path: root/drivers/scsi/bnx2i
2011-08-28[SCSI] bnx2i: Fixed the endian on TTT for NOP out transmissionEddie Wai
The iscsi_nopout task's TTT is defined as __be32 while the DMA memory to the chip is CPU specific. This creates a problem for unsolicited NOP-In responses where the TTT is not the RESERVED tag of 0xFFs. This patch adds a call to be32_to_cpu for the TTT specified. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-27Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: target: Convert to DIV_ROUND_UP_SECTOR_T usage for sectors / dev_max_sectors kernel.h: Add DIV_ROUND_UP_ULL and DIV_ROUND_UP_SECTOR_T macro usage iscsi-target: Add iSCSI fabric support for target v4.1 iscsi: Add Serial Number Arithmetic LT and GT into iscsi_proto.h iscsi: Use struct scsi_lun in iscsi structs instead of u8[8] iscsi: Resolve iscsi_proto.h naming conflicts with drivers/target/iscsi
2011-07-25iscsi: Use struct scsi_lun in iscsi structs instead of u8[8]Andy Grover
struct scsi_lun is also just a struct with an array of 8 octets (64 bits) but using it instead in iscsi structs lets us call scsilun_to_int without a cast, and also lets us copy it using assignment, instead of memcpy(). Signed-off-by: Andy Grover <agrover@redhat.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-25iscsi: Resolve iscsi_proto.h naming conflicts with drivers/target/iscsiNicholas Bellinger
This patch renames the following iscsi_proto.h structures to avoid namespace issues with drivers/target/iscsi/iscsi_target_core.h: *) struct iscsi_cmd -> struct iscsi_scsi_req *) struct iscsi_cmd_rsp -> struct iscsi_scsi_rsp *) struct iscsi_login -> struct iscsi_login_req This patch includes useful ISCSI_FLAG_LOGIN_[CURRENT,NEXT]_STAGE*, and ISCSI_FLAG_SNACK_TYPE_* definitions used by iscsi_target_mod, and fixes the incorrect definition of struct iscsi_snack to following RFC-3720 Section 10.16. SNACK Request. Also, this patch updates libiscsi, iSER, be2iscsi, and bn2xi to use the updated structure definitions in a handful of locations. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org>
2011-07-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (77 commits) [SCSI] fix crash in scsi_dispatch_cmd() [SCSI] sr: check_events() ignore GET_EVENT when TUR says otherwise [SCSI] bnx2i: Fixed kernel panic due to illegal usage of sc->request->cpu [SCSI] bfa: Update the driver version to 3.0.2.1 [SCSI] bfa: Driver and BSG enhancements. [SCSI] bfa: Added support to query PHY. [SCSI] bfa: Added HBA diagnostics support. [SCSI] bfa: Added support for flash configuration [SCSI] bfa: Added support to obtain SFP info. [SCSI] bfa: Added support for CEE info and stats query. [SCSI] bfa: Extend BSG interface. [SCSI] bfa: FCS bug fixes. [SCSI] bfa: DMA memory allocation enhancement. [SCSI] bfa: Brocade-1860 Fabric Adapter vHBA support. [SCSI] bfa: Brocade-1860 Fabric Adapter PLL init fixes. [SCSI] bfa: Added Fabric Assigned Address(FAA) support [SCSI] bfa: IOC bug fixes. [SCSI] bfa: Enable ASIC block configuration and query. [SCSI] bnx2i: Updated copyright and bump version [SCSI] bnx2i: Modified to skip CNIC registration if iSCSI is not supported ... Fix up some trivial conflicts in: - drivers/scsi/bnx2fc/{bnx2fc.h,bnx2fc_fcoe.c}: Crazy broadcom version number conflicts - drivers/target/tcm_fc/tfc_cmd.c Just trivial cleanups done on adjacent lines
2011-07-21[SCSI] bnx2i: Fixed kernel panic due to illegal usage of sc->request->cpuEddie Wai
A kernel panic was observed when passing the sc->request->cpu = -1 to retrieve the per_cpu variable pointer: #0 [ffff880011203960] machine_kexec at ffffffff81022bc3 #1 [ffff8800112039b0] crash_kexec at ffffffff81088630 #2 [ffff880011203a80] __die at ffffffff8139ea20 #3 [ffff880011203aa0] no_context at ffffffff8102f3a7 #4 [ffff880011203ae0] __bad_area_nosemaphore at ffffffff8102f665 #5 [ffff880011203ba0] retint_signal at ffffffff8139dd1f #6 [ffff880011203cc8] bnx2i_indicate_kcqe at ffffffffa03dc4f2 #7 [ffff880011203da8] service_kcqes at ffffffffa03cb04f #8 [ffff880011203e68] cnic_service_bnx2x_kcq at ffffffffa03cb14a #9 [ffff880011203e88] cnic_service_bnx2x_bh at ffffffffa03cb1b3 The problem lies in the slow path sg_io (and perhaps sg_scsi_ioctl) call to blk_get_request->get_request/wait->blk_alloc_request->blk_rq_init which re-initializes the request->cpu to -1. There is no assignment for cpu from that to the request_fn call to low level drivers. When this happens, the sc->request->cpu will be using the init value of -1. This will create a kernel panic when it hits bnx2i because the code refers it to get the per_cpu variables ptr. This change is to put in a guard against that and also for cases when bio affinity/queue completion to the same cpu is not enabled. In those cases, the request->cpu will remain a -1 also. This bug was created from commit: b5cf6b63f73abdc051035f0050b367beeb2ef94c For the case when the blk layer did not setup the request->cpu, bnx2i will complete the sc with the current CPU of the thread. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-21cnic: Add VLAN ID as a parameter during netevent upcallMichael Chan
