Some versions of the Virtual I/O Server on Power
return 0x99 in the non-SCSI error status field as success,
rather than 0. This fixes the ibmvscsi driver to treat this
response as success.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
- struct scsi_cmnd had a 16 bytes command buffer of its own.
This is an unnecessary duplication and copy of request's
cmd. It is probably left overs from the time that scsi_cmnd
could function without a request attached. So clean that up.
- Once above is done, few places, apart from scsi-ml, needed
adjustments due to changing the data type of scsi_cmnd->cmnd.
- Lots of drivers still use MAX_COMMAND_SIZE. So I have left
that #define but equate it to BLK_MAX_CDB. The way I see it
and is reflected in the patch below is.
MAX_COMMAND_SIZE - means: The longest fixed-length (*) SCSI CDB
as per the SCSI standard and is not related
to the implementation.
BLK_MAX_CDB. - The allocated space at the request level
- I have audit all ISA drivers and made sure none use ->cmnd in a DMA
Operation. Same audit was done by Andi Kleen.
(*)fixed-length here means commands that their size can be determined
by their opcode and the CDB does not carry a length specifier, (unlike
the VARIABLE_LENGTH_CMD(0x7f) command). This is actually not exactly
true and the SCSI standard also defines extended commands and
vendor specific commands that can be bigger than 16 bytes. The kernel
will support these using the same infrastructure used for VARLEN CDB's.
So in effect MAX_COMMAND_SIZE means the maximum size command
scsi-ml supports without specifying a cmd_len by ULD's
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
Adds support to the ibmvscsi driver to handle non SCSI error
status. This is needed to support some new VIOS enhancements.
Signed-off-by: Santiago Leon <santil@us.ibm.com>
It's big, but there doesn't seem to be a way to split it up smaller...
Signed-off-by: Tony Jones <tonyj@suse.de>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Sean Hefty <sean.hefty@intel.com>
Cc: Hal Rosenstock <hal.rosenstock@gmail.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
With the sg table code, every SCSI driver is now either chain capable
or broken (or has sg_tablesize set so chaining is never activated), so
there's no need to have a check in the host template.
Also tidy up the code by moving the scatterlist size defines into the
SCSI includes and permit the last entry of the scatterlist pools not
to be a power of two.
CRQ send errors that return with H_CLOSED should return with
SCSI_MLQUEUE_HOST_BUSY until firmware alerts the client of a CRQ
transport event. The transport event will either reinitialize and
requeue the requests or fail and return IO with DID_ERROR.
To avoid failing the eh_* functions while re-attaching to the server
adapter this will retry for a period of time while ibmvscsi_send_srp_event
returns SCSI_MLQUEUE_HOST_BUSY.
In ibmvscsi_eh_abort_handler() the loop includes the search of the
event list. The lock on the hostdata is dropped while waiting to try
again after failing ibmvscsi_send_srp_event. The event could have been
purged if a login was in progress when the function was called.
In ibmvscsi_eh_device_reset_handler() the loop includes the call to
get_event_struct() because a failing call to ibmvscsi_send_srp_event()
will have freed the event struct.
Signed-off-by: Robert Jennings <rcj@linux.vnet.ibm.com>
Set the default command timeout for ibmvscsi disks to 60 seconds
to ensure we don't prematurely timeout commands. This fixes a problem
seen where the default 30 seconds was not long enough due to
congestion on the server.
By setting the request_limit in send_srp_login to 1 we allowed login
requests to be sent to the server adapter. If this was not an initial
login, but was a login after a disconnect with the server, other I/O
requests could attempt to be processed before the login occured. These
I/O requests would fail, sometimes resulting in filesystems getting
marked read-only.
To address this we can set the request_limit to 0 while doing the login
and add an exception where login requests, along with task management
events, are always passed to the server.
There is a case where the request_limit had already reached 0 would result
in all events being sent rather than returning SCSI_MLQUEUE_HOST_BUSY; this
has also been fixed by this patch.
This option is true if a low-level driver can support sg
chaining. This will be removed eventually when all the drivers are
converted to support sg chaining. q->max_phys_segments is set to
SCSI_MAX_SG_SEGMENTS if false.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
If you build a multiplatform kernel for iSeries and pSeries, with
ibmvscsic support, the resulting client doesn't work on iSeries.
This fixes that, using the appropriate low-level operations
for the machine detected at runtime.
[jejb: fixed up rejections around the srp transport patch]
Acked by: Brian King <brking@linux.vnet.ibm.com>
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
This adds a 'roles' attribute to rport like transport_fc. The role can
be initiator or target. That is, the initiator driver creates target
remote ports and the target driver creates initiator remote ports.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
This converts ibmvscsi to use the srp transport class.
Acked-by: Brian King <brking@us.ibm.com>
Acked-by: Brian King <brking@linux.vnet.ibm.com>
No need to check use_sg since sg_tablesize is set appropriately in the
scsi host template.
