path: root/drivers/scsi/arcmsr
2008-04-19SCSI: convert struct class_device to struct deviceTony Jones
It's big, but there doesn't seem to be a way to split it up smaller... Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-14[SCSI] arcmsr: fix iounmap error for Type B adapternickcheng
The Type B Adapter teardown does iounmap on pointers subtracted by a constant offset. Since the offset is in bytes, we need the pointers to be of type void * not uint32_t * so the subtraction is done in the correct units and we iounmap the correct area. Signed-off-by: Nick Cheng <nick.cheng@areca.com.tw> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-03[SCSI] arcmsr: update version and changelogNick Cheng
The fix up from Daniel Drake for replacing GFP_DMA with something more sensible has gone in here: commit 69e562c234440fb7410877b5b24f4b29ef8521d1 Author: Daniel Drake <dsd@gentoo.org> Date: Wed Feb 20 13:29:05 2008 +0000 [SCSI] arcmsr: fix message allocation add a change log and update the version for this. Signed-off-by: Nick Cheng <nick.cheng@areca.com.tw> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-22[SCSI] arcmsr: fix message allocationDaniel Drake
arcmsr_iop_message_xfer() is called from atomic context under the queuecommand scsi_host_template handler. James Bottomley pointed out that the current GFP_KERNEL|GFP_DMA flags are wrong: firstly we are in atomic context, secondly this memory is not used for DMA. Also removed some unneeded casts. Signed-off-by: Daniel Drake <dsd@gentoo.org> Cc: Nick Cheng <nick.cheng@areca.com.tw> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] arcmsr: updates (1.20.00.15)Nick Cheng
- add arcmsr_enable_eoi_mode()and readl(reg->iop2drv_doorbell_reg) in arcmsr_handle_hbb_isr() on adapter Type B in case of the doorbell interrupt clearance is cached - add conditional declaration for arcmsr_pci_error_detected() and arcmsr_pci_slot_reset - check if the sg list member number exceeds arcmsr default limit in arcmsr_build_ccb() - change the returned value type of arcmsr_build_ccb()from "void" to "int" returns FAILED in arcmsr_queue_command() - modify arcmsr_drain_donequeue() to ignore unknown command and let kernel process command timeout. This could handle IO request violating maximum segments, i.e. Linux XFS over DM-CRYPT. Thanks to Milan Broz's comments <mbroz@redhat.com> - fix the release of dma memory for type B in arcmsr_free_ccb_pool() - fix the arcmsr_polling_hbb_ccbdone() Signed-off-by: Nick Cheng <nick.cheng@areca.com.tw> Cc: Milan Broz <mbroz@redhat.com> Cc: <thenzl@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-30[SCSI] remove use_sg_chainingJames Bottomley
With the sg table code, every SCSI driver is now either chain capable or broken (or has sg_tablesize set so chaining is never activated), so there's no need to have a check in the host template. Also tidy up the code by moving the scatterlist size defines into the SCSI includes and permit the last entry of the scatterlist pools not to be a power of two. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] replace sizeof sense_buffer with SCSI_SENSE_BUFFERSIZEFUJITA Tomonori
This replaces sizeof sense_buffer with SCSI_SENSE_BUFFERSIZE in several LLDs. It's a preparation for the future changes to remove sense_buffer array in scsi_cmnd structure. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-29deal with resource allocation bugs in arcmsrAl Viro
a) for type B we should _not_ iounmap() acb->pmu; it's not ioremapped. b) for type B we should iounmap() two regions we _do_ ioremap. c) if ioremap() fails, we need to bail out (and clean up). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-29fix reentrancy bug in arcmsr_get_iop_{r,w}qbuffer()Al Viro
doh... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-29arcmsr: endianness bugAl Viro
initializing a field in data shared with the card with cpu_to_le32(something) | 0x100000 is broken - the field is, indeed, little-endian and we need cpu_to_le32() on both parts. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-29trivial annotations in arcmsrAl Viro
driver still has serious portability problems Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22[SG] Update drivers to use sg helpersJens Axboe
