[ Upstream commit bef18d308a2215eff8c3411a23d7f34604ce56c3 ]
Fixes the occasional adapter panic when sg_reset is issued with -d, -t, -b
and -H flags. Removal of command type HBA_IU_TYPE_SCSI_TM_REQ in
aac_hba_send since iu_type, request_id and fib_flags are not populated.
Device and target reset handlers are made to send TMF commands only when
reset_state is 0.
Link: https://lore.kernel.org/r/1581553771-25796-1-git-send-email-Sagar.Biradar@microchip.com
Reviewed-by: Sagar Biradar <Sagar.Biradar@microchip.com>
Signed-off-by: Sagar Biradar <Sagar.Biradar@microchip.com>
Signed-off-by: Balsundar P <balsundar.p@microsemi.com>
Based on 1 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license as published by
the free software foundation either version 2 or at your option any
later version this program is distributed in the hope that it will
be useful but without any warranty without even the implied warranty
of merchantability or fitness for a particular purpose see the gnu
general public license for more details you should have received a
copy of the gnu general public license along with this program see
the file copying if not write to the free software foundation 675
mass ave cambridge ma 02139 usa
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 52 file(s).
Reviewed-by: Jilayne Lovejoy <opensource@jilayne.com>
Reviewed-by: Steve Winslow <swinslow@gmail.com>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190519154042.342335923@linutronix.de
There are a few windows during AER/EEH when we can access PCIe I/O mapped
registers. This will harden the access to insure we do not allow PCIe
access during errors
Signed-off-by: Dave Carroll <david.carroll@microsemi.com>
Reviewed-by: Sagar Biradar <sagar.biradar@microchip.com>
Add missing break statement and fix identation issue.
This bug was found thanks to the ongoing efforts to enable
-Wimplicit-fallthrough.
Fixes: 9cb62fa24e0d ("aacraid: Log firmware AIF messages")
Cc: stable@vger.kernel.org
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
There are several issues with badly indented statements. Fix these
and clean up the formatting.
Acked-by: Mahesh Rajashekhara <mahesh.rajashekhara@microchip.com>
The event_wait semaphore has completion semantics, so we can
change it over to the completion interface for clarity without
changing the behavior.
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Reviewed-by: Dave Carroll <david.carroll@microsemi.com>
The wait_sem member is used like a completion, so we should
use the respective API. The behavior is unchanged.
Variables dev and cpu are not being used and are redundant and hence can
be removed.
Cleans up clang warnings:
warning: variable 'dev' set but not used [-Wunused-but-set-variable]
warning: variable 'cpu' set but not used [-Wunused-but-set-variable]
requesed -> requested
Signed-off-by: Dongliang Mu <mudongliangabcd@gmail.com>
commit b60710ec7d7a ("scsi: aacraid: enable sending of TMFs from
aac_hba_send()") allows aac_hba_send() to send scsi commands, and TMF
requests, but the existing code only updates the iu_type for scsi
commands. For TMF requests we are sending an unknown iu_type to
firmware, which causes a fault.
Include iu_type prior to determining the validity of the command
Reported-by: Noah Misner <nmisner@us.ibm.com>
Fixes: b60710ec7d7ab ("aacraid: enable sending of TMFs from aac_hba_send()")
Fixes: 423400e64d377 ("aacraid: Include HBA direct interface")
Tested-by: Noah Misner <nmisner@us.ibm.com>
cc: stable@vger.kernel.org
Reviewed-by: Raghava Aditya Renukunta <RaghavaAditya.Renukunta@microsemi.com>
Reviewed-by: Brian King <brking@linux.vnet.ibm.com>
If a recursive IOP_RESET is invoked, usually due to the eh_thread
handling errors after the first reset, be sure we flag that the command
thread has been stopped to avoid an Oops of the form;
[ 336.620256] CPU: 28 PID: 1193 Comm: scsi_eh_0 Kdump: loaded Not tainted 4.14.0-49.el7a.ppc64le #1
[ 336.620297] task: c000003fd630b800 task.stack: c000003fd61a4000
