[ Upstream commit 6bd520ab7cf69486ea81fd3cdfd2d5a390ad1100 ]
use of_node_put() to release the refcount.
Signed-off-by: Yangtao Li <tiny.windzz@gmail.com>
[ Upstream commit 87d81a23e24f24ebe014891e8bdf3ff8785031e8 ]
A null check before a kfree is redundant, so remove it.
Use the of_get_child_by_name() helper instead of open coding searching
for the '/options' node. This removes directly accessing the name
pointer as well.
Cc: sparclinux@vger.kernel.org
Signed-off-by: Rob Herring <robh@kernel.org>
As files move around, their previous links break. Fix the
references for them.
Acked-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
Acked-by: Jonathan Corbet <corbet@lwn.net>
Nobody is using it anymore, and it's been abandoned. Since David
is fine with removing it, kill it.
Suggested-by: Christoph Hellwig <hch@lst.de>
Just kmap the bio single page payload before processing it.
(and yes, now highmem on sparc32 anyway, but kmap_(un)map atomic are nops,
so this gives the right example)
The license text in both oradax files mistakenly specifies "version 3" of
the GNU General Public License. This is corrected to specify "version 2".
Signed-off-by: Rob Gardner <rob.gardner@oracle.com>
Signed-off-by: Jonathan Helman <jonathan.helman@oracle.com>
Each Oracle DAX CCB has a corresponding completion area, and the required
number of areas must fit within a previously allocated array of completion
areas beginning at the requested index. Since the completion area index
is specified by a file offset, a user can pass arbitrary values, including
negative numbers. So the index must be thoroughly range checked to prevent
access to addresses outside the bounds of the allocated completion
area array. The index cannot be negative, and it cannot exceed the
total array size, less the number of CCBs requested. The old code did
not check for negative values and was off by one on the upper bound.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
sparc:allmodconfig fails to build as follows.
ERROR: "mdesc_release" [drivers/sbus/char/oradax.ko] undefined!
ERROR: "sun4v_hvapi_register" [drivers/sbus/char/oradax.ko] undefined!
ERROR: "mdesc_get_property" [drivers/sbus/char/oradax.ko] undefined!
ERROR: "mdesc_node_by_name" [drivers/sbus/char/oradax.ko] undefined!
ERROR: "mdesc_grab" [drivers/sbus/char/oradax.ko] undefined!
ERROR: "sun4v_ccb_info" [drivers/sbus/char/oradax.ko] undefined!
ERROR: "sun4v_ccb_submit" [drivers/sbus/char/oradax.ko] undefined!
ERROR: "sun4v_ccb_kill" [drivers/sbus/char/oradax.ko] undefined!
The symbols are only available with SPARC64 builds, thus the driver
depends on it.
Fixes: dd0273284c74 ("sparc64: Oracle DAX driver")
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
- skip AER driver error recovery callbacks for correctable errors
reported via ACPI APEI, as we already do for errors reported via the
native path (Tyler Baicar)
- fix DPC shared interrupt handling (Alex Williamson)
- print full DPC interrupt number (Keith Busch)
- enable DPC only if AER is available (Keith Busch)
- simplify DPC code (Bjorn Helgaas)
- calculate ASPM L1 substate parameter instead of hardcoding it (Bjorn
Helgaas)
- enable Latency Tolerance Reporting for ASPM L1 substates (Bjorn
Helgaas)
- move ASPM internal interfaces out of public header (Bjorn Helgaas)
- allow hot-removal of VGA devices (Mika Westerberg)
- speed up unplug and shutdown by assuming Thunderbolt controllers
don't support Command Completed events (Lukas Wunner)
- add AtomicOps support for GPU and Infiniband drivers (Felix Kuehling,
Jay Cornwall)
- expose "ari_enabled" in sysfs to help NIC naming (Stuart Hayes)
- clean up PCI DMA interface usage (Christoph Hellwig)
- remove PCI pool API (replaced with DMA pool) (Romain Perier)
- deprecate pci_get_bus_and_slot(), which assumed PCI domain 0 (Sinan
Kaya)
- move DT PCI code from drivers/of/ to drivers/pci/ (Rob Herring)
- add PCI-specific wrappers for dev_info(), etc (Frederick Lawler)
- remove warnings on sysfs mmap failure (Bjorn Helgaas)
- quiet ROM validation messages (Alex Deucher)
- remove redundant memory alloc failure messages (Markus Elfring)
- fill in types for compile-time VGA and other I/O port resources