2007-10-16[SCSI] add use_sg_chaining option to scsi_host_templateFUJITA Tomonori
This option is true if a low-level driver can support sg chaining. This will be removed eventually when all the drivers are converted to support sg chaining. q->max_phys_segments is set to SCSI_MAX_SG_SEGMENTS if false. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-12[SCSI] arcmsr: build fixAndrew Morton
drivers/scsi/arcmsr/arcmsr_hba.c:129: error: 'arcmsr_pci_error_detected' undeclared here (not in a function) drivers/scsi/arcmsr/arcmsr_hba.c:130: error: 'arcmsr_pci_slot_reset' undeclared here (not in a function) Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] arcmsr: irq handler fixes, cleanups, micro-optsJeff Garzik
* Remove IRQF_DISABLED, it is clearly wrong for this driver. * Remove wasteful spin_lock_irqsave() in interrupt handler. The lighter-weight spin_lock() is all that's needed. * Annotate with FIXME where arcmsr_interrupt() is called without any spinlock being acquired. * Eliminate pointless cast from void pointer in arcmsr_do_interrupt() [jejb: conflict resolution] Signed-off-by: Jeff Garzik <jeff@garzik.org> Acked-by: Nick Cheng <nick.cheng@areca.com.tw> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] arcmsr: Fix hardware wait loopsJeff Garzik
Remove _interruptible, since receiving a signal while waiting on a hardware condition will simply cause the driver to busy-wait. Using msleep_interruptible() is rarely the right thing to do, when waiting on a hardware condition to change. Also, replace msleep with ssleep while doing this, where appropriate. [jejb: fix up merge conflict] Signed-off-by: Jeff Garzik <jeff@garzik.org> Acked-by: Nick Cheng <nick.cheng@areca.com.tw> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] arcmsr: fix compile problemsJames Bottomley
CC [M] drivers/scsi/arcmsr/arcmsr_hba.o drivers/scsi/arcmsr/arcmsr_attr.c:186: warning: initialization from incompatible pointer type drivers/scsi/arcmsr/arcmsr_attr.c:196: warning: initialization from incompatible pointer type drivers/scsi/arcmsr/arcmsr_attr.c:206: warning: initialization from incompatible pointer type drivers/scsi/arcmsr/arcmsr_hba.c: In function 'arcmsr_alloc_ccb_pool': drivers/scsi/arcmsr/arcmsr_hba.c:329: warning: assignment from incompatible pointer type drivers/scsi/arcmsr/arcmsr_hba.c: At top level: drivers/scsi/arcmsr/arcmsr_hba.c:101: warning: 'arcmsr_pci_error_detected' declared 'static' but never defined drivers/scsi/arcmsr/arcmsr_hba.c:102: warning: 'arcmsr_pci_slot_reset' declared 'static' but never defined The majority being incorrect casting or the fact that binary attributes now take an additional argument. Cc: Nick Cheng <nick.cheng@areca.com.tw> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] arcmsr: 1.20.00.15: add SATA RAID plus other fixesNick Cheng
Description: ** support ARC1200/1201/1202 SATA RAID adapter, which is named ACB_ADAPTER_TYPE_B ** modify the arcmsr_pci_slot_reset function ** modify the arcmsr_pci_ers_disconnect_forepart function ** modify the arcmsr_pci_ers_need_reset_forepart function  Signed-off-by: Nick Cheng <nick.cheng@areca.com.tw> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-15Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (166 commits) [SCSI] ibmvscsi: convert to use the data buffer accessors [SCSI] dc395x: convert to use the data buffer accessors [SCSI] ncr53c8xx: convert to use the data buffer accessors [SCSI] sym53c8xx: convert to use the data buffer accessors [SCSI] ppa: coding police and printk levels [SCSI] aic7xxx_old: remove redundant GFP_ATOMIC from kmalloc [SCSI] i2o: remove redundant GFP_ATOMIC from kmalloc from device.c [SCSI] remove the dead CYBERSTORMIII_SCSI option [SCSI] don't build scsi_dma_{map,unmap} for !HAS_DMA [SCSI] Clean up scsi_add_lun a bit [SCSI] 53c700: Remove printk, which triggers because of low scsi clock on SNI RMs [SCSI] sni_53c710: Cleanup [SCSI] qla4xxx: Fix underrun/overrun conditions [SCSI] megaraid_mbox: use mutex instead of semaphore [SCSI] aacraid: add 51245, 51645 and 52245 adapters to documentation. [SCSI] qla2xxx: update version to 8.02.00-k1. [SCSI] qla2xxx: add support for NPIV [SCSI] stex: use resid for xfer len information [SCSI] Add Brownie 1200U3P to blacklist [SCSI] scsi.c: convert to use the data buffer accessors ...
