This driver is a pick up of the old IBM VIO scsi Target Driver
that was started by Nick and Fujita 2-4 years ago.
http://comments.gmane.org/gmane.linux.scsi/90119
The driver provides a virtual SCSI device on IBM Power Servers.
This patch contains the fifth version for an initial merge of the
tcm ibmvscsis driver. More information on this driver and config
can be found:
https://github.com/powervm/ibmvscsis/wiki/Configuration
http://www.linux-iscsi.org/wiki/IBM_vSCSI
(Drop extra libsrp review breakage + Fix kconfig typo - nab)
Signed-off-by: Steven Royer <seroyer@linux.vnet.ibm.com>
Signed-off-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com>
Signed-off-by: Michael Cyr <mikecyr@linux.vnet.ibm.com>
Signed-off-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com>
Cc: FUJITA Tomonori <tomof@acm.org>
A VIOSRP_HOST_CONFIG_TYPE management datagram (MAD) has existed in the
code for some time. From what information I've gathered from Brian King
this was likely implemented on the host side in a SLES 9 based VIOS,
which is no longer supported anywhere. Further, it is not defined in
PAPR or supported by any AIX based VIOS.
Treating as bit rot and removing the associated host config code. The
config attribute and its show function are left as not to break
userspace. The behavior remains the same returning nothing.
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Add defines for mad version and mad os_type, and replace the magic
numbers in set_adapter_info() accordingly.
Reviewed-by: Manoj Kumar <manoj@linux.vnet.ibm.com>
The PAPR defines four valid header values for the first byte of a CRQ
message. Namely, an unused/empty message (0x00), a valid
command/response entry (0x80), a valid initialization entry (0xC0), and
a valid transport event (0xFF). Further, initialization responses have
two formats namely initialize (0x01) and initialize complete
(0x02). Define these values as enums and use them in the code in
place of their magic number equivalents.
Reported-by: Johannes Thumshirn <jthumshirn@suse.de>
The enum values for VIOSRP_LINUX_FORMAT and VIOSRP_INLINE_FORMAT are off
by one. They are currently defined as 0x06 and 0x07 respetively. These
values are defined in PAPR correctly as 0x05 and 0x06. This
inconsistency has gone unnoticed as neither enum is currently used. The
possible future support of PING messages between the VIOS and client
adapter relies on VIOSRP_INLINE_FORMAT crq messages. Corrected these
enum values to match PAPR definitions.
The hypervisor is big endian, so little endian kernel builds need
to byteswap.
[jejb: fix checkpatch errors]
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Add support to ibmvscsi for the capabilities MAD. This command gets sent
to the Virtual I/O server prior to login in order to communicate client
capabilities. Additionally it returns information regarding capabilities
that the server supports. The two main capabilities communicated in this
MAD are related to partition migration and client reserve. Client reserve
allows for SCSI-2 reservations to be sent to virtual disks which are backed
by physical LUNs and will result in the reservation being sent to the
physical LUN.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
A new mode of error reporting, fast fail, has been added to the VIOS
which allows failover to happen more quickly.
If this new fast fail mode is enabled on the VIOS and the vSCSI client
supports the mode, the VIOS will not return MEDIUM error on path failures,
but rather return VIOSRP_ADAPTER_FAIL in the crq response, which
ibmvscsi will translate to DID_ERROR.
This new mode can be enabled for single path configurations as well,
so it is the new default error reporting mode. A module parameter is
provided to disable this new behavior on the off chance it causes a
problem on some old VIOS version.
Some versions of the Virtual I/O Server on Power
return 0x99 in the non-SCSI error status field as success,
rather than 0. This fixes the ibmvscsi driver to treat this
response as success.
Adds support to the ibmvscsi driver to handle non SCSI error
status. This is needed to support some new VIOS enhancements.
Signed-off-by: Santiago Leon <santil@us.ibm.com>
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
infrastructure for it.
Let it rip!
