Whenever the cpu loads an enabled wait PSW it will appear as idle to the
underlying host system. The code in default_idle calls vtime_stop_cpu
which does the necessary voodoo to get the cpu time accounting right.
The udelay code just loads an enabled wait PSW. To correct this rework
the vtime_stop_cpu/vtime_start_cpu logic and move the difficult parts
to entry[64].S, vtime_stop_cpu can now be called from anywhere and
vtime_start_cpu is gone. The correction of the cpu time during wakeup
from an enabled wait PSW is done with a critical section in entry[64].S.
As vtime_start_cpu is gone, s390_idle_check can be removed as well.
This patch provides the architecture specific part of the s390 kdump
support.
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Current IRQ statistics support does not show detail counts for I/O
interrupts which are processed internally only. The result is a
summation count which is way off such as this one:
CPU0 CPU1 CPU2
I/O: 1331 710 442
QAI: 15 16 16 [I/O] QDIO Adapter Interrupt
QDI: 1 0 0 [I/O] QDIO Interrupt
DAS: 706 645 381 [I/O] DASD
C15: 26 10 0 [I/O] 3215
C70: 0 0 0 [I/O] 3270
TAP: 0 0 0 [I/O] Tape
VMR: 0 0 0 [I/O] Unit Record Devices
LCS: 0 0 0 [I/O] LCS
CLW: 0 0 0 [I/O] CLAW
CTC: 0 0 0 [I/O] CTC
APB: 0 0 0 [I/O] AP Bus
Fix this by moving I/O interrupt accounting into the common I/O layer.
Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com>
Ensure that adapter interrupts are correctly processed when they are
retrieved using TEST PENDING INTERRUPTION.
Move the options member from struct subchannel to
io_subchannel_private since it's I/O subchannel specific.
Also remove the unused cio_get_options function.
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
Don't check for the int_type if an adapter interrupt is presented.
__get_cpu_var() can be replaced with this_cpu_read and will then use a single
read instruction with implied address calculation to access the correct per cpu
instance.
However, the address of a per cpu variable passed to __this_cpu_read() cannot be
determed (since its an implied address conversion through segment prefixes).
Therefore apply this only to uses of __get_cpu_var where the addres of the
variable is not used.
V3->V4:
- Move one instance of this_cpu_inc_return to a later patch
so that this one can go in without percpu infrastructrure
changes.
Sedat: fixed compile failure caused by an extra ')'.
Cc: Neil Horman <nhorman@tuxdriver.com>
Cc: Sedat Dilek <sedat.dilek@gmail.com>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Signed-off-by: Christoph Lameter <cl@linux.com>
A machine check can interrupt the i/o and external interrupt handler
anytime. If the machine check occurs while the interrupt handler is
waking up from idle vtime_start_cpu can get executed a second time
and the int_clock / async_enter_timer values in the lowcore get
clobbered. This can confuse the cpu time accounting.
To fix this problem two changes are needed. First the machine check
handler has to use its own copies of int_clock and async_enter_timer,
named mcck_clock and mcck_enter_timer. Second the nested execution
of vtime_start_cpu has to be prevented. This is done in s390_idle_check
by checking the wait bit in the program status word.
Using stsch on schids with ssid != 0 can lead to an operand
exception. Use stsch_err to handle potential exceptions
if we fail to reenable mss after hibernation.
Cc: <stable@kernel.org>
Use asm offsets to make sure the offset defines to struct _lowcore and
its layout don't get out of sync.
Also add a BUILD_BUG_ON() which checks that the size of the structure
is sane.
And while being at it change those sites which use odd casts to access
the current lowcore. These should use S390_lowcore instead.
Introduce the MACHINE_IS_LPAR flag for code that should only be
executed if Linux is running in an LPAR.
Allow the architecture to request a normal jiffy tick when the system
goes idle and tick_nohz_stop_sched_tick is called . On s390 the hook is
used to prevent the system going fully idle if there has been an
interrupt other than a clock comparator interrupt since the last wakeup.
On s390 the HiperSockets response time for 1 connection ping-pong goes
down from 42 to 34 microseconds. The CPU cost decreases by 27%.
LKML-Reference: <20090929122533.402715150@de.ibm.com>
We used the init_name to set the console subchannels name early
at the boot stage. With the patch cio: fix memleak in subchannel validation
we moved the name setting to the point where we actually register the
console subchannel. At this time we can do dynamic allocations and therefore
use dev_set_name.
When scanning for new subchannels we have a code path where we allocate
memory for a struct subchannel, set the device name (which is dynamically
allocated now) and do a check if the underlying device is blacklisted - if
so we free the subchannel structure.
Since we have not set up refcounting at this stage, the device name's memory
is lost. Fix this by moving the dev_set_name after the blacklist test.
Note: With this patch the init_name for the console subchannel becomes
virtually obsolete.
Move debug traces for start I/O and interrupt events to exclusive
trace levels. Also change tracing in hot-path from sprintf (costly)
to hex.