(Bjorn Helgaas)
- make "pci=pcie_scan_all" work for Root Ports as well as Downstream
Ports to help AmigaOne X1000 (Bjorn Helgaas)
- add SPDX tags to all PCI files (Bjorn Helgaas)
- quirk Marvell 9128 DMA aliases (Alex Williamson)
- quirk broken INTx disable on Ceton InfiniTV4 (Bjorn Helgaas)
- fix CONFIG_PCI=n build by adding dummy pci_irqd_intx_xlate() (Niklas
Cassel)
- use DMA API to get MSI address for DesignWare IP (Niklas Cassel)
- fix endpoint-mode DMA mask configuration (Kishon Vijay Abraham I)
- fix ARTPEC-6 incorrect IS_ERR() usage (Wei Yongjun)
- add support for ARTPEC-7 SoC (Niklas Cassel)
- add endpoint-mode support for ARTPEC (Niklas Cassel)
- add Cadence PCIe host and endpoint controller driver (Cyrille
Pitchen)
- handle multiple INTx status bits being set in dra7xx (Vignesh R)
- translate dra7xx hwirq range to fix INTD handling (Vignesh R)
- remove deprecated Exynos PHY initialization code (Jaehoon Chung)
- fix MSI erratum workaround for HiSilicon Hip06/Hip07 (Dongdong Liu)
- fix NULL pointer dereference in iProc BCMA driver (Ray Jui)
- fix Keystone interrupt-controller-node lookup (Johan Hovold)
- constify qcom driver structures (Julia Lawall)
- rework Tegra config space mapping to increase space available for
endpoints (Vidya Sagar)
- simplify Tegra driver by using bus->sysdata (Manikanta Maddireddy)
- remove PCI_REASSIGN_ALL_BUS usage on Tegra (Manikanta Maddireddy)
- add support for Global Fabric Manager Server (GFMS) event to
Microsemi Switchtec switch driver (Logan Gunthorpe)
- add IDs for Switchtec PSX 24xG3 and PSX 48xG3 (Kelvin Cao)
* tag 'pci-v4.16-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (140 commits)
PCI: cadence: Add EndPoint Controller driver for Cadence PCIe controller
dt-bindings: PCI: cadence: Add DT bindings for Cadence PCIe endpoint controller
PCI: endpoint: Fix EPF device name to support multi-function devices
PCI: endpoint: Add the function number as argument to EPC ops
PCI: cadence: Add host driver for Cadence PCIe controller
dt-bindings: PCI: cadence: Add DT bindings for Cadence PCIe host controller
PCI: Add vendor ID for Cadence
PCI: Add generic function to probe PCI host controllers
PCI: generic: fix missing call of pci_free_resource_list()
PCI: OF: Add generic function to parse and allocate PCI resources
PCI: Regroup all PCI related entries into drivers/pci/Makefile
PCI/DPC: Reformat DPC register definitions
PCI/DPC: Add and use DPC Status register field definitions
PCI/DPC: Squash dpc_rp_pio_get_info() into dpc_process_rp_pio_error()
PCI/DPC: Remove unnecessary RP PIO register structs
PCI/DPC: Push dpc->rp_pio_status assignment into dpc_rp_pio_get_info()
PCI/DPC: Squash dpc_rp_pio_print_error() into dpc_rp_pio_get_info()
PCI/DPC: Make RP PIO log size check more generic
PCI/DPC: Rename local "status" to "dpc_status"
PCI/DPC: Squash dpc_rp_pio_print_tlp_header() into dpc_rp_pio_print_error()
In case of error, the function class_create() returns ERR_PTR() and
never returns NULL. The NULL test in the return value check should be
replaced with IS_ERR().
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
DAX is a coprocessor which resides on the SPARC M7 (DAX1) and M8
(DAX2) processor chips, and has direct access to the CPU's L3 caches
as well as physical memory. It can perform several operations on data
streams with various input and output formats. This driver provides a
transport mechanism and has limited knowledge of the various opcodes
and data formats. A user space library provides high level services
and translates these into low level commands which are then passed
into the driver and subsequently the hypervisor and the coprocessor.
The library is the recommended way for applications to use the
coprocessor, and the driver interface is not intended for general use.
Signed-off-by: Sanath Kumar <sanath099@gmail.com>
pci_get_bus_and_slot() is restrictive such that it assumes domain=0 as
where a PCI device is present. This restricts the device drivers to be
reused for other domain numbers.
Getting ready to remove pci_get_bus_and_slot() function in favor of
pci_get_domain_bus_and_slot().
Hard-coding the domain as 0 since domain information is not available.
