This patch improves FFDC (first failure data capture) by requesting
a hardware trace in case the device driver, the hardware or a user
detects an error.
Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com>
Set rx csum default to hw checksumming again.
Remove sysfs interface for rx csum (checksumming) and TSO (large_send).
With the new hw_features it does not work to keep the old sysfs
interface in parallel. Convert options.checksum_type to new hw_features.
If a qeth device is set offline, data and control subchannels are
cleared, which means removal of all IP Assist Primitive settings
implicitly. There is no need to delete those settings explicitly.
This patch removes all IP Assist invocations from offline.
Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com>
Setting of a MAC-address may fail because an already used MAC-address
is to bet set or because of authorization problems. In those cases
qeth issues a message, but the mentioned MAC-address is not the
new MAC-address to be set, but the actual MAC-address. This patch
chooses now the new MAC-address to be set for the error messages.
The open function of qeth is not executed if the qeth device is in
state DOWN or HARDSETUP. A recovery switches from state SOFTSETUP to
HARDSETUP to DOWN to HARDSETUP and back to SOFTSETUP. If open and
recover are running concurrently, open fails if it hits the states
HARDSETUP or DOWN. This patch inserts waiting for recovery finish
in the qeth open functions to enable successful qeth device opening
in spite of a running recovery.
Device initialization of a qeth device contains a STARTLAN step.
This step may fail, if cable is not yet plugged in. The qeth device
stays in state HARDSETUP until cable is plugged in. This prevents
further preparational initialization steps of the qeth device and
its network interface. This patch makes sure initialization of qeth
device continues, even though cable is not yet plugged in.
Once carrier is available, qeth is notified, triggers a recovery
which results in a working network interface.
This patch adapts qeth to handle tagged frames with VLAN-ID 0 and
with or without priority information in the tag. It enables qeth to
receive priority-tagged frames on a base interface, for example from
z/OS, without configuring an additional VLAN interface.
This patch adds NAPI support to the qeth layer 2 and layer 3
discipline. It is important to understand that we can not enable/disable
IRQs as usual, we have to use the corresponding new QDIO interface.
Also to not overdraw the budget we have to stop and restart buffer
processing at any point during processing a bulk of QDIO buffers.
Having the driver NAPI enabled it is possible to turn on GRO for the
layer 3 discipline.
Function qeth_l2_remove_device invokes qeth_l2_del_all_mc at the end.
This is needless, because it is already called in the offline function.
And even more this is invalid, because multicast addresses cannot be
removed in DOWN state. Thus this patch deletes invocation of
qeth_l2_del_all_mc in function qeth_l2_remove_device.
This patch serializes device removal and other sysfs-triggered
configurations by moving removal of sysfs-attributes to the beginning
of the remove functions. And it serializes online/offline setting
and discipline-switching (causing reestablishing of the net_device)
by making use of a new discipline mutex.
Turning on memory debugging showed there could be page breaks in
hardware headers. OSA does not allow this so we had to add code
to bounce the header in case there is a page break. This patch also
fixes a problem in case the skb->data part of a fragmented skb
spreads multiple pages.
This patch removes the qeth_trace debug area. All relevant data is logged into
either qeth_setup or into each card's own debug area. Superfluous information
(such as the card number when logging into the card's own debug area) is
removed without replacement.
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
The qeth driver is enabled to support the new OSA CHPID types OSX
and OSM.
Synchronize access to the drivers configuration interface.
Also do not allow configuration changes during online/offline
transition.
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
In mlx4, using char * to store mc address in private structure instead.
Depending on their definition in z/VM, virtual devices for z/VM
VSWITCH or GuestLAN must be configured either in layer2 or in
layer3 mode. If qeth detects a layer mismatch, device activation
fails. Trying to recover from this error cannot help; thus
scheduling a recovery should be avoided.
In addition, since recovery is forbidden during online setting of
a qeth device, existence of its network device is guaranteed for all
dev_close() calls in qeth. The corresponding checks can be removed.
This patch introduces three macros to work with uc list from net drivers.
If a qeth device is set online, several initialisation steps are
performed. If a failure in one of these steps occurs, the qeth
device is reset into DOWN state. If due to the failure a qeth recovery
is scheduled and started in another thread, this might cause all kinds
of conflicts, even a kernel panic. The patch forbids scheduling of a
qeth recovery while online processing is performed till the card is in
state SOFTSETUP.
