path: root/drivers/s390
2008-05-07[S390] tty3270: fix put_char fail/success conversion.Heiko Carstens
The wrong function got coverted ;) CC drivers/s390/char/tty3270.o drivers/s390/char/tty3270.c:1747: warning: initialization from incompatible pointer type Acked-by: Alan Cox <alan@redhat.com> Cc: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-05-07[S390] s390mach compile warningMartin Schwidefsky
Fix the following compile warning: drivers/s390/s390mach.c: In function 's390_collect_crw_info': drivers/s390/s390mach.c:77: warning: ignoring return value of 'down_interruptibl Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-05-07[S390] cio: Fix parsing mechanism for blacklisted devices.Michael Ernst
New format cssid.ssid.devno is now parsed correctly. Signed-off-by: Michael Ernst <mernst@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-05-07[S390] cio: Remove cio_msg kernel parameter.Michael Ernst
The only sporadically used CIO_DEBUG messages are replaced by ordinary CIO_MSG_EVENT messages. The CIO_MSG_EVENT messages debug levels are consolidated. Signed-off-by: Michael Ernst <mernst@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-05-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: [SCSI] aic94xx: fix section mismatch [SCSI] u14-34f: Fix 32bit only problem [SCSI] dpt_i2o: sysfs code [SCSI] dpt_i2o: 64 bit support [SCSI] dpt_i2o: move from virt_to_bus/bus_to_virt to dma_alloc_coherent [SCSI] dpt_i2o: use standard __init / __exit code [SCSI] megaraid_sas: fix suspend/resume sections [SCSI] aacraid: Add Power Management support [SCSI] aacraid: Fix jbod operations scan issues [SCSI] aacraid: Fix warning about macro side-effects [SCSI] add support for variable length extended commands [SCSI] Let scsi_cmnd->cmnd use request->cmd buffer [SCSI] bsg: add large command support [SCSI] aacraid: Fix down_interruptible() to check the return value correctly [SCSI] megaraid_sas; Update the Version and Changelog [SCSI] ibmvscsi: Handle non SCSI error status [SCSI] bug fix for free list handling [SCSI] ipr: Rename ipr's state scsi host attribute to prevent collisions [SCSI] megaraid_mbox: fix Dell CERC firmware problem
2008-05-02[SCSI] Let scsi_cmnd->cmnd use request->cmd bufferBoaz Harrosh
- struct scsi_cmnd had a 16 bytes command buffer of its own. This is an unnecessary duplication and copy of request's cmd. It is probably left overs from the time that scsi_cmnd could function without a request attached. So clean that up. - Once above is done, few places, apart from scsi-ml, needed adjustments due to changing the data type of scsi_cmnd->cmnd. - Lots of drivers still use MAX_COMMAND_SIZE. So I have left that #define but equate it to BLK_MAX_CDB. The way I see it and is reflected in the patch below is. MAX_COMMAND_SIZE - means: The longest fixed-length (*) SCSI CDB as per the SCSI standard and is not related to the implementation. BLK_MAX_CDB. - The allocated space at the request level - I have audit all ISA drivers and made sure none use ->cmnd in a DMA Operation. Same audit was done by Andi Kleen. (*)fixed-length here means commands that their size can be determined by their opcode and the CDB does not carry a length specifier, (unlike the VARIABLE_LENGTH_CMD(0x7f) command). This is actually not exactly true and the SCSI standard also defines extended commands and vendor specific commands that can be bigger than 16 bytes. The kernel will support these using the same infrastructure used for VARLEN CDB's. So in effect MAX_COMMAND_SIZE means the maximum size command scsi-ml supports without specifying a cmd_len by ULD's Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (53 commits) tcp: Overflow bug in Vegas [IPv4] UFO: prevent generation of chained skb destined to UFO device iwlwifi: move the selects to the tristate drivers ipv4: annotate a few functions __init in ipconfig.c atm: ambassador: vcc_sf semaphore to mutex MAINTAINERS: The socketcan-core list is subscribers-only. netfilter: nf_conntrack: padding breaks conntrack hash on ARM ipv4: Update MTU to all related cache entries in ip_rt_frag_needed() sch_sfq: use del_timer_sync() in sfq_destroy() net: Add compat support for getsockopt (MCAST_MSFILTER) net: Several cleanups for the setsockopt compat support. ipvs: fix oops in backup for fwmark conn templates bridge: kernel panic when unloading bridge module bridge: fix error handling in br_add_if() netfilter: {nfnetlink,ip,ip6}_queue: fix skb_over_panic when enlarging packets netfilter: x_tables: fix net namespace leak when reading /proc/net/xxx_tables_names netfilter: xt_TCPOPTSTRIP: signed tcphoff for ipv6_skip_exthdr() retval tcp: Limit cwnd growth when deferring for GSO tcp: Allow send-limited cwnd to grow up to max_burst when gso disabled [netdrvr] gianfar: Determine TBIPA value dynamically ...
