The SCSI standard defines 64-bit values for LUNs, and large arrays
employing large or hierarchical LUN numbers become more and more
common.
So update the linux SCSI stack to use 64-bit LUN numbers.
Signed-off-by: Hannes Reinecke <hare@suse.de>
Reviewed-by: Christoph Hellwig <hch@infradead.org>
Reviewed-by: Ewan Milne <emilne@redhat.com>
It's a NOOP since 2.6.35 and it will be removed one day.
[jejb: remove from missed arm scsi drivers]
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Adam Radford <linuxraid@lsi.com>
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
portable.
This is to change use of "0x%08x" in favour of "%p" as per ../Documentation/printk-formats.txt,
which also takes care about the following warning during compilation time:
drivers/scsi/aha152x.c: In function ‘get_command’:
drivers/scsi/aha152x.c:2987: warning: cast from pointer to integer of different size
Signed-off-by: Krzysztof Wilczynski <krzysztof.wilczynski@linux.com>
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
Add ISA PNP IDs of the following cards to aha152x driver:
AVA-1502
AVA-1505
AHA-1510
AVA-1515
AHA-1520
AHA-1522
AHA-1530
AHA-1532
AIC-6360
(list from SCSI.INF file)
This makes my AHA-1530P card (has ADP3015 ID) work automatically.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
Move the mid-layer's ->queuecommand() invocation from being locked
with the host lock to being unlocked to facilitate speeding up the
critical path for drivers who don't need this lock taken anyway.
The patch below presents a simple SCSI host lock push-down as an
equivalent transformation. No locking or other behavior should change
with this patch. All existing bugs and locking orders are preserved.
Additionally, add one parameter to queuecommand,
struct Scsi_Host *
and remove one parameter from queuecommand,
void (*done)(struct scsi_cmnd *)
Scsi_Host* is a convenient pointer that most host drivers need anyway,
and 'done' is redundant to struct scsi_cmnd->scsi_done.
Minimal code disturbance was attempted with this change. Most drivers
needed only two one-line modifications for their host lock push-down.
Acked-by: James Bottomley <James.Bottomley@suse.de>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com>
[jejb: fixed up a ton of missed conversions.
All of you are on notice this has happened, driver trees will now
need to be rebased]
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: SCSI List <linux-scsi@vger.kernel.org>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
drivers/scsi/aha152x.c:3585:60: warning: Using plain integer as NULL pointer
drivers/scsi/aha152x.c:3845:56: warning: Using plain integer as NULL pointer
drivers/scsi/qla1280.c:2814:37: warning: Using plain integer as NULL pointer
drivers/scsi/atp870u.c:750:47: warning: Using plain integer as NULL pointer
drivers/scsi/3w-9xxx.c:1281:36: warning: Using plain integer as NULL pointer
drivers/scsi/3w-9xxx.c:1293:36: warning: Using plain integer as NULL pointer
drivers/scsi/3w-9xxx.c:1301:35: warning: Using plain integer as NULL pointer
drivers/scsi/hptiop.c:447:10: warning: Using plain integer as NULL pointer
drivers/scsi/hptiop.c:457:10: warning: Using plain integer as NULL pointer
drivers/scsi/hptiop.c:479:24: warning: Using plain integer as NULL pointer
drivers/scsi/hptiop.c:483:22: warning: Using plain integer as NULL pointer
drivers/scsi/hptiop.c:1213:23: warning: Using plain integer as NULL pointer
drivers/scsi/hptiop.c:1214:23: warning: Using plain integer as NULL pointer
Reported-by: Frank de Jong <frapex@xs4all.nl>
> after trying to unload the module:
> BUG: unable to handle kernel paging request at 00100100
> IP: [<fb9ff667>] :aha152x:aha152x_exit+0x47/0x6a
> *pde = 00000000
> Oops: 0000 [#1] PREEMPT SMP
> Modules linked in: aha152x(-) w83781d hwmon_vid tun ne 8390 bonding
> usb_storage snd_usb_audio snd_usb_lib snd_rawmidi pwc snd_seq_device
> compat_ioctl32 snd_hwdep videodev v4l1_compat 3c59x mii intel_agp
> agpgart snd_pcm_oss snd_pcm snd_timer snd_page_alloc snd_mixer_oss snd
> Pid: 2837, comm: rmmod Not tainted (2.6.25.3 #1)
> EIP: 0060:[<fb9ff667>] EFLAGS: 00210212 CPU: 0
> EIP is at aha152x_exit+0x47/0x6a [aha152x]
> EAX: 00000001 EBX: 000ffdc4 ECX: f7c517a8 EDX: 00000001
> ESI: 00000000 EDI: 00000003 EBP: e7880000 ESP: e7881f58
> DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
> Process rmmod (pid: 2837, ti=e7880000 task=f27eb580 task.ti=e7880000)
> Stack: fba03700 c01419d2 31616861 00783235 e795ee70 c0157709 b7f24000 e79ae000
> c0158271 ffffffff b7f25000 e79ae004 e795e370 b7f25000 e795e37c e795e370
> 009ae000 fba03700 00000880 e7881fa8 00000000 bf93ec20 bf93ec20 c0102faa
> Call Trace:
> [<c01419d2>] sys_delete_module+0x112/0x1a0
> [<c0157709>] remove_vma+0x39/0x50
> [<c0158271>] do_munmap+0x181/0x1f0
> [<c0102faa>] sysenter_past_esp+0x5f/0x85
> [<c0490000>] rsc_parse+0x0/0x3c0
The problem is that the driver calls aha152x_release() under a
list_for_each_entry(). Unfortunately, aha152x_release() deletes from
the list in question. Fix this by using list_for_each_entry_safe().