New feature to trace HiperSockets network traffic for debugging
purposes.
Use the %pM kernel extension to display the MAC address.
The maximum TSO size OSA can handle is 15 * PAGE_SIZE. This
patch reduces gso_max_size to this value and adds some sanity
checks and statistics to the TSO implementation.
Since only layer 3 is able to do TSO move all TSO related functions
to the qeth_l3 module.
Setting a qeth device online requires to call function
ccw_device_set_online() for read-, write-, and data-subchannel.
Failures should be detected immediately without an attempt to
invoke follow-on activity qeth_qdio_clear_card().,
In addition, ccw_device_set_online calls are consolidated in
qeth_core_main.c only.
Isolate data connection to a shared OSA card against other data
connections to the same OSA card. Connectivity between isolated
data connections sharing the same OSA card is therefore possible only
through external network gear (e.g. a router).
Signed-off-by: Einar Lueck <elelueck@de.ibm.com>
This string query operation was supposed to be replaced by the
generic get_sset_count() starting in 2007. Convert qeth's
implementation.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
The generic packet receive code takes care of setting
netdev->last_rx when necessary, for the sake of the
bonding ARP monitor.
Acked-by: Neil Horman <nhorman@txudriver.com>
No need to put ethtool_ops in data, they should be const.
Clear separation of cast-type determination (send path) for layer-2
resp. layer-3. Allowing to have inline functions for qeth layer-
discipline.
Signed-off-by: Klaus-Dieter Wacker <kdwacker@de.ibm.com>
This patch converts the remaining occurences of raw return values to their
symbolic counterparts in ndo_start_xmit() functions that were missed by the
previous automatic conversion.
Additionally code that assumed the symbolic value of NETDEV_TX_OK to be zero
is changed to explicitly use NETDEV_TX_OK.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (55 commits)
netxen: fix tx ring accounting
netxen: fix detection of cut-thru firmware mode
forcedeth: fix dma api mismatches
atm: sk_wmem_alloc initial value is one
net: correct off-by-one write allocations reports
via-velocity : fix no link detection on boot
Net / e100: Fix suspend of devices that cannot be power managed
TI DaVinci EMAC : Fix rmmod error
net: group address list and its count
ipv4: Fix fib_trie rebalancing, part 2
pkt_sched: Update drops stats in act_police
sky2: version 1.23
sky2: add GRO support
sky2: skb recycling
sky2: reduce default transmit ring
sky2: receive counter update
sky2: fix shutdown synchronization
sky2: PCI irq issues
sky2: more receive shutdown
sky2: turn off pause during shutdown
Manually fix trivial conflict in net/core/skbuff.c due to kmemcheck
This patch is inspired by patch recently posted by Johannes Berg. Basically what
my patch does is to group list and a count of addresses into newly introduced
structure netdev_hw_addr_list. This brings us two benefits:
1) struct net_device becames a bit nicer.
2) in the future there will be a possibility to operate with lists independently
on netdevices (with exporting right functions).
I wanted to introduce this patch before I'll post a multicast lists conversion.
drivers/net/bnx2.c | 4 +-
drivers/net/e1000/e1000_main.c | 4 +-
drivers/net/ixgbe/ixgbe_main.c | 6 +-
drivers/net/mv643xx_eth.c | 2 +-
drivers/net/niu.c | 4 +-
drivers/net/virtio_net.c | 10 ++--
drivers/s390/net/qeth_l2_main.c | 2 +-
include/linux/netdevice.h | 17 +++--
net/core/dev.c | 130 ++++++++++++++++++--------------------
9 files changed, 89 insertions(+), 90 deletions(-)
This patch converts unicast address list to standard list_head using
previously introduced struct netdev_hw_addr. It also relaxes the
locking. Original spinlock (still used for multicast addresses) is not
needed and is no longer used for a protection of this list. All
reading and writing takes place under rtnl (with no changes).
I also removed a possibility to specify the length of the address
while adding or deleting unicast address. It's always dev->addr_len.