Function graph tracer support for s390.
All definition in cpu.h have to do with cputime accounting. Move
them to cputime.h and remove the header file.
Acting upon the assumption that cio_disable_subchannel()
is only called when we really want to disable the subchannel
(a) remove the check for activity (it is already done in
ccw_device_offline(), which is the place where it matters)
(b) collect pending status via tsch() and ignore it (it
can't matter anymore since the subchannel will be disabled).
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Split machine check handler code and move it to cio and kernel code
where it belongs to. No functional change.
When I review ocfs2 code, find there are 2 typos to "successfull". After
doing grep "successfull " in kernel tree, 22 typos found totally -- great
minds always think alike :)
This patch fixes all the similar typos. Thanks for Randy's ack and comments.
Signed-off-by: Coly Li <coyli@suse.de>
Acked-by: Roland Dreier <rolandd@cisco.com>
Cc: Jeremy Kerr <jk@ozlabs.org>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Vlad Yasevich <vladislav.yasevich@hp.com>
Cc: Sridhar Samudrala <sri@us.ibm.com>
Distinguish the cputime of the idle process where idle is actually using
cpu cycles from the cputime where idle is sleeping on an enabled wait psw.
The former is accounted as system time, the later as idle time.
Signed-off-by: Michael Ernst <mernst@de.ibm.com>
To change the configuration of a subchannel we alter the modifiable
bits of the subchannel's schib field and issue a modify subchannel.
There can be the case that not all changes were applied -or worse-
quietly overwritten by the hardware. With the next store subchannel
we obtain the current state of the hardware but lose our target
configuration.
With this patch we introduce a subchannel_config structure which
contains the target subchannel configuration. Additionally the msch
wrapper cio_modify is replaced with cio_commit_config which
copies the desired changes to a temporary schib. msch is then
called with the temporary schib. This schib is only written back
to the subchannel if all changes were applied.
There is the chance that we get condition code 0 for a stsch but
the resulting schib is not vaild. In the current code there are
2 cases:
* we do a check for validity of the schib after stsch, but at this
time we have already stored the invaild schib in the subchannel
structure. This may lead to problems.
* we don't do a check for validity, which is not that good either.
The patch addresses both issues by introducing the stsch wrapper
cio_update_schib which performs stsch on a local schib. This schib
is only written back to the subchannel if it's valid.
side note: For some functions (chp_events) the return codes are
different now (-ENXIO vs -ENODEV) but this shouldn't do harm
since the caller doesn't check for _specific_ errors.
Move cio_tpi() to the rest of the CONFIG_CCW_CONSOLE functions to
get rid of this one:
drivers/s390/cio/cio.c:115: warning: 'cio_tpi' defined but not used
Move cio's private simple udelay function to lib/delay.c and turn it
into something much more readable. So we have all implementations
at one place.
In cio_tpi only disable bottom halves when not in interrupt context.
Otherwise a WARN_ON gets triggered. Besides that, when we are in
interrupt context bottom halves are disabled anyway.
Fixes this one:
Badness at kernel/softirq.c:77
Modules linked in:
CPU: 2 Not tainted 2.6.26 #4
Process swapper (pid: 0, task: 000000003fe83db0, ksp: 000000003fea7d28)
Krnl PSW : 0404c00180000000 0000000000053f4e (__local_bh_disable+0xbe/0xcc)
R:0 T:1 IO:0 EX:0 Key:0 M:1 W:0 P:0 AS:3 CC:0 PM:0 EA:3
Krnl GPRS: 0000000000008ee0 00000000005f95e0 0000000000000000 0000000000000001
000000000020be92 0000000000000000 0000000000000210 00000000005d36c0
000000003fb5f4d8 0000000000000000 000000000020bed0 000000003fb5f3c8
00000000009be920 0000000000364898 000000003fb5f408 000000003fb5f3c8
Krnl Code: 0000000000053f42: bf2f1000 icm %r2,15,0(%r1)
0000000000053f46: a774ffc5 brc 7,53ed0
0000000000053f4a: a7f40001 brc 15,53f4c
>0000000000053f4e: a7280001 lhi %r2,1
0000000000053f52: 50201000 st %r2,0(%r1)
0000000000053f56: a7f4ffbd brc 15,53ed0
0000000000053f5a: 0707 bcr 0,%r7
0000000000053f5c: a7f13fc0 tmll %r15,16320
Call Trace:
([<0000000000000210>] 0x210)
[<0000000000053f86>] local_bh_disable+0x2a/0x38
[<000000000020bed0>] wait_cons_dev+0xd4/0x154
[<0000000000247cb2>] raw3215_make_room+0x6a/0x1a8
[<000000000024861a>] raw3215_write+0x86/0x28c
[<00000000002488a0>] con3215_write+0x80/0x110
[<000000000004c3e0>] __call_console_drivers+0xc8/0xe4
[<000000000004c47e>] _call_console_drivers+0x82/0xc4
[<000000000004c744>] release_console_sem+0x218/0x2c0
[<000000000004cf64>] vprintk+0x3c0/0x504
[<0000000000354a4a>] printk+0x52/0x64