Brian King's patch (2a7309372fe56ae46c499b772d811ad31c501dd9) did this
cleanup but the data buffer accessors patch (written before the patch
and merged after it) restored the check.
- remove the unnecessary map_single path.
- convert to use the new accessors for the sg lists and the
parameters.
Cc: Santiago Leon <santil@us.ibm.com>
The viosrp_crq timeout field is in seconds.
Since it is completely possible for scsi core to call
a LLDD's eh_abort function after the command has completed,
fix ibmvscsi to return SUCCESS if this is the case.
Fix a couple locking bugs discovered during code inspection.
ibmvscsi_send_srp_event needs to be called with the host lock
held. This patch fixes a couple paths in the code where this
wasn't true.
Adds an eh_host_reset_handler to ibmvscsi which resets the connection
to the vscsi server. This patch also adds a timer to internally
issues commands to prevent client hangs in the case of a misbehaving
server. Tested by modifying the VIOS such that it would occasionally
drop one or more request in sequence.
Converts ibmvscsi to use dev_printk and friends to simplify
debugging. ibmvscsi adapter initialization now looks like this:
ibmvscsi 30000005: SRP_VERSION: 16.a
ibmvscsi 30000005: partner initialization complete
ibmvscsi 30000005: sent SRP login
ibmvscsi 30000005: SRP_LOGIN succeeded
Additionally, this patch adds the logging of a couple return codes in
a couple logs.
Since sg_tablesize is set appropriately in the scsi host template,
remove the unnecessary check to make sure it is not exceeded
following the dma_map_sg call.
Adds support for a changeable queue depth to ibmvscsi.
Fixed the kernel-doc comment for ibmvscsi_slave_configure. Thanks to
Randy Dunlap for pointing this out.
Adding a slave_configure function for the driver. Now the disks can be
restarted by the scsi mid-layer when the are disconnected and reconnected.
Signed-off-by: "Robert Jennings" <rcj@linux.vnet.ibm.com>
Signed-off-by: "Santiago Leon" <santil@us.ibm.com>
The request limit calculations used previously on the client failed to
mirror the state of the server. Additionally, when a value < 3 was provided
there could be problems setting can_queue and handling abort and reset
commands.
The "ibmvscsi: treat busy and error conditions separately" patch
submitted by Dave Boutcher back in June incorrectly reenables the CRQ.
The broken logic causes the adapter to get disabled if the CRQ
connection happens to close temporarily. This patch "fixes that
obviously wrong logic check" (Dave's words).
Signed-off-by: David Boutcher <sleddog@us.ibm.com>
This patch fixes a condition where ibmvscsi treats a transport error as a
"busy" condition, so no errors were returned to the scsi mid-layer.
In a RAID environment this means that I/O hung rather than failing
over.
Convert kmalloc + memset to kcalloc in ibmvscsi
Acked-by: Dave Boutcher <sleddog@us.ibm.com>
There is a window where we can be re-enabling an adapter, but
still allow SCSI commands to be sent to the target. This fix
sets our window (request_limit) to -1 as soon as we know the
adapter is being reenabled, and closes a very teeny tiny
window where we could set the window back to 1 before we
grab a lock.
Signed-off-by: Dave Boutcher <sleddog@us.ibm.com>
New versions of the Power5 firmware can send a "re-enable" message to
the virtual scsi adapter. This fix makes us handle the message
correctly. Without it, the driver goes catatonic and the system crashes
unpleasantly.
Just set the name field directly in the device_driver structure
contained in the vio_driver struct.
Linda Xie ever so gently pointed out that she had a patch
to preserve compatibility with older SLES targets, and I told
her we didn't need to push it to mainline.
This patch explicitly checks the version of the IBMVSCSI target
and ensures that large scatterlists are not sent to older
targets.
Signed-off-by: Linda Xie <lxie@us.ibm.com>
Signed-off-by: Dave Boutcher <boutcher@us.ibm.com>
The maximum size of a scatter-gather list that the current IBM VSCSI
Client can handle is 10. This patch adds large scatter-gather support
to the client so that it is capable of handling up to SG_ALL(255)
number of requests in the scatter-gather list.
Acked by: Dave C Boutcher <sleddog@us.ibm.com>
Rejections fixed up and
Make MODULE_DEVICE_TABLE work for vio devices.
This patch fixes a long term borkenness in
ibmvscsi where we were using the wrong timeout
field from the scsi command (and using the
wrong units.) Now broken by the fact that the
scsi_cmnd timeout field is gone entirely.
This only worked before because all the SCSI
targets assumed that 0 was default.
With the removal of the spinlocking around eh calls, we need to add a
little more locking back in, otherwise we do some naked list
manipulation.
Fix the problem in IBM VSCSI Client where the client doesn't send the
information which is expected by the server.
infrastructure for it.
Let it rip!
