[ Upstream commit 8b47ae69e049ae0b3373859d901f0334322f9fe9 ]
Depending on the chipset, the number of NPIV vports may vary and be in
excess of what most switches support (256). To avoid confusion with the
users, limit the reported NPIV vports to 256.
Additionally correct the 16G adapter which is reporting a bogus NPIV vport
number if the link is down.
Signed-off-by: Dick Kennedy <dick.kennedy@broadcom.com>
Signed-off-by: James Smart <jsmart2021@gmail.com>
[ Upstream commit 2289e9598dde9705400559ca2606fb8c145c34f0 ]
The driver ignored checks on whether the link should be kept
administratively down after a link bounce. Correct the checks.
Signed-off-by: James Smart <james.smart@broadcom.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
[ Upstream commit 6c9231f604c2575be24c96d38deb70f145172f92 ]
Correct host name in symbolic_name field of nameserver registrations
When building with -Wextra, we get a lot of warnings for the lpfc driver
concerning expressions that are always true, starting with:
drivers/scsi/lpfc/lpfc_attr.c: In function 'lpfc_enable_npiv_init':
drivers/scsi/lpfc/lpfc_attr.c:2786:77: error: comparison of unsigned expression >= 0 is always true [-Werror=type-limits]
drivers/scsi/lpfc/lpfc_attr.c: In function 'lpfc_enable_rrq_init':
drivers/scsi/lpfc/lpfc_attr.c:2802:76: error: comparison of unsigned expression >= 0 is always true [-Werror=type-limits]
drivers/scsi/lpfc/lpfc_attr.c: In function 'lpfc_suppress_link_up_init':
drivers/scsi/lpfc/lpfc_attr.c:2812:2050: error: comparison of unsigned expression >= 0 is always true [-Werror=type-limits]
drivers/scsi/lpfc/lpfc_attr.c: In function 'lpfc_log_verbose_init':
drivers/scsi/lpfc/lpfc_attr.c:3064:1930: error: comparison of unsigned expression >= 0 is always true [-Werror=type-limits]
The code works as intended, but it would be nice to shut up the warning
so we don't clutter up build logs with this. Using a separate inline
function for it makes it clear to the compiler that the comparison is
necessary in the caller but still lets it do the constant-folding.
[mkp: fix typo]
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Acked-by: James Smart <james.smart@broadcom.com>
Re-organize source for easier driver attribute management
Remove global lpfc_sli_mode attribute in leiu of per-hba lpfc_sli_mode
lpfc_delay_discovery
Remove global lpfc_delay_discovery attribute in leiu of per-hba
lpfc_enable_npiv
Remove global lpfc_enable_npiv attribute in leiu of per-hba lpfc_enable_npiv
Add support for XLane LUN priority
Add MDS Diagnostics Support
Signed-off-by: Dick Kennedy <dick.kennedy@avagotech.com>
Signed-off-by: James Smart <james.smart@avagotech.com>
Pass cmd iu payloads inline to adapter job structure rather than as
separate dma buffers.
Use new FDMI speed definitions for 10G, 25G and 40G FCoE.
Reviewed-by: Hannes Reinicke <hare@suse.de>
Modularize, cleanup, add comments - for FDMI code in driver
Note: I don't like the comments with leading # - but as we have a lot if
present, I'm deferring to handle it in one big fix later.
Signed-off-by: James Bottomley <JBottomley@Odin.com>
Remove set but not used variables.
Signed-off-by: Sebastian Herbszt <herbszt@gmx.de>
Reviewed-by: Hannes Reinecke <hare@suse.de>
Update copyright to 2015
Signed-off-by: Dick Kennedy <dick.kennedy@emulex.com>
Signed-off-by: James Smart <james.smart@emulex.com>
Fixed Low priority issues from lpfc given by fortify source code scan.
Now that we're using 64-bit LUNs internally we need to increase
the size of max_luns to 64 bits, too.
