path: root/drivers/sbus
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2011-12-04sbus: convert drivers/sbus/char/* to use module_platform_driver()Axel Lin
This patch converts the drivers in drivers/sbus/char/* to use the module_platform_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-04bbc_i2c: Remove unneeded err variableAxel Lin
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-28dt/sparc: Eliminate users of of_platform_{,un}register_driverGrant Likely
Get rid of old users of of_platform_driver in arch/sparc. Most of_platform_driver users can be converted to use the platform_bus directly. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-01-03sparc: explicitly cast negative phandle checks to s32Andres Salomon
When we switched sparc from using 'int's to 'phandle's (which is a u32), we neglected to do anything with the various checks for -1. For those tests, explicitly cast the phandles to s32. Signed-off-by: Andres Salomon <dilinger@queued.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-25Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: mtd/m25p80: add support to parse the partitions by OF node of/irq: of_irq.c needs to include linux/irq.h of/mips: Cleanup some include directives/files. of/mips: Add device tree support to MIPS of/flattree: Eliminate need to provide early_init_dt_scan_chosen_arch of/device: Rework to use common platform_device_alloc() for allocating devices of/xsysace: Fix OF probing on little-endian systems of: use __be32 types for big-endian device tree data of/irq: remove references to NO_IRQ in drivers/of/platform.c of/promtree: add package-to-path support to pdt of/promtree: add of_pdt namespace to pdt code of/promtree: no longer call prom_ functions directly; use an ops structure of/promtree: make drivers/of/pdt.c no longer sparc-only sparc: break out some PROM device-tree building code out into drivers/of of/sparc: convert various prom_* functions to use phandle sparc: stop exporting openprom.h header powerpc, of_serial: Endianness issues setting up the serial ports of: MTD: Fix OF probing on little-endian systems of: GPIO: Fix OF probing on little-endian systems
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-09of/sparc: convert various prom_* functions to use phandleAndres Salomon
Rather than passing around ints everywhere, use the phandle type where appropriate for the various functions that talk to the PROM. Signed-off-by: Andres Salomon <dilinger@queued.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-05drivers: autoconvert trivial BKL users to private mutexArnd Bergmann
All these files use the big kernel lock in a trivial way to serialize their private file operations, typically resulting from an earlier semi-automatic pushdown from VFS. None of these drivers appears to want to lock against other code, and they all use the BKL as the top-level lock in their file operations, meaning that there is no lock-order inversion problem. Consequently, we can remove the BKL completely, replacing it with a per-file mutex in every case. Using a scripted approach means we can avoid typos. These drivers do not seem to be under active maintainance from my brief investigation. Apologies to those maintainers that I have missed. file=$1 name=$2 if grep -q lock_kernel ${file} ; then if grep -q 'include.*linux.mutex.h' ${file} ; then sed -i '/include.*<linux\/smp_lock.h>/d' ${file} else sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file} fi sed -i ${file} \ -e "/^#include.*linux.mutex.h/,$ { 1,/^\(static\|int\|long\)/ { /^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex); } }" \ -e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \ -e '/[ ]*cycle_kernel_lock();/d' else sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \ -e '/cycle_kernel_lock()/d' fi Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-08-05Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: (63 commits) of/platform: Register of_platform_drivers with an "of:" prefix of/address: Clean up function declarations of/spi: call of_register_spi_devices() from spi core code of: Provide default of_node_to_nid() implementation. of/device: Make of_device_make_bus_id() usable by other code. of/irq: Fix endian issues in parsing interrupt specifiers of: Fix phandle endian issues of/flattree: fix of_flat_dt_is_compatible() to match the full compatible string of: remove of_default_bus_ids of: make of_find_device_by_node generic microblaze: remove references to of_device and to_of_device sparc: remove references to of_device and to_of_device powerpc: remove references to of_device and to_of_device of/device: Replace of_device with platform_device in includes and core code of/device: Protect against binding of_platform_drivers to non-OF devices of: remove asm/of_device.h of: remove asm/of_platform.h of/platform: remove all of_bus_type and of_platform_bus_type references of: Merge of_platform_bus_type with platform_bus_type drivercore/of: Add OF style matching to platform bus ... Fix up trivial conflicts in arch/microblaze/kernel/Makefile due to just some obj-y removals by the devicetree branch, while the microblaze updates added a new file.
