa1100: make sa1100_register_uart_fns a function
tty: serial: 8250: add MOXA Smartio MUE boards support
serial: 8250: convert drivers to use up_to_u8250p()
serial: 8250/mediatek: fix building with SERIAL_8250=m
serial: 8250/ingenic: fix building with SERIAL_8250=m
serial: 8250/uniphier: fix modular build
Revert "drivers/tty/serial: make 8250/8250_ingenic.c explicitly non-modular"
Revert "drivers/tty/serial: make 8250/8250_mtk.c explicitly non-modular"
serial: mvebu-uart: initial support for Armada-3700 serial port
serial: mctrl_gpio: Add missing module license
serial: ifx6x60: avoid uninitialized variable use
tty/serial: at91: fix bad offset for UART timeout register
tty/serial: at91: restore dynamic driver binding
serial: 8250: Add hardware dependency to RT288X option
TTY, devpts: document pty count limiting
tty: goldfish: support platform_device with id -1
drivers: tty: goldfish: Add device tree bindings
Convert the uses of pr_warning to pr_warn so there are fewer
uses of the old pr_warning.
Miscellanea:
o Align arguments
o Coalesce formats
The tty core no longer provides nor uses ASYNC_CLOSING; remove from
tty_port_close_start() and tty_port_close_end() as well as tty drivers
which open-code these state changes. Unfortunately, even though the
bit is masked from userspace, its inclusion in a uapi header precludes
removing the macro.
Cc: linux-s390@vger.kernel.org
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: linux-cris-kernel@axis.com
Cc: Samuel Ortiz <samuel@sortiz.org>
"Among the traditional bug fixes and cleanups are some improvements:
- A tool to generated the facility lists, generating the bit fields
by hand has been a source of bugs in the past
- The spinlock loop is reordered to avoid bursts of hypervisor calls
- Add support for the open-for-business interface to the service
element
- The get_cpu call is added to the vdso
- A set of tracepoints is defined for the common I/O layer
- The deprecated sclp_cpi module is removed
- Update default configuration"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (56 commits)
s390/sclp: fix possible control register corruption
s390: fix normalization bug in exception table sorting
s390/configs: update default configurations
s390/vdso: optimize getcpu system call
s390: drop smp_mb in vdso_init
s390: rename struct _lowcore to struct lowcore
s390/mem_detect: use unsigned longs
s390/ptrace: get rid of long longs in psw_bits
s390/sysinfo: add missing SYSIB 1.2.2 multithreading fields
s390: get rid of CONFIG_SCHED_MC and CONFIG_SCHED_BOOK
s390/Kconfig: remove pointless 64 bit dependencies
s390/dasd: fix failfast for disconnected devices
s390/con3270: testing return kzalloc retval
s390/hmcdrv: constify hmcdrv_ftp_ops structs
s390/cio: add NULL test
s390/cio: Change I/O instructions from inline to normal functions
s390/cio: Introduce common I/O layer tracepoints
s390/cio: Consolidate inline assemblies and related data definitions
s390/cio: Fix incorrect xsch opcode specification
s390/cio: Remove unused inline assemblies
Pull misc vfs updates from Al Viro:
"All kinds of stuff. That probably should've been 5 or 6 separate
branches, but by the time I'd realized how large and mixed that bag
had become it had been too close to -final to play with rebasing.
Some fs/namei.c cleanups there, memdup_user_nul() introduction and
switching open-coded instances, burying long-dead code, whack-a-mole
of various kinds, several new helpers for ->llseek(), assorted
cleanups and fixes from various people, etc.
One piece probably deserves special mention - Neil's
lookup_one_len_unlocked(). Similar to lookup_one_len(), but gets
called without ->i_mutex and tries to avoid ever taking it. That, of
course, means that it's not useful for any directory modifications,
but things like getting inode attributes in nfds readdirplus are fine
with that. I really should've asked for moratorium on lookup-related
changes this cycle, but since I hadn't done that early enough... I
*am* asking for that for the coming cycle, though - I'm going to try
and get conversion of i_mutex to rwsem with ->lookup() done under lock
taken shared.
There will be a patch closer to the end of the window, along the lines
of the one Linus had posted last May - mechanical conversion of
->i_mutex accesses to inode_lock()/inode_unlock()/inode_trylock()/
inode_is_locked()/inode_lock_nested(). To quote Linus back then:
| This is an automated patch using
| sed 's/mutex_lock(&\(.*\)->i_mutex)/inode_lock(\1)/'
| sed 's/mutex_unlock(&\(.*\)->i_mutex)/inode_unlock(\1)/'
| sed 's/mutex_lock_nested(&\(.*\)->i_mutex,[ ]*I_MUTEX_\([A-Z0-9_]*\))/inode_lock_nested(\1, I_MUTEX_\2)/'
| sed 's/mutex_is_locked(&\(.*\)->i_mutex)/inode_is_locked(\1)/'
| sed 's/mutex_trylock(&\(.*\)->i_mutex)/inode_trylock(\1)/'
| with a very few manual fixups
I'm going to send that once the ->i_mutex-affecting stuff in -next
gets mostly merged (or when Linus says he's about to stop taking
merges)"
* 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
nfsd: don't hold i_mutex over userspace upcalls
fs:affs:Replace time_t with time64_t
fs/9p: use fscache mutex rather than spinlock
proc: add a reschedule point in proc_readfd_common()
logfs: constify logfs_block_ops structures
fcntl: allow to set O_DIRECT flag on pipe
fs: __generic_file_splice_read retry lookup on AOP_TRUNCATED_PAGE
fs: xattr: Use kvfree()
[s390] page_to_phys() always returns a multiple of PAGE_SIZE
nbd: use ->compat_ioctl()
fs: use block_device name vsprintf helper
lib/vsprintf: add %*pg format specifier
fs: use gendisk->disk_name where possible
poll: plug an unused argument to do_poll
amdkfd: don't open-code memdup_user()
cdrom: don't open-code memdup_user()
rsxx: don't open-code memdup_user()
mtip32xx: don't open-code memdup_user()
[um] mconsole: don't open-code memdup_user_nul()
[um] hostaudio: don't open-code memdup_user()
sclp_sync_wait() disables all external interrupt classes except for
the service signal subclass.
The static mask used for that however is wrong. It clears a couple of
bits which shouldn't be cleared and on the other hand potentially does
not clear bits which should be cleared.
Fix this by using the same generic mask like we do it in our delay
implementation.
Reviewed-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
A _lot_ of ->write() instances were open-coding it; some are
converted to memdup_user_nul(), a lot more remain...
Return value from kzalloc is not tested and
using a null pointer would lead to crash.
Even if this should not happen at this moment, we
may let the system decide if there is a better choice.
Signed-off-by: Pierre Morel <pmorel@linux.vnet.ibm.com>
Constifies hmcdrv_ftp_ops structures in s390's char
driver since they are not modified after their
initialization.
Detected and found using Coccinelle.
Suggested-by: Julia Lawall <Julia.Lawall@lip6.fr>
Signed-off-by: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
