path: root/drivers/s390
2011-06-06[S390] qdio: Split SBAL entry flagsJan Glauber
The qdio SBAL entry flag is made-up of four different values that are independent of one another. Some of the bits are reserved by the hardware and should not be changed by qdio. Currently all four values are overwritten since the SBAL entry flag is defined as an u32. Split the SBAL entry flag into four u8's as defined by the hardware and don't touch the reserved bits. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-26[S390] irq: merge irq.c and s390_ext.cHeiko Carstens
Merge irq.c and s390_ext.c into irq.c. That way all external interrupt related functions are together. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-26[S390] irq: fix service signal external interrupt handlingHeiko Carstens
Interrupt sources like pfault, sclp, dasd_diag and virtio all use the service signal external interrupt subclass mask in control register 0 to enable and disable the corresponding interrupt. Because no reference counting is implemented each subsystem thinks it is the only user of subclass and sets and clears the bit like it wants. This leads to case that unloading the dasd diag module under z/VM causes both sclp and pfault interrupts to be masked. The result will be locked up system sooner or later. Fix this by introducing a new way to set (register) and clear (unregister) the service signal subclass mask bit in cr0. Also convert all drivers. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23[S390] get CPC image nameMartin Schwidefsky
Provide sysfs attributes that contain the CPC name and the HMC network name of the machine the operating system is running on. This information is retrieved with the operation communication parameters (OCF) sclp interface. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23[S390] sclp: event buffer dissectionMartin Schwidefsky
Move gds vector/subvector find functions to the sclp header file. Simplify event buffer dissection in sclp tty code. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23[S390] chsc: process channel-path-availability informationSebastian Ott
Update affected channel path descriptors when receiving channel path availability information. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23[S390] qdio: prevent compile warningJan Glauber
Prevent the following compile warning for !CONFIG_64BIT: CC drivers/s390/cio/qdio_main.o drivers/s390/cio/qdio_main.c: In function ‘handle_outbound’: drivers/s390/cio/qdio_main.c:1449: warning: ‘state’ may be used uninitialized in this function Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23[S390] sclp: remove unnecessary sendmask checkHeiko Carstens
The sendmask check is not needed. Remove it. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23[S390] ap: skip device registration on type probe failureHolger Dengler
The registration of an ap device will be skipped, if the device type probing fails. Add names of current crypto adapters to the Kconfig help. Signed-off-by: Holger Dengler <hd@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23[S390] tape: remove unused/not handled return codesHeiko Carstens
Return codes are on purpose not handled or used. So remove them. Acked-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23[S390] monwriter: fix return code handlingHeiko Carstens
Fix return code handling within monwrite_new_hdr(). Return code handling is everwhere implemented, the return code of the diagnose function was just not passed. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23[S390] dasd: fix return code handlingHeiko Carstens
Check return value of itcw_add_dcw() for error code and return it. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23[S390] get rid of unused variablesHeiko Carstens
Remove trivially unused variables as detected with -Wunused-but-set-variable. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23[S390] Remove tape block device driver.Heiko Carstens
Remove the tape block device driver. It's not of real use but has already created some confusion when users wanted to access tape devices and used the block device nodes instead of the character device nodes. Also remove the whole tape documentation since it's completely outdated and we have the device drivers book which is the place where everything is properly documented. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23[S390] cio: fix unreg race in set_online pathSebastian Ott
In ccw_device_set_online we basically start path verification and wait for the device to reach a final state. If it turns out that the device has no useable path we schedule the deregistration of the device (which is still in an non-final state) and wake up the waiting process. The deregistration process will set a final state, but if the wake up happens to be prior to this, the device will hang forever in ccw_device_set_online. To fix this just set the final NOT_OPER state prior to the scheduled deregistration of the device. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits) macvlan: fix panic if lowerdev in a bond tg3: Add braces around 5906 workaround. tg3: Fix NETIF_F_LOOPBACK error macvlan: remove one synchronize_rcu() call networking: NET_CLS_ROUTE4 depends on INET irda: Fix error propagation in ircomm_lmp_connect_response() irda: Kill set but unused variable 'bytes' in irlan_check_command_param() irda: Kill set but unused variable 'clen' in ircomm_connect_indication() rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport() be2net: Kill set but unused variable 'req' in lancer_fw_download() irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication() atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined. rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer(). rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler() rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection() rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window() pkt_sched: Kill set but unused variable 'protocol' in tc_classify() isdn: capi: Use pr_debug() instead of ifdefs. tg3: Update version to 3.119 tg3: Apply rx_discards fix to 5719/5720 ... Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c as per Davem.