2008-04-30Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: [S390] Update default configuration. [S390] use generic sys_ptrace [S390] Remove self ptrace IEEE_IP hack. [S390] Convert to SPARSEMEM & SPARSEMEM_VMEMMAP [S390] System z large page support. [S390] Convert machine feature detection code to C. [S390] vmemmap: use clear_table to initialise page tables. [S390] Move stfl to system.h and delete duplicated version. [S390] uaccess_mvcos: #ifdef config dependent code. [S390] cpu topology: Fix possible deadlock. [S390] Add topology_core_siblings to topology.h [S390] cio: Make isc handling more robust. [S390] remove -traditional [S390] Automatically detect added cpus. [S390] smp: Fix locking order. [S390] Add missing ifndef/define to include/asm-s390/sysinfo.h. [S390] Move show_regs to traps.c. [S390] cio: Use strict_strtoul() for attributes.
2008-04-30s390 tty: Prepare for put_char to return success/failAlan Cox
Put the changes into the drivers first. This will still compile/work but produce a warning if bisected so can still be debugged Signed-off-by: Alan Cox <alan@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30[S390] Convert to SPARSEMEM & SPARSEMEM_VMEMMAPHeiko Carstens
Convert s390 to SPARSEMEM and SPARSEMEM_VMEMMAP. We do a select of SPARSEMEM_VMEMMAP since it is configurable. This is because SPARSEMEM without SPARSEMEM_VMEMMAP gives us a hell of broken include dependencies that I don't want to fix. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-04-30[S390] cio: Make isc handling more robust.Cornelia Huck
Introduce an ->isc field in the subchannel to store the desired interruption subclass, since sch->schib.pmcw.isc may be overwritten by the hardware on stsch() after machine checks. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-04-30[S390] Automatically detect added cpus.Heiko Carstens
2008-04-30[S390] cio: Use strict_strtoul() for attributes.Cornelia Huck
Make parsing of attribute writes handle incorrect input better. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-04-29s390: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create() to make sure that ->proc_fops be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_root from driversAlexey Dobriyan
Remove proc_root export. Creation and removal works well if parent PDE is supplied as NULL -- it worked always that way. So, one useless export removed and consistency added, some drivers created PDEs with &proc_root as parent but removed them as NULL and so on. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29netiucv: Fix missing driver attributes.Cornelia Huck
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29qeth: layer 2 allow ethtool to set TSOFrank Blaschka
Allow ethtool to turn on/off EDDP via ethtool TSO interface. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29qeth: read number of ports from cardUrsula Braun
Read out number of ports from the hardware. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29qeth: layer 3 add missing dev_open/close to ccwgroup handlerFrank Blaschka
In case the ccwgroup device is set online/offline we have to run the corresponding dev_open/close for the netdevice. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29qeth: rework fast pathFrank Blaschka
Remove unnecessary traces. Remove unnecessary wrappers for skb functions. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29qeth: provide get ethtool settingsFrank Blaschka
Load balancing bonding queries the speed of the slave interfaces. To support a bond consisting of different slave speeds we have to report the speed by ethtool settings. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29qeth: layer 3 support vlan IPv6 on hiper socketFrank Blaschka
hiper socket require the QETH_HDR_EXT_VLAN_FRAME flag in the qdio header to handle vlan tagged frames. Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29qeth module size reduction.Peter Tiedemann
Replace complex macro for s390dbf calls by equivalent function. This reduces module size about 10% without visible performance impact. Signed-off-by: Peter Tiedemann <ptiedem@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29ccwgroup: Unify parsing for group attribute.Ursula Braun
Instead of having each driver for ccwgroup slave device parsing the input itself and calling ccwgroup_create(), introduce a new function ccwgroup_create_from_string() and handle parsing inside the ccwgroup core. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29netiucv: get rid of in_atomic() useUrsula Braun