Cc: Stable Tree <stable@kernel.org>
convention
> [1.] One line summary of the problem:
> linux-2.6.25.3, aha152x'->init suspiciously returned 1, it should
> follow 0/-E convention. The module / driver works okay. Unloading the
> module is impossible.
The driver is apparently returning 0 on failure and 1 on success.
That's a bit unfortunate. Fix it by altering to -ENODEV and 0.
drivers/scsi/aic7xxx/aic7770_osm.c:53:58: warning: Using plain integer as NULL pointer
drivers/scsi/aic7xxx/aic7xxx_osm_pci.c:355:47: warning: Using plain integer as NULL pointer
drivers/scsi/aic7xxx/aic7xxx_osm_pci.c:372:55: warning: Using plain integer as NULL pointer
drivers/scsi/aha152x.c:997:28: warning: Using plain integer as NULL pointer
drivers/scsi/aha152x.c:1003:28: warning: Using plain integer as NULL pointer
drivers/scsi/aha152x.c:1165:46: warning: Using plain integer as NULL pointer
drivers/scsi/fdomain.c:1446:40: warning: Using plain integer as NULL pointer
drivers/scsi/sym53c8xx_2/sym_hipd.c:1650:51: warning: Using plain integer as NULL pointer
drivers/scsi/sym53c8xx_2/sym_hipd.c:3171:42: warning: Using plain integer as NULL pointer
drivers/scsi/sym53c8xx_2/sym_hipd.c:5732:52: warning: Using plain integer as NULL pointer
drivers/scsi/ncr53c8xx.c:8189:31: warning: Using plain integer as NULL pointer
drivers/scsi/ncr53c8xx.c:8225:34: warning: Using plain integer as NULL pointer
drivers/scsi/dpt_i2o.c:156:32: warning: Using plain integer as NULL pointer
drivers/scsi/ultrastor.c:954:42: warning: Using plain integer as NULL pointer
drivers/scsi/ultrastor.c:1104:18: warning: Using plain integer as NULL pointer
- remove pointless casts from void*
- remove needless references to 'irq' function argument, when that
information is already stored somewhere in a driver-private struct.
- where the 'irq' function argument is known never to be used, rename
it to 'dummy' to make this more obvious
- remove always-false tests for dev_id==NULL
- remove always-true tests for 'irq == host_struct->irq'
- replace per-irq lookup functions and tables with a direct reference
to data object obtained via 'dev_id' function argument, passed from
request_irq()
This change's main purpose is to prepare for the patchset in
jgarzik/misc-2.6.git#irq-remove, that explores removal of the
never-used 'irq' argument in each interrupt handler.
- Use new scsi_eh_prep/restor_cmnd() for synchronous
REQUEST_SENSE invocation.
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
* Convert files to UTF-8.
* Also correct some people's names
(one example is Eißfeldt, which was found in a source file.
Given that the author used an ß at all in a source file
indicates that the real name has in fact a 'ß' and not an 'ss',
which is commonly used as a substitute for 'ß' when limited to
7bit.)
* Correct town names (Goettingen -> Göttingen)
* Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313)
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
We were releasing the IRQ before removing the host, so commands could
still be coming in which would never be seen by the interrupt handler.
Just remove the host before releasing the IRQ to close this race.
Signed-off-by: Matthew Wilcox <matthew@wil.cx>
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
And finally this is the regular !use_sg cleanup
and use of data accessors.
check_condition code-path was similar but more
complicated to Reset. It went like this:
1. extra space was allocated at aha152x_scdata for mirroring
scsi_cmnd members.
2. At aha152x_internal_queue() every not check_condition
(REQUEST_SENSE) command was copied to above members in
case of error.
3. At busfree_run() in the DONE_CS phase if a Status of
SAM_STAT_CHECK_CONDITION was detected. The command was
re-queued Internally using aha152x_internal_queue(,,check_condition,)
The old command members are over written with the
REQUEST_SENSE info.
4. At busfree_run() in the DONE_CS phase again. If it is a
check_condition command, info was restored from mirror
made at first call to aha152x_internal_queue() (see 2)
and the command is completed.