2011-05-18qeth: use ndo_set_features callback for initial setup and recoveryFrank Blaschka
This patch uses the ndo_set_features callback during normal device startup or recovery to turn on hardware RX checksum. Patch was done with much help from Michal Miroslaw, thx!!! Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Reviewed-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-18Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blocklatestLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: don't delay blk_run_queue_async scsi: remove performance regression due to async queue run blk-throttle: Use task_subsys_state() to determine a task's blkio_cgroup block: rescan partitions on invalidated devices on -ENOMEDIA too cdrom: always check_disk_change() on open block: unexport DISK_EVENT_MEDIA_CHANGE for legacy/fringe drivers
2011-05-13ctcm: get rid of compile warningUrsula Braun
-Wunused-but-set-variable generates compile warnings. The affected variables are removed. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-13lcs: get rid of compile warningHeiko Carstens
-Wunused-but-set-variable generates a compile warning for lcs' tasklet function. Invoked functions contain already error handling; thus additional return code checking is not needed here. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-13claw: remove unused return code handlingHeiko Carstens
Remove unused return code handling. The claw driver is mostly dead, so just make sure it keeps compiling without warnings. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-13qeth: add owner to ccw driverSebastian Ott
Fill in the owner of qeth's ccw device driver. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-13qeth: add OSA concurrent hardware trapFrank Blaschka
This patch improves FFDC (first failure data capture) by requesting a hardware trace in case the device driver, the hardware or a user detects an error. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-13qeth: convert to hw_features part 2Frank Blaschka
Set rx csum default to hw checksumming again. Remove sysfs interface for rx csum (checksumming) and TSO (large_send). With the new hw_features it does not work to keep the old sysfs interface in parallel. Convert options.checksum_type to new hw_features. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-10[S390] dasd: prevent IO error during reserve/release loopStefan Haberland
The termination of running CQR caused by reserve/release operations may lead to an IO error if reserve/release is done in a tight loop. Prevent this by increasing the retry counter after termination. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-10[S390] sclp/memory hotplug: fix initial usecount of incrementsHeiko Carstens
Fix initial usecount of attached and assigned storage increments so they can be set offline. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-05net: call dev_alloc_name from register_netdeviceJiri Pirko
Force dev_alloc_name() to be called from register_netdevice() by dev_get_valid_name(). That allows to remove multiple explicit dev_alloc_name() calls. The possibility to call dev_alloc_name in advance remains. This also fixes veth creation regresion caused by 84c49d8c3e4abefb0a41a77b25aa37ebe8d6b743 Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-29[S390] irqstats: fix counting of pfault, dasd diag and virtio irqsHeiko Carstens
pfault, dasd diag and virtio all use the same external interrupt number. The respective interrupt handlers decide by the subcode if they are meant to handle the interrupt. Counting is currently done before looking at the subcode which means each handler counts an interrupt even if it is not handling it. Fix this by moving the kstat code after the code which looks at the subcode. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-04-21block: unexport DISK_EVENT_MEDIA_CHANGE for legacy/fringe driversTejun Heo
In-kernel disk event polling doesn't matter for legacy/fringe drivers and may lead to infinite event loop if ->check_events() implementation generates events on level condition instead of edge. Now that block layer supports suppressing exporting unlisted events, simply leaving disk->events cleared allows these drivers to keep the internal revalidation behavior intact while avoiding weird interactions with userland event handler. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-04-20net: s390: convert to hw_featuresMichał Mirosław
options.large_send was easy to get rid of. options.checksum_type has deeper roots so is left for later cleanup. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-20[S390] dasd: check sense type in device change handlerStefan Weinhuber
