[ Upstream commit 4d19db777a2f32c9b76f6fd517ed8960576cb43e ]
Calling napi_schedule() from process context does not ensure that the
NET_RX softirq is run in a timely fashion. So trigger it manually.
This is no big issue with current code. A call to ndo_open() is usually
followed by a ndo_set_rx_mode() call, and for qeth this contains a
spin_unlock_bh(). Except for OSN, where qeth_l2_set_rx_mode() bails out
early.
Nevertheless it's best to not depend on this behaviour, and just fix
the issue at its source like all other drivers do. For instance see
commit 83a0c6e58901 ("i40e: Invoke softirqs after napi_reschedule").
Fixes: a1c3ed4c9ca0 ("qeth: NAPI support for l2 and l3 discipline")
Signed-off-by: Julian Wiedmann <jwi@linux.ibm.com>
[ Upstream commit 335726195e460cb6b3f795b695bfd31f0ea70ef0 ]
Enabling sysfs attribute bridge_hostnotify triggers a series of udev events
for the MAC addresses of all currently connected peers. In case no VLAN is
set for a peer, the device reports the corresponding MAC addresses with
VLAN ID 4096. This currently results in attribute VLAN=4096 for all
non-VLAN interfaces in the initial series of events after host-notify is
enabled.
Instead, no VLAN attribute should be reported in the udev event for
non-VLAN interfaces.
Only the initial events face this issue. For dynamic changes that are
reported later, the device uses a validity flag.
This also changes the code so that it now sets the VLAN attribute for
MAC addresses with VID 0. On Linux, no qeth interface will ever be
registered with VID 0: Linux kernel registers VID 0 on all network
interfaces initially, but qeth will drop .ndo_vlan_rx_add_vid for VID 0.
Peers with other OSs could register MACs with VID 0.
Fixes: 9f48b9db9a22 ("qeth: bridgeport support - address notifications")
Signed-off-by: Alexandra Winter <wintera@linux.ibm.com>
[ Upstream commit 0ac1487c4b2de383b91ecad1be561b8f7a2c15f4 ]
For inbound data with an unsupported HW header format, only dump the
actual HW header. We have no idea how much payload follows it, and what
it contains. Worst case, we dump past the end of the Inbound Buffer and
access whatever is located next in memory.
[ Upstream commit 6be687395b3124f002a653c1a50b3260222b3cd7 ]
On removal, a qeth card's netdevice is currently not properly freed
because the call chain looks as follows:
qeth_core_remove_device(card)
lx_remove_device(card)
unregister_netdev(card->dev)
card->dev = NULL !!!
qeth_core_free_card(card)
if (card->dev) !!!
free_netdev(card->dev)
Fix it by free'ing the netdev straight after unregistering. This also
fixes the sysfs-driven layer switch case (qeth_dev_layer2_store()),
where the need to free the current netdevice was not considered at all.
Note that free_netdev() takes care of the netif_napi_del() for us too.
Fixes: 4a71df50047f ("qeth: new qeth device driver")
Signed-off-by: Julian Wiedmann <jwi@linux.vnet.ibm.com>
Reviewed-by: Ursula Braun <ubraun@linux.vnet.ibm.com>
[ Upstream commit 6d69b1f1eb7a2edf8a3547f361c61f2538e054bb ]
Using GSO with small MTUs currently results in a substantial throughput
regression - which is caused by how qeth needs to map non-linear skbs
into its IO buffer elements:
compared to a linear skb, each GSO-segmented skb effectively consumes
twice as many buffer elements (ie two instead of one) due to the
additional header-only part. This causes the Output Queue to be
congested with low-utilized IO buffers.
Fix this as follows:
If the MSS is low enough so that a non-SG GSO segmentation produces
order-0 skbs (currently ~3500 byte), opt out from NETIF_F_SG. This is
where we anticipate the biggest savings, since an SG-enabled
GSO segmentation produces skbs that always consume at least two
buffer elements.
Larger MSS values continue to get a SG-enabled GSO segmentation, since
1) the relative overhead of the additional header-only buffer element
becomes less noticeable, and
2) the linearization overhead increases.
With the throughput regression fixed, re-enable NETIF_F_SG by default to
reap the significant CPU savings of GSO.
Fixes: 5722963a8e83 ("qeth: do not turn on SG per default")
Reported-by: Nils Hoppmann <niho@de.ibm.com>
[ Upstream commit 0cbff6d4546613330a1c5f139f5c368e4ce33ca1 ]
The current GSO skb size limit was copy&pasted over from the L3 path,
where it is needed due to a TSO limitation.
As L2 devices don't offer TSO support (and thus all GSO skbs are
segmented before they reach the driver), there's no reason to restrict
the stack in how large it may build the GSO skbs.