[ 336.620326] NIP: c000000000176794 LR: c00000000013038c CTR: c00000000024bc10
[ 336.620361] REGS: c000003fd61a7720 TRAP: 0300 Not tainted (4.14.0-49.el7a.ppc64le)
[ 336.620395] MSR: 9000000000009033 <SF,HV,EE,ME,IR,DR,RI,LE> CR: 22084022 XER: 20040000
[ 336.620435] CFAR: c000000000130388 DAR: 0000000000000000 DSISR: 40000000 SOFTE: 1
[ 336.620435] GPR00: c00000000013038c c000003fd61a79a0 c0000000014c7e00 0000000000000000
[ 336.620435] GPR04: 000000000000000c 000000000000000c 9000000000009033 0000000000000477
[ 336.620435] GPR08: 0000000000000477 0000000000000000 0000000000000000 c008000010f7d940
[ 336.620435] GPR12: c00000000024bc10 c000000007a33400 c0000000001708a8 c000003fe3b881d8
[ 336.620435] GPR16: c000003fe3b88060 c000003fd61a7d10 fffffffffffff000 000000000000001e
[ 336.620435] GPR20: 0000000000000001 c000000000ebf1a0 0000000000000001 c000003fe3b88000
[ 336.620435] GPR24: 0000000000000003 0000000000000002 c000003fe3b88840 c000003fe3b887e8
[ 336.620435] GPR28: c000003fe3b88000 c000003fc8181788 0000000000000000 c000003fc8181700
[ 336.620750] NIP [c000000000176794] exit_creds+0x34/0x160
[ 336.620775] LR [c00000000013038c] __put_task_struct+0x8c/0x1f0
[ 336.620804] Call Trace:
[ 336.620817] [c000003fd61a79a0] [c000003fe3b88000] 0xc000003fe3b88000 (unreliable)
[ 336.620853] [c000003fd61a79d0] [c00000000013038c] __put_task_struct+0x8c/0x1f0
[ 336.620889] [c000003fd61a7a00] [c000000000171418] kthread_stop+0x1e8/0x1f0
[ 336.620922] [c000003fd61a7a40] [c008000010f7448c] aac_reset_adapter+0x14c/0x8d0 [aacraid]
[ 336.620959] [c000003fd61a7b00] [c008000010f60174] aac_eh_host_reset+0x84/0x100 [aacraid]
[ 336.621010] [c000003fd61a7b30] [c000000000864f24] scsi_try_host_reset+0x74/0x180
[ 336.621046] [c000003fd61a7bb0] [c000000000867ac0] scsi_eh_ready_devs+0xc00/0x14d0
[ 336.625165] [c000003fd61a7ca0] [c0000000008699e0] scsi_error_handler+0x550/0x730
[ 336.632101] [c000003fd61a7dc0] [c000000000170a08] kthread+0x168/0x1b0
[ 336.639031] [c000003fd61a7e30] [c00000000000b528] ret_from_kernel_thread+0x5c/0xb4
[ 336.645971] Instruction dump:
[ 336.648743] 384216a0 7c0802a6 fbe1fff8 f8010010 f821ffd1 7c7f1b78 60000000 60000000
[ 336.657056] 39400000 e87f0838 f95f0838 7c0004ac <7d401828> 314affff 7d40192d 40c2fff4
[ 336.663997] -[ end trace 4640cf8d4945ad95 ]-
So flag when the thread is stopped by setting the thread pointer to NULL.
Reviewed-by: Raghava Aditya Renukunta <raghavaaditya.renukunta@microsemi.com>
Pull SCSI updates from James Bottomley:
"This is mostly updates of the usual driver suspects: arcmsr,
scsi_debug, mpt3sas, lpfc, cxlflash, qla2xxx, aacraid, megaraid_sas,
hisi_sas.
We also have a rework of the libsas hotplug handling to make it more
robust, a slew of 32 bit time conversions and fixes, and a host of the
usual minor updates and style changes. The biggest potential for
regressions is the libsas hotplug changes, but so far they seem stable
under testing"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (313 commits)
scsi: qla2xxx: Fix logo flag for qlt_free_session_done()
scsi: arcmsr: avoid do_gettimeofday
scsi: core: Add VENDOR_SPECIFIC sense code definitions
scsi: qedi: Drop cqe response during connection recovery
scsi: fas216: fix sense buffer initialization
scsi: ibmvfc: Remove unneeded semicolons
scsi: hisi_sas: fix a bug in hisi_sas_dev_gone()
scsi: hisi_sas: directly attached disk LED feature for v2 hw
scsi: hisi_sas: devicetree: bindings: add LED feature for v2 hw
scsi: megaraid_sas: NVMe passthrough command support
scsi: megaraid: use ktime_get_real for firmware time
scsi: fnic: use 64-bit timestamps
scsi: qedf: Fix error return code in __qedf_probe()
scsi: devinfo: fix format of the device list
scsi: qla2xxx: Update driver version to 10.00.00.05-k
scsi: qla2xxx: Add XCB counters to debugfs
scsi: qla2xxx: Fix queue ID for async abort with Multiqueue
scsi: qla2xxx: Fix warning for code intentation in __qla24xx_handle_gpdb_event()
scsi: qla2xxx: Fix warning during port_name debug print
scsi: qla2xxx: Fix warning in qla2x00_async_iocb_timeout()
Remove unused rescan variable.