When evaluating sense data in dasd_eckd_check_for_device_change, we must always check for the type of sense data in byte 27, bit 0, to make sure that the rest of the sense data is interpreted correctly. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-04-20[S390] qdio: reset error states immediatelyJan Glauber
The qdio hardware may surpress further interrupts as long as a SBAL is in the error state. That can lead to unnotified data in the SBALs following the error state. To prevent this behaviour change the SBAL[s] in error state immediately to another program owned state so interrupts are again received for further traffic on the device. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-04-20[S390] dasd: fix race between open and offlineStefan Weinhuber
The dasd_open function uses the private_data pointer of the gendisk to find the dasd_block structure that matches the gendisk. When a DASD device is set offline, we set the private_data pointer of the gendisk to NULL and later remove the dasd_block structure, but there is still a small race window, in which dasd_open could first read a pointer from the private_data field and then try to use it, after the structure has already been freed. To close this race window, we will store a pointer to the dasd_devmap structure of the base device in the private_data field. The devmap entries are not deleted, and we already have proper locking and reference counting in place, so that we can safely get from a devmap pointer to the dasd_device and dasd_block structures of the device. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-04-08Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] compile fix for latest binutils [S390] cio: prevent purging of CCW devices in the online state [S390] qdio: fix init sequence [S390] Fix parameter passing for smp_switch_to_cpu() [S390] oprofile s390: prevent stack corruption
2011-04-04[S390] cio: prevent purging of CCW devices in the online statePeter Oberparleiter
The cio_ignore purge function is intended to only remove CCW devices which are in the offline state. There is a time frame after the purge function finished where a CCW device is scheduled for removal but still accessible. When the device is set online during this time frame, it may first appear online before it is then removed. Fix this by preventing that CCW devices can be set online while there is work (such as removal triggered by the purge function) for it pending. Also ensure that the purge function does not schedule devices for removal which are in the process of being set online. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-04-04[S390] qdio: fix init sequenceSebastian Ott
Reorder the initialization sequence of the qdio module to avoid writing to an uninitialized debug feature entry. Also reorder the exit function to restore a consistent cleanup path. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-03-25Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] cmpxchg: implement cmpxchg64() [S390] xchg/cmpxchg: move to own header file [S390] ccwgroup_driver: remove duplicate members [S390] ccw_bus_type: make it static [S390] ccw_driver: remove duplicate members [S390] qdio: prevent handling of buffers if count is zero [S390] setup: register bss section as resource [S390] setup: simplify setup_resources() [S390] wire up sys_syncfs [S390] wire up sys_clock_adjtime [S390] wire up sys_open_by_handle_at [S390] wire up sys_name_to_handle_at [S390] oprofile: disable hw sampling for CONFIG_32BIT [S390] early: limit savesys cmd string handling [S390] early: Fix possible overlapping data buffer
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-23[S390] ccwgroup_driver: remove duplicate membersSebastian Ott
Remove the owner and name members of struct ccwgroup_driver and convert all drivers to store this data in the embedded struct device_driver. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-03-23[S390] ccw_bus_type: make it staticSebastian Ott
Make ccw_bus_type static. ccw_device drivers have to use ccw_driver_register. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-03-23[S390] ccw_driver: remove duplicate membersSebastian Ott
Remove the owner and name members of struct ccw_driver and convert all drivers to store this data in the embedded struct device_driver. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-03-23[S390] qdio: prevent handling of buffers if count is zeroJan Glauber