2007-07-11sysfs: add parameter "struct bin_attribute *" in .read/.write methods for ↵Zhang Rui
sysfs binary attributes Well, first of all, I don't want to change so many files either. What I do: Adding a new parameter "struct bin_attribute *" in the .read/.write methods for the sysfs binary attributes. In fact, only the four lines change in fs/sysfs/bin.c and include/linux/sysfs.h do the real work. But I have to update all the files that use binary attributes to make them compatible with the new .read and .write methods. I'm not sure if I missed any. :( Why I do this: For a sysfs attribute, we can get a pointer pointing to the struct attribute in the .show/.store method, while we can't do this for the binary attributes. I don't know why this is different, but this does make it not so handy to use the binary attributes as the regular ones. So I think this patch is reasonable. :) Who benefits from it: The patch that exposes ACPI tables in sysfs requires such an improvement. All the table binary attributes share the same .read method. Parameter "struct bin_attribute *" is used to get the table signature and instance number which are used to distinguish different ACPI table binary attributes. Without this parameter, we need to offer different .read methods for different ACPI table binary attributes. This is impossible as there are various ACPI tables on different platforms, and we don't know what they are until they are loaded. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11sysfs: kill unnecessary attribute->ownerTejun Heo
sysfs is now completely out of driver/module lifetime game. After deletion, a sysfs node doesn't access anything outside sysfs proper, so there's no reason to hold onto the attribute owners. Note that often the wrong modules were accounted for as owners leading to accessing removed modules. This patch kills now unnecessary attribute->owner. Note that with this change, userland holding a sysfs node does not prevent the backing module from being unloaded. For more info regarding lifetime rule cleanup, please read the following message. http://article.gmane.org/gmane.linux.kernel/510293 (tweaked by Greg to not delete the field just yet, to make it easier to merge things properly.) Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-06-17[SCSI] areca: improve driver stability and compatibilitynickcheng(鄭守謙
Description: 1. Implement PCI-Express error recovery function and AER capability, especially thanks to Yanmin Zhang's openhanded help about AER 2. Implement the selection of ARCMSR_MAX_XFER_SECTORS_B=4096 if firmware version is latter than 1.42 3. Add arcmsr_done4_abort_postqueue in arcmsr_iop_reset function to improve the stability as hot-unplug/plug 4. Modify the ISR, arcmsr_interrupt routine, to prevent the inconsistency with sg_mod driver if application directly calls the arcmsr driver w/o passing through scsi midlayer Signed-off-by: Nick Cheng <nick.cheng@areca.com.tw> [jejb: unused variable removal] Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-27[SCSI] arcmsr: convert to use the data buffer accessorsFUJITA Tomonori
- remove the unnecessary map_single path. - convert to use the new accessors for the sg lists and the parameters. Jens Axboe <jens.axboe@oracle.com> did the for_each_sg cleanup. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Nick Cheng <nick.cheng@areca.com.tw> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-02PCI: Cleanup the includes of <linux/pci.h>Jean Delvare