There is no urgent need to restart a netiucv connection automatically, if packets are sent while the netiucv device is not up and running. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-29lcs: CCL-sequ. numbers required for protocol 802.2 only.Klaus D. Wacker
Sequence numbers in skbs (Receive path) are assigned only to 802.2 packets. Signed-off-by: Klaus D. Wacker <kdwacker@de.ibm.com> Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-28return pfn from direct_access, for XIPJared Hulbert
Alter the block device ->direct_access() API to work with the new get_xip_mem() API (that requires both kaddr and pfn are returned). Some architectures will not do the right thing in their virt_to_page() for use by XIP (to translate from the kernel virtual address returned by direct_access(), to a user mappable pfn in XIP's page fault handler. However, we can't switch it to just return the pfn and not the kaddr, because we have no good way to get a kva from a pfn, and XIP requires the kva for its read(2) and write(2) handlers. So we have to return both. Signed-off-by: Jared Hulbert <jaredeh@gmail.com> Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux-mm@kvack.org Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (40 commits) [SCSI] jazz_esp, sgiwd93, sni_53c710, sun3x_esp: fix platform driver hotplug/coldplug [SCSI] aic7xxx: add const [SCSI] aic7xxx: add static [SCSI] aic7xxx: Update _shipped files [SCSI] aic7xxx: teach aicasm to not emit unused debug code/data [SCSI] qla2xxx: Update version number to 8.02.01-k2. [SCSI] qla2xxx: Correct regression in relogin code. [SCSI] qla2xxx: Correct misc. endian and byte-ordering issues. [SCSI] qla2xxx: make qla2x00_issue_iocb_timeout() static [SCSI] qla2xxx: qla_os.c, make 2 functions static [SCSI] qla2xxx: Re-register FDMI information after a LIP. [SCSI] qla2xxx: Correct SRB usage-after-completion/free issues. [SCSI] qla2xxx: Correct ISP84XX verify-chip response handling. [SCSI] qla2xxx: Wakeup DPC thread to process any deferred-work requests. [SCSI] qla2xxx: Collapse RISC-RAM retrieval code during a firmware-dump. [SCSI] m68k: new mac_esp scsi driver [SCSI] zfcp: Add some statistics provided by the FCP adapter to the sysfs [SCSI] zfcp: Print some messages only during ERP [SCSI] zfcp: Wait for free SBAL during exchange config [SCSI] scsi_transport_fc: fc_user_scan correction ...
2008-04-27[SCSI] zfcp: Add some statistics provided by the FCP adapter to the sysfsSwen Schillig
The new FCP adapter statistics provide a variety of information about the virtual adapter (subchannel). In order to collect this information the zfcp driver is extended to query this information. The information provided by the new FCP adapter statistics can be fetched by reading from the following files in the sysfs filesystem /sys/class/scsi_host/host<n>/seconds_active /sys/class/scsi_host/host<n>/requests /sys/class/scsi_host/host<n>/megabytes /sys/class/scsi_host/host<n>/utilization These are the statistics on a virtual adapter (subchannel) level. The information provided is raw and not modified or interpreted by any means. No interpretation or modification of the values is done by the zfcp driver. Signed-off-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-27[SCSI] zfcp: Print some messages only during ERPSwen Schillig
When statistics are polled from sysfs, the statistics use the same commands as the adapter initialization. Change the messages printed here, so they are only printed during initialization and not for each poll of adapter data. Signed-off-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-27[SCSI] zfcp: Wait for free SBAL during exchange configSwen Schillig
When sending a exchange config data command, wait for a free SBAL. This does not matter during adapter initialization, but this is required for pulling adapter statistics during high I/O load. Signed-off-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-27s390: KVM guest: virtio device support, and kvm hypercallsChristian Borntraeger
