Remove the file name from the comment at top of many files. In most
cases the file name was wrong anyway, so it's rather pointless.
Also unify the IBM copyright statement. We did have a lot of sightly
different statements and wanted to change them one after another
whenever a file gets touched. However that never happened. Instead
people start to take the old/"wrong" statements to use as a template
for new files.
So unify all of them in one go.
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 updates from Martin Schwidefsky:
"Just a random collection of bug-fixes and cleanups, nothing new in
this merge request."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (46 commits)
s390/ap: Fix wrong or missing comments
s390/ap: move receive callback to message struct
s390/dasd: re-prioritize partition detection message
s390/qeth: reshuffle initialization
s390/qeth: cleanup drv attr usage
s390/claw: cleanup drv attr usage
s390/lcs: cleanup drv attr usage
s390/ctc: cleanup drv attr usage
s390/ccwgroup: remove ccwgroup_create_from_string
s390/qeth: stop using struct ccwgroup driver for discipline callbacks
s390/qeth: switch to ccwgroup_create_dev
s390/claw: switch to ccwgroup_create_dev
s390/lcs: switch to ccwgroup_create_dev
s390/ctcm: switch to ccwgroup_create_dev
s390/ccwgroup: exploit ccwdev_by_dev_id
s390/ccwgroup: introduce ccwgroup_create_dev
s390: fix race on TIF_MCCK_PENDING
s390/barrier: make use of fast-bcr facility
s390/barrier: cleanup barrier functions
s390/claw: remove "eieio" calls
Commit 1abd2296b4a1ee7b6a883541c3ede52042a09521 starts removing
token ring from qeth_l3. This patch removes the rest of token
ring related code from the driver.
Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com>
The interface between qeth and its disciplines should not depend on
struct ccwgroup_driver, as a qeth discipline is not a ccwgroup
driver on its own. Instead provide the particular callbacks in struct
qeth_discipline.
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
Switch to the new ccwgroup_create_dev interface. Also wrap device
attributes in a struct device_type and let the driver core create
these attributes automagically.
The token ring support is going away from the core kernel.
Divorce the S390 drivers from it in advance.
Cc: linux390@de.ibm.com
Cc: linux-s390@vger.kernel.org
Add qeth device private ioctl to query the OSA address table.
This helps debugging hw related problems.
Patch avoids SIGA-r calls in case of SIGA-r required. It only calls
SIGA-r if a threshold of free buffer is reached. CPU consumption is
reduced as a consequence.
Signed-off-by: Einar Lueck <elelueck@de.ibm.com>
This patch extends the HiperSockets device driver to send and receive
af_iucv traffic over HiperSockets transport.
TX: Driver uses new asynchronous delivery of storage blocks to pass
flow control/congestion information from the HiperSockets microcode
to the af_iucv socket.
RX: Memory for incoming traffic is preallocated and passed to
HiperSockets layer. If receiver is not capable to clean its buffers
shared with HiperSockets and pass new memory to the HiperSockets
layer this will cause flow control/congestion events on the
sender.
Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com>
This patch exploits the QDIO support for asynchronous delivery of storage
blocks for Hipersockets. The exploitation is not configured per default and
may be enabled via the function qeth_configure_cq.
This patch ensures that signal adapter commands are issued if they are
indicated to be required.
- unify vlan and nonvlan rx path
- kill card->vlangrp and qeth_l3_vlan_rx_register
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
The qdio SBAL entry flag is made-up of four different values that are
independent of one another. Some of the bits are reserved by the
hardware and should not be changed by qdio. Currently all four values
are overwritten since the SBAL entry flag is defined as an u32.
Split the SBAL entry flag into four u8's as defined by the hardware
and don't touch the reserved bits.
Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com>
This patch improves FFDC (first failure data capture) by requesting
a hardware trace in case the device driver, the hardware or a user
detects an error.
Set rx csum default to hw checksumming again.
Remove sysfs interface for rx csum (checksumming) and TSO (large_send).
With the new hw_features it does not work to keep the old sysfs
interface in parallel. Convert options.checksum_type to new hw_features.
options.large_send was easy to get rid of. options.checksum_type has deeper
roots so is left for later cleanup.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
This patch turns on RX checksum and GRO by default. To improve
receiving performance and reduce congestion in case of network
bursts we also increase the default number of inbound buffers.
If a qeth device is set offline, data and control subchannels are
cleared, which means removal of all IP Assist Primitive settings
implicitly. There is no need to delete those settings explicitly.
This patch removes all IP Assist invocations from offline.
For a certain Hipersockets specific error code in the xmit path, the
qeth driver tries to invoke dev_queue_xmit again.
Commit 79640a4ca6955e3ebdb7038508fa7a0cd7fa5527 introduces a busylock
causing locking problems in case of re-invoked dev_queue_xmit by qeth.
This patch removes the attempts to retry packet sending with
dev_queue_xmit from the qeth driver.
This patch adds NAPI support to the qeth layer 2 and layer 3
discipline. It is important to understand that we can not enable/disable
IRQs as usual, we have to use the corresponding new QDIO interface.