The bnx2fc driver needs to handle netdev events on VLAN devices. Signed-off-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-29[SCSI] bnx2i: Updated copyright and bump versionEddie Wai
Bumped version from 2.6.2.3 to 2.7.0.3 Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-06-29[SCSI] bnx2i: Modified to skip CNIC registration if iSCSI is not supportedEddie Wai
The init routine will now examine the cnic->max_iscsi_conn variable before registering to CNIC during ulp_init. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Acked-by: Michael Chan <mchan@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-06-29[SCSI] bnx2i: Added the use of kthreads to handle SCSI cmd completionEddie Wai
This patch breaks the SCSI cmd completion into two parts: 1. The bh will allocate and queued work to the cmd specific CPU IO completion kthread. The CPU for the cmd is from the sc->request->cpu. 2. The CPU specific IO completion kthread will call the scsi_cmd_resp routine to do the actual cmd completion. In the normal case, these IO completion kthreads should complete before the blk IO times out at 60s. However, in the case when these kthreads are blocked for whatever reason and exceeded the timeout, the call to conn_destroy will have to iterate and exhaust all related work in the percpu work list for all online CPUs. This will guarantee the protection of the work->session and conn pointers before they get freed. Also modified the event coalescing formula to have at least the event_coal_min outstanding cmds in the pipeline so the SCSI producer would not get underrun. Also changed the following SCSI parameters: - can_queue from 1024 to 2048 - cmds_per_lun from 24 to 128 Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Acked-by: Benjamin Li <benli@broadcom.com> Acked-by: Michael Chan <mchan@broadcom.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-06-29[SCSI] iscsi: Use struct scsi_lun in iscsi structs instead of u8[8]Andy Grover
2011-06-21cnic, bnx2i: Add support for new devices - 57800, 57810, and 57840Michael Chan
And change iSCSI RQ doorbell size from 16B to 64B to match new firmware. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-15New 7.0 FW: bnx2x, cnic, bnx2i, bnx2fcVlad Zolotarov
New FW/HSI (7.0): - Added support to 578xx chips - Improved HSI - much less driver's direct access to the FW internal memory needed. New implementation of the HSI handling layer in the bnx2x (bnx2x_sp.c): - Introduced chip dependent objects that have chip independent interfaces for configuration of MACs, multicast addresses, Rx mode, indirection table, fast path queues and function initialization/cleanup. - Objects functionality is based on the private function pointers, which allows not only a per-chip but also PF/VF differentiation while still preserving the same interface towards the driver. - Objects interface is not influenced by the HSI changes which do not require providing new parameters keeping the code outside the bnx2x_sp.c invariant with regard to such HSI chnages. Changes in a CNIC, bnx2fc and bnx2i modules due to the new HSI. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2011-05-24[SCSI] bnx2i: Optimized the iSCSI offload performanceEddie Wai
Modified the event coalescing code for iSCSI offload to combat both corner cases and optimize performance as follows: 1. Added mechanism to loop back a second time to process any leftover CQEs that was generated by the hardware during the time the driver is busy processing previous CQEs in the bh. This not only helps the performance but also fixes the corner case when no more CQEs are being generated in the pipeline; so those leftover CQEs will get a a chance to be processed. 2. Added ARM_CQE_FP to distinguish between fast path arming versus slow path arming. This change will guarantee that the CQEs will always get a chance to be re-armed during fast path completions. 3. Removed the inline event coalescing division for perf optimization. Also fixed a division-by-zero error when the event_coal_div module param was set to 0. 4. Changed the default SQ WQEs size from 256 to 128 to match chip default. 5. Changed the cmd_per_lun from 32 to 24. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <jbottomley@parallels.com>
2011-05-24[SCSI] bnx2i: Updated the connection shutdown/cleanup timeoutEddie Wai