This patch implements kvm guest kernel support for paravirtualized devices and contains two parts: o a basic virtio stub using virtio_ring and external interrupts and hypercalls o full hypercall implementation in kvm_para.h Currently we dont have PCI on s390. Making virtio_pci usable for s390 seems more complicated that providing an own stub. This virtio stub is similar to the lguest one, the memory for the descriptors and the device detection is made via additional mapped memory on top of the guest storage. We use an external interrupt with extint code 0x2603 for host->guest notification. The hypercall definition uses the diag instruction for issuing a hypercall. The parameters are written in R2-R7, the hypercall number is written in R1. This is similar to the system call ABI (svc) which can use R1 for the number and R2-R6 for the parameters. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-18Convert asm/semaphore.h users to linux/semaphore.hMatthew Wilcox
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-04-18drivers: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.26Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.26: (1090 commits) [NET]: Fix and allocate less memory for ->priv'less netdevices [IPV6]: Fix dangling references on error in fib6_add(). [NETLABEL]: Fix NULL deref in netlbl_unlabel_staticlist_gen() if ifindex not found [PKT_SCHED]: Fix datalen check in tcf_simp_init(). [INET]: Uninline the __inet_inherit_port call. [INET]: Drop the inet_inherit_port() call. SCTP: Initialize partial_bytes_acked to 0, when all of the data is acked. [netdrvr] forcedeth: internal simplifications; changelog removal phylib: factor out get_phy_id from within get_phy_device PHY: add BCM5464 support to broadcom PHY driver cxgb3: Fix __must_check warning with dev_dbg. tc35815: Statistics cleanup natsemi: fix MMIO for PPC 44x platforms [TIPC]: Cleanup of TIPC reference table code [TIPC]: Optimized initialization of TIPC reference table [TIPC]: Remove inlining of reference table locking routines e1000: convert uint16_t style integers to u16 ixgb: convert uint16_t style integers to u16 sb1000.c: make const arrays static sb1000.c: stop inlining largish static functions ...
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (137 commits) [SCSI] iscsi: bidi support for iscsi_tcp [SCSI] iscsi: bidi support at the generic libiscsi level [SCSI] iscsi: extended cdb support [SCSI] zfcp: Fix error handling for blocked unit for send FCP command [SCSI] zfcp: Remove zfcp_erp_wait from slave destory handler to fix deadlock [SCSI] zfcp: fix 31 bit compile warnings [SCSI] bsg: no need to set BSG_F_BLOCK bit in bsg_complete_all_commands [SCSI] bsg: remove minor in struct bsg_device [SCSI] bsg: use better helper list functions [SCSI] bsg: replace kobject_get with blk_get_queue [SCSI] bsg: takes a ref to struct device in fops->open [SCSI] qla1280: remove version check [SCSI] libsas: fix endianness bug in sas_ata [SCSI] zfcp: fix compiler warning caused by poking inside new semaphore (linux-next) [SCSI] aacraid: Do not describe check_reset parameter with its value [SCSI] aacraid: Fix down_interruptible() to check the return value [SCSI] sun3_scsi_vme: add MODULE_LICENSE [SCSI] st: rename flush_write_buffer() [SCSI] tgt: use KMEM_CACHE macro [SCSI] initio: fix big endian problems for auto request sense ...
2008-04-18[SCSI] zfcp: Fix error handling for blocked unit for send FCP commandChristof Schmitt
In the case the unit is blocked, zfcp_unit_get has not been called yet, so the error handling path should not call zfcp_unit_put. Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-18[SCSI] zfcp: Remove zfcp_erp_wait from slave destory handler to fix deadlockChristof Schmitt
The testcase # chchp -v 0 0.da && sleep 59 && chchp -v 1 0.da results in this deadlock situation: STACK TRACE FOR TASK: 0x7e9a2048 (zfcperp0.0.c613) 0 schedule+816 [0x356b3c] 1 schedule_timeout+172 [0x357340] 2 wait_for_common+192 [0x3565fc] 3 flush_cpu_workqueue+116 [0x52af0] 4 flush_workqueue+116 [0x533b8] 5 fc_remote_port_add+64 [0x1c83ec] 6 zfcp_erp_thread+4534 [0x26585a] 7 kernel_thread_starter+6 [0x195d2] STACK TRACE FOR TASK: 0x7f8ec048 (fc_wq_0) 0 schedule+816 [0x356b3c] 1 zfcp_erp_wait+104 [0x264568] 2 zfcp_scsi_slave_destroy+64 [0x261b24] 3 __scsi_remove_device+154 [0x1c24ba] 4 scsi_remove_device+62 [0x1c2512] 5 __scsi_remove_target+198 [0x1c25ea] 6 __remove_child+58 [0x1c26d6] 7 device_for_each_child+66 [0x1ab566] 8 scsi_remove_target+98 [0x1c268a] 9 run_workqueue+200 [0x5272c] 10 worker_thread+146 [0x52882] 11 kthread+140 [0x58360] 12 kernel_thread_starter+6 [0x195d2] Remove the zfcp_erp_wait call that is not required here to prevent the deadlock situation. Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-18[SCSI] zfcp: fix 31 bit compile warningsMartin Peschke
