path: root/drivers/s390/net
2008-06-10qeth: start dev queue after tx drop errorFrank Blaschka
In case the xmit function drop out with an error, we have to wake the netdevice queue to start another xmit. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-10qeth: Prepare-function to call s390dbf was wrongPeter Tiedemann
Prepare-function to call s390dbf was wrong handling variable arguments. This worked as macro but not as function any more. Now using va_list processing. Signed-off-by: Peter Tiedemann <ptiedem@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-10qeth: reduce number of kernel messagesFrank Blaschka
Remove unnecessary messages. Write important debug information to s390dbf. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-10qeth: Use ccw_device_get_id().Cornelia Huck
Get the devno from the ccw device via ccw_device_get_id() instead of parsing the bus_id. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-10qeth: layer 3 Oops in ip event handlerFrank Blaschka
The ip event handler may present us non qeth network interfaces. Add qeth card pointer check. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29netiucv: Fix missing driver attributes.Cornelia Huck
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29qeth: layer 2 allow ethtool to set TSOFrank Blaschka
Allow ethtool to turn on/off EDDP via ethtool TSO interface. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29qeth: read number of ports from cardUrsula Braun
Read out number of ports from the hardware. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29qeth: layer 3 add missing dev_open/close to ccwgroup handlerFrank Blaschka
In case the ccwgroup device is set online/offline we have to run the corresponding dev_open/close for the netdevice. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29qeth: rework fast pathFrank Blaschka
Remove unnecessary traces. Remove unnecessary wrappers for skb functions. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29qeth: provide get ethtool settingsFrank Blaschka
Load balancing bonding queries the speed of the slave interfaces. To support a bond consisting of different slave speeds we have to report the speed by ethtool settings. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29qeth: layer 3 support vlan IPv6 on hiper socketFrank Blaschka
hiper socket require the QETH_HDR_EXT_VLAN_FRAME flag in the qdio header to handle vlan tagged frames. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29qeth module size reduction.Peter Tiedemann
Replace complex macro for s390dbf calls by equivalent function. This reduces module size about 10% without visible performance impact. Signed-off-by: Peter Tiedemann <ptiedem@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29ccwgroup: Unify parsing for group attribute.Ursula Braun
Instead of having each driver for ccwgroup slave device parsing the input itself and calling ccwgroup_create(), introduce a new function ccwgroup_create_from_string() and handle parsing inside the ccwgroup core. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29netiucv: get rid of in_atomic() useUrsula Braun
There is no urgent need to restart a netiucv connection automatically, if packets are sent while the netiucv device is not up and running. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29lcs: CCL-sequ. numbers required for protocol 802.2 only.Klaus D. Wacker
Sequence numbers in skbs (Receive path) are assigned only to 802.2 packets. Signed-off-by: Klaus D. Wacker <kdwacker@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.26Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.26: (1090 commits) [NET]: Fix and allocate less memory for ->priv'less netdevices [IPV6]: Fix dangling references on error in fib6_add(). [NETLABEL]: Fix NULL deref in netlbl_unlabel_staticlist_gen() if ifindex not found [PKT_SCHED]: Fix datalen check in tcf_simp_init(). [INET]: Uninline the __inet_inherit_port call. [INET]: Drop the inet_inherit_port() call. SCTP: Initialize partial_bytes_acked to 0, when all of the data is acked. [netdrvr] forcedeth: internal simplifications; changelog removal phylib: factor out get_phy_id from within get_phy_device PHY: add BCM5464 support to broadcom PHY driver cxgb3: Fix __must_check warning with dev_dbg. tc35815: Statistics cleanup natsemi: fix MMIO for PPC 44x platforms [TIPC]: Cleanup of TIPC reference table code [TIPC]: Optimized initialization of TIPC reference table [TIPC]: Remove inlining of reference table locking routines e1000: convert uint16_t style integers to u16 ixgb: convert uint16_t style integers to u16 sb1000.c: make const arrays static sb1000.c: stop inlining largish static functions ...
