path: root/drivers/scsi/FlashPoint.c
2010-01-18[SCSI] FlashPoint: fix off by one testsDan Carpenter
The check on MAX_SCSI_TAR should be >= instead of > or we could go past the end of the array. Joe Eykholt aslo correctly points out that the check on MAX_LUN should be >= as well. That matches with how it is used in the rest of the file. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2008-04-27[SCSI] FlashPoint: fix off-by-one errorsAdrian Bunk
This patch fixes off-by-one errors in error checks (the variables are used as array indexes for arrays with MAX_SCSI_TAR resp. MAX_LUN elements) spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] BusLogic: make FlashPoint support x86-32 onlyMatthew Wilcox
We've verified that there are 64 bit and endianness problems in the flashpoint driver. Reverse the logic of CONFIG_OMIT_FLASHPOINT (make it CONFIG_SCSI_FLASHPOINT) and make it depend on X86_32 so it can't appear for any other architectures. Long term, if someone chooses, they could make FlashPoint 64 bit compliant (it looks like its a question of fixing up the sizes in some of the packed descriptors) Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-19FlashPoint, use BIT instead of BITWJiri Slaby
FlashPoint, use BIT instead of BITW BITW was an ushort variant of BIT, use BIT instead Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19define global BIT macroJiri Slaby
define global BIT macro move all local BIT defines to the new globally define macro. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Russell King <rmk@arm.linux.org.uk> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-07[SCSI] BusLogic: Replace 'boolean' by 'bool'Richard Knutsson
Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-12[SCSI] drivers/scsi/FlashPoint.c: don't use parenthesis with "return"Alexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-12[SCSI] drivers/scsi/FlashPoint.c: LindentAlexey Dobriyan
It's much, much more readable now. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-12[SCSI] drivers/scsi/FlashPoint.c: untypedef struct SCCBcardAlexey Dobriyan
* struct SCCBcard => struct sccb_card * PSCCBcard => struct sccb_card * * SCCBCARD => struct sccb_card Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-12[SCSI] drivers/scsi/FlashPoint.c: untypedef struct NVRAMInfoAlexey Dobriyan
* struct NVRAMInfo => struct nvram_info * PNVRamInfo => struct nvram_info * * NVRAMINFO => struct nvram_info Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-12[SCSI] drivers/scsi/FlashPoint.c: untypedef struct SCCBMgr_tar_infoAlexey Dobriyan
* struct SCCBMgr_tar_info => struct sccb_mgr_tar_info * PSCCBMgr_tar_info => struct sccb_mgr_tar_info * * SCCBMGR_TAR_INFO => struct sccb_mgr_tar_info Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-12[SCSI] drivers/scsi/FlashPoint.c: untypedef struct SCCBMgr_infoAlexey Dobriyan
* struct SCCBMgr_info => struct sccb_mgr_info * PSCCBMGR_INFO => struct sccb_mgr_info * * SCCBMGR_INFO => struct sccb_mgr_info Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-12[SCSI] drivers/scsi/FlashPoint.c: untypedef struct _SCCBAlexey Dobriyan
* struct _SCCB => struct sccb * PSCCB => struct sccb * * SCCB => struct sccb Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-12[SCSI] drivers/scsi/FlashPoint.c: use standard fixed size typesAlexey Dobriyan
2006-03-12[SCSI] drivers/scsi/FlashPoint.c: remove ushort_ptrAlexey Dobriyan
2006-03-12[SCSI] drivers/scsi/FlashPoint.c: remove ULONGAlexey Dobriyan
2006-03-12[SCSI] drivers/scsi/FlashPoint.c: remove UINTAlexey Dobriyan
2006-03-12[SCSI] drivers/scsi/FlashPoint.c: remove USHORTAlexey Dobriyan
2006-03-12[SCSI] drivers/scsi/FlashPoint.c: remove UCHARAlexey Dobriyan
2006-03-12[SCSI] drivers/scsi/FlashPoint.c: remove trivial wrappersAlexey Dobriyan
2006-03-12[SCSI] drivers/scsi/FlashPoint.c: remove unused thingsAlexey Dobriyan
* Remove unused #define's * Remove unused typedefs. * Remove prototypes for non-existing functions. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-15Fix "stuct", "strut", "struc" typosAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-05-20[SCSI] drivers/scsi/FlashPoint.c: cleanupsJames Bottomley
From: Adrian Bunk <bunk@stusta.de> This patch contains cleanups including the following: - remove #ifdef'ed code for other OS's - remove other unused code - make needlessly global code static Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
