This patch improves FFDC (first failure data capture) by requesting
a hardware trace in case the device driver, the hardware or a user
detects an error.
Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com>
This patch serializes device removal and other sysfs-triggered
configurations by moving removal of sysfs-attributes to the beginning
of the remove functions. And it serializes online/offline setting
and discipline-switching (causing reestablishing of the net_device)
by making use of a new discipline mutex.
Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com>
This patch fixes a problem that occurs when switching from layer 3 to layer 2
mode. Resetting this mac_bits makes sure that we retrieve our mac address from
the card, otherwise the interface simply would'nt work.
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
The qeth driver is enabled to support the new OSA CHPID types OSX
and OSM.
Synchronize access to the drivers configuration interface.
Also do not allow configuration changes during online/offline
transition.
provide qeth kmsg definitions to enable hash string generation for
kernel message created with dev_err().
Set default BLKT values for new OSA/3 hardware.
Signed-off-by: Einar Lueck <elelueck@de.ibm.com>
New feature to trace HiperSockets network traffic for debugging
purposes.
The maximum TSO size OSA can handle is 15 * PAGE_SIZE. This
patch reduces gso_max_size to this value and adds some sanity
checks and statistics to the TSO implementation.
Since only layer 3 is able to do TSO move all TSO related functions
to the qeth_l3 module.
Isolate data connection to a shared OSA card against other data
connections to the same OSA card. Connectivity between isolated
data connections sharing the same OSA card is therefore possible only
through external network gear (e.g. a router).
If nothing has been written into the qeth sysfs-attribute layer2,
its value is "-1" meaning "not yet defined". But the value is
displayed as "1" meaning "layer2 selected". The patch changes the
reading of this "-1"-value to "-1" to make clear the layer2-attribute
has not yet been defined.
Performance measurements showed EDDP does not lower CPU costs but increase
them. So we dump out EDDP code from qeth driver.
Remove unnecessary messages. Write important debug information to
s390dbf.
List of major changes and improvements:
no manipulation of the global ARP constructor
clean code split into core, layer 2 and layer 3 functionality
better exploitation of the ethtool interface
better representation of the various hardware capabilities
fix packet socket support (tcpdump), no fake_ll required
osasnmpd notification via udev events
coding style and beautification
Signed-off-by: Jeff Garzik <jeff@garzik.org>