2010-07-24of/platform: remove all of_bus_type and of_platform_bus_type referencesGrant Likely
Both of_bus_type and of_platform_bus_type are just #define aliases for the platform bus. This patch removes all references to them and switches to the of_register_platform_driver()/of_unregister_platform_driver() API for registering. Subsequent patches will convert each user of of_register_platform_driver() into plain platform_drivers without the of_platform_driver shim. At which point the of_register_platform_driver()/of_unregister_platform_driver() functions can be removed. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net>
2010-07-24Merge commit 'v2.6.35-rc6' into devicetree/nextGrant Likely
Conflicts: arch/sparc/kernel/prom_64.c
2010-07-20sbus: autoconvert trivial BKL users to private mutexArnd Bergmann
All these files use the big kernel lock in a trivial way to serialize their private file operations, typically resulting from an earlier semi-automatic pushdown from VFS. None of these drivers appears to want to lock against other code, and they all use the BKL as the top-level lock in their file operations, meaning that there is no lock-order inversion problem. Consequently, we can remove the BKL completely, replacing it with a per-file mutex in every case. Using a scripted approach means we can avoid typos. file=$1 name=$2 if grep -q lock_kernel ${file} ; then if grep -q 'include.*linux.mutex.h' ${file} ; then sed -i '/include.*<linux\/smp_lock.h>/d' ${file} else sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file} fi sed -i ${file} \ -e "/^#include.*linux.mutex.h/,$ { 1,/^\(static\|int\|long\)/ { /^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex); } }" \ -e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \ -e '/[ ]*cycle_kernel_lock();/d' else sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \ -e '/cycle_kernel_lock()/d' fi Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-12drivers/sbus: Remove unnecessary casts of private_dataJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-28sparc/of: Move of_device fields into struct pdev_archdataGrant Likely
This patch moves SPARC architecture specific data members out of struct of_device and into the pdev_archdata structure. The reason for this change is to unify the struct of_device definition amongst all the architectures. It also remvoes the .sysdata, .slot, .portid and .clock_freq properties because they aren't actually used by anything. A subsequent patch will replace struct of_device entirely with struct platform_device and the of_platform support code will share common routines with the platform bus (but the bus instances themselves can remain separate). This patch also adds 'struct resources *resource' and num_resources to match the fields defined in struct platform_device. After this change, 'struct platform_device' can be used as a drop-in replacement for 'struct of_platform'. This change is in preparation for merging the of_platform_bus_type with the platform_bus_type. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au>
2010-05-24Merge branch 'bkl/ioctl' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing * 'bkl/ioctl' of git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing: uml: Pushdown the bkl from harddog_kern ioctl sunrpc: Pushdown the bkl from sunrpc cache ioctl sunrpc: Pushdown the bkl from ioctl autofs4: Pushdown the bkl from ioctl uml: Convert to unlocked_ioctls to remove implicit BKL ncpfs: BKL ioctl pushdown coda: Clean-up whitespace problems in pioctl.c coda: BKL ioctl pushdown drivers: Push down BKL into various drivers isdn: Push down BKL into ioctl functions scsi: Push down BKL into ioctl functions dvb: Push down BKL into ioctl functions smbfs: Push down BKL into ioctl function coda/psdev: Remove BKL from ioctl function um/mmapper: Remove BKL usage sn_hwperf: Kill BKL usage hfsplus: Push down BKL into ioctl function
2010-05-22Merge remote branch 'origin' into secretlab/next-devicetreeGrant Likely
Merging in current state of Linus' tree to deal with merge conflicts and build failures in vio.c after merge. Conflicts: drivers/i2c/busses/i2c-cpm.c drivers/i2c/busses/i2c-mpc.c drivers/net/gianfar.c Also fixed up one line in arch/powerpc/kernel/vio.c to use the correct node pointer. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-22of: Remove duplicate fields from of_platform_driverGrant Likely
.name, .match_table and .owner are duplicated in both of_platform_driver and device_driver. This patch is a removes the extra copies from struct of_platform_driver and converts all users to the device_driver members. This patch is a pretty mechanical change. The usage model doesn't change and if any drivers have been missed, or if anything has been fixed up incorrectly, then it will fail with a compile time error, and the fixup will be trivial. This patch looks big and scary because it touches so many files, but it should be pretty safe. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com>
2010-05-18of: Always use 'struct device.of_node' to get device node pointer.Grant Likely