Fixes: d52aec97e5bc ("qeth: enable scatter/gather in layer 2 mode")
Taking a full copy via skb_realloc_headroom() on every xmit is overkill
and wastes CPU time; all we actually need is to push on the qeth_hdr.
So rework the L2 OSA TX path to avoid the copy.
Minor complications arise because struct qeth_hdr must not cross a page
boundary. So add a new helper qeth_push_hdr() that catches this, and
falls back to the hdr cache that we already use for IQDs.
This change uncovered that qeth's TX completion takes rather long.
Now that we no longer free the original skb straight away and thus call
skb->destructor later than before, throughput regresses significantly.
For now, restore old behaviour by adding an explicit skb_orphan(),
and a big TODO to improve the TX completion time.
Tested-by: Nils Hoppmann <niho@de.ibm.com>
This is a prerequisite for unifying the code to build header elements.
The TSO header has a different size, so we can no longer rely on implicitly
adding the size of a normal qeth_hdr.
No functional change.
For TSO we need to skip the skb's qeth/IP/TCP headers when mapping
it into buffer elements. Instead of (mis)using skb_pull(), pass a
corresponding offset to fill_buffer() like we already do for IQDs.
No actual change in the resulting TSO buffers.
The TSO code already calculates the length of its header element,
no need to duplicate this in the low-level code again.
Use this opportunity to make hd_len unsigned, and for TSO match
its calculation to what tso_fill_header() does.
For IQD we already need to fix up the qeth_hdr's length field, and
future changes will require more flexibility for OSA as well. The
device-specific path knows best what header length it requires, so just
pass it from there.
While at it, remove the unused qeth_card parameter.
l2_hard_start_xmit() actually doesn't contain much shared code,
and having device-specific paths makes isolated changes a lot easier.
So split it into three routines for IQD, OSN and OSD/OSM/OSX.
Consolidation of duplicated code, no functional change.
Clean up the inline cruft in s390 net drivers. Many of the inlined
functions had only one caller anyway.
Suggested-by: Joe Perches <joe@perches.com>
Replace some open-coded parts with their proper API calls.
Also remove two skb_[re]set_mac_header() calls in the L2
xmit paths that are clearly no longer required, since at least
commit 6d1ccff62780 ("net: reset mac header in dev_start_xmit()").
Acked-by: Ursula Braun <ubraun@linux.vnet.ibm.com>
qeth_l2_request_initial_mac() queries the device for its supported
adapterparms, even though they already have been queried as part of the
device's high-level setup. Remove that extra call.
The only call chain for qeth_l2_request_initial_mac() is
__qeth_l2_set_online()
qeth_core_hardsetup_card()
qeth_query_setadapterparms()
qeth_l2_setup_netdev()
, and we only reach qeth_l2_request_initial_mac() if the first
adapterparms query succeeds. Hence removing the second query results in
no loss of functionality.
After transmitting a skb via send_packet[_fast](), the statistics
code accesses the skb once more to account for transmitted page frags.
This has a (theoretical?) race against the TX completion - if the TX
completion is processed and frees the skb before hard_start_xmit()
gets to the statistics part, we access random memory.
Fix this by caching the # of page frags, before the skb is transmitted.
When a s390 guest runs on a z/VM host that's part of a SSI cluster,
it can be migrated to a different host. In this case, the MAC address
it originally obtained on the old host may be re-assigned to a new
guest. This would result in address conflicts between the two guests.
When running as z/VM guest, use the diag26c MAC Service to obtain
a hypervisor-managed MAC address. The MAC Service is SSI-aware, and
won't re-assign the address after the guest is migrated to a new host.
This patch adds support for the z/VM MAC Service on L2 devices.
add ipa return codes for Bridgeport (HiperSockets and OSA) according to
system level design.
Signed-off-by: Kittipon Meesompop <kmeesomp@linux.vnet.ibm.com>
Reviewed-by: Julian Wiedmann <jwi@linux.vnet.ibm.com>
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions return void * and remove all the casts across
the tree, adding a (u8 *) cast only where the unsigned char pointer
was used directly, all done with the following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = { skb_push, __skb_push, skb_push_rcsum };
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
- fn(SKB, LEN)[0]
Note that the last part there converts from push(...)[0] to the
more idiomatic *(u8 *)push(...).
Bridgeport is a l2-specific feature, and we should write its
capabilities to a debug entry.
Access card->dev only after checking whether's its valid.
commit b4d72c08b358 ("qeth: bridgeport support - basic control")
broke the support for OSM and OSN devices as follows:
As OSM and OSN are L2 only, qeth_core_probe_device() does an early
setup by loading the l2 discipline and calling qeth_l2_probe_device().