drivers/s390/scsi/zfcp_aux.c: In function ‘zfcp_fsf_incoming_els_rscn’: drivers/s390/scsi/zfcp_aux.c:1379: warning: cast from pointer to integer of different size drivers/s390/scsi/zfcp_aux.c: In function ‘zfcp_fsf_incoming_els_plogi’: drivers/s390/scsi/zfcp_aux.c:1432: warning: cast from pointer to integer of different size drivers/s390/scsi/zfcp_aux.c: In function ‘zfcp_fsf_incoming_els_logo’: drivers/s390/scsi/zfcp_aux.c:1457: warning: cast from pointer to integer of different size .. Just passing pointers rids us of these warnings and improves readability. Signed-off-by: Martin Peschke <mp3@de.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-17[SCSI] zfcp: fix compiler warning caused by poking inside new semaphore ↵Martin Peschke
(linux-next) as seen in linux-next tree: drivers/s390/scsi/zfcp_dbf.c: In function ‘zfcp_rec_dbf_event_thread’: drivers/s390/scsi/zfcp_dbf.c:697: warning: passing argument 1 of ‘atomic_read’ from incompatible pointer type Caused by recent git commit: commit 348447e85749120ad600a5c8e23b6bb7058b931d Author: Martin Peschke <mp3@de.ibm.com> Date: Thu Mar 27 14:22:01 2008 +0100 [SCSI] zfcp: Add trace records for recovery thread and its queues We are not supposed to poke inside semaphore. Signed-off-by: Martin Peschke <mp3@de.ibm.com> Acked-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-17[S390] Remove code duplication from monreader / dcssblk.Martin Schwidefsky
Move the function that prints the segment warning messages found in the monreader driver and the dcssblk driver to the extmem base code. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-04-17[S390] zcrypt: Comments and kernel-doc cleanupFelix Beck
Comments, which suggested to be kernel-doc but were not in the right formatting, have been corrected. Additionally some minor cleanup in the comments has been done. Signed-off-by: Felix Beck <felix.beck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-04-17[S390] Fix a lot of sparse warnings.Heiko Carstens
Most noteable part of this commit is the new local header file entry.h which contains all the function declarations of functions that get only called from asm code or are arch internal. That way we can avoid extern declarations in C files. This is more or less the same that was done for sparc64. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-04-17[S390] Convert s390 to GENERIC_CLOCKEVENTS.Heiko Carstens
This way we get rid of s390's NO_IDLE_HZ and use the generic dynticks variant instead. In addition we get high resolution timers for free. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-04-17[S390] Convert monitor calls to function calls.Heiko Carstens
Remove the program check generating monitor calls and use function calls instead. Theres is no real advantage in using monitor calls, but they do make debugging harder, because of all the program checks it generates. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-04-17[S390] qdio (new feature): enhancing info-retrieval from QDIO-adaptersUrsula Braun
Next generation of OSA adapters allows retrieval of further self-describing infos. This is the preparational infrastructure patch for further exploitation in the qeth driver. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-04-17[S390] replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-04-17[S390] zcrypt: add support for large random numbersRalph Wuerthner
This patch allows user space applications to access large amounts of truly random data. The random data source is the build-in hardware random number generator on the CEX2C cards. Signed-off-by: Ralph Wuerthner <rwuerthn@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-04-17[S390] Add new fields for System z10 to /proc/sysinfoMartin Schwidefsky
Add permanent and temporary model capacity and the corresponding capacity value fields for the three capacity identifiers to the output of /proc/sysinfo. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-04-17[S390] KVM preparation: split sysinfo definitions for kvm useChristian Borntraeger
drivers/s390/sysinfo.c uses the store system information intruction to query the system about information of the machine, the LPAR and additional hypervisors. KVM has to implement the host part for this instruction. To avoid code duplication, this patch splits the common definitions from sysinfo.c into a separate header file include/asm-s390/sysinfo.h for KVM use. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
