path: root/drivers/scsi/53c700.c
2008-05-02[SCSI] Let scsi_cmnd->cmnd use request->cmd bufferBoaz Harrosh
- struct scsi_cmnd had a 16 bytes command buffer of its own. This is an unnecessary duplication and copy of request's cmd. It is probably left overs from the time that scsi_cmnd could function without a request attached. So clean that up. - Once above is done, few places, apart from scsi-ml, needed adjustments due to changing the data type of scsi_cmnd->cmnd. - Lots of drivers still use MAX_COMMAND_SIZE. So I have left that #define but equate it to BLK_MAX_CDB. The way I see it and is reflected in the patch below is. MAX_COMMAND_SIZE - means: The longest fixed-length (*) SCSI CDB as per the SCSI standard and is not related to the implementation. BLK_MAX_CDB. - The allocated space at the request level - I have audit all ISA drivers and made sure none use ->cmnd in a DMA Operation. Same audit was done by Andi Kleen. (*)fixed-length here means commands that their size can be determined by their opcode and the CDB does not carry a length specifier, (unlike the VARIABLE_LENGTH_CMD(0x7f) command). This is actually not exactly true and the SCSI standard also defines extended commands and vendor specific commands that can be bigger than 16 bytes. The kernel will support these using the same infrastructure used for VARLEN CDB's. So in effect MAX_COMMAND_SIZE means the maximum size command scsi-ml supports without specifying a cmd_len by ULD's Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] replace sizeof sense_buffer with SCSI_SENSE_BUFFERSIZEFUJITA Tomonori
This replaces sizeof sense_buffer with SCSI_SENSE_BUFFERSIZE in several LLDs. It's a preparation for the future changes to remove sense_buffer array in scsi_cmnd structure. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-07-14[SCSI] 53c700: Remove printk, which triggers because of low scsi clock on ↵Thomas Bogendoerfer
SNI RMs remove printk, which triggers because of low scsi clock on SNI RMs Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-17[SCSI] 53c700: m68k support for the 53c700 SCSI coreKars de Jong
Add m68k support to the 53c700 SCSI driver Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-26[SCSI] 53c700: convert to use the data buffer accessorsFUJITA Tomonori
- remove the unnecessary map_single path. - convert to use the new accessors for the sg lists and the parameters. Jens Axboe <jens.axboe@oracle.com> did the for_each_sg cleanup. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-13[SCSI] 53c700: Allow setting burst lengthThomas Bogendoerfer
This is a patch, which allows not only disabling bursting but to specify different burst lenghts. This feature is needed to get the 53c700 driver working for the onboard SCSI controller of SNI RM machines, which only work reliably with a 4 word burst length. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-12-07[PATCH] Pass struct dev pointer to dma_cache_sync()Ralf Baechle
Pass struct dev pointer to dma_cache_sync() dma_cache_sync() is ill-designed in that it does not have a struct device pointer argument which makes proper support for systems that consist of a mix of coherent and non-coherent DMA devices hard. Change dma_cache_sync to take a struct device pointer as first argument and fix all its callers to pass it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Add struct dev pointer to dma_is_consistent()Ralf Baechle
dma_is_consistent() is ill-designed in that it does not have a struct device pointer argument which makes proper support for systems that consist of a mix of coherent and non-coherent DMA devices hard. Change dma_is_consistent to take a struct device pointer as first argument and fix the sole caller to pass it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-03[SCSI] 53c700: brown paper bag fix for auto request senseJames Bottomley
In the switch over, I forgot to set the command length, so it sends out a request sense with whatever length the prior command had (and fails badly if it wasn't 6). Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-01[PATCH] completions: lockdep annotate on stack completionsPeter Zijlstra
All on stack DECLARE_COMPLETIONs should be replaced by: DECLARE_COMPLETION_ONSTACK Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03Merge ../scsi-misc-2.6James Bottomley
Conflicts: drivers/scsi/nsp32.c drivers/scsi/pcmcia/nsp_cs.c Removal of randomness flag conflicts with SA_ -> IRQF_ global replacement. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-29[SCSI] 53c700: fix breakage caused by the autosense updateJames Bottomley
A bit of a brown paper bag issue. The previous patch to remove the soon to be ripped out fields that were used in autosense actually broke the driver. This patch fixes it and has been tested (honestly). Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-26[SCSI] kmalloc argument switcheroo in recent 53c700 change.Dave Jones
On Wed, Jun 21, 2006 at 07:00:34PM +0000, Linux Kernel wrote: > commit 67d59dfdeb21df2c16dcd478b66177e91178ecd0 > tree ae85703651d81740f4a6cd398f9dd4d6aabe6a2f > parent 6db874fbdbedba5e15e76cc03b42f52ea70338c0 > author James Bottomley <James.Bottomley@steeleye.com> Wed, 14 Jun 2006 07:31:19 -0500 > committer James Bottomley <jejb@mulgrave.il.steeleye.com> Tue, 20 Jun 2006 05:34:01 -0500 > > [SCSI] 53c700: remove reliance on deprecated cmnd fields > ... > > + SDp->hostdata = kmalloc(GFP_KERNEL, sizeof(struct NCR_700_sense)); > + > + if (!SDp->hostdata) > + return -ENOMEM; "I'll take reversed arguments for $100 please Alex". Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-19[SCSI] 53c700: remove reliance on deprecated cmnd fieldsJames Bottomley
This one's quite tricky. The 53c700 uses the now deprecated fields of the command structure for saving the prior command when it does autosense. To fix this, we have to add extra fields to the LUN to accommodate a copy of the real command. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-10[SCSI] drivers/scsi: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove duplicates of the macro. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-05-28[SCSI] audit drivers for incorrect max_id useHannes Reinecke
max_id now means the maximum number of ids on the bus, which means it is one greater than the largest possible id number. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-27[SCSI] Add spi_populate_*_msg functionsMatthew Wilcox
Introduce new helpers: - spi_populate_width_msg() - spi_populate_sync_msg() - spi_populate_ppr_msg() and use them in drivers which already enable the SPI transport. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-15[SCSI] Rename scsi_print_msg to spi_print_msgMatthew Wilcox
Rename scsi_print_msg to spi_print_msg and move its prototype from scsi_dbg.h to scsi_transport_spi.h Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28[SCSI] use scmd_id(), scmd_channel() throughout codeJeff Garzik
Wrap a highly common idiom. Makes the code easier to read, helps pave the way for sdev->{id,channel} removal, and adds a token that can easily by grepped-for in the future. There are a couple sdev_id() and scmd_printk() updates thrown in as well. Rejections fixed up and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28[SCSI] use sfoo_printk() in driversJeff Garzik
2005-06-20[PATCH] Driver Core: drivers/s390/net/qeth_sys.c - ↵Yani Ioannou
drivers/usb/gadget/pxa2xx_udc.c: update device attribute callbacks Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-17[SCSI] allow sleeping in ->eh_host_reset_handler()Jeff Garzik
2005-06-17[SCSI] allow sleeping in ->eh_bus_reset_handler()Jeff Garzik
2005-06-17[SCSI] Remove no-op implementations of SCSI EH hooksJeff Garzik
Drivers need not implement a hook that returns FAILED, and does nothing else, since the SCSI midlayer code will do that for us. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-04-16[PATCH] finally fix 53c700 to use the generic iomem infrastructure
This driver has had it's own different infrastructure for doing this for ages, but it's time it used the common one. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