2008-04-17[S390] replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-04-16qeth: keep ip-address after LAN_OFFLINE failureUrsula Braun
Problem: If setting of an ip-address fails with LAN_OFFLINE, qeth does not save the ip-address in its internal list of set ip-addresses. qeth recovers after a following STARTLAN event, but cannot set the unsaved ip-address. Solution: save the ip-address in the qeth-maintained list of ip-addresses after a LAN_OFFLINE failure for SETIP. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-16qeth: core code should alloc headroom for LLC protocolFrank Blaschka
Allocate headroom for TR_HLEN but using only ETH_HLEN causes rx performance degradation. Allocate ETH_HLEN for ethernet and TR_HLEN for token ring (layer 3 mode). Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-16qeth: improving debug message handlingPeter Tiedemann
Improving debug message handling, moving ipa into messages from kernel to dbf, some cleanups and typo fixes. Signed-off-by: Peter Tiedemann <ptiedem@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-16qeth: layer 3 do not allow to change mac addressFrank Blaschka
hw does not allow to change the mac address. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-16qeth: CCL-sequence numbers required for protocol ETH_P_802_2 onlyUrsula Braun
Symptom: slow CCL response time Problem: non-ETH_P_802_2 packets are not delivered to NDH for CCL. But CCL detects missing sequence numbers, which cause a serious performance problem with CCL. Solution: assign sequence numbers only to 802.2 packets. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-16qeth: set lan_online flag after a received STARTLANUrsula Braun
Problem: A STARTLAN command from the adapter may arrive while a qeth recovery is currently running with a failed qeth STARTLAN. Usually qeth schedules a recovery when receiving a STARTLAN command from the adapter. But another recovery scheduled while a recovery is already running never starts. Thus the qeth-administered lan_online flag remains zero in this scenario, even though the adapter-STARTLAN has happened. Solution: Set lan_online flag for a received STARTLAN from the adapter in case scheduled recovery does not start. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-16qeth: allow qdio queue element addresses > 2GBUrsula Braun
OSA-adapters do not have an address limitation for the qdio queue structures except the MAX storage level of the current processor. And due to a recent z/VM APAR there is no longer a restriction to allocate qdio structures below 2 GB. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-16qeth: improve ip_list administration after deregister failuresUrsula Braun
1. ip_list handling after deregister failure of multicast address: If error code "MC Address not found" is returned do not re-add multicast address to ip_list. For other error codes readd multicast address at the end of function qeth_delete_all_mc. 2. ip_list handling after deregister failure or normal ip address: If error code "IP Address not found" is returned do not re-add multicast address to ip list. This is especially important in IP address takeover scenarios, to enable re-takeover of a taken over IP address. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-22Merge branch 'upstream-net26' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 Conflicts: drivers/s390/net/qeth_main.c
2008-03-17qeth: remove old qeth filesFrank Blaschka
Remove all obsolete qeth files. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-17qeth: new qeth device driverFrank Blaschka
List of major changes and improvements: no manipulation of the global ARP constructor clean code split into core, layer 2 and layer 3 functionality better exploitation of the ethtool interface better representation of the various hardware capabilities fix packet socket support (tcpdump), no fake_ll required osasnmpd notification via udev events coding style and beautification Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-17ctc: removal of the old ctc driverPeter Tiedemann
ctc driver is replaced by a new ctcm driver. The ctcm driver supports the channel-to-channel connections of the old ctc driver plus an additional MPC protocol to provide SNA connectivity. This patch removes the functions of the old ctc driver. Signed-off-by: Peter Tiedemann <ptiedem@de.ibm.com> Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-17ctcm: infrastructure for replaced ctc driverPeter Tiedemann
ctcm driver supports the channel-to-channel connections of the old ctc driver plus an additional MPC protocol to provide SNA connectivity. This new ctcm driver replaces the existing ctc driver. Signed-off-by: Peter Tiedemann <ptiedem@de.ibm.com> Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-17drivers/s390/net: Kconfig brush upUrsula Braun