Signed-off-by: Sinan Kaya <okaya@codeaurora.org>
Signed-off-by: Bjorn Helgaas <helgaas@kernel.org>
Pull sparc updates from David Miller:
1) Add missing cmpxchg64() for 32-bit sparc.
2) Timer conversions from Allen Pais and Kees Cook.
3) vDSO support, from Nagarathnam Muthusamy.
4) Fix sparc64 huge page table walks based upon bug report by Al Viro,
from Nitin Gupta.
5) Optimized fls() for T4 and above, from Vijay Kumar.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc:
sparc64: Fix page table walk for PUD hugepages
sparc64: Convert timers to user timer_setup()
sparc64: convert mdesc_handle.refcnt from atomic_t to refcount_t
sparc/led: Convert timers to use timer_setup()
sparc64: Use sparc optimized fls and __fls for T4 and above
sparc64: SPARC optimized __fls function
sparc64: SPARC optimized fls function
sparc64: Define SPARC default __fls function
sparc64: Define SPARC default fls function
vDSO for sparc
sparc32: Add cmpxchg64().
sbus: char: Move D7S_MINOR to include/linux/miscdevice.h
sparc: time: Remove unneeded linux/miscdevice.h include
sparc64: mmu_context: Add missing include files
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
This patch move the define for D7S_MINOR to include/linux/miscdevice.h.
It's better that all minor number are in the same place.
Signed-off-by: Corentin Labbe <clabbe.montjoie@gmail.com>
Now that we have a custom printf format specifier, convert users of
full_name to use %pOF instead. This is preparation to remove storing
of the full path string for each node.
Instead move it to the callers. Those that either don't use bio_data() or
page_address() or are specific to architectures that do not support highmem
are skipped.
Currently we use nornal Linux errno values in the block layer, and while
we accept any error a few have overloaded magic meanings. This patch
instead introduces a new blk_status_t value that holds block layer specific
status codes and explicitly explains their meaning. Helpers to convert from
and to the previous special meanings are provided for now, but I suspect
we want to get rid of them in the long run - those drivers that have a
errno input (e.g. networking) usually get errnos that don't know about
the special block layer overloads, and similarly returning them to userspace
will usually return somethings that strictly speaking isn't correct
for file system operations, but that's left as an exercise for later.
For now the set of errors is a very limited set that closely corresponds
to the previous overloaded errno values, but there is some low hanging
fruite to improve it.
blk_status_t (ab)uses the sparse __bitwise annotations to allow for sparse
typechecking, so that we can easily catch places passing the wrong values.
Signed-off-by: Jens Axboe <axboe@fb.com>
Compile-tested only (by hacking it to compile on x86).
Signed-off-by: Omar Sandoval <osandov@fb.com>
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
Fix following warnings:
openprom.c:510:2: warning: 'tmp' may be used uninitialized in this function [-Wmaybe-uninitialized]
openprom.c:503:3: warning: 'str' may be used uninitialized in this function [-Wmaybe-uninitialized]
openprom.c:459:8: warning: 'str' may be used uninitialized in this function [-Wmaybe-uninitialized]
openprom.c:422:7: warning: 'str' may be used uninitialized in this function [-Wmaybe-uninitialized]
Fixed by introducing PTR_ERR etc.
This simplified the code as a nice side effect.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
A _lot_ of ->write() instances were open-coding it; some are
converted to memdup_user_nul(), a lot more remain...
orderly_poweroff() unconditionally returns 0, so remove the dead code that
checks the return value.
A future patch will change the return type to void.
Signed-off-by: Joel Stanley <joel@jms.id.au>
Cc: Fabian Frederick <fabf@skynet.be>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Jeremy Kerr <jk@ozlabs.org>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
arch/sparc/mm/init_64.c
Conflict was simple non-overlapping additions.
Fix regression in bbc i2c temperature and fan control on some Sun systems
that causes the driver to refuse to load due to the bbc_i2c_bussel resource not
being present on the (second) i2c bus where the temperature sensors and fan
control are located. (The check for the number of resources was removed when
the driver was ported to a pure OF driver in mid 2008.)
Signed-off-by: Christopher Alexander Tobias Schulze <cat.schulze@alice-dsl.net>
Flipping a bit doesn't need four lines of code; and gcc seems to
actually generate two branches.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
This patch moves data allocated using kzalloc to managed data allocated
using devm_kzalloc and cleans now unnecessary kfrees in probe and remove
functions. The header file is added to make the devm function explicitly
available.