Exit do_QDIO early if the buffer count is zero to prevent side effects in the following functions. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-03-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (170 commits) [SCSI] scsi_dh_rdac: Add MD36xxf into device list [SCSI] scsi_debug: add consecutive medium errors [SCSI] libsas: fix ata list corruption issue [SCSI] hpsa: export resettable host attribute [SCSI] hpsa: move device attributes to avoid forward declarations [SCSI] scsi_debug: Logical Block Provisioning (SBC3r26) [SCSI] sd: Logical Block Provisioning update [SCSI] Include protection operation in SCSI command trace [SCSI] hpsa: fix incorrect PCI IDs and add two new ones (2nd try) [SCSI] target: Fix volume size misreporting for volumes > 2TB [SCSI] bnx2fc: Broadcom FCoE offload driver [SCSI] fcoe: fix broken fcoe interface reset [SCSI] fcoe: precedence bug in fcoe_filter_frames() [SCSI] libfcoe: Remove stale fcoe-netdev entries [SCSI] libfcoe: Move FCOE_MTU definition from fcoe.h to libfcoe.h [SCSI] libfc: introduce __fc_fill_fc_hdr that accepts fc_hdr as an argument [SCSI] fcoe, libfc: initialize EM anchors list and then update npiv EMs [SCSI] Revert "[SCSI] libfc: fix exchange being deleted when the abort itself is timed out" [SCSI] libfc: Fixing a memory leak when destroying an interface [SCSI] megaraid_sas: Version and Changelog update ... Fix up trivial conflicts due to whitespace differences in drivers/scsi/libsas/{sas_ata.c,sas_scsi_host.c}
2011-03-17Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] kexec: Disable ftrace during kexec [S390] support XZ compressed kernel [S390] css_bus_type: make it static [S390] css_driver: remove duplicate members [S390] css: remove subchannel private [S390] css: move chsc_private to drv_data [S390] css: move io_private to drv_data [S390] cio: move cdev pointer to io_subchannel_private [S390] cio: move options to io_sch_private [S390] cio: move asms to generic header [S390] cio: move orb definitions to separate header [S390] Write protect module text and RO data [S390] dasd: get rid of compile warning [S390] remove superfluous check from do_IRQ [S390] remove redundant stack check option
2011-03-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1480 commits) bonding: enable netpoll without checking link status xfrm: Refcount destination entry on xfrm_lookup net: introduce rx_handler results and logic around that bonding: get rid of IFF_SLAVE_INACTIVE netdev->priv_flag bonding: wrap slave state work net: get rid of multiple bond-related netdevice->priv_flags bonding: register slave pointer for rx_handler be2net: Bump up the version number be2net: Copyright notice change. Update to Emulex instead of ServerEngines e1000e: fix kconfig for crc32 dependency netfilter ebtables: fix xt_AUDIT to work with ebtables xen network backend driver bonding: Improve syslog message at device creation time bonding: Call netif_carrier_off after register_netdevice bonding: Incorrect TX queue offset net_sched: fix ip_tos2prio xfrm: fix __xfrm_route_forward() be2net: Fix UDP packet detected status in RX compl Phonet: fix aligned-mode pipe socket buffer header reserve netxen: support for GbE port settings ... Fix up conflicts in drivers/staging/brcm80211/brcmsmac/wl_mac80211.c with the staging updates.
2011-03-16Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (76 commits) pch_uart: reference clock on CM-iTC pch_phub: add new device ML7213 n_gsm: fix UIH control byte : P bit should be 0 n_gsm: add a documentation serial: msm_serial_hs: Add MSM high speed UART driver tty_audit: fix tty_audit_add_data live lock on audit disabled tty: move cd1865.h to drivers/staging/tty/ Staging: tty: fix build with epca.c driver pcmcia: synclink_cs: fix prototype for mgslpc_ioctl() Staging: generic_serial: fix double locking bug nozomi: don't use flush_scheduled_work() tty/serial: Relax the device_type restriction from of_serial MAINTAINERS: Update HVC file patterns tty: phase out of ioctl file pointer for tty3270 as well tty: forgot to remove ipwireless from drivers/char/pcmcia/Makefile pch_uart: Fix DMA channel miss-setting issue. pch_uart: fix exclusive access issue pch_uart: fix auto flow control miss-setting issue pch_uart: fix uart clock setting issue pch_uart : Use dev_xxx not pr_xxx ... Fix up trivial conflicts in drivers/misc/pch_phub.c (same patch applied twice, then changes to the same area in one branch)
2011-03-15[S390] css_bus_type: make it staticSebastian Ott
Make css_bus_type static. Subchannel drivers have to use css_driver_register. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-03-15[S390] css_driver: remove duplicate membersSebastian Ott
Remove the owner and name members of struct css_driver and convert all drivers to store this data in the embedded struct device_driver. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-03-15[S390] css: remove subchannel privateSebastian Ott
All subchannel drivers use drv_data, so get rid of the additional private pointer of struct subchannel. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