adapt drivers/s390/net/Kconfig to current IBM wording and further cosmetics Signed-off-by: Peter Tiedemann <ptiedem@de.ibm.com> Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-28[NETNS]: Disable inetaddr notifiers in namespaces other than initial.Denis V. Lunev
ip_fib_init is kept enabled. It is already namespace-aware. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-23claw: make use of DIV_ROUND_UPJulia Lawall
The kernel.h macro DIV_ROUND_UP performs the computation (((n) + (d) - 1) / (d)) but is perhaps more readable. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11claw/lcs/netiucv: check s390dbf level before sprintsPeter Tiedemann
additional check of s390dbf level results in better performance if the default low debugging level is active. Signed-off-by: Peter Tiedemann <ptiedem@de.ibm.com> Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11lcs: avoid/reduce unused s390dbf debug areas.Peter Tiedemann
Since lcs makes use of 1 debug area only, the number of debug areas is reduced, while the number of pages per area is increased. Signed-off-by: Peter Tiedemann <ptiedem@de.ibm.com> Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11netiucv: change name of nop functionUrsula Braun
Dummy NOP actions for fsm-statemachines have to be defined separately for every using module of fsm-statemachines. Thus the generic name fsm_action_nop is replaced by module specific name netiucv_action_nop. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11netiucv: Remember to set driver->owner.Cornelia Huck
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11claw: removal of volatile variablesUrsula Braun
Volatile variables queme_switch and pk_delay are not used anyway. They are just a left over from an unused timer based packing logic. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-28[VLAN]: Turn VLAN_DEV_INFO into inline functionPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add netns parameter to inet_(dev_)add_type.Eric W. Biederman
The patch extends the inet_addr_type and inet_dev_addr_type with the network namespace pointer. That allows to access the different tables relatively to the network namespace. The modification of the signature function is reported in all the callers of the inet_addr_type using the pointer to the well known init_net. Acked-by: Benjamin Thery <benjamin.thery@bull.net> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-26[S390] constify function pointer tables.Jan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-26[S390] use LIST_HEAD instead of LIST_HEAD_INITDenis Cheng
single list_head variable initialized with LIST_HEAD_INIT could almost always can be replaced with LIST_HEAD declaration, this shrinks the code and looks better. Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-26[S390] drivers/s390: Add missing "space"Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-24netiucv: Use device_driver default attribute groups.Cornelia Huck
CC: Ursula Braun <ubraun@linux.vnet.ibm.com> Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-12-11[S390]: Fix use of skb after netif_rxJulia Lawall
Recently, Wang Chen submitted a patch (d30f53aeb31d453a5230f526bea592af07944564) to move a call to netif_rx(skb) after a subsequent reference to skb, because netif_rx may call kfree_skb on its argument. netif_rx_ni calls netif_rx, so the same problem occurs in the files below. I have left the updating of dev->last_rx after the calls to netif_rx_ni because it seems time dependent, but moved the other field updates before. This was found using the following semantic match. (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression skb, e,e1; @@ ( netif_rx(skb); | netif_rx_ni(skb); ) ... when != skb = e ( skb = e1 | * skb ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-04drivers/s390/net/ctcmain.c: fix build bugIngo Molnar
SET_MODULE_OWNER() is obsolete. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-01ctc: make use of alloc_netdev()Peter Tiedemann
Currently ctc-device initialization is broken (kernel bug in ctc_new_device). The new network namespace code reveals a deficiency of the ctc driver. It should make use of alloc_netdev() as described in Documentation/networking/netdevices.txt. Signed-off-by: Peter Tiedemann <ptiedem@de.ibm.com> Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-05[S390] Fix smsgiucv init on no iucv machinesChristian Borntraeger
smsgiucv is a driver that relies on iucv to work properly. If iucv ans smsgiucv are compiled into the kernel and run on an lpar the following scenario happens: iucv is initialized early as a subsystem. It checks for z/VM and returns with EPROTONOTSUPPORT. Later smsgiucv tries to run driver_register with iucv_bus as bus. As this bus is not initialized the driver core and list debugging issue several warnings and oopses. Solution is to let smsgiucv also check for z/VM and return EPROTONOTSUPPORT as well. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