Modified the 10s wait time for inflight offload connections to advance to the next state to 2s based on test result. Modified the 20s shutdown timeout to 30s based on test result. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Cc: stable@kernel.org Signed-off-by: James Bottomley <jbottomley@parallels.com>
2011-05-24[SCSI] bnx2i: Fixed packet error created when the sq_size is set to 16Eddie Wai
The number of chip's internal command cell, which is use to generate SCSI cmd packets to the target, was not initialized correctly by the driver when the sq_size is changed from the default 128. This, in turn, will create a problem where the chip's transmit pipe will erroneously reuse an old command cell that is no longer valid. The fix is to correctly initialize the chip's command cell upon setup. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Cc: stable@kernel.org Signed-off-by: James Bottomley <jbottomley@parallels.com>
2011-02-24[SCSI] bnx2i: fix null ptr ref in conn get paramMike Christie
bnx2i has some checks to try and make sure the ep is not destroyed while the addr/port is getting read. However, if after this check: if (!(bnx2i_conn && bnx2i_conn->ep && bnx2i_conn->ep->hba)) goto out; bnx2i_conn->ep is cleared by ep_disconnect then we will oops. This patches fixes the problem by having the driver use the get_ep_param callback instead of get_conn_param. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-24[SCSI] bnx2i: Updated to version 2.6.2.3Eddie Wai
Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-24[SCSI] bnx2i: Added iSCSI text pdu support for iSCSI offloadEddie Wai
This is part of an effort to support send target discovery via the iSCSI offload path. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-24[SCSI] bnx2i: Added jumbo MTU support for the no shost caseEddie Wai
For scenarios where the shost is not being passed to bnx2i for the iSCSI offload connection request, the code would consult the routing table to select the CNIC device. This code path will erroneously error out if the corresponding L2 interface's MTU has been setup to > 1500. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-24[SCSI] bnx2i: Added support for the 57712(E) devicesEddie Wai
Moved all PCI_DEVICE_ID_NX2_57712(E) definitions to pci_ids.h Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Acked-by: Michael Chan <mchan@broadcom.com> Acked-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-24[SCSI] bnx2i: Added handling for unsupported iSCSI offload hbaEddie Wai
The hba will now be unregistered and freed when iSCSI offload is not supported by the NIC. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-24[SCSI] bnx2i: Fixed the 32-bit swapping of the LUN field for nopouts for 5771XEddie Wai
Fixed a bug where the 64-bit LUN field for nopouts were 32-bit swapped. This only pertains to 5771X devices. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-24[SCSI] bnx2i: Allow ep CONNECT_FAILED condition to go through proper cleanupEddie Wai
Allow CNIC to go through the proper cleanup procedure for an endpoint which failed to connect. Proper cleanup is necessary for the chip to reset back to the initial state for the offloaded endpoint. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-24[SCSI] bnx2i: Added reconnect fix connecting against Lefthand targetsEddie Wai
The nopout's reserved field was not being initialized to zero before being reused. Stale CDB values from previous SCSI cmds of the same BHS offset was the cause of the disconnection initiated by the Lefthand target. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (147 commits) [SCSI] arcmsr: fix write to device check [SCSI] lpfc: lower stack use in lpfc_fc_frame_check [SCSI] eliminate an unnecessary local variable from scsi_remove_target() [SCSI] libiscsi: use bh locking instead of irq with session lock [SCSI] libiscsi: do not take host lock in queuecommand [SCSI] be2iscsi: fix null ptr when accessing task hdr [SCSI] be2iscsi: fix gfp use in alloc_pdu [SCSI] libiscsi: add more informative failure message during iscsi scsi eh [SCSI] gdth: Add missing call to gdth_ioctl_free [SCSI] bfa: remove unused defintions and misc cleanups [SCSI] bfa: remove inactive functions [SCSI] bfa: replace bfa_assert with WARN_ON [SCSI] qla2xxx: Use sg_next to fetch next sg element while walking sg list. [SCSI] qla2xxx: Fix to avoid recursive lock failure during BSG timeout. [SCSI] qla2xxx: Remove code to not reset ISP82xx on failure. [SCSI] qla2xxx: Display mailbox register 4 during 8012 AEN for ISP82XX parts. [SCSI] qla2xxx: Don't perform a BIG_HAMMER if Get-ID (0x20) mailbox command fails on CNAs. [SCSI] qla2xxx: Remove redundant module parameter permission bits [SCSI] qla2xxx: Add sysfs node for displaying board temperature. [SCSI] qla2xxx: Code cleanup to remove unwanted comments and code. ...