Signed-off-by: Hannes Reinecke <hare@suse.de>
Reviewed-by: Christoph Hellwig <hch@infradead.org>
Reviewed-by: Ewan Milne <emilne@redhat.com>
Fix ExpressLane priority setup
Reviewed-By: Dick Kennedy <dick.kennedy@emulex.com>
Update lpfc version to driver version 10.2.8000.0
Convert runtime references to old xlane cfg param to fof cfg param
Fix FW dump using sysfs
128 CPUs.
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Pull misc SCSI driver updates from James Bottomley:
"This patch set is a set of driver updates (megaraid_sas, fnic, lpfc,
ufs, hpsa) we also have a couple of bug fixes (sd out of bounds and
ibmvfc error handling) and the first round of esas2r checker fixes and
finally the much anticipated big endian additions for megaraid_sas"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (47 commits)
[SCSI] fnic: fnic Driver Tuneables Exposed through CLI
[SCSI] fnic: Kernel panic while running sh/nosh with max lun cfg
[SCSI] fnic: Hitting BUG_ON(io_req->abts_done) in fnic_rport_exch_reset
[SCSI] fnic: Remove QUEUE_FULL handling code
[SCSI] fnic: On system with >1.1TB RAM, VIC fails multipath after boot up
[SCSI] fnic: FC stat param seconds_since_last_reset not getting updated
[SCSI] sd: Fix potential out-of-bounds access
[SCSI] lpfc 8.3.42: Update lpfc version to driver version 8.3.42
[SCSI] lpfc 8.3.42: Fixed issue of task management commands having a fixed timeout
[SCSI] lpfc 8.3.42: Fixed inconsistent spin lock usage.
[SCSI] lpfc 8.3.42: Fix driver's abort loop functionality to skip IOs already getting aborted
[SCSI] lpfc 8.3.42: Fixed failure to allocate SCSI buffer on PPC64 platform for SLI4 devices
[SCSI] lpfc 8.3.42: Fix WARN_ON when driver unloads
[SCSI] lpfc 8.3.42: Avoided making pci bar ioremap call during dual-chute WQ/RQ pci bar selection
[SCSI] lpfc 8.3.42: Fixed driver iocbq structure's iocb_flag field running out of space
[SCSI] lpfc 8.3.42: Fix crash on driver load due to cpu affinity logic
[SCSI] lpfc 8.3.42: Fixed logging format of setting driver sysfs attributes hard to interpret
[SCSI] lpfc 8.3.42: Fixed back to back RSCNs discovery failure.
[SCSI] lpfc 8.3.42: Fixed race condition between BSG I/O dispatch and timeout handling
[SCSI] lpfc 8.3.42: Fixed function mode field defined too small for not recognizing dual-chute mode
timeout
hard to interpret
Pull trivial tree from Jiri Kosina:
"The usual trivial updates all over the tree -- mostly typo fixes and
documentation updates"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (52 commits)
doc: Documentation/cputopology.txt fix typo
treewide: Convert retrun typos to return
Fix comment typo for init_cma_reserved_pageblock
Documentation/trace: Correcting and extending tracepoint documentation
mm/hotplug: fix a typo in Documentation/memory-hotplug.txt
power: Documentation: Update s2ram link
doc: fix a typo in Documentation/00-INDEX
Documentation/printk-formats.txt: No casts needed for u64/s64
doc: Fix typo "is is" in Documentations
treewide: Fix printks with 0x%#
zram: doc fixes
Documentation/kmemcheck: update kmemcheck documentation
doc: documentation/hwspinlock.txt fix typo
PM / Hibernate: add section for resume options
doc: filesystems : Fix typo in Documentations/filesystems
scsi/megaraid fixed several typos in comments
ppc: init_32: Fix error typo "CONFIG_START_KERNEL"
treewide: Add __GFP_NOWARN to k.alloc calls with v.alloc fallbacks
page_isolation: Fix a comment typo in test_pages_isolated()
doc: fix a typo about irq affinity
was not in online mode
Correct spelling typo in printk
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
Fixed NMI watch dog panic's when resetting the hba.
Fix bug with Target Resets and FCP2 devices
Create module parameter to disable Target Reset on FCP-Tape devices
when a "bus reset" is requested. Default is to reset all devices on
bus reset.
Fixed boot from san failure when SLI4 FC device presented on the same PCI bus
The request_firmware interface can induce delays while looking
for firmware files, even if no fw file is present. In some situations
the delays exceeded scan_wait timeouts, resulting in situations in which
the boot device had not been discovered in time. Boot Device does not
need to be on a lpfc device.
Change request_firmware use to be module paramater driven. Default is to
not attempt firmware download on boot. Add sysfs parameter to invoke
firmware update.