Also to not overdraw the budget we have to stop and restart buffer
processing at any point during processing a bulk of QDIO buffers.
Having the driver NAPI enabled it is possible to turn on GRO for the
layer 3 discipline.
If qeth issues an ipa command, but for some reasons the response
never comes back, qeth reaches a timeout.
Reset the irq_pending flag of the write channel in timeout handling
code and trigger a recovery to avoid endless looping for the following
ipa command.
This patch serializes device removal and other sysfs-triggered
configurations by moving removal of sysfs-attributes to the beginning
of the remove functions. And it serializes online/offline setting
and discipline-switching (causing reestablishing of the net_device)
by making use of a new discipline mutex.
The qeth IP address flag setting is possible when device is
offline. When setting device online afterwards the current set
IP addresses have to be correctly registered with the device
regarding the IP address takeover attribute.
Signed-off-by: Klaus-Dieter Wacker <kdwacker@de.ibm.com>
Turning on memory debugging showed there could be page breaks in
hardware headers. OSA does not allow this so we had to add code
to bounce the header in case there is a page break. This patch also
fixes a problem in case the skb->data part of a fragmented skb
spreads multiple pages.
This patch removes the qerr debug area. Most info that goes in here is logged
to the card's local debug area already, those duplicates are removed. All other
elements are moved to the card's local debug area.
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
This patch removes the misc debug area. Instead of logging the entire skb
we just log a pointer to it into the card's local debug area in
qeth_core_get_next_skb. Other then that, this debug area is not used anywhere.
This patch removes the sense debug area completely. Despite the name this
debug area makes no sense at all because it's unused completely. Ouch.
This patch removes the qeth_trace debug area. All relevant data is logged into
either qeth_setup or into each card's own debug area. Superfluous information
(such as the card number when logging into the card's own debug area) is
removed without replacement.
This patch adds a debug area for each qeth card. This debug area will replace
various other debug areas that are global for all cards handled by the device
driver. On crash dump analysis this makes life easier when trying to find out
what's going on with an interface. Also, the forest of debug areas for this
device driver is significantly cleared up.
This patch decouples qeth_dbf_longtext from qeth's static debug array. The
function only uses one member anyway.
The qeth driver is enabled to support the new OSA CHPID types OSX
and OSM.
Synchronize access to the drivers configuration interface.
Also do not allow configuration changes during online/offline
transition.
OSA supports HW TX checksumming in layer 3 mode. Enable this
feature and remove software fallback used for TSO. Cleanup
checksum bits to indicate OSA can do checksumming only for
IPv4 TCP and UDP.
dhcp frames are valid IPv4 packets so there is no need to send them
in pass thru mode. This allows dhcp packets to pass HiperSockets.
Also the dhcp release frame is send out correctly with this patch.
New feature to trace HiperSockets network traffic for debugging
purposes.
The maximum TSO size OSA can handle is 15 * PAGE_SIZE. This
patch reduces gso_max_size to this value and adds some sanity
checks and statistics to the TSO implementation.
Since only layer 3 is able to do TSO move all TSO related functions
to the qeth_l3 module.
EDDP code has been removed from qeth in 2009. This patch removes two
useless remaining EDDP-references.
Isolate data connection to a shared OSA card against other data
connections to the same OSA card. Connectivity between isolated
data connections sharing the same OSA card is therefore possible only
through external network gear (e.g. a router).
This string query operation was supposed to be replaced by the
generic get_sset_count() starting in 2007. Convert qeth's
implementation.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Clear separation of cast-type determination (send path) for layer-2
resp. layer-3. Allowing to have inline functions for qeth layer-
discipline.
Qeth HiperSockets support now retries sending of packets when the
IBM System z signals a temporary resource shortage (e.g. target
buffer full). The packet is enqueued into the device queue.
After 3 times of unsuccessful send the packet is dropped.
Performance measurements showed EDDP does not lower CPU costs but increase
them. So we dump out EDDP code from qeth driver.
Add statistics counter for software tx checksumming.
OSA-devices operating in layer3 mode offer adding of the source MAC
address to the QDIO header of inbound packets. The qeth driver can
exploit this functionality to replace FAKELL-entries in the ethernet
header of received packets.
Add a new proc interface /proc/service_levels that allows any code
to report a relevant service level, e.g. the microcode level of
devices, the service level of the hypervisor, etc.
bus_id -> dev_name() conversions in s390 code.
[cornelia.huck@de.ibm.com: minor adaptions]
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
In case the netdev unicast list contains additional entries we have
to register/deregister them.
For hiper socket devices this patch will economize the reallocation
of the tx skb data segment by allocating separate memory for the qdio
transport information (qeth header).
List of major changes:
- split qdio driver into several files
- seperation of thin interrupt code
- improved handling for multiple thin interrupt devices
- inbound and outbound processing now always runs in tasklet context
- significant less tasklet schedules per interrupt needed
- merged qebsm with non-qebsm handling
- cleanup qdio interface and added kerneldoc
- coding style
Reviewed-by: Utz Bacher <utz.bacher@de.ibm.com>
Reviewed-by: Ursula Braun <braunu@de.ibm.com>