Signed-off-by: Raghava Aditya Renukunta <RaghavaAditya.Renukunta@microsemi.com>
There is a chance of the driver to be stuck in kdump if drives start
acting up in kdump discovery process and the kernel decides to send eh
resets, which would prompt rescan to be scheduled.
Do not perform a rescan in kdump context, since we do not expect a hotplug
event during kdump and all the devices are going to go away anyway.
Add back the ability to scan for hotplug changes while eh was in progress.
Schedule a rescan for a later time in the eh recovery code and wait for
eh to complete in the rescan worker.
If the driver fails to retrieve information from the fw (could happen when
the fw is not fully in its senses), the driver does nothing and change is
not processed correctly by the driver
Schedule host rescan in case of failure. This is only for SAFW, since
the information retrieval failure will happen on SAFW devices.
Driver uses scsi_scan_host to add new devices in the driver init path,
which adds all the fw exposed devices. The drivers resorts to queue
command checks to block out commands to _hidden_ devices.
Use the hotplug handler code to add new devices during driver init and
other areas, this is only for safw. For ARC scsi_scan_host will still
apply.
Currently driver will attempt to process hotplug events concurrently based
on the FW interrupt.
Protect safw update function with a scan mutex.
The device hotplug events are processed only after retrieving the updated
lun information from the fw. Does not make sense to keep them separate.
Merge both the hotplug handling and safw adapter setup code into single
function.
Resolve luns checks the if a sdev is already present in the os to figure
out if it needs to be removed. Internally the driver exposes HBA on bus
2 even though its bus 1 in the fw. Its mildly confusing.
Refactor out the sdev lookup into its function to check if sdev has been
added to the kernel or not. Add helper functions to add, remove and put
devices based on their fw bus and target number.
Added macros to loop through the MAX SUPPORTED Buses and Targets. This
will make the code a bit easier to read.
The hotplug handler code is duplicated for hba handling and container
handling.
Merged function to handle hba and container hot plug events into the
resolve luns functions. Added a bunch of helper functions to check the
validity of a given target and to check if bus, target is container
device.
Merge aac_get_containers to setup target function, so that information
about all the present devices can be retrieved in one shot.
Add helper function to setup targets devices and create the base for the
upcoming patches
Rename variables and functions to make bmic identify, report phy luns
to make them consistent across code internal existing code bases
Edit function that retrieves phy lun information to use common
bmic function
Ideally driver needs to wait for IO to be submitted or responded to before
shutdown.
Move code to wait for IO completion into shutdown path
As part of the recovery process, the drivers removes offline devices (
done by the kernel) and then tries to add them back in the rescan code.
Removing the device is like taking a sledgehammer to a nail.
Set the device as running if it is marked offline.
Driver attempts to perform a device scan and device add after coming out
of reset. At times when the kdump kernel loads and it tries to perform
eh recovery, the device scan hangs since its commands are blocked because
of the eh recovery. This should have shown up in normal eh recovery path
(Should have been obvious)
Remove the code that performs scanning.I can live without the rescanning
support in the stable kernels but a hanging kdump/eh recovery needs to be
fixed.
Fixes: a2d0321dd532901e (scsi: aacraid: Reload offlined drives after controller reset)
Cc: <stable@vger.kernel.org>
Reported-by: Douglas Miller <dougmill@linux.vnet.ibm.com>
Tested-by: Guilherme G. Piccoli <gpiccoli@linux.vnet.ibm.com>
As reported by Meelis Roos, my previous patch causes an incorrect
calculation of the timeout, through an undefined signed integer
overflow:
[ 12.228155] UBSAN: Undefined behaviour in drivers/scsi/aacraid/commsup.c:2514:49
[ 12.228229] signed integer overflow:
[ 12.228283] 964297611 * 250 cannot be represented in type 'long int'
The problem is that doing a multiplication with HZ first and then
dividing by USEC_PER_SEC worked correctly for 32-bit microseconds,
but not for 32-bit nanoseconds, which would require up to 41 bits.
This reworks the calculation to first convert the nanoseconds into
jiffies, which should give us the same result as before and not overflow.