The following structure elements duplicate the information in 'struct device.of_node' and so are being eliminated. This patch makes all readers of these elements use device.of_node instead. (struct of_device *)->node (struct dev_archdata *)->prom_node (sparc) (struct dev_archdata *)->of_node (powerpc & microblaze) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-17drivers: Push down BKL into various driversArnd Bergmann
These are the last remaining device drivers using the ->ioctl file operation in the drivers directory (except from v4l drivers). [fweisbec: drop i8k pushdown as it has been done from procfs pushdown branch already] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2010-04-27drivers/sbus/char/flash.c: flash_read should update ppos instead of file->f_posJan Blunck
flash_read() updates file->f_pos directly instead of the ppos given. The VFS later updates the file->f_pos and overwrites it with the unchanged value of ppos. Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-28Merge commit 'v2.6.33-rc5' into secretlab/test-devicetreeGrant Likely
2010-01-28of: unify phandle name in struct device_nodeGrant Likely
In struct device_node, the phandle is named 'linux_phandle' for PowerPC and MicroBlaze, and 'node' for SPARC. There is no good reason for the difference, it is just an artifact of the code diverging over a couple of years. This patch renames both to simply .phandle. Note: the .node also existed in PowerPC/MicroBlaze, but the only user seems to be arch/powerpc/platforms/powermac/pfunc_core.c. It doesn't look like the assignment between .linux_phandle and .node is significantly different enough to warrant the separate code paths unless ibm,phandle properties actually appear in Apple device trees. I think it is safe to eliminate the old .node property and use phandle everywhere. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net> Tested-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-01-04bbc_envctrl: Clean up properly if kthread_run() fails.David S. Miller
In bbc_envctrl_init() we have to unlink the fan and temp instances from the lists because our caller is going to free up the 'bp' object if we return an error. We can't rely upon bbc_envctrl_cleanup() to do this work for us in this case. Reported-by: Patrick Finnegan <pat@computer-refuge.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-22const: make block_device_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-17sparc: Fix cleanup crash in bbc_envctrl_cleanup()David S. Miller
If kthread_run() fails or never gets to run we'll have NULL or a pointer encoded error in kenvctrld_task, rather than a legitimate task pointer. So this makes bbc_envctrl_cleanup() crash as it passed this bogus pointer into kthread_stop(). Reported-by: BERTRAND Joël <joel.bertrand@systella.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-16openprom: Squelch useless GCC warning.David S. Miller
drivers/sbus/char/openprom.c: In function ‘openprom_sunos_ioctl’: drivers/sbus/char/openprom.c:306: warning: ‘opp’ may be used uninitialized in this function Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-11block: implement and enforce request peek/start/fetchTejun Heo
Till now block layer allowed two separate modes of request execution. A request is always acquired from the request queue via elv_next_request(). After that, drivers are free to either dequeue it or process it without dequeueing. Dequeue allows elv_next_request() to return the next request so that multiple requests can be in flight. Executing requests without dequeueing has its merits mostly in allowing drivers for simpler devices which can't do sg to deal with segments only without considering request boundary. However, the benefit this brings is dubious and declining while the cost of the API ambiguity is increasing. Segment based drivers are usually for very old or limited devices and as converting to dequeueing model isn't difficult, it doesn't justify the API overhead it puts on block layer and its more modern users. Previous patches converted all block low level drivers to dequeueing model. This patch completes the API transition by... * renaming elv_next_request() to blk_peek_request() * renaming blkdev_dequeue_request() to blk_start_request() * adding blk_fetch_request() which is combination of peek and start * disallowing completion of queued (not started) requests * applying new API to all LLDs Renamings are for consistency and to break out of tree code so that it's apparent that out of tree drivers need updating. [ Impact: block request issue API cleanup, no functional change ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Mike Miller <mike.miller@hp.com> Cc: unsik Kim <donari75@gmail.com> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: David S. Miller <davem@davemloft.net> Cc: Laurent Vivier <Laurent@lvivier.info> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Adrian McMenamin <adrian@mcmen.demon.co.uk> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: Pierre Ossman <drzeus@drzeus.cx> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Stefan Weinhuber <wein@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11jsflash: dequeue in-flight requestTejun Heo