The following Coccinelle semantic patch was used for making a part of
the change:
@platform@
identifier p, probefn, removefn;
struct platform_driver p = {
.probe = probefn,
.remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e, e1, e2;
probefn(struct platform_device *pdev, ...) {
- e = kzalloc(e1, e2)
+ e = devm_kzalloc(&pdev->dev, e1, e2)
?-kfree(e);
@rem depends on prb@
identifier platform.removefn;
expression e;
removefn(...) {
- kfree(e);
Signed-off-by: Himangi Saraogi <himangi774@gmail.com>
Acked-by: Julia Lawall <julia.lawall@lip6.fr>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
sparc_cpu_model isn't in asm/system.h any more, so remove a comment
about it.
cc: "David S. Miller" <davem@davemloft.net>
cc: sparclinux@vger.kernel.org
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Fix following warning:
WARNING: drivers/sbus/char/bbc.o(.text+0x674): Section mismatch in reference from the function bbc_i2c_probe() to the function .init.text:T.463()
The function bbc_i2c_probe() references the function __init T.463().
This is often because bbc_i2c_probe lacks a __init
annotation or the annotation of T.463 is wrong.
bbc_i2c_probe() referenced the inlined attach_one_i2c().
As probe may be called after init drop __init annotations
on all functions used by bbc_i2c_probe()
The warning was seen with a sparc64 defconfig build
Pull vfs pile (part one) from Al Viro:
"Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent
locking violations, etc.
The most visible changes here are death of FS_REVAL_DOT (replaced with
"has ->d_weak_revalidate()") and a new helper getting from struct file
to inode. Some bits of preparation to xattr method interface changes.
Misc patches by various people sent this cycle *and* ocfs2 fixes from
several cycles ago that should've been upstream right then.
PS: the next vfs pile will be xattr stuff."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits)
saner proc_get_inode() calling conventions
proc: avoid extra pde_put() in proc_fill_super()
fs: change return values from -EACCES to -EPERM
fs/exec.c: make bprm_mm_init() static
ocfs2/dlm: use GFP_ATOMIC inside a spin_lock
ocfs2: fix possible use-after-free with AIO
ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path
get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero
target: writev() on single-element vector is pointless
export kernel_write(), convert open-coded instances
fs: encode_fh: return FILEID_INVALID if invalid fid_type
kill f_vfsmnt
vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op
nfsd: handle vfs_getattr errors in acl protocol
switch vfs_getattr() to struct path
default SET_PERSONALITY() in linux/elf.h
ceph: prepopulate inodes only when request is aborted
d_hash_and_lookup(): export, switch open-coded instances
9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate()
9p: split dropping the acls from v9fs_set_create_acl()
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a
while now and is almost always enabled by default. As agreed during the
Linux kernel summit, remove it from any "depends on" lines in Kconfigs.
CC: "David S. Miller" <davem@davemloft.net>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, and __devexit
from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Peter Senna Tschudin <peter.senna@gmail.com>
removes unnecessary semicolon
Found by Coccinelle: http://coccinelle.lip6.fr/
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
This patch converts the drivers in drivers/sbus/char/* to use the
module_platform_driver() macro which makes the code smaller and a bit
simpler.
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
Get rid of old users of of_platform_driver in arch/sparc. Most
of_platform_driver users can be converted to use the platform_bus
directly.
When we switched sparc from using 'int's to 'phandle's (which is a u32), we
neglected to do anything with the various checks for -1. For those tests,
explicitly cast the phandles to s32.
Signed-off-by: Andres Salomon <dilinger@queued.net>
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6:
mtd/m25p80: add support to parse the partitions by OF node
of/irq: of_irq.c needs to include linux/irq.h
of/mips: Cleanup some include directives/files.
of/mips: Add device tree support to MIPS
of/flattree: Eliminate need to provide early_init_dt_scan_chosen_arch
of/device: Rework to use common platform_device_alloc() for allocating devices
of/xsysace: Fix OF probing on little-endian systems
of: use __be32 types for big-endian device tree data
of/irq: remove references to NO_IRQ in drivers/of/platform.c
of/promtree: add package-to-path support to pdt
of/promtree: add of_pdt namespace to pdt code
of/promtree: no longer call prom_ functions directly; use an ops structure
of/promtree: make drivers/of/pdt.c no longer sparc-only
sparc: break out some PROM device-tree building code out into drivers/of
of/sparc: convert various prom_* functions to use phandle
sparc: stop exporting openprom.h header
powerpc, of_serial: Endianness issues setting up the serial ports
of: MTD: Fix OF probing on little-endian systems
of: GPIO: Fix OF probing on little-endian systems
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
Rather than passing around ints everywhere, use the
phandle type where appropriate for the various functions
that talk to the PROM.