2010-12-23cnic: Improve ->iscsi_nl_msg_send()Michael Chan
1. Change first parameter from cnic_dev to ulp_handle which is the hba pointer. All other similar upcalls are using hba pointer. The callee can then directly reference the hba without conversion. 2. Change return value from void to int so that an error code can be passed back. This allows the operation to be retried. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-21[SCSI] bnx2i: Updated version to 2.6.2.2Eddie Wai
Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-21[SCSI] bnx2i: Updated copyright and maintainer infoEddie Wai
2010-12-21[SCSI] bnx2i: Cleaned up various error conditions in ep_connect/disconnectEddie Wai
Various error conditions inside ep_connect and ep_disconnect were either not being handled or not being handled correctly. This patch fixes all those issues. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Acked-by: Anil Veerabhadrappa <anilgv@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-21[SCSI] bnx2i: Added return code check for chip kwqe submission requestEddie Wai
Added the handling for cases when a chip request is made to the CNIC module but the hardware is not ready to accept. This would lead to many unnecessary wait timeouts. This code adds check in the connect establishment and destruction path. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-21[SCSI] bnx2i: Modified the bnx2i stop path to compensate for in progress opsEddie Wai
The stop path has been augmented to wait a max of 10s for all in progress offload and destroy activities to complete before proceeding to terminate all active connections (via iscsid or forcefully). Note that any new offload and destroy requests are now blocked and return to the caller immediately. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Acked-by: Anil Veerabhadrappa <anilgv@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-21[SCSI] bnx2i: Removed the dynamic registration of CNICEddie Wai
The code no longer needs to dynamically register and unregister the CNIC device. The CNIC device will be kept registered until module unload. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-21[SCSI] bnx2i: Added mutex lock protection to conn_get_paramEddie Wai
Added net_dev mutex lock protection before accessing the csk parameters. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-21[SCSI] bnx2i: Allow to abort the connection if connect request times outEddie Wai
In the situation where the connect completion response arrives after the connect request has already timed out, the connection was not being aborted but only the resource was being freed. This creates a problem for 5771X (10g) as the chip flags this with an assertion. This change will properly aborts the connection before freeing the resource. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-21[SCSI] bnx2i: Fixed the remote TCP RST handling for the 570X (1g)Eddie Wai
Modified the handling of the remote TCP RST code so the chip can now flush the tx pipe accordingly upon a remote TCP RST reception. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-21[SCSI] bnx2i: Fixed a cid leak issue for 5771X (10g)Eddie Wai
A cid leak issue was found when the connect destroy request exceeded the driver's disconnection timeout. This will lead to a cid resource leak issue. The fix is to allow the cid cleanup even when this happens. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Acked-by: Anil Veerabhadrappa <anilgv@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-21[SCSI] bnx2i: Fixed the endian bug in the TMF LUN cmd sendEddie Wai
Added a be32_to_cpu call for the TMF LUN wqe. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-21[SCSI] bnx2i: Added fix for NOP-Out response panic from unsolicited NOP-InEddie Wai
The patch fixes the following situations where NOP-Out pkt is called for: - local unsolicited NOP-Out requests (requesting no NOP-In response) - local NOP-Out responses to unsolicited NOP-In requests kernel panic is observed due to double session spin_lock requests; one in the bnx2i_process_nopin_local_cmpl routine in bnx2i_hwi.c and the other in the iscsi_put_task routine in libiscsi.c The proposed fix is to export the currently static __iscsi_put_task() routine and have bnx2i call it directly instead of the iscsi_put_task() routine which holds the session spin lock. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Anil Veerabhadrappa <anilgv@broadcom.com> Acked-by: Benjamin Li <benli@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-21[SCSI] bnx2i: Fixed bugs in the handling of unsolicited NOP-InsEddie Wai