In this context, adding the l2-specific bridgeport sysfs attributes
via qeth_l2_create_device_attributes() hits a BUG_ON in fs/sysfs/group.c,
since the basic sysfs infrastructure for the device hasn't been
established yet.
Note that OSN actually has its own unique sysfs attributes
(qeth_osn_devtype), so the additional attributes shouldn't be created
at all.
For OSM, add a new qeth_l2_devtype that contains all the common
and l2-specific sysfs attributes.
When qeth_core_probe_device() does early setup for OSM or OSN, assign
the corresponding devtype so that the ccwgroup probe code creates the
full set of sysfs attributes.
This allows us to skip qeth_l2_create_device_attributes() in case
of an early setup.
Any device that can't do early setup will initially have only the
generic sysfs attributes, and when it's probed later
qeth_l2_probe_device() adds the l2-specific attributes.
If an early-setup device is removed (by calling ccwgroup_ungroup()),
device_unregister() will - using the devtype - delete the
l2-specific attributes before qeth_l2_remove_device() is called.
So make sure to not remove them twice.
What complicates the issue is that qeth_l2_probe_device() and
qeth_l2_remove_device() is also called on a device when its
layer2 attribute changes (ie. its layer mode is switched).
For early-setup devices this wouldn't work properly - we wouldn't
remove the l2-specific attributes when switching to L3.
But switching the layer mode doesn't actually make any sense;
we already decided that the device can only operate in L2!
So just refuse to switch the layer mode on such devices. Note that
OSN doesn't have a layer2 attribute, so we only need to special-case
OSM.
Based on an initial patch by Ursula Braun.
Fixes: b4d72c08b358 ("qeth: bridgeport support - basic control")
When setting up the device from within the layer discipline's
probe routine, creating the layer-specific sysfs attributes can fail.
Report this error back to the caller, and handle it by
releasing the layer discipline.
Signed-off-by: Ursula Braun <ubraun@linux.vnet.ibm.com>
[jwi: updated commit msg, moved an OSN change to a subsequent patch]
get_settings() is deprecated and lacks support for higher link
speeds, so implement get_link_ksettings() instead.
Reviewed-by: Thomas Richter <tmricht@linux.vnet.ibm.com>
1. a buffer has 16 is_header flags, because that's its # of elements
2. replace the last occurrence of QETH_HEADER_SIZE, and remove it
ndo_start_xmit() expects us to return netdev_tx_t here...
'elements_needed' is not used in qeth_do_send_packet_fast(),
so consequently remove it.
Duplicated code.
Identical code, we just need to call a layer-specific hook
to process any received buffer.
qeth_buffer_reclaim_work() is shuffled around to avoid a
forward declaration for qeth_queue_input_buffer().
There's a number of layer-independent ioctls that we can handle
in core, and reduce code duplication. For layer-specific ioctls,
add a do_ioctl() discipline hook.
1. options.add_hhlen is set but never used, drop it
2. clean up no longer required forward declarations
3. delete all sorts of unused defines
Depending on the device type, hard_start_xmit() builds different output
buffer formats. For instance with HiperSockets, on both L2 and L3 we
strip the ETH header from the skb - L3 doesn't need it, and L2 carries
it in the buffer's header element.
For this, we pass data_offset = ETH_HLEN all the way down to
__qeth_fill_buffer(), where skb->data is then adjusted accordingly.
But the initial size calculation still considers the *full* skb length
(including the ETH header). So qeth_get_elements_no() can erroneously
reject a skb as too big, even though it would actually fit into an
output buffer once the ETH header has been trimmed off later.
Fix this by passing an additional offset to qeth_get_elements_no(),
that indicates where in the skb the on-wire data actually begins.
Since the current code uses data_offset=-1 for some special handling
on OSA, we need to clamp data_offset to 0...
On HiperSockets this helps when sending ~MTU-size skbs with weird page
alignment. No change for OSA or AF_IUCV.
STARTLAN needs to be the first IPA command after MPC initialization
completes.
So move the qeth_send_startlan() call from the layer disciplines
into the core path, right after the MPC handshake.
While at it, replace the magic LAN OFFLINE return code
with the existing enum.
Move all MAC utility functions in one place, and drop the
forward declarations.
This matches qeth_l2_write_mac().
Consolidate errno handling for MAC management: Instead of doing this in every
caller, do it in one place.
Suggested-by: Ursula Braun <ubraun@linux.vnet.ibm.com>
qeth_l2_send_groupmac() already translates the return code, so
calling qeth_setdel_makerc() a second time only produces garbage.