Unfortunately I did not understand the exact intention of the algorithm,
in particular the part where we add half a second, so it's possible that
there is still a preexisting problem in this function. I added a comment
that this would be handled more nicely using usleep_range(), which
generally works better for waking up at a particular time than the
current schedule_timeout() based implementation. I did not feel
comfortable trying to implement that without being sure what the
intent is here though.
Fixes: 820f18865912 ("scsi: aacraid: use timespec64 instead of timeval")
Tested-by: Meelis Roos <mroos@linux.ee>
As part of the scsi EH path, aacraid performs a reinitialization of the
adapter, which encompass freeing resources and IRQs, NULLifying lots of
pointers, and then initialize it all over again. We've identified a
problem during the free IRQ portion of this path if CONFIG_DEBUG_SHIRQ
is enabled on kernel config file.
Happens that, in case this flag was set, right after free_irq()
effectively clears the interrupt, it checks if it was requested as
IRQF_SHARED. In positive case, it performs another call to the IRQ
handler on driver. Problem is: since aacraid currently free some
resources *before* freeing the IRQ, once free_irq() path calls the
handler again (due to CONFIG_DEBUG_SHIRQ), aacraid crashes due to NULL
pointer dereference with the following trace:
aac_src_intr_message+0xf8/0x740 [aacraid]
__free_irq+0x33c/0x4a0
free_irq+0x78/0xb0
aac_free_irq+0x13c/0x150 [aacraid]
aac_reset_adapter+0x2e8/0x970 [aacraid]
aac_eh_reset+0x3a8/0x5d0 [aacraid]
scsi_eh_ready_devs+0xc70/0x1510
scsi_error_handler+0x624/0xa20
This patch prevents the crash by changing the order of the
deinitialization in this path of aacraid: first we clear the IRQ, then
we free other resources. No functional change intended.
Signed-off-by: Guilherme G. Piccoli <gpiccoli@linux.vnet.ibm.com>
Commit 16ae9dd35d37 ("scsi: aacraid: Fix for excessive prints on EEH")
introduced checks about the state of device before any PCI operations in
the driver. Basically, this prevents it to perform PCI accesses when
device is in the process of recover from a PCI error. In PowerPC, such
mechanism is called EEH, and the aforementioned commit introduced checks
that are based on EEH-specific primitives for that.
The potential problems with this approach are three: first, these checks
are "locked" to powerpc only - another archs could have error recovery
methods too, like AER in Intel. Also, the powerpc primitives perform
expensive FW accesses to validate the precise PCI state of a device.
Finally, code becomes more complicated and needs ifdef validation based
on arch config being set.
So, this patch makes use of generic PCI state checks, which are
lightweight and non-dependent of arch configs - also, it makes the code
cleaner.
Fixes: 16ae9dd35d37 ("scsi: aacraid: Fix for excessive prints on EEH")
aacraid passes the current time to the firmware in one of two ways,
either as year/month/day/... or as 32-bit unsigned seconds.
The first one is broken on 32-bit architectures as it cannot go past
year 2038. Using timespec64 here makes it behave properly on both 32-bit
and 64-bit architectures, and avoids relying on signed integer overflow
to pass times into the second interface.
The interface used in aac_send_hosttime() however is still problematic
in year 2106 when 32-bit seconds overflow. Hopefully we don't have to
worry about aacraid by that time.
To correctly identify which fib has a scsi command callback this
patch implements a flag FIB_CONTEXT_FLAG_SCSI_CMD.
Signed-off-by: Hannes Reinecke <hare@suse.com>
aac_hba_send() will return FAILED for any non-SCSI command requests,
failing any TMFs. This patch updates the check to allow TMFs.
Remove reference to Series-9 HBA and created arc ctrl check function.
Signed-off-by: Prasad B Munirathnam <prasad.munirathnam@microsemi.com>
Reviewed-by: David Carroll <david.carroll@microsemi.com>
Made sure that ioctl commands return in case of a controller reset.
The command thread checks the ctrl health periodically before sending
updates to the controller. The function that it uses is aac_check_health
which does more than get the health status.
Check health does not need to reset the ctrl but just return the
controller health status.
The driver changed the DMA consistent map after consistent memory was
allocated, this invalidated the IOMMU identity mapping. The fix was to
make sure that we set the DMA consistent mask setting once depending on
the controller card.