The convertion touched especially e1000 and ixgbe codes when the
change is not so trivial.
drivers/net/bnx2.c | 13 +--
drivers/net/e1000/e1000_main.c | 24 +++--
drivers/net/ixgbe/ixgbe_common.c | 14 ++--
drivers/net/ixgbe/ixgbe_common.h | 4 +-
drivers/net/ixgbe/ixgbe_type.h | 4 +-
drivers/net/macvlan.c | 11 +-
drivers/net/mv643xx_eth.c | 11 +-
drivers/net/niu.c | 7 +-
drivers/net/virtio_net.c | 7 +-
drivers/s390/net/qeth_l2_main.c | 6 +-
drivers/scsi/fcoe/fcoe.c | 16 ++--
include/linux/netdevice.h | 18 ++--
net/8021q/vlan.c | 4 +-
net/8021q/vlan_dev.c | 10 +-
net/core/dev.c | 195 +++++++++++++++++++++++++++-----------
net/dsa/slave.c | 10 +-
net/packet/af_packet.c | 4 +-
18 files changed, 227 insertions(+), 137 deletions(-)
z/VM Virtual Switch Port Isolation allows guests on a VLAN UNAWARE
virtual switch to be isolated from other guests on the VSWITCH.
(See z/VM Apars VM64281 and VM64463).
The Linux qeth driver is affected, because it has to handle new
error codes introduced with the z/VM VSWITCH Port Isolation support.
If a qeth device is plugged off, setting the device online stops in
state HARDSETUP and a failure is reported to the base cio-layer
causing halt/clear to be invoked. Replugging the device again triggers
a qeth recovery without notification of the cio-layer. If a device
is ungrouped in this state, the qeth set_offline function is not
invoked, because the corresponding ccwgroup device is not in state
ONLINE. Then incoming traffic is still handled by the qdio layer
resulting in a crash in qeth_l<x>_qdio_input_handler, because (part
of) the qeth data structures for this device are already removed.
Solution: After replugging the device qeth recovery should lead to a
working net device. Thus a "LAN offline" result when setting a qeth
device online must not report a failure to the base cio-layer.
When a recovery is started for a qeth device, additional invocations
to change a mac address, to configure a VLAN interface on top, or to
add multicast addresses should wait till recovery is finished,
otherwise recovery might fail.
qeth: Unregister MAC addresses from device (layer 2) during
recovery cycle. When the device is set online the MAC
addresses are registered again on the device.
Performance measurements showed EDDP does not lower CPU costs but increase
them. So we dump out EDDP code from qeth driver.
Add statistics counter for software tx checksumming.
Have separate netdev_ops for OSA and HiperSocket/TR.
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
qeth_l2, qeth_l3 convert to net_device_ops.
qeth_l3 remove vlan neigh_setup hack since it does not work any longer
with the new net_device_ops.
Replace s390_root_dev_register() with root_device_register() etc.
[Includes fix from Cornelia Huck]
Signed-off-by: Mark McLoughlin <markmc@redhat.com>
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
For z/VM GuestLAN or VSWITCH devices the transport layer is
configured in z/VM. The layer2 attribute of a participating Linux
device has to match the z/VM definition. In case of a mismatch
Linux currently crashes in qeth recovery due to a reference to the
not yet existing net_device.
Solution: add a check for existence of net_device and add a message
pointing to the mismatch of layer definitions in Linux and z/VM.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1429 commits)
net: Allow dependancies of FDDI & Tokenring to be modular.
igb: Fix build warning when DCA is disabled.
net: Fix warning fallout from recent NAPI interface changes.
gro: Fix potential use after free
sfc: If AN is enabled, always read speed/duplex from the AN advertising bits
sfc: When disabling the NIC, close the device rather than unregistering it
sfc: SFT9001: Add cable diagnostics
sfc: Add support for multiple PHY self-tests
sfc: Merge top-level functions for self-tests
sfc: Clean up PHY mode management in loopback self-test
sfc: Fix unreliable link detection in some loopback modes
sfc: Generate unique names for per-NIC workqueues
802.3ad: use standard ethhdr instead of ad_header
802.3ad: generalize out mac address initializer
802.3ad: initialize ports LACPDU from const initializer
802.3ad: remove typedef around ad_system
802.3ad: turn ports is_individual into a bool
802.3ad: turn ports is_enabled into a bool
802.3ad: make ntt bool
ixgbe: Fix set_ringparam in ixgbe to use the same memory pools.
Fixed trivial IPv4/6 address printing conflicts in fs/cifs/connect.c due
to the conversion to %pI (in this networking merge) and the addition of
doing IPv6 addresses (from the earlier merge of CIFS).
drivers/net/wireless/p54/p54common.c
A number of places still use %02x:...:%02x because it's
in debug statements or for no real reason. Make a few
of them use %pM.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