jsflash processes requests one-by-one synchronously from a kthread and can be easily converted to dequeueing model. Convert it. [ Impact: dequeue in-flight request ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: blk_rq_[cur_]_{sectors|bytes}() usage cleanupTejun Heo
With the previous changes, the followings are now guaranteed for all requests in any valid state. * blk_rq_sectors() == blk_rq_bytes() >> 9 * blk_rq_cur_sectors() == blk_rq_cur_bytes() >> 9 Clean up accessor usages. Notable changes are * nbd,i2o_block: end_all used instead of explicit byte count * scsi_lib: unnecessary conditional on request type removed [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: convert to pos and nr_sectors accessorsTejun Heo
With recent cleanups, there is no place where low level driver directly manipulates request fields. This means that the 'hard' request fields always equal the !hard fields. Convert all rq->sectors, nr_sectors and current_nr_sectors references to accessors. While at it, drop superflous blk_rq_pos() < 0 test in swim.c. [ Impact: use pos and nr_sectors accessors ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Tested-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Mike Miller <mike.miller@hp.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Dario Ballabio <ballabio_dario@emc.com> Cc: David S. Miller <davem@davemloft.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: unsik Kim <donari75@gmail.com> Cc: Laurent Vivier <Laurent@lvivier.info> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28block: replace end_request() with [__]blk_end_request_cur()Tejun Heo
end_request() has been kept around for backward compatibility; however, it's about time for it to go away. * There aren't too many users left. * Its use of @updtodate is pretty confusing. * In some cases, newer code ends up using mixture of end_request() and [__]blk_end_request[_all](), which is way too confusing. So, add [__]blk_end_request_cur() and replace end_request() with it. Most conversions are straightforward. Noteworthy ones are... * paride/pcd: next_request() updated to take 0/-errno instead of 1/0. * paride/pf: pf_end_request() and next_request() updated to take 0/-errno instead of 1/0. * xd: xd_readwrite() updated to return 0/-errno instead of 1/0. * mtd/mtd_blkdevs: blktrans_discard_request() updated to return 0/-errno instead of 1/0. Unnecessary local variable res initialization removed from mtd_blktrans_thread(). [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Joerg Dorchain <joerg@dorchain.net> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Laurent Vivier <Laurent@lvivier.info> Cc: Tim Waugh <tim@cyberelk.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: unsik Kim <donari75@gmail.com>
2009-04-14sbus: changed ioctls to unlockedStoyan Gaydarov
Signed-off-by: Stoyan Gaydarov <stoyboyker@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-13sbus: Auto-load openprom module when device opened.Scott James Remnant
The openprom module is missing the char-major-10-139 alias that would cause it to be auto-loaded when a device of that type is opened. This patch adds the alias. Signed-off-by: Scott James Remnant <scott@canonical.com> Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-04sparc64: wait_event_interruptible_timeout may return -ERESTARTSYSRoel Kluin
wait_event_interruptible_timeout may return -ERESTARTSYS. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-04jsflash: stop defining MAJOR_NRChristoph Hellwig
Ever since early 2.5 kernels block drivers don't need to define MAJOR_NR anymore, so use the JSFD_MAJOR defined directly and kill it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-06sparc64: Fix unsigned long long warnings in drivers.Sam Ravnborg
Fix warnings caused by the unsigned long long usage in sparc specific drivers. The drivers were considered sparc specific more or less from the filename alone. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-01Revert "of_platform_driver noise on sparce"Linus Torvalds
This reverts commit e669dae6141ff97d3c7566207f5de3b487dcf837, since it is incomplete, and clashes with fuller patches and the sparc 32/64 unification effort. Requested-by: David Miller <davem@davemloft.net> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-30of_platform_driver noise on sparceAl Viro
switch to __init for those; unlike powerpc sparc has no hotplug support for that stuff and their ->probe() tends to call __init functions while being declared __devinit. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-04drivers: remove duplicated #includeJianjun Kong
Signed-off-by: Jianjun Kong <jianjun@zeuux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-03sparc: Kill sbus mostek RTC driver.David S. Miller
No longer used. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-31sparc: Annotate of_device_id arrays with const or __initdata.David S. Miller
As suggested by Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29bbc_envctrl: Fix build errors from bbc_i2c OF conversion.David S. Miller
2008-08-29bbc_i2c: Convert to pure OF driver.David S. Miller
This thing was a mess, who wrote this junk? :) Luckily we'll soon have nice generic I2C layer drivers for this PCF based I2C stuff on sparc64. Signed-off-by: David S. Miller <davem@davemloft.net>