[<0000000000088004>] __print_symbol+0x40/0x50
[<0000000000071dbc>] print_stack_trace+0x78/0xac
[<0000000000079e78>] print_lock_dependencies+0x148/0x208
[<000000000007a050>] print_irq_inversion_bug+0x118/0x15c
[<000000000007a106>] check_usage_forwards+0x72/0x84
[<000000000007a36e>] mark_lock+0x1d2/0x594
[<000000000007baca>] __lock_acquire+0x886/0xf48
[<000000000007c234>] lock_acquire+0xa8/0xe0
[<0000000000350316>] _write_lock+0x56/0x98
[<000000000026cd92>] zfcp_erp_adapter_reopen+0x4e/0x8c
[<000000000026f1e8>] zfcp_qdio_int_resp+0x2e4/0x2f4
[<00000000002210f4>] qdio_int_handler+0x274/0x888
[<00000000002177b6>] ccw_device_call_handler+0x6e/0xd8
[<0000000000215336>] ccw_device_irq+0xd6/0x160
[<0000000000212f88>] io_subchannel_irq+0x8c/0x118
[<000000000020c120>] do_IRQ+0x1d0/0x1fc
[<00000000000270b2>] io_return+0x0/0x8
[<000000000001c8a4>] cpu_idle+0x178/0x21c
([<000000000001c884>] cpu_idle+0x158/0x21c)
[<00000000003483a2>] start_secondary+0xb6/0xc8
INFO: lockdep is turned off.
Last Breaking-Event-Address:
[<0000000000053f4a>] __local_bh_disable+0xba/0xcc
Fix incorrect in- and output constraints, remove volatile declaration
of inline assembly parameters and reformat constraint declarations to
be more consistent.
Convert remaining s390 users setting bus_id to dev_set_name()
or init_name.
bus_id -> dev_name() conversions in s390 code.
[cornelia.huck@de.ibm.com: minor adaptions]
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
The functions cio_tm_start_key and cio_start_key use the same private
orb structure of a subchannel, so the orb needs to be cleared of old
data before it is used again. A respective memset is missing from
cio_start_key and hereby added.
Signed-off-by: Stefan Weinhuber <wein@de.ibm.com>
Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com>
ssch() has two classes of return codes:
- condition codes (0-3) which need to be translated to Linux
error codes
- Linux error codes (-EIO on exceptions) which should be passed
to the caller (instead of erronously being handled like
condition code 3)
Unnecessary dev_info, dev_warn and printk messages are removed.
This patch adds a driver for subchannels of type chsc.
A device /dev/chsc is created which may be used to issue ioctls to:
- obtain information about the machine's I/O configuration
- dynamically change the machine's I/O configuration via
asynchronous chsc commands
Use the new isc registration functions for all places that need
an I/O interruption subclass.
Enhance the adapter interruption API so that device drivers can
register a handler for a specific interruption subclass. This
will allow different device drivers to move to differently
prioritized subclasses in order to avoid congestion.
Replace the numeric values for I/O interruption subclass usage
with abstract definitions and collect them all in asm/isc.h.
This gives us a better overview of which iscs are actually used
and makes it possible to better spread out isc usage in the
future.
Provide functions for assembling and starting fcx enabled I/O request
blocks.
Extend the scsw data structure to the format required by fcx. Also
provide helper functions for easier access to fields which are present
in both the traditional as well as the modified format.
Rework the css driver methods to provide sane callbacks for
subchannels of all types.
As a bonus, this cleans up and simplyfies the machine check
handling for I/O subchannels a lot.
Register all valid subchannels, not only I/O subchannels.
Move I/O subchannel specific initialization to io_subchannel_probe().
Fallout from the console isc 7 -> 1 change.
Priorities for I/O interruption subclasses range from 0 (highest)
to 7 (lowest). Unfortunately, the console has been using isc 7
instead of an isc with a higher priority than regular I/O
subchannels (which use 3). Fix this by making the console use
isc 1.
The only sporadically used CIO_DEBUG messages are replaced by ordinary
CIO_MSG_EVENT messages. The CIO_MSG_EVENT messages debug levels are
consolidated.
Introduce an ->isc field in the subchannel to store the desired
interruption subclass, since sch->schib.pmcw.isc may be overwritten
by the hardware on stsch() after machine checks.
Most noteable part of this commit is the new local header file entry.h
which contains all the function declarations of functions that get only
called from asm code or are arch internal. That way we can avoid extern
declarations in C files.
This is more or less the same that was done for sparc64.
This way we get rid of s390's NO_IDLE_HZ and use the generic dynticks
variant instead. In addition we get high resolution timers for free.
Remove the program check generating monitor calls and use function
calls instead. Theres is no real advantage in using monitor calls,
but they do make debugging harder, because of all the program checks
it generates.