"This update includes the usual round of major driver updates
(hisi_sas, ufs, fnic, cxlflash, be2iscsi, ipr, stex). There's also the
usual amount of cosmetic and spelling stuff"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (155 commits)
scsi: qla4xxx: fix spelling mistake: "Tempalate" -> "Template"
scsi: stex: make S6flag static
scsi: mac_esp: fix to pass correct device identity to free_irq()
scsi: aacraid: pci_alloc_consistent() failures on ARM64
scsi: ufs: make ufshcd_get_lists_status() register operation obvious
scsi: ufs: use MASK_EE_STATUS
scsi: mac_esp: Replace bogus memory barrier with spinlock
scsi: fcoe: make fcoe_e_d_tov and fcoe_r_a_tov static
scsi: sd_zbc: Do not write lock zones for reset
scsi: sd_zbc: Remove superfluous assignments
scsi: sd: sd_zbc: Rename sd_zbc_setup_write_cmnd
scsi: Improve scsi_get_sense_info_fld
scsi: sd: Cleanup sd_done sense data handling
scsi: sd: Improve sd_completed_bytes
scsi: sd: Fix function descriptions
scsi: mpt3sas: remove redundant wmb
scsi: mpt: Move scsi_remove_host() out of mptscsih_remove_host()
scsi: sg: reset 'res_in_use' after unlinking reserved array
scsi: mvumi: remove code handling zero scsi_sg_count(scmd) case
scsi: fusion: fix spelling mistake: "Persistancy" -> "Persistency"
There were pci_alloc_consistent() failures on ARM64 platform. Use
dma_alloc_coherent() with GFP_KERNEL flag DMA memory allocations.
Signed-off-by: Mahesh Rajashekhara <mahesh.rajashekhara@microsemi.com>
[hch: tweaked indentation, removed memsets]
Acked-by: Dave Carroll <david.carroll@microsemi.com>
During a PCI error recovery, if aac_check_health() is not aware that a
PCI error happened and we have an offline PCI channel, it might trigger
some errors (like NULL pointer dereference) and inhibit the error
recovery process to complete.
This patch makes the health check procedure aware of PCI channel issues,
and in case of error recovery process, the function
aac_adapter_check_health() returns -1 and let the recovery process to
complete successfully. This patch was tested on upstream kernel
v4.11-rc5 in PowerPC ppc64le architecture with adapter 9005:028d
(VID:DID) - the error recovery procedure was able to recover fine.
Fixes: 5c63f7f710bd ("aacraid: Added EEH support")
Cc: stable@vger.kernel.org # v4.6+
Currently, command threads fails to return ioctls commands for older
controller versions, since it returns when all the fibs have been
allocated. Another issue is even all the fibs have not been allocated,
the correct allocated fibs is not updated nor freed.
Fixes: 113156bcea9ef1e6 (scsi: aacraid: Reworked aac_command_thread)
Reported-by: Tomas Henzl <thenzl@redhat.com>
The check for ret being zero is redundant as a few statements earlier we
break out of the while loop if ret is non-zero. Thus we can remove the
zero check and also the dead-code non-zero case too.
Detected by CoverityScan, CID#1411632 ("Logically Dead Code")
Current driver Hotplug processing code skips over Enclosure channel,
therefore any addition/removal of expander enclosure is not processed.
Additionally device addition code relies on older device type, which
prevents the hotplug of adapter expanders.
Fixed by removing code that skips over Enclosure channels and using the
latest device type for addition or removal or enclosure expanders.
Fixes: 6223a39fe6fbbeef (scsi: aacraid: Added support for hotplug)
The driver does not unlock the reply queue spin lock after handling SMART
adapter events. Instead it might attempt to unlock an already unlocked
spin lock.
Fixed by making sure the driver locks the spin lock before freeing it.
Thank you dan for finding this issue out.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Reviewed-by: David Carroll <David.Carroll@microsemi.com>
During the IOP reset stress testing, it was found that the drives can be
marked offline when the adapter controller crashes and IO's are running
in parallel. When the controller does come back from the reset, the drive
that is marked offline is not exposed.
Fixed by removing and adding drives that are marked offline. In addition
invoke a scsi host bus rescan to capture any additional configuration
changes.
aac_command_thread checks on the health of controller periodically,
using aac_check_health. If the status is an error state KERNEL_PANIC or
anything else. The driver will attempt to restart the adapter, but the
response is not checked in aac_command_thread. This allows the periodic
sync to go thru and lead the driver to a hung state.
Fixed by terminating the periodic loop(intended per original design),
if the controller is not restored to a healthy state.
Fixes: 3d77d8404478353358 (scsi: aacraid: Added support for periodic wellness sync)
aac_fib_map_free frees misaligned fib dma memory, additionally it does not
free up the whole memory.
Fixed by changing the code to free up the correct and full memory
allocation.
Fixes: e8b12f0fb835223 ([SCSI] aacraid: Add new code for PMC-Sierra's SRC based controller family)