Unsolicited NOP-Ins are placed in the receive queue of the hardware which requires to be read out regardless if the receive pipe is suspended or not. This patch adds the disposal of this RQ element under this condition. Also fixed the bug in the unsolicited NOP-In handling routine which checks for the RESERVED_ITT. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits) bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL. vlan: Calling vlan_hwaccel_do_receive() is always valid. tproxy: use the interface primary IP address as a default value for --on-ip tproxy: added IPv6 support to the socket match cxgb3: function namespace cleanup tproxy: added IPv6 support to the TPROXY target tproxy: added IPv6 socket lookup function to nf_tproxy_core be2net: Changes to use only priority codes allowed by f/w tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled tproxy: added tproxy sockopt interface in the IPV6 layer tproxy: added udp6_lib_lookup function tproxy: added const specifiers to udp lookup functions tproxy: split off ipv6 defragmentation to a separate module l2tp: small cleanup nf_nat: restrict ICMP translation for embedded header can: mcp251x: fix generation of error frames can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set can-raw: add msg_flags to distinguish local traffic 9p: client code cleanup rds: make local functions/variables static ... Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and drivers/net/wireless/ath/ath9k/debug.c as per David
2010-10-14cnic: Defer iscsi connection cleanupMichael Chan
The bnx2x devices require a 2 second quiet time before sending the last RAMROD command to destroy a connection. This sleep wait adds up to a long delay when iscsid is serially destroying maultiple connections. Create a workqueue to perform the final connection cleanup in the background to speed up the process. This significantly speeds up the process as the wait time can be done in parallel for multiple connections. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-06bnx2x, cnic, bnx2i: use new FW/HSIDmitry Kravkov
This is the new FW HSI blob and the relevant definitions without logic changes. It also included code adaptation for new HSI. New features are not enabled. New FW/HSI includes: - Support for 57712 HW - Future support for VF (not used) - Improvements in FW interrupts scheme - FW FCoE hooks (stubs for future usage) Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-05[SCSI] bnx2i: Updated version to bnx2i-2.1.3Eddie Wai
Also updated maintainer info. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-09-05[SCSI] bnx2i: Added chip cleanup for the remove module pathEddie Wai
In the case when an ep_connect request is interrupted due to route request stall, if the iSCSI daemon is terminated by the user, the chip will be left in a state which will not get cleaned up upon module removal. Upon module reload, when the same context id is used for a new connection, chip panic would occur. This patch adds chip cleanup in the module removal path. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Acked-by: Benjamin Li <benli@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-09-05[SCSI] bnx2i: Recouple the CFC delete cleanup with cm_abort/close completionEddie Wai
Specific to the Broadcom 10g chipset, the CFC delete operation must be coupled with the cm_abort/close with does the SRC delete/terminate offload operation prior. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Acked-by: Benjamin Li <benli@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-09-05[SCSI] bxn2i: Added support for other TMFs besides ABORT_TASKEddie Wai
Expanded the TMF request routine to support other TMFs such as LUN RESET, etc. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Anil Veerabhadrappa <anilgv@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-09-05[SCSI] bnx2i: Fixed a protocol violation on nopout responsesEddie Wai
According to RFC3720, nopout packet sent in response to unsolicited nopin packet requesting a response must retain the TTT of the requester. Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-08-11scsi: fix bnx2i build errorsRandy Dunlap
bnx2i should depend on NET since it selects SCSI_ISCSI_ATTRS, which depends on NET. Also move the dependencies together. The "depends" change fixes multiple build errors when CONFIG_NET is not enabled: ERROR: "skb_trim" [drivers/scsi/scsi_transport_iscsi.ko] undefined! ERROR: "netlink_kernel_create" [drivers/scsi/scsi_transport_iscsi.ko] undefined! ERROR: "netlink_kernel_release" [drivers/scsi/scsi_transport_iscsi.ko] undefined! ERROR: "skb_pull" [drivers/scsi/scsi_transport_iscsi.ko] undefined! ERROR: "init_net" [drivers/scsi/scsi_transport_iscsi.ko] undefined! ERROR: "__alloc_skb" [drivers/scsi/scsi_transport_iscsi.ko] undefined! ERROR: "netlink_broadcast" [drivers/scsi/scsi_transport_iscsi.ko] undefined! ERROR: "kfree_skb" [drivers/scsi/scsi_transport_iscsi.ko] undefined! ERROR: "skb_put" [drivers/scsi/scsi_transport_iscsi.ko] undefined! Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Anil Veerabhadrappa <anilgv@broadcom.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