The only caller passes del = 0, so remove both the parameter and
the code that handles != 0.
ctcm:
- min_mtu = 576, max_mtu = 65527
netiucv:
- min_mtu = 576, max_mtu = 65535
qeth:
- min_mtu = 64, max_mtu = 65535
CC: netdev@vger.kernel.org
CC: linux-s390@vger.kernel.org
CC: Ursula Braun <ubraun@linux.vnet.ibm.com>
Signed-off-by: Jarod Wilson <jarod@redhat.com>
According to recent performance measurements, turning on net_device
feature NETIF_F_SG only behaves well, but turning on feature
NETIF_F_GSO shows bad results. Since the kernel activates NETIF_F_GSO
automatically as soon as the driver configures feature NETIF_F_SG, qeth
should not activate feature NETIF_F_SG per default, until the qeth
problems with NETIF_F_GSO are solved.
To reduce the need of skb_linearize() calls, gso_max_segs of qeth
net_devices had been limited according to the maximum number of qdio SBAL
elements. But a gso segment cannot be larger than the mtu-size, while an
SBAL element can contain up to 4096 bytes. The gso_max_segs limitation
limits the maximum packet size given to the qeth driver. Performance
measurements with tso-enabled qeth network interfaces and mtu-size 1500
showed, that the disadvantage of smaller packets is much more severe than
the advantage of fewer skb_linearize() calls.
This patch gets rid of the gso_max_segs limitations in the qeth driver.
After device recovery, only a basic set of network device features is
enabled on the device. If features like checksum offloading or TSO were
enabled by the user before the recovery, this results in a mismatch
between the network device features, that the kernel assumes to be
enabled on the device, and the features actually enabled on the device.
This patch tries to restore previously set features, that require
changes on the device, after the recovery of a device. In case of an
error, the network device's features are changed to contain only the
features that are actually turned on.
Signed-off-by: Hans Wippel <hwippel@linux.vnet.ibm.com>
drivers/net/ethernet/mellanox/mlx5/core/en.h
drivers/net/ethernet/mellanox/mlx5/core/en_main.c
drivers/net/usb/r8152.c
All three conflicts were overlapping changes.
A qeth_card contains a napi_struct linked to the net_device during
device probing. This struct must be deleted when removing the qeth
device, otherwise Panic on oops can occur when qeth devices are
repeatedly removed and added.
Fixes: a1c3ed4c9ca ("qeth: NAPI support for l2 and l3 discipline")
Cc: stable@vger.kernel.org # v2.6.37+
Tested-by: Alexander Klein <ALKL@de.ibm.com>
Network device features indicate the capabilities of network devices (e.g.,
TX checksum offloading and TSO) and their configuration state. Additional
network device features (vlan_features) indicate for each network device,
which capabilities can be used on VLAN devices, that are configured on the
respective base network device.
In the current qeth implementation, network device features are only set
for the base network devices and not for the VLAN devices. Thus, features
like TX checksum offloading cannot be used on VLAN devices.
This patch adds network device features to vlan_features, so they can be
used by VLAN devices.
This patch introduces a common set of fix_features and set_features
functions for layer 2 and layer 3. The RX, TX and TSO offload
functionality on the OSA card is enabled using ethtool at user's
request and not at device initialization as done before.
For layer 3 the RX checksum offloading is disabled at device
initialization time.
Signed-off-by: Thomas Richter <tmricht@linux.vnet.ibm.com>
In layer3 mode of the qeth driver, multicast IP addresses
from struct net_device and other type of IP addresses
from other sources require mapping to the OSA-card.
This patch simplifies the IP address mapping logic, and changes imple-
mentation of ndo_set_rx_mode callback and ip notifier events.
Addresses are stored in private hashtables instead of lists now.
It allows hardware registration/removal for new/deleted multicast
addresses only.
Signed-off-by: Lakhvich Dmitriy <ldmitriy@ru.ibm.com>
Reviewed-by: Evgeny Cherkashin <Eugene.Crosser@ru.ibm.com>
When skb data touches too many pages, skb_linearize() is called
opportunistically in the hope that less pages will be required
for a big linear buffer than for multiple fragments. This patch
intoduces a separate counter in ethtool statistics structure
representing _failed_ linearization attempts.
Signed-off-by: Eugene Crosser <Eugene.Crosser@ru.ibm.com>
Reviewed-by: Lakhvich Dmitriy <ldmitriy@ru.ibm.com>
Reviewed-by: Thomas Richter <tmricht@de.ibm.com>
Set scatter/gather ON by default on OSA, for both layer 2 and
layer 3 modes. We always use fragmentation over QDIO anyway,
so let the upper layers of the stack take advantage of that.