I noticed that many source files include <linux/pci.h> while they do not appear to need it. Here is an attempt to clean it all up. In order to find all possibly affected files, I searched for all files including <linux/pci.h> but without any other occurence of "pci" or "PCI". I removed the include statement from all of these, then I compiled an allmodconfig kernel on both i386 and x86_64 and fixed the false positives manually. My tests covered 66% of the affected files, so there could be false positives remaining. Untested files are: arch/alpha/kernel/err_common.c arch/alpha/kernel/err_ev6.c arch/alpha/kernel/err_ev7.c arch/ia64/sn/kernel/huberror.c arch/ia64/sn/kernel/xpnet.c arch/m68knommu/kernel/dma.c arch/mips/lib/iomap.c arch/powerpc/platforms/pseries/ras.c arch/ppc/8260_io/enet.c arch/ppc/8260_io/fcc_enet.c arch/ppc/8xx_io/enet.c arch/ppc/syslib/ppc4xx_sgdma.c arch/sh64/mach-cayman/iomap.c arch/xtensa/kernel/xtensa_ksyms.c arch/xtensa/platform-iss/setup.c drivers/i2c/busses/i2c-at91.c drivers/i2c/busses/i2c-mpc.c drivers/media/video/saa711x.c drivers/misc/hdpuftrs/hdpu_cpustate.c drivers/misc/hdpuftrs/hdpu_nexus.c drivers/net/au1000_eth.c drivers/net/fec_8xx/fec_main.c drivers/net/fec_8xx/fec_mii.c drivers/net/fs_enet/fs_enet-main.c drivers/net/fs_enet/mac-fcc.c drivers/net/fs_enet/mac-fec.c drivers/net/fs_enet/mac-scc.c drivers/net/fs_enet/mii-bitbang.c drivers/net/fs_enet/mii-fec.c drivers/net/ibm_emac/ibm_emac_core.c drivers/net/lasi_82596.c drivers/parisc/hppb.c drivers/sbus/sbus.c drivers/video/g364fb.c drivers/video/platinumfb.c drivers/video/stifb.c drivers/video/valkyriefb.c include/asm-arm/arch-ixp4xx/dma.h sound/oss/au1550_ac97.c I would welcome test reports for these files. I am fine with removing the untested files from the patch if the general opinion is that these changes aren't safe. The tested part would still be nice to have. Note that this patch depends on another header fixup patch I submitted to LKML yesterday: [PATCH] scatterlist.h needs types.h http://lkml.org/lkml/2007/3/01/141 Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-14[PATCH] Scheduled removal of SA_xxx interrupt flags fixupsThomas Gleixner
The obsolete SA_xxx interrupt flags have been used despite the scheduled removal. Fixup the remaining users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Roland Dreier <rolandd@cisco.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Dave Airlie <airlied@linux.ie> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-08-02[SCSI] arcmsr: fix up sysfs valuesJames Bottomley
The sysfs files in arcmsr are non-standard in that they aren't simple filename value pairs, the values actually contain preceeding text which would have to be parsed. The idea of sysfs files is that the file name is the description and the contents is a simple value. Fix up arcmsr to conform to this standard. Acked-By: Erich Chen <erich@areca.com.tw> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-08-02[SCSI] areca sysfs fixAndrew Morton
Remove sysfs_remove_bin_file() return-value checking from the areca driver. There's nothing a driver can do if sysfs file removal fails, so we'll soon be changing sysfs_remove_bin_file() to internally print a diagnostic and to return void. Cc: Erich Chen <erich@areca.com.tw> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-28[SCSI] arcmsr: initial driver, version 1.20.00.13Erich Chen
arcmsr is a driver for the Areca Raid controller, a host based RAID subsystem that speaks SCSI at the firmware level. This patch is quite a clean up over the initial submission with contributions from: Randy Dunlap <rdunlap@xenotime.net> Christoph Hellwig <hch@lst.de> Matthew Wilcox <matthew@wil.cx> Adrian Bunk <bunk@stusta.de> Signed-off-by: Erich Chen <erich@areca.com.tw> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