What I did is:
1. Allocate less space in aha152x_scdata only for the 16-byte
original command. (which is actually not needed by scsi-ml
anymore at this stage. But this is to much knowledge of scsi-ml)
2. If Status == SAM_STAT_CHECK_CONDITION, then like before
re-queue a REQUEST_SENSE command. But only now save original
command members. (Less of them)
3. In aha152x_internal_queue(), just like for Reset, use the
check_condition hint to set differently the working members.
execute the command.
4. At busfree_run() in the DONE_CS phase again. restore needed
members.
While at it. This patch fixes a BUG. Old code when sending
a REQUEST_SENSE for a failed command. Would than return with
cmd->resid == 0 which was the status of the REQUEST_SENSE.
The failing command resid was lost. And when would resid
be interesting if not on a failing command?
What Reset code was doing: Save command's important/dangerous
Info on stack. NULL those members from scsi_cmnd.
Issue a Reset. wait for it to finish than restore members
and return.
What I do is save or NULL nothing. But use the "resetting"
hint in aha152x_internal_queue() to NULL out working members
and leave struct scsi_cmnd alone.
The indent here looks funny but it will change/drop in last
patch and it is clear this way what changed.
hunk by hunk:
- CHECK_CONDITION is what happens to cmnd->status >> 1
or after status_byte() macro. But here it is used
directly on status which means 0x1 which is an undefined
bit in the standard. And is a status that will never
return from a target.
- in busfree_run at the DONE_SC phase we have 3 distinct
operation:
1-if(DONE_SC->SCp.phase & check_condition)
The REQUEST_SENSE command return.
- Restore original command
- Than continue to operation 3.
2-if(DONE_SC->SCp.Status==SAM_STAT_CHECK_CONDITION)
A regular command returned with a status.
- Internally re-Q a REQUEST_SENSE.
- Do not do operation 3.
3-
- Complete the command and return it to scsi-ml
So the 0x2 in both these operations (1,2) means the scsi
check-condition status, hence SAM_STAT_CHECK_CONDITION
- Here the code asks about !(DONE_SC->SCp.Status & not_issued)
but "not_issued" is an enum belonging to the "phase" member
and not to the Status returned from target. The reason this
works is because not_issued==1 and Also CHECK_CONDITION==1
(remember from hunk 1). So actually the code was asking
!(DONE_SC->SCp.Status & CHECK_CONDITION). Which means
"Has the status been read from target yet?"
Staus is read at status_run(). "not_issued" is
cleared in seldo_run() which is usually earlier than
status_run().
So this patch does nothing as far as assembly is concerned
but it does let the reader understand what is going on.
Cause highmem buffers to be bounced to low memory until this
driver supports highmem addresses. Otherwise it just oopses
on NULL buffer addresses.
The symbol <debug_locks> conflicts with the rather global one in
include/linux/locks.h.
Use wait_for_completion_timeout instead a semaphore + timer.
After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Fix up for make allyesconfig.
Signed-Off-By: David Howells <dhowells@redhat.com>
In preparation for moving check_signature, change these users from asm/io.h
to linux/io.h
Signed-off-by: Matthew Wilcox <willy@parisc-linux.org>
- Eliminate casts to/from void*
- Eliminate checks for conditions that never occur. These typically
fall into two classes:
1) Checking for 'dev_id == NULL', then it is never called with
NULL as an argument.
2) Checking for invalid irq number, when the only caller (the
system) guarantees the irq handler is called with the proper
'irq' number argument.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Fix this driver not to use a static two element host array instead use
a list. This should fix panic on multiple eject reinsert of the
pcmcia version of this device.
Currently struct scsi_cmnd has various fields that are used to backup
original data after the corresponding fields have been overridden for
EH commands. This means drivers can easily get at it and misuse it.
Due to the old_ naming this doesn't happen for most of them, but two
that have different names have been used wrong a lot (see previous
patch). Another downside is that they unessecarily bloat the scsi_cmnd
size.
This patch moves them onstack in scsi_send_eh_cmnd to fix those two
issues aswell as allowing future EH fixes like moving the EH command
submissions to use SG lists like everything else.
Stop poking into the old_ & co scsi_cmnd fields that should only be used
in the EH code. Untested, but this is required to move ahead with the
EH fixes.
Cc: James Bottomley <James.Bottomley@steeleye.com>
- change interface of the reset functions from Scsi_Cmnd to Scsi_Host.
- add functions with the original interface and rename the new
functions to reflect the new interface.
- call these from the pcmcia driver, thereby avoiding the need to
construct a (broken) Scsi_Cmnd from a Scsi_Host.
- just run the bh if the interrupt is from the controller and if so
ensure that it's only called once per interrupt.
Signed-off-by: Juergen E. Fischer <fischer@linux-buechse.de>
Introduce new helpers:
- spi_populate_width_msg()
- spi_populate_sync_msg()
- spi_populate_ppr_msg()
and use them in drivers which already enable the SPI transport.
Rename scsi_print_msg to spi_print_msg and move its prototype from
scsi_dbg.h to scsi_transport_spi.h
Rejections fixed up and
We have the scsi_print_* functions in the proper namespace for a long
time now and there weren't a lot users left.
infrastructure for it.
Let it rip!
